BZT52B2V4-BZT52B51
Surface Mount Zener Diode
SOD-123
0.022(0.55)
Typ. Min.
0.053(1.35)
Max.
Features
Planar die construction.
0.152(3.85)
0.140(3.55)
“B” for ±2% tolerance.
General purpose, medium current.
Ideally suited for automated assembly processes.
0.112(2.85)
0.100(2.55)
0.010(0.25)
Min.
0.067(1.70)
0.055(1.40)
0.006(0.15)
Typ. Min.
Applications
0.004(0.10)
Max.
Zener diode.
Ultra-small surface mount package.
Dimensions in inches and (millimeters)
Ordering Information
Type No.
Marking
BZT52B2V4-BZT52B51
See table 2
Package Code
SOD-123
Package Information
Device
Package
Shipping
BZT52B2V4-BZT52B51
SOD-123
3000/Tape&Reel
MAXIMUM RATING @ Ta=25℃ unless otherwise specified
Characteristic
Symbol
Value
Unit
VF
0.9
V
Power Dissipation
Pd
500
mW
Thermal resistance,junction to ambient air
RθjA
305
℃/W
Junction temperature
Tj
150
Storage temperature range
Tstg
-65-150
Forward Voltage
@ IF=10mA
Notes: 1. Device mounted on ceramic PCB; 7.6mm x 9.4mm x 0.87mm with pad areas 25mm2
2. Short duration test pulse used to minimize self-heating effect.
3. When provided, otherwise, parts are provided with date code only, and type number
identifications appears on reel only.
4. f = 1KHz
ht t p : //
Revision:20170701-P1
www.lgesemi .c o m
mail:lge@lgesemi.com
BZT52B2V4-BZT52B51
ELECTRICAL CHARACTERISTICS @ Ta=25℃ unless otherwise specified
Type
Number
Maximum Zener
Impedance
Zener Voltage Range
Marking
Code
VZ@IZT
IZT
Nom(V)
Min(V)
Max(V)
mA
ZZT@IZT
ZZK@IZK
Ω
IZK
mA
BZT52B2V4
2WX
2.4
2.35
2.45
5
85
600
1.0
BZT52B2V7
2W1
2.7
2.65
2.75
5
83
500
1.0
BZT52B3V0
2W2
3.0
2.94
3.06
5
95
500
1.0
BZT52B3V3
2W3
3.3
3.23
3.37
5
95
500
1.0
BZT52B3V6
2W4
3.6
3.53
3.67
5
95
500
1.0
BZT52B3V9
2W5
3.9
3.82
3.98
5
95
500
1.0
BZT52B4V3
2W6
4.3
4.21
4.39
5
95
500
1.0
BZT52B4V7
2W7
4.7
4.61
4.79
5
78
500
1.0
BZT52B5V1
2W8
5.1
5
5.2
5
60
480
1.0
BZT52B5V6
2W9
5.6
5.49
5.71
5
40
400
1.0
BZT52B6V2
2WA
6.2
6.08
6.32
5
10
200
1.0
BZT52B6V8
2WB
6.8
6.66
6.94
5
8
150
1.0
BZT52B7V5
2WC
7.5
7.35
7.65
5
7
50
1.0
BZT52B8V2
2WD
8.2
8.04
8.36
5
7
50
1.0
BZT52B9V1
2WE
9.1
8.92
9.28
5
10
50
1.0
BZT52B10
2WF
10
9.8
10.2
5
15
70
1.0
BZT52B11
2WG
11
10.8
11.2
5
1.0
BZT52B12
2WH
12
11.8
12.2
5
1.0
BZT52B13
2WI
13
12.7
13.3
5
25
110
1.0
BZT52B15
2WJ
15
14.7
15.3
5
30
110
1.0
BZT52B16
2WK
16
15.7
16.3
5
40
170
1.0
BZT52B18
2WL
18
17.6
18.4
5
50
170
1.0
BZT52B20
2WM
20.4
5
50
220
1.0
BZT52B22
2WN
22
21.6
22.4
5
55
220
1.0
BZT52B24
2WO
24
23.5
24.5
5
80
220
1.0
BZT52B27
2WP
27
26.5
27.5
5
80
250
1.0
BZT52B30
2WQ
30
29.4
30.6
5
80
250
1.0
BZT52B33
2WR
33
32.3
33.7
5
80
250
1.0
BZT52B36
2WS
36
35.3
36.7
5
90
250
1.0
BZT52B39
2WT
39
38.2
39.8
5
90
300
1.0
BZT52B43
2WU
43
42.1
43.9
5
100
700
1.0
BZT52B47
2WV
47
46.1
47.9
5
100
750
1.0
BZT52B51
2WW
51
50
52
5
100
750
1.0
ht t p : //
www.lgesemi .c o m
BZT52B2V4-BZT52B51
TYPICAL CHARACTERISTICS @ Ta=25℃ unless otherwise specified
PACKAGE
SPQ/PCS
CARTON
SPQ/PCS
CARTON
SIZE/CM
CARTON
GW/KG
CARTON
NW/KG
SOD-123
3000/REEL
90000
40X20X22
5.00
4.00
ht t p : //
www.lgesemi .c o m
很抱歉,暂时无法提供与“BZT52B33”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.11433
- 300+0.07566
- 1200+0.07453
- 3000+0.06554
- 国内价格
- 10+0.13278
- 100+0.10391
- 300+0.08787
- 3000+0.07611
- 6000+0.06775
- 9000+0.06328
