1SMA4728A THRU 1SMA4777A
Zener Voltage - 3.3 to 330 Volts
Peak Pulse Power - 1.0 W
ZENER DIODES
Features
DO-214AC/SMA
For surface mounted applications in order to optimize board
space
Low profile package
Built-in strain relief
Glass passivated junction
Low inductance
0.110(2.80)
0.094(2.40)
0.067 (1.70)
0.051 (1.30)
Typical IR less than 5.0μA above 11V
0.177(4.50)
0.157(3.99)
High temperature soldering guaranteed:
0.012(0.305)
0.006(0.152)
260°C / 10 seconds at terminals
0.096(2.42)
0.078(1.98)
Plastic package has Underwriters Laboratory Flammability
Classification 94V-0
0.060(1.52)
0.030(0.76)
0.008(0.203)MAX.
0.208(5.30)
0.188(4.80)
Mechanical Data
Case : JEDEC DO-214AC/SMA Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.0019ounce, 0.055grams
Dimensions in inches and (millimeters)
Standard packing : 12mm tape(E1A-481)
Maximum Ratings And Electrical Characteristics
Ratings at 25 C ambient temperature unless otherwise specified.
MDD Catalog Number
Peak Power Dissipation at TA=50OC,
Derate above 50 OC (Note 1)
Peak Forward Surge Current, 8.3 ms Single Half
Sine-wave Superimposed on Rated Load
(JEDEC method) (Note 2)
Forward Voltage
Operating and Storage Temperature Range
SYMBOLS
VALUE
UNITS
PD
1.0
6.67
Watts
mW/ OC
IFSM
10.0
A
VF
1.2
V
TJ, TSTG
-55 to + 150
O
C
Notes: 1. Mounted on 5.0mm2 (0.013mm thick) land areas.
2. Measured on 8.3ms Single Half Sine-wave or Equivalent Square Wave,
Duty Cycle=4 Pulses Per Minute Maximum.
http://www.microdiode.com
Rev:2024A1
Page :1
Ratings And Characteristic Curves
Dynamic
Impedance
Zener Voltage Range (1)
Type
Marking
Min(V)
Nom(V)
1SMA4728A
728A
3.10
3.3
1SMA4729A
729A
3.40
1SMA4730A
730A
1SMA4731A
V ZT(at I ZT)
Reverse Current
Admissible
Zener Current
I ZT
Z ZT(at I ZT)
IR
at V R
Max(V)
(mA)
Max (Ω)
Max(μA)
(V)
I ZM (mA)
3.50
75
10
100
1
285
3.6
3.80
69
10
100
1
263
3.70
3.9
4.10
64
9.0
50
1
243
731A
4.06
4.3
4.56
58
9.0
25
1
219
1SMA4732A
732A
4.50
4.7
4.93
53
8.0
10
1
203
1SMA4733A
733A
4.84
5.1
5.36
49
7.0
10
1
186
1SMA4734A
734A
5.32
5.6
5.92
45
5.0
10
2
170
1SMA4735A
735A
5.86
6.2
6.51
41
2.0
10
3
154
1SMA4736A
736A
6.46
6.8
7.18
37
3.5
10
4
140
1SMA4737A
737A
7.12
7.5
7.88
34
4.0
10
5
127
1SMA4738A
738A
7.79
8.2
8.67
31
4.5
10
6
116
1SMA4739A
739A
8.60
9.1
9.59
28
5.0
10
7
104
95
1SMA4740A
740A
9.50
10
10.5
25
7.0
10
7
1SMA4741A
741A
10.4
11
11.6
23
8.0
5
8
86
1SMA4742A
742A
11.4
12
12.6
21
9.0
5
9
79
1SMA4743A
743A
12.4
13
14.1
19
10
5
10
71
1SMA4744A
744A
13.8
15
15.8
17
14
5
11
63
1SMA4745A
745A
15.2
16
17.1
16
16
5
12
58
1SMA4746A
746A
16.8
18
19.2
14
13
52
47
1SMA4747A
747A
19.0
13
22
5
15
1SMA4748A
748A
20.8
22
23.3
12
23
5
17
43
1SMA4749A
749A
22.8
24
26.0
11
25
5
18
38
35
1SMA4750A
750A
25.3
27
28.9
9.5
35
5
21
1SMA4751A
751A
28.2
30
32.0
8.5
40
5
23
31
1SMA4752A
752A
31.3
33
34.9
7.5
45
5
25
28
26
1SMA4753A
753A
34.2
36
37.9
7.0
50
5
27
1SMA4754A
754A
37.2
39
41.5
6.5
60
5
30
24
1SMA4755A
755A
40.9
43
45.6
6.0
70
1
32
22
1SMA4756A
756A
44.9
47
49.8
5.5
80
1
35
1SMA4757A
757A
48.6
51
54.0
5.0
95
1
38
18
1SMA4758A
758A
53.6
56
58.8
4.5
110
1
42
17
1SMA4759A
759A
58.9
62
65.6
4.0
125
1
47
15
1SMA4760A
760A
64.6
68
71.7
3.7
150
1
52
14
1SMA4761A
761A
71.2
75
78.8
3.3
175
1
56
12
1SMA4762A
762A
77.9
82
87.0
3.0
200
1
62
11
1SMA4763A
763A
86.0
91
96.0
2.8
250
1
69
10
9.5
1SMA4764A
764A
95.0
100
105
2.5
350
1
76
1SMA4765A
765A
104
110
116
2.3
450
1
84
8.6
1SMA4766A
766A
114
120
127
2.0
550
1
91
7.8
1SMA4767A
767A
125
135
142
1.9
700
1
100
7.0
1SMA4768A
768A
140
150
157
1.7
900
1
110
6.3
1SMA4769A
769A
155
165
172
1.6
1100
1
120
5.8
1SMA4770A
770A
170
180
191
1.4
1200
1
135
5.2
1SMA4771A
771A
189
200
211
1.2
1400
1
150
4.7
1SMA4772A
772A
209
220
231
1.0
1600
1
165
4.3
1SMA4773A
773A
229
240
251
1.0
1800
1
180
3.9
1SMA4774A
774A
249
260
271
1.0
2000
1
190
3.7
1SMA4775A
775A
269
280
291
1.0
2100
1
205
3.4
1SMA4776A
776A
289
300
315
1.0
2300
1
230
3.1
1SMA4777A
777A
313
330
346
1.0
2500
1
250
2.8
(1) V ZT is tested with pulses (20 ms)
Rev:2024A1
Page :2
FIG.1- POWER TEMPERATURE DERATING CURVE
FIG.2- TYPICAL FORWARD CHARACTERISTICS
1000
1.25
MINIMUM
MAXIMUM
500
IF, FORWARD CURRENT (mA)
PD, MAXIMUM POWER DISSIPATION (WATTS)
1.0
0.75
0.50
0.25
200
100
50
5.0
70 C
o
150 C
o
25 C
o
2.0
60
80
100
120
140
160
180
0 oC
1.0
0.4
200
0.5
o
AMBIENT TEMPERATURE( C)
10000
7000
5000
1000
TJ = 25 C
IZ(rms)= 0.1 IZ(dc)
f = 1KHz
o
ZZ, DYNAMIC IMPEDANCE (OHMS)
200
47V
100
1000
700
500
27V
0.1
0.2
0.5
1.0
2.0
5.0
10
100
IZ, ZENER CURRENT (mA)
FIG.4- EFFECT OF ZENER VOLTAGE
ON ZENER IMPEDANCE
1000
700
500
IR, LEAKAGE CURRENT ( A)
2.0
1.1
7.0
5.0
2.0
1.0
0.7
0.5
+125 C
o
0.2
TJ = 25 C
IZ(rms)= 0.1 IZ(dc)
f = 1KHz
o
IZ = 1.0mA
200
100
70
50
5.0mA
20mA
0.1
0.07
0.05
0.02
0.01
0.007
0.005
10
7.0
5.0
+25 C
o
0.002
2.0
1.0
1.0
100
70
50
5.0
1.0
0.9
200
0.8V
10
0.8
TYPICAL LEAKAGE CURRENT
AT 80% OF NOMINAL
BREAKDOWN VOLTAGE
2000
50
FIG.5- TYPICAL LEAKAGE CURRENT
FIG.3- EFFECT OF ZENER CURRENT
ON ZENER IMPEDANCE
500
0.6
VF, FORWARD VOLTAGE (VOLTS)
0.001
3.0
1.0
2.0
3.0
5.0
7.0
10
50 70
4.0
5.0
6.0
7.0
8.0
9.0
10
11
12
13
14
15
VZ, NOMINAL ZENER VOLTAGE (VOLTS)
100
FIG.6- TYPICAL CAPACITANCE versus Vz
FIG.7- TEMPERATURE COEFFICIENTS
400
300
C, CAPACITANCE (pF)
0V BIAS
1.0V BIAS
100
10
8
50% OF BREAKDOWN BIAS
4
1.0
10
VZ, FORWARD VOLTAGE (VOLTS)
100
OVZ, TEMPERAYURE COEFFICIENT (mV/oC)
a-RANGE FOR UNITS TO 12 VOLTS
200
+12
+10
+8.0
+6.0
+4.0
+2.0
RANGE
VZ @ IZT
-2.0
-4.0
2.0
3.0
4.0
5.0
6.0
7.0
8.0
9.0
10
11
12
VZ, ZENER VOLTAGE (VOLTS)
The cruve graph is for reference only
Rev:2024A1
Page :3
FIG.8- EFFECT OF ZENER CURRENT
b-RANGE FOR UNITS 12 TO 100 VOLTS
100
70
50
30
VZ @ IZT
RANGE
10
7.0
5.0
3.0
2.0
1.0
10
50
70
+6.0
VZ @ IZT
TA25 oC
+4.0
+2.0
20mA
0.01mA
1.0mA
-2.0
-4.0
100
NOTE: BELOW 3 VOLTS AND ABOVE a VOLTS
CHANGES IN ZENER CURRENT OO NOT
AFFECT TEMPERATURE COEFFICIENTS
3.0
4.0
5.0
6.0
7.0
8.0
Ppk, PEAK SURGE POWER IWATTSO
FIG.9- MAXIMUM SURGE POWER
100
70
50
30
5% DUTY CYCLE
0.8V-10V NON-REPETITIVE
7.0
5.0
3.0
RECTANGULAR
WAVEFORM
o
TJ = 25 C PRIOR TO
INITIAL PULSE
11V-91V NON-REPETITIVE
10% DUTY CYCLE
20% DUTY CYCLE
2.0
1.0
0.01
0.02
0.05
0.1
0.2
0.5
1.0
2.0
5.0
10
100
200
500
1000
PW, PULSE WIDTH (ms)
Rev:2024A1
Page :4
Packing information
unit:mm
P0
P1
d
Item
Symbol
Tolerance
SMA
Carrier width
Carrier length
Carrier depth
Sprocket hole
13" Reel outside diameter
13" Reel inner diameter
7" Reel outside diameter
7" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
Reel width
A
B
C
d
D
D1
D
D1
D2
E
F
P
P0
P1
T
W
W1
0.1
0.1
0.1
0.05
2.0
min
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
2.80
5.33
2.36
1.50
330.00
50.00
178.00
62.00
13.00
1.75
5.50
4.00
4.00
2.00
0.28
12.00
18.00
E
F
B
A
W
P
D2
T
D1
C
W1
D
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
REEL SIZE
REEL
(pcs)
COMPONENT
SPACING
(m/m)
BOX
(pcs)
INNER
BOX
(m/m)
REEL
DIA,
(m/m)
2,000
4.0
4,000
183*155*183
178
CARTON
SIZE
(m/m)
CARTON
(pcs)
APPROX.
GROSS WEIGHT
(kg)
SMA
7"
SMA
11"
5,000
4.0
10,000
290*290*38
330
310*310*360
80,000
11.0
SMA
13"
7,500
4.0
15,000
335*335*38
330
350*330*360
120,000
14.5
382*356*392
80,000
12.0
Suggested Pad Layout
Symbol
Unit (mm)
A
1.68
Unit (inch)
0.066
B
1.52
0.060
C
3.93
0.154
D
2.41
0.095
E
5.45
0.215
Rev:2024A1
Page :5
很抱歉,暂时无法提供与“1SMA4746A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.28772
- 100+0.23080
- 300+0.20229
- 1000+0.18101
- 5000+0.13922
- 10000+0.13068
- 国内价格
- 10+0.26374
- 100+0.21156
- 1000+0.16592
- 2000+0.16343
- 5000+0.12761
- 国内价格
- 1+0.23000
- 500+0.15295
- 2500+0.13340
- 5000+0.12075
