ELECTRONICS
Metal
Oxide
Varistors
RL0603E Series
Circuit Protection
System
Specifications are subject to change without notice.
Metal Oxide Varistors - RL0603E Series
Features
1. Excellent ESD clamping & Small Insertion Loss
2. High transient current capability, Fastest response time
3. Capacitance is designed to ultra-low value, which can be efficiently suitable to high speed data line.
4. EU-RoHS Compliance
Product Name
R
L
Brand Name
E
EIA
Type
0603
E:ESD
Varistor Voltage
M
M±30%
5
K
capacitance
Type
0.15PF=015
Package Dimensions
Unit:mm
EIA
L1(mm)
W(mm)
H(mm)
L2&L3(mm)
0603
1.60±0.15
0.80±0.15
0.95
0.35±0.15
Circuit Protection
System
Page:1
Electriacl Characteristics
Max.
Operating
Voltage
Max.
Leakage
Curren
VDC(V)
(uA)
@1MHz(Cp)
(V)
(V)
RL0603E005M005K
5
0.001
0.05
450
RL0603E005M015K
5
0.05
0.15
RL0603E005M250K
5
1
RL0603E005M500K
5
RL0603E012M005K
capacitance Trigger Voltage
Clamping
Voltage
Attenuation
esd capability3
Cont.Discharge
50
-3dB at 5GHz
8KV
250
50
-3dB at 5GHz
8KV
2.5
200
50
8KV
1
5
15
25
8KV
12
0.05
0.05
250
50
-3dB at 5GHz
8KV
RL0603E012M015K
12
1
0.15
200
50
-3dB at 5GHz
8KV
RL0603E012M100K
12
1
1
200
50
8KV
RL0603E018M015K
18
1
0.15
250
50
-3dB at 5GHz
8KV
RL0603E018M100K
18
1
1
200
50
8KV
RL0603E018M300K
18
1
3
125
50
8KV
RL0603E024M015K
24
1
0.15
200
50
-3dB at 5GHz
8KV
RL0603E024M250K
24
1
2.5
200
50
8KV
Part Number
Notes:
1.Leakage current at Max.operating Voltage
2.Capacitance is measured with 1Vrms
3.per IEC 61000-4-2,30A@8KV,level 4,clamp measuremtne made 30ns after initiation of pulse,all test IN contact discharge mode.
Circuit Protection
System
Page:2
Electrical Rating
No
ltem
1
Operation
Range
1. -40°C ~ 85°C
2
Leakage
current
Satisfaction to the specification, under 1uA
Applied voltage : specified working voltage
3
Capacitance
Satisfaction to the specification, under 1pF
Frquency & OSC level : 1MHz, 1.0Vrms
4
Solderability
More than 90% of the terminal electrode
shall be covered with new solder.
1. Type of solder : H63A
2. Soldering Temp & Time : 230+/-5°C, 5+/-1 sec
5
Reflow
soldering
1. No Serious mechanical damage
2. More than 50% of the terminal electrode
3. Leakage Currrent :≤ 10uA
2. Temp & Time : max 260+/-5°C, min 10sec
* Refer to the soldering profile of page 6
6
Humidity
Load Test
2. Leakage Currrent :≤ 10uA
Test Temp. & Relative Humidity & Time : 85+/- 5°C,
85 +/- 5% RH, Vw Applied, 500 +/- 12hrs
7
Thermal
Shock
1. Step 1 : -40 +/- 5°C, Step 2 : 85 +/- 5°C
2. Cycle : 30min ± 3min, each 5 cycles
8
High Temp.
Test
Temp. & time : 85+/-5°C , 1000 +/- 24hrs
9
Adhesive
strength
10
ESD
Test Condition / Description
Requirement
under condition of
1005 : min 0.5kgf, 1608 : min 1.0kgf
1. No mechanical damage after test
2. Leakage Current :≤ 10uA
* ESD gun (IEC61000-4-2 standard)
* C=150pF R=330Ω
Circuit Protection
System
W [kgf] min.
1. Contact discharge
* Voltage :+/-8kV(Level 4)
* Number : 10 times in 10sec
2. Air discharge
* Voltage :+/-15kV(Level 4)
Page:3
Packing specifications
Metal
1. Carrier tape
Unit:mm
Size
A
B
W
D
E
F
P
P0
P2
t
0603
1.10+/-0.10
1.90+/-0.10
8.00+/0.20
1.50+/0.25
1.75+/0.10
3.50+/0.50
4.0+/-0.1
4.0+/0.10
2.0+/0.10
1.1max
2. Reel & Label
[Plastic Reel]
Unit:mm
t
A
code
A
50
C
Code
ΦA
ΦB
unit : mm
dimension
dimension
178+/-2.0
178+/-2.0
13.0+/-0.5
B
ΦC 13.0+/-0.5
22.0+/-2.0
C
G 22.0+/-2.0
10.0+/-1.5
t
2.5+/-0.5
G
t
10.0+/-1.5
2.5+/-0.5
Label
B
G
Frequency properties ; Cp, Insertion Loss
1.0
5
-5
-10
-15
-25
(a)
(a)
(b)
LOPIVA-0.8pF
LOPIVA-0.15pF
2
4
6
Frequency (GHz)
Circuit Protection
System
8
10
Capacitance (pF)
Attenuation (dB)
(a)
(b)
(b)
0.8
LOPIVA-0.8pF
LOPIVA-0.15pF
0.6
(a)
0.4
0.2
0.0
(b)
1
10
100
1000
Frequency (MHz)
Page:4
Metal Oxide
1) Land Pattern Design
a
Code
b
Land Dimension with Chip Size [mm]
0201
0402
0603
0805
a
0.20~0.35
0.30~0.50
0.60~0.70
0.60~0.70
b
0.25~0.40
0.40~0.60
0.60~0.80
0.80~1.10
c
0.25~0.40
0.30~0.50
0.60~0.80
1.00~1.20
c
2) Reflow Soldering
300
Temp. [deg. C]
250
200
150
100
a
50
d
c
b
LOPIVA
16G05D
Time [sec]
Zone
a
Curing
temp. range [deg. C]
time [sec]
RT ~ 130
60
b
Preheat
max 220
90 ~ 150
c
Soldering
220 ~ 260 [max 270]
90 ~ 150
d
Cooling
220 ~ RT
min 60
3) Soldering Iron
Remark
* Solder : Sn-Ag-Cu
* 260deg. C, over 10sec
Solder Iron
400+/
400+/--5 deg. C, max 5sec
Terminal Electrode
Solder
Solder pad
To prevent a defective crack from thermal shock due to solder iron, the end of
iron-tip must be located on between terminal electrode and solder pad
PCB
Circuit Protection
System
Page:5
RuiLongYuan Electronics Co., Ltd.
· Reproducing and modifying information of the document is prohibited without permission from
Ruilongyuan International Inc.
· Ruilongyuan International Inc. reserves the rights to make changes of the content herein the document anytime
without notification. Please refer to our website for the latest document.
· Ruilongyuan International Inc. disclaims any and all liability arising out of the application or use of any product
including damages incidentally and consequentially occurred.
· Ruilongyuan International Inc. does not assume any and all implied warranties, including warranties of fitness
for particular purpose, non-infringement and merchantability.
· Applications shown on the herein document are examples of standard use and operation. Customers are responsible
in comprehending the suitable use in particular applications.Ruilongyuan International Inc. makes no representation or
warranty that such applications will be suitable for the specifed use without further testing or modifcation.
· The products shown herein are not designed and authorized for equipments requiring high level of reliability or relating to
human life and for any applications concerning life-saving or life-sustaining, such as medical instruments, transportation
equipment,aerospace machinery et cetera. Customers using or selling these products for use in such applications do so at
their own risk and agree to fullyindemnify Ruilongyuan International Inc. for any damages resulting from such improper use or
sale.
Circuit Protection
System
Page:6
很抱歉,暂时无法提供与“RL0603E012M100K”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.26026
- 100+0.20894
- 800+0.16403
- 1600+0.16157
- 4000+0.13659
- 国内价格
- 1000+0.08204
- 4000+0.07955
- 国内价格
- 1+0.31130
- 200+0.20020
- 2000+0.17380
- 4000+0.15400
- 国内价格
- 10+0.28393
- 100+0.22794
- 300+0.19994
- 1000+0.17895
- 4000+0.14901
- 8000+0.14065
