ELECTRONICS
Positive
Thermal
Coefficent
SMD0603 Series
Circuit Protection
System
Specifications are subject to change without notice.
Positive Thermal Coefficent - SMD0603 Series
Features
1. I(hold): 0.1~1.1A
2. RoHS compliant, lead-free and halogen-free
3. Fast response to fault currents
4. Compact design saves board space
5. Low resistance
6. Low-profile
7.X Compatible with high temperature solders
Applications
1. USB peripherals
2. Disk drives
3. CD-ROMs
4. Plug and play protection for motherboards and peripherals
5. Mobile phones - battery and port protection
6. Disk drives
7. PDAs / digital cameras
8. Game console port protection
Product Name
S
M
Surface Mount
Device
D
Device
Dimensions:
Length/Width
(Unit: 1/100
inch)
Circuit Protection
System
P
Polytronics
Symbol
Current Rating
0.1A
T
F
T: Thin
Version
(Optional)
F: Lead-free
Special
Voltage
Rating
(Optional)
Page:1
Dimension
A
B
D
Ihold Itrip
Type Number
Marking
A
A
Maximum
Time To Trip
Current A Time s
C
P
Rmin R1max
Vmax Imax
dmax
Vdc
A
W
Ω
Ω
Package Dimensions
(mm)
Package
A
B
C
D
min max min max min max min
SMD0603P010TF
1
0.1
0.3
0.5
1
15
40
0.5
0.9
6
0603
1.45 1.85 0.65 1.05 0.15 0.4 0.1
SMD0603P020TF
2
0.2
0.5
1
0.6
9
40
0.5
0.55
3.5
0603
SMD0603P025TF
2
0.25 0.55
8
0.08
9
40
0.5
0.5
3
0603
SMD0603P035TF
3
0.35 0.75
8
0.1
6
40
0.5
0.2
1.4
0603
SMD0603P050TF
5
0.5
1
8
0.1
6
40
0.5
0.1
0.8
0603
1.45 1.85 0.65 1.05 0.15 0.5 0.11
SMD0603P075TF
7
0.75
1.4
8
0.1
6
40
0.5
0.06
0.45
0603
SMD0603P100TF
2
8
0.1
6
40
0.5
0.04
0.3
0603
SMD0603P110TF
2.2
8
0.1
6
40
0.5
0.04
0.28
0603
Vocabulary
Ihold = Hold current: maximum current device will pass without tripping in 23ºC still air.
Itrip = Trip current: minimum current at which the device will trip in 23 ºC still air.
Vmax = Maximum voltage device can withstand without damage at rated current (I max)
Imax = Maximum fault current device can withstand without damage at rated voltage (Vmax)
Pd typ = Typical power dissipated from device when in the tripped state at 23 ºC still air.
Rmin = Minimum resistance of device in initial (un-soldered) state.
R1max = Maximum resistance of device at 23 ºC measured one hour after tripping or reflow soldering of 260 ºC for 20 sec.
Circuit Protection
System
Page:2
Thermal Derating Curve
Percentage of Rated Current
200.00
150.00
100.00
50.00
0.00
-40.00
0.00
40.00
80.00
Device Ambient Temperature (
120.00
Thermal Derating Chart
Profile Feature
Pb-Free Assembly
Average Ramp-Up Rate(Ts max to T p)
3°C/second mac.
Preheat
-Temperature Min(Ts min)
-Temperature Max(Ts max)
-Time(Ts min to Ts max)
150°C
200°C
60~180 seconds
Time maintained above:
-Temperature(TL)
-Time(tL)
+217°C
60~150 seconds
Peak Temperature(Tp)
Ramp-Down Rate
·Recommended reflow methods: IR, vapor phase oven, hot air oven,
N2 environment for lead-free
·Recommended maximum paste thickness is 0.25mm (0.010 inch)
·Devices can be cleaned using standard industry methods and
solvents.
Note 1: All temperature refer to topside of the package, measured on
the package body surface.
Note 2: If reflow temperatures exceed the recommended profile,
devices may not meet the performance requirements.
Circuit Protection
System
Time 25°C to Peak Temperature
Storage Condition
260°C
6°C/second max.
8 minutes max
0°C~35°C,70%RH
Page:3
Tape and Reel Specificatons
H
P1
P2
D0
P0
E1
W4
W3
D
F
W
T
W2
W
F
D2
C
W1
K0
A0
H1
B0
TAPE SPECIFICATIONS: EIA-481-1 (mm)
0805L010
0805L020
0805L035
0805L050
0805L075
0805L100
W
8.0+/- 0.10
8.0+/- 0.10
8.0+/- 0.10
8.0+/- 0.10
F
3.5+/- 0.05
3.5+/- 0.05
3.5+/- 0.05
3.5+/- 0.05
E1
1.75+/- 0.10
1.75+/- 0.10
1.75+/- 0.10
1.75+/- 0.10
D0
1.55+/- 0.05
1.55+/- 0.05
1.55+/- 0.05
1.55+/- 0.05
D1
1.0 (min)
1.0 (min)
1.0 (min)
1.0 (min)
P0
4.0+/- 0.10
4.0+/- 0.10
4.0+/- 0.10
4.0+/- 0.10
P1
4.0+/- 0.10
4.0+/- 0.10
4.0+/- 0.10
4.0+/- 0.10
P2
2.0+/- 0.05
2.0+/- 0.05
2.0+/- 0.05
2.0+/- 0.05
A0
1.45+/- 0.10
1.45+/- 0.10
1.45+/- 0.10
1.45+/- 0.10
B0
2.30+/- 0.10
2.30+/- 0.10
2.30+/- 0.10
2.30+/- 0.10
T
0.25+/- 0.10
0.25+/- 0.10
0.25+/- 0.10
0.25+/- 0.10
K0
0.9+/- 0.10
0.9+/- 0.10
0.9+/- 0.10
0.9+/- 0.10
Leader min.
390
390
390
390
Trailer min.
160
160
160
160
Circuit Protection
System
REEL DIMENSIONS:
EIA-481-1 (mm)
H
12.0+/- 0.05
W
9.0+/- 0.5
D
Ø60+0.5
F
Ø13.0+/- 0.2
C
Ø178+/- 1.0
H1
11+/- 0.5
W1
2.2+/- 0.5
W2
3.0+0.5
W3
4.0+0.5
W4
5.5+0.5
Page:4
Part Numberr
-40℃
-20℃
0℃
23℃
40℃
50 ℃
60℃
70℃
85℃
SMD0603P004TF
0.052
0.048
0.044
0.040
0.032
0.028
0.024
0.020
0.012
SMD0603P010TF
0.13
0.12
0.11
0.10
0.08
0.07
0.06
0.05
0.03
SMD0603P020TF
0.27
0.25
0.23
0.20
0.17
0.14
0.12
0.10
0.07
SMD0603P025TF
0.32
0.29
0.27
0.25
0.21
0.18
0.16
0.14
0.10
SMD0603P035TF
0.47
0.41
0.38
0.35
0.29
0.26
0.24
0.20
0.14
SMD0603P050TF
0.67
0.59
0.54
0.50
0.41
0.37
0.34
0.29
0.20
Warehouse Storage Conditions of Products
· Storage Conditions:
1. Storage Temperature: -10°C~+40°C
2. Relative Humidity:≤75%RH
3. Keep away from corrosive atmosphere and sunlight.
· Period of Storage: 1 year
Circuit Protection
System
Page:5
很抱歉,暂时无法提供与“SMD0603P075TF”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.07269
- 50+0.83487
- 150+0.73287
- 500+0.60575
- 2500+0.47114
- 4000+0.43708
- 国内价格
- 1+0.68442
- 200+0.47124
- 2000+0.42840
- 4000+0.40086
- 国内价格
- 5+0.95069
- 50+0.74149
- 150+0.65179
- 国内价格
- 1+0.51840
- 10+0.49680
- 50+0.48390
- 100+0.46660
