ES5AC THRU ES5JC
Reverse Voltage - 50 to 600 Volts
Forward Current - 5.0 Ampere
SURFACE MOUNT SUPER FAST RECOVERY RECTIFIER
Features
DO-214AB/SMC
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
For surface mounted applications
Low reverse leakage
Built-in strain relief,ideal for automated
placement High forward surge current capability
High temperature soldering guaranteed:
0.245(6.22)
0.220(5.59)
0.126 (3.20)
0.114 (2.90)
0.280(7.11)
0.260(6.60)
0.012(0.305)
0.006(0.152)
250°C/10 seconds at terminals
Glass passivated chip junction
0.103(2.62)
0.079(2.06)
0.060(1.52)
0.030(0.76)
Mechanical Data
0.008(0.203)MAX.
0.320(8.13)
0.305(7.75)
Case : JEDEC DO-214AB/SMC Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.007 ounce, 0.25 grams
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward r ectified
current at T L=100℃
Peak forward surge current
8.3ms single half sine-wave
superimposed onrated load (JEDEC Method)
Maximum instantaneous forward voltage at 5.0A
Maximum DC reverse current
TA=25℃
at rated DCblocking voltage
TA=125℃
Maximum reverse recovery time
(NOTE 1)
Typical junction capacitance (NOTE 2)
Typical thermal resistance (NOTE 3)
Operating junction and storage temperature range
SYMBOLS
VRRM
VRMS
VDC
I(AV)
MDD
MDD
MDD
MDD
MDD
MDD
MDD
ES5AC ES5BC ES5CC ES5DC ES5EC ES5GC ES5JC
50
35
50
100
70
100
150
105
150
IFSM
VF
IR
1
200
140
200
300
210
300
400
280
400
600
420
600
UNITS
V
V
V
5.0
A
120
A
5
100
1.25
1.68
V
μA
trr
35
ns
CJ
50
pF
RθJA
35
13
℃/W
RθJC
TJ,TSTG
- 5 5t o + 1 5 0
Note:1.Reverse recovery condition IF=0.5A,IR=1.0A,Irr=0.25A
2.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
3.P.C.B. mounted with 2.0”x2.0”(5.0x5.0cm) copper pad areas
http://www.microdiode.com
Rev:2024A2
Page :1
ES5AC THRU ES5JC
Ratings And Characteristic Curves
Fig.1 Reverse Recovery Time Characteristic And Test Circuit Diagram
trr
10 ohm
Noninductive
50 ohm
Noninductive
+0.5
D.U.T
PULSE
GENERATOR
Note 2
25Vdc
approx
1 ohm
NonInductive
OSCILLOSCOPE
Note 1
-1.0
Note:1.Rise Time = 7ns, max.
Input Impedance = 1megohm,22pF.
2. Ries Time =10ns, max.
Source Impedance = 50 ohms.
10ns/div
Set time Base for 10ns/div
Fig.3 Typical Reverse Characteristics
7.0
300
6.0
100
I R - Reverse Current (μA)
Average Forward Current (A)
Fig.2 Maximum Average Forward Current Rating
5.0
4.0
3.0
2.0
1.0
Single phase half-wave 60 Hz resistive
or inductive load
0.0
25
50
75
100
125
150
TJ=125°C
10
TJ=75°C
1.0
TJ=25°C
0.1
175
Case Temperature (°C)
Junction Capacitance (pF)
Instaneous Forward Current (A)
TJ=25°C
1.0
ES5AC~ES5DC
ES5EC/ES5GC
ES5JC
0.01
0.5
1.0
1.5
100
TJ=25°C
100
10
TJ=25°C
f = 1.0MHz
Vsig = 50mVp-p
1
Fig.5 Typical Junction Capacitance
10
0.001
60
% of PIV.VOLTS
Fig.4 Typical Forward Characteristics
0.1
40
2.0
2.5
Instaneous Forward Voltage (V)
0.1
1.0
10
100
Reverse Voltage (V)
Peak Forward Surage Current (A)
Fig.6 Maximum Non-Repetitive Peak
140
120
100
80
60
40
8.3 ms Single Half Sine Wave (JEDEC
Method)
1
10
100
Number of Cycles
The curve above is for reference only.
Rev:2024A2
Page :2
ES5AC THRU ES5JC
Packing information
P0
unit:mm
P1
d
E
F
B
A
Item
Symbol
Tolerance
SMC
Carrier width
Carrier length
Carrier depth
Sprocket hole
13" Reel outside diameter
13" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
A
B
C
d
D
D1
D2
E
F
P
P0
P1
T
W
Reel width
W1
0.1
0.1
0.1
0.05
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
6.15
8.41
2.42
1.50
330.00
50.00
13.00
1.75
7.50
8.00
4.00
2.00
0.25
16.00
16.50
W
P
D2
T
D1
C
W1
D
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
REEL SIZE
REEL
(pcs)
COMPONENT
SPACING
(mm)
SMC
13"
3,000
4.0
INNER
BOX
(mm)
REEL
DIA,
(mm)
190*190*41
330
BOX
(pcs)
6000
CARTON
SIZE
(mm)
CARTON
(pcs)
365*365*340
42000
APPROX.
GROSS WEIGHT
(kg)
14.0
Suggested Pad Layout
Symbol
Unit (mm)
A
4.3
0.170
C
4.1
7.9
0.160
0.311
D
3.8
0.150
E
12
0.472
B
Unit (inch)
Rev:2024A2
Page :3
很抱歉,暂时无法提供与“ES3DC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.51375
- 100+0.43025
- 300+0.38846
- 3000+0.26547
- 6000+0.24043
- 9000+0.22785
- 国内价格
- 10+0.51300
- 100+0.42930
- 300+0.38460
- 3000+0.26280
- 6000+0.23810
- 9000+0.22570
- 国内价格
- 10+0.47093
- 100+0.39440
- 600+0.35608
- 1200+0.35074
- 3000+0.24334
- 国内价格
- 1+0.38755
- 200+0.24955
- 1500+0.21735
- 3000+0.19205
- 国内价格
- 100+0.22374
- 1000+0.20510
- 3000+0.19888
