BZV55C SERIES
500mW.Hermetically Sealed Glass Zener Voltage Rectifiers
MINI-MELF
Features
Zener voltage range 2.0 to 75 volts
LL-34(Mini-MELF) package
Surface device type mounting
Hermetically sealed glass
Compression Bonded Construction
All external surfaces are corrosion
resistant and terminals are readily
solderable
RoHS compliant
Matte Tin(Sn) lead finish
Blue color band indicates negative polarity
Dimension in millimeters
Maximum Ratings and Electrical Characteristics
Rating at 25 oC ambient temperature unless otherwise specified.
Type Number
Power Dissipation
Operating and Storage Temperature Range
Notes:
Value
Units
500
-65 to + 200
mW
o
C
These ratings are limiting values above which the serviceability of the diode may be impaired
ht t p : //
Revision:20170701-P1
Symbol
Ptot
TJ, TSTG
www.lgesemi .c o m
mail:lge@lgesemi.com
BZV55C SERIES
TKVZ - Temperature Coefficient of VZ (10-4/K)
Ptot - Total Power Dissipation (mW)
RATINGS AND CHARACTERISTIC CURVES (BZV55C SERIES)
600
500
400
300
200
100
80
120
160
200
Tamb - Ambient Temperature (°C)
Figure 1. Total Power Dissipation vs. Ambient Temperature
15
10
5
IZ = 5 mA
CD - Diode Capacitance (pF)
Tj = 25 °C
100
IZ = 5 mA
10
150
VR = 2 V
Tj = 25 °C
100
50
10
15
Figure 2. Typical Change of Working Voltage under Operating
Conditions at Tamb=25°C
15
Figure 5. Diode Capacitance vs. Z-Voltage
100
1.3
1.2
IF - Forward Current (mA)
VZtn = VZt/VZ (25 °C)
TKVZ = 10 x 10-4/K
-4
8 x 10 /K
6 x 10-4/K
1.1
4 x 10-4/K
2 x 10-4/K
1.0
- 2 x 10-4/K
- 4 x 10-4/K
0.9
0.8
- 60
10
VZ - Z-Voltage (V)
VZ - Z-Voltage (V)
VZtn - Relative Voltage Change
50
200
1
10
Tj = 25 °C
1
0.1
0.01
0.001
120
180
ht t p : //
0.2
0.4
0.6
0.8
1.0
VF - Forward Voltage (V)
Tj - Junction Temperature (°C)
Figure 3. Typical Change of Working Voltage vs. Junction
Temperature
30
VZ - Z-Voltage (V)
Figure 4. Temperature Coefficient of Vz vs. Z-Voltage
1000
VZ - Voltage Change (mV)
10
Figure 6. Forward Current vs. Forward Voltage
www.lgesemi .c o m
BZV55C SERIES
rZ - Differential Z-Resistance (Ω)
100
IZ - Z-Current (mA)
80
Ptot = 500 mW
Tamb = 25 °C
60
40
6
12
8
1000
IZ = 1 mA
100
5 mA
10 10 mA
Tj = 25 °C
1
VZ - Z-Voltage (V)
10
15
VZ - Z-Voltage (V)
Figure 7. Z-Current vs. Z-Voltage
Figure 9. Differential Z-Resistance vs. Z-Voltage
IZ - Z-Current (mA)
50
Ptot = 500 mW
Tamb = 25 °C
40
30
35
30
VZ - Z-Voltage (V)
Zthp - Thermal Resistance for Pulse Cond. (KW)
Figure 8. Z-Current vs. Z-Voltage
1000
tP/T = 0.5
100
tP/T = 0.2
Single Pulse
10
RthJA = 300 K/W
T = Tjmax - Tamb
tP/T = 0.01
tP/T = 0.1
tP/T = 0.02
tP/T = 0.05
1
10-1
iZM = (- VZ + (VZ2 + 4rzj x T/Zthp) 1/2)/(2rzj)
100
101
102
tP - Pulse Length (ms)
Figure 10. Thermal Response
ht t p : //
www.lgesemi .c o m
BZV55C SERIES
ELECTRICAL CHARACTERISTICS (TA=25OC
VZ @ IZT
(Volts)
unless otherwise noted)
VZ
Min (V)
VZ
Max (V)
IZT
mA
ZZT @ IZT
Ohms
Max
IZK
mA
ZZK @ IZK
Ohms
IR @ VR
uA
Max
VR
V
BZV55C2V0
1.88
2.11
5
100
1.0
600
50
1.0
BZV55C2V2
2.08
2.33
5
100
1.0
600
50
1.0
BZV55C2V4
2.28
2.56
5
85
1.0
600
50
1.0
BZV55C2V7
2.51
2.89
5
85
1.0
600
10
1.0
BZV55C3V0
2.8
3.2
5
85
1.0
600
4
1.0
BZV55C3V3
3.1
3.5
5
85
1.0
600
2
1.0
BZV55C3V6
3.4
3.8
5
85
1.0
600
2
1.0
BZV55C3V9
3.7
4.1
5
85
1.0
600
2
1.0
BZV55C4V3
4.0
4.6
5
75
1.0
600
1
1.0
BZV55C4V7
4.4
5.0
5
60
1.0
600
0.5
1.0
BZV55C5V1
4.8
5.4
5
35
1.0
550
0.1
1.0
BZV55C5V6
5.2
6.0
5
25
1.0
450
0.1
1.0
BZV55C6V2
5.8
6.6
5
10
1.0
200
0.1
2.0
BZV55C6V8
6.4
7.2
5
8
1.0
150
0.1
3.0
BZV55C7V5
7.0
7.9
5
7
1.0
50
0.1
5.0
BZV55C8V2
7.7
8.7
5
7
1.0
50
0.1
6.2
BZV55C9V1
8.5
9.6
5
10
1.0
50
0.1
6.8
BZV55C10
9.4
10.6
5
15
1.0
70
0.1
7.5
BZV55C11
10.4
11.6
5
70
0.1
8.2
BZV55C12
11.4
12.7
5
90
0.1
9.1
BZV55C13
12.4
14.1
5
26
1.0
110
0.1
10
BZV55C15
13.8
15.6
5
30
1.0
110
0.1
11
BZV55C16
15.3
17.1
5
40
1.0
170
0.1
12
BZV55C18
16.8
19.1
5
50
1.0
170
0.1
13
BZV55C20
18.8
21.1
5
55
1.0
220
0.1
15
BZV55C22
20.8
23.3
5
55
1.0
220
0.1
16
BZV55C24
22.8
25.6
5
80
1.0
220
0.1
18
BZV55C27
25.1
28.9
2
80
1.0
220
0.1
BZV55C30
28
32
2
80
1.0
220
0.1
22
BZV55C33
31
35
2
80
1.0
220
0.1
24
BZV55C36
34
38
2
80
1.0
220
0.1
27
BZV55C39
37
41
2
90
0.5
500
0.1
28
BZV55C43
40
46
2
90
0.5
600
0.1
32
BZV55C47
44
50
2
110
0.5
700
0.1
35
BZV55C51
48
54
2
125
0.5
700
0.1
38
BZV55C56
52
60
2
135
0.5
1000
0.1
42
BZV55C62
58
66
2.5
150
0.5
1000
0.1
47
BZV55C68
64
72
2.5
160
0.5
1000
0.1
51
BZV55C75
70
80
2.5
170
0.5
1000
0.1
56
Type
Number
VF Forward Voltage = 1.0v Maximum @ IF=100mA for all types.
Notes:
1. The type numbers listed have zener voltage min/max limits as shown.
2. The zener impedance is derived from the 60-cycle ac voltage, which results
when an ac current having an rams value equal to 10% of the dc zener current
(IZT or IZK) is superimposed to IZT or IZK.
Version: B07
ht t p : //
www.lgesemi .c o m
很抱歉,暂时无法提供与“BZV55C47”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.16730
- 200+0.12939
- 600+0.10833
- 2500+0.09288
- 10000+0.08198
- 20000+0.07604
- 国内价格
- 50+0.15335
- 500+0.09930
- 1000+0.09781
- 2500+0.08514
