規 格 承 認 書
PECIFICATION FOR APPROVAL
客 戶
CUSTOMER
項 目
ITEM
型 號
立创
电磁无源一体蜂鸣器(外部驱动)
TYPE
: GMC25125YB-25R800
DESCRIPTION :
φ25.0 x 12.5mm 800Hz
客戶料號
CUSTOMER NO. :
規 格 書 號
25Ω
≥85DB
PBT 材质
P=10.2mm
SPECIFICATION NO.:
版 本
EDITION NO.
日 期
DATE
V1.1
2019-12-27
客戶承認
CUSTOMER CONFIRM AND SIGN
檢查
TESTED BY
審核
CHECKED BY
承認
APPROVED BY
東莞市赢海電子有限公司
DONGUAN INGHAI ELECTRONICS CO.,LTD
製作
ISSUED BY
審查
CHECKED BY
周明
李林
確認
APPROVED BY
地址:廣東省東莞市長安鎮廈邊元灶頭工業區 16-6 號
電話 / TEL:0769-83060958
傳真 / FAX: 0769-81608993
網址:HTTP://WWW.INGHAI.COM
1/4
DONGGUAN INGHAI ELECTRONICS CO.,LTD
Model NO: GMC25125YB-25R800
A: DIMEMSIONS:
2-φ0.6
φ25
10.2±0.2
0.5
12.5
Potting
Sound
Emission Hole
3.5
5.0
Tolerance:+0.5mm
Unit:mm
B: SPECIFICATIONS
Model NO
Rated Voltage
GMC25125YB
3.6.0V
Operating Voltage
2.5.0~5.0V
Max.Rated Current
Max.80mA
Sound Pressure level(dB)at10cm/1000HZ
Min.85dB
Resonant Frequency
800Hz
Coil Resistance
25±15%
Operating Temperature
-20 ℃~+70 ℃
Storage Temperature
-30 ℃~+80 ℃
Case material and color
PBT / Black
Measuring condition
Part shall be measured under a condition (Temperature: 5~35℃, Humidity: 45%~85%R.H., Atmospheric pressure:
860 ~1060hPa) unless the standard condition (Temperature: 25±3℃, Humidity: 60±10%R.H. Atmospheric pressure:
860 ~1060hPa) is regulated to measure.
2/4
C: Acoustic Characteristics:
The oscillation frequency, current consumption and sound pressure are measured by the
measuring instruments shown below
In the measuring test, buzzer is placed as follows:
D: Typical Frequency Response Curve
3/4
E: Reliability Test
After any following tests the part shall meet specifications without any degradation in
appearance and performance except SPL. SPL shall not deviate more than -10 dB
from the initial value
1.
Ordinary Temperature Life Test
The part shall be subjected to 96 hours at 25±10℃. Input rated voltage
2.
3.
4.
5.
6.
7.
Resonant frequency, 1/2 duty Square wave.
High Temperature Test
The part shall be capable of with standing a storage temperature of +80℃ for 96 hours.
Low Temperature Test
The part shall be capable of with standing a storage temperature of -30℃ for 96 hours.
Humidity Test
Temperature:+40℃±3℃
Relative Humidity:90%~95% Duration: 48 hours
and expose to room temperature for 6 hours
Temperature Shock Test
Temperature:70℃ /1hour→ 25℃/3hours→-30℃/1hour→ 25℃/3hours (1cycle)
Total cycle: 10 cycles
Drop Test
Standard Packaging From 120mm(Drop on hard wood or board of 5cm thick,
three sides, six plain.)
Vibration Test
Vibration:1000cycles /min. Amplitude:1.5mm, Duration: 1 hour in each 3 axes
Note:
As this product is not protected from foreign material entering, please make sure that any foreign materials
(e.g. magnetic powder, washing solvent, flux, corrosive gas) do not enter this product in your production
processes. The functional degradation (e.g. SPL down) may occur if foreign material enter it.
产品命名(编号)说明:
4/4
5/4
很抱歉,暂时无法提供与“GMC25125YB-85R800”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+4.46880
- 10+3.61620
- 30+3.19480
- 国内价格
- 1+4.92480
- 10+3.98520
- 30+3.52080
