規 格 承 認 書
PECIFICATION FOR APPROVAL
客 戶
CUSTOMER
項 目
ITEM
: 贴片式压电无源蜂鸣器(外部驱动)
型 號
TYPE
: GSC14045YB-3V4000
DESCRIPTION :
L14.0 x W14.0 x H4.0 mm 4000Hz 3V ≥75DB 正发音 PPS 材质
客戶料號
CUSTOMER NO. :
規 格 書 號
SPECIFICATION NO.:
版 本
EDITION NO.
日 期
DATE
V1.2
2014-1-16
客戶承認
CUSTOMER CONFIRM AND SIGN
檢查
審核
承認
TESTED BY
CHECKED BY
APPROVED BY
東莞市赢海電子有限公司
DONGUAN INGHAI ELECTRONICS CO.,LTD
製作
審查
確認
ISSUED BY
CHECKED BY
APPROVED BY
周明
李林
1/5
地址:廣東省東莞市長安鎮廈邊元灶頭工業區 16-6 號
電話 / TEL:0769-83060958
傳真 / FAX: 0769-81608993
網址:HTTP://WWW.INGHAI.COM
A. SCOPE
This specification applies SMD piezoelectric buzzer, GSC14045YB-3V4000
B. SPECIFICATION
1
Part Number
2
Rated Voltage (Vp-p)
3
Operating Voltage (Vp-p)
1~25
4
*Current Consumption (mA)
≤2.5
5
Capacitance at100Hz (PF)
6
*Sound Output at 10cm (dB)
7
Resonant Frequency (Hz)
4000±500
8
Operating Temperature (℃)
-20~+70
9
Storage Temperature (℃)
-30~+80
10
Weight (g)
2.0
11
Housing Material
PPS
GSC1440YB
3
12000±30%
≥75
*Applying rated voltage (Resonant frequency, Square wave)
Measuring condition
Part shall be measured under a condition (Temperature: 5~35℃, Humidity: 45%~85%R.H., Atmospheric
pressure: 860 ~1060hPa) unless the standard condition (Temperature: 25±3℃, Humidity: 60±10%R.H.
Atmospheric pressure: 860 ~1060hPa) is regulated to measure.
C.
APPEARANCE DRAWING
Tolerance: ±0.5mm Except Specified
2/5
D: TEST METHOD:
In the measuring test, buzzer is placed as follows:
E: FREQUENCY RESPONSE:
3/5
4/5
E:Recommended Temp. Profile for Reflow Oven (Fig.1)
Profile Feature
Average ramp-up rate(TL to Tp)
Pb-Free Assembly
3℃/second max.
Preheat
-Temperature Min.(Tsmin)
150℃
-Temperature Min.(Tsmax)
200℃
-Temperature Min.(ts)
60~180 seconds
Tsmax to TL
-Ramp-up Rate
3℃/second max.
Time maintained above:
- Temperature(TL)
-Time(TL)
217℃
60~150 seconds
Peak temperature(Tp)
245℃+0/-5℃
Time within 5℃of actual Peak temperature (tp)
6 seconds max.
Ramp-down Rate
Time 25℃ to Peak Temperature
6℃/second max.
8 minutes max.
5/7
F: Reliability Test
After any following tests the part shall meet specifications without any degradation in
appearance and performance except SPL. SPL shall not deviate more than -10 dB
from the initial value
1.
2.
3.
4.
5.
6.
7.
Ordinary Temperature Life Test
The part shall be subjected to 96 hours at 25±10℃. Input rated voltage
Resonant frequency, 1/2 duty Square wave.
High Temperature Test
The part shall be capable of with standing a storage temperature of +70℃ for 96 hours.
Low Temperature Test
The part shall be capable of with standing a storage temperature of -30℃ for 96 hours.
Humidity Test
Temperature:+40℃±3℃ Relative Humidity:90%~95% Duration: 48 hours
and expose to room temperature for 6 hours
Temperature Shock Test
Temperature:60℃ /1hour→ 25℃/3hours→-30℃/1hour→ 25℃/3hours (1cycle)
Total cycle: 10 cycles
Drop Test
Standard Packaging From 120mm(Drop on hard wood or board of 5cm thick,
three sides, six plain.)
Vibration Test
Vibration:1000cycles /min. Amplitude:1.5mm, Duration: 1 hour in each 3 axes
Note:
As this product is not protected from foreign material entering, please make sure that any foreign materials
(e.g. magnetic powder, washing solvent, flux, corrosive gas) do not enter this product in your production
processes. The functional degradation (e.g. SPL down) may occur if foreign material enter it.
6/7
G: PACKING:
7/7
PACKING:
NOTES:
1.600 PCS per tray
2.Total 10 trays per carton
3.Total 6000 PCS carton
4.Volume:36×44.2×36cm
8/7
很抱歉,暂时无法提供与“GSC14045YB-3V4000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.50000
- 30+3.37500
- 100+3.25000
- 500+3.00000
- 1000+2.87500
- 2000+2.80000
- 国内价格
- 1+3.49596
- 10+2.71728
- 30+2.17988
- 100+2.04207
- 500+1.95437
- 1000+1.91052
