GMC0942YB-42R2700
GMC0942YB-42R2700
    INGHAI(赢海)
    MIC_D9X4.2MM_TM
    电磁无源一体蜂鸣器(外部驱动) 2.7KHz
GMC0942YB-42R2700 数据手册
規 格 承 認 書 PECIFICATION FOR APPROVAL 客 戶 CUSTOMER 項 目 ITEM 型 號 : : 电磁无源一体蜂鸣器(外部驱动) TYPE : GMC0942YB-8-42R2700 描述 DESCRIPTION : φ9.0 x H4.2 mm 2700Hz 8-42Ω/1.5-7V 客戶料號 CUSTOMER NO. : 規 格 書 號 ≥80dB PBT 材质 P=4.0mm SPECIFICATION NO.: 版 本 EDITION NO. 日 期 DATE : : V1.1 20 客戶承認 CUSTOMER CONFIRM AND SIGN 檢查 審核 承認 TESTED BY CHECKED BY APPROVED BY 東莞市赢海電子有限公司 DONGUAN INGHAI ELECTRONICS CO.,LTD 製作 審查 確認 ISSUED BY CHECKED BY APPROVED BY 周明 刘承成 地址:广东省东莞市长安镇上沙第五工业区新春路 1 号新春科技园 号電話 / TEL:0769-83060958 傳真 / FAX: 0769-81608993 網址:HTTP://WWW.INGHAI.COM 1/4 DONGGUAN INGHAI ELECTRONICS CO.,LTD Model NO: GMC0942YB-8~42R2700 A: DIMEMSIONS: Unit:mm Tolerance:±0.2 B: SPECIFICATIONS Model NO GMC0942YB Rated Voltage 1.5-7V Operating Voltage 1.5-7V Max.Rated Current Max.60mA Sound Pressure level(dB)at10cm/2700HZ Min.100dB Resonant Frequency 2700Hz Coil Resistance 8-42±15%Ω Operating Temperature -20 ℃~+70 ℃ Storage Temperature -30 ℃~+80 ℃ Case material and color PBT/ Black Measuring condition Part shall be measured under a condition (Temperature: 5~ 35℃, Humidity: 45% ~ 85%R.H., Atmospheric pressure: 860 ~ 1060hPa) unless the standard condition (Temperature: 25±3℃, Humidity: 60±10%R.H. Atmospheric pressure: 860 ~1060hPa) is regulated to measure. 2/4 C: Acoustic Characteristics: The oscillation frequency, current consumption and sound pressure are measured by the measuring instruments shown below In the measuring test, buzzer is placed as follows: D: Typical Frequency Response Curve 3/4 E: Reliability Test After any following tests the part shall meet specifications without any degradation in appearance and performance except SPL. SPL shall not deviate more than -10 dB from the initial value 1. Ordinary Temperature Life Test The part shall be subjected to 96 hours at 25±10℃. Input rated voltage 2. 3. 4. 5. 6. 7. Resonant frequency, 1/2 duty Square wave. High Temperature Test The part shall be capable of with standing a storage temperature of +80℃ for 96 hours. Low Temperature Test The part shall be capable of with standing a storage temperature of -30℃ for 96 hours. Humidity Test Temperature:+40℃±3℃ Relative Humidity:90%~95% Duration: 48 hours and expose to room temperature for 6 hours Temperature Shock Test Temperature:70℃ /1hour→ 25℃/3hours→-30℃/1hour→ 25℃/3hours (1cycle) Total cycle: 10 cycles Drop Test Standard Packaging From 120mm(Drop on hard wood or board of 5cm thick, three sides, six plain.) Vibration Test Vibration:1000cycles /min. Amplitude:1.5mm, Duration: 1 hour in each 3 axes Note: As this product is not protected from foreign material entering, please make sure that any foreign materials (e.g. magnetic powder, washing solvent, flux, corrosive gas) do not enter this product in your production processes. The functional degradation (e.g. SPL down) may occur if foreign material enter it. 4/4
GMC0942YB-42R2700 价格&库存
很抱歉,暂时无法提供与“GMC0942YB-42R2700”相匹配的价格&库存,您可以联系我们找货
GMC0942YB-42R2700
  • 1+1.11999
  • 30+1.07999
  • 100+1.03999
  • 500+0.95999
  • 1000+0.91999
  • 2000+0.89599
GMC0942YB-42R2700
    • 5+1.64765
    • 50+1.29384
    • 200+1.14210
    • 500+0.95289
    库存:954
    GMC0942YB-42R2700
    • 1+3.65220
    • 100+2.17880
    • 500+1.52510
    • 1000+1.08940
    • 2000+1.03490
    • 10000+0.95860
    库存:5
