ESD5Z12V
ESD5Z12V
    MDD(辰达半导体)
    SOD-523(SC-79)
    Uni PD=174W VRWM=12V VBR=14.1V VC=29V IPP=6A IR=0.02uA CJ=35PF
ESD5Z12V 数据手册
ESD5Z Series Transient Voltage Suppressors SOD-523 Plastic-Encapsulate ESD Protection Diodes DESCRIPTION The ESD5Z Series is designed to protect voltage sensitive components from ESD and transient voltage events. Excellent clamping capability, low leakage, and fast response time, make these parts ideal for ESD protection on designs where board space is at a premium. Because of its small size, it is suited for use in cellular phones, portable devices, digital cameras, power supplies and many other portable applications.. Features Pin Configuration  IEC61000-4-2 Level 4 ESD Protection  Protects one directional I/O line  Low clamping voltage  Working voltages : 2.5V,3.3V,5V,6V,7V, 12V,15V  Low leakage current) Circuit Diagram 2 1 Applications       Cell Phone Handsets and Accessories Microprocessor based equipment Personal Digital Assistants (PDA’s) Notebooks, Desktops, and Servers Portable Instrumentation Peripherals Mechanical Characteristics  Package: SOD-523  Flammability Rating: UL 94V-0  High temperature soldering guaranted: 260℃/10s  Packaging: Tape and Reel Absolute Maximum Ratings (TA=25°C unless otherwise specified) Parameter ESD per IEC 61000−4−2 (Air) ESD per IEC 61000−4−2 (Contact) ESD Voltage per human body model ESD Voltage per machine model Total Power Dissipation on FR-5 Board (Note 1) @ Ta=25°C Junction and Storage Temperature Lead Solder Temperature – Maximum (10 Second Duration) Symbol Value Unit VESD ± 30 ± 22 kV ESD 16 400 kV PD 150 mW TJ,TSTG −55 to +150 °C TL 260(10S) °C V hese ratings are limiting values above which the serviceability of the diode may be impaired Note:1.FR-5=1.0x0.75x0.62 in 2.The above data above is for reference only. http://www.microdiode.com Rev:2025A3 Page :1 ESD5Z Series Transient Voltage Suppressors ESD5Z12V ESD5Z15V (V) M Max ax Max Min (mA) Max @A Max 6 ESD5Z7V0 (μA) 2.5 6.0 4.0 1 9.0 5.0 8 ESD5Z6V0 (V) 3.3 0.90 5.0 1 10.0 8 ESD5Z5V0 VB 5.0 0.08 6.2 1 5 ESD5Z3V3 IR 6.0 0.05 6.8 8 ESD5Z2V5 VRWM 7.0 0.03 8 PART NUMBER 12.0 8 Electrical Characteristics (TA=25°C unless otherwise specified) 15.0 DEVICE MARKING ZD ·· ZE ·· ZF ·· ZG ·· ZH ·· ZM ·· ZN ·· http://www.microdiode.com VC VC PPK CJ (V) (V) (W) (pF) @A Max Max 11.5 9.0 104 145 5.0 14.0 7.5 .5 105 105 11.6 5.0 15.0 7.0 .0 105 80 1 13.5 5.0 17.5 6.0 .0 105 70 7.5 1 14.0 5.0 18.0 6.0 .0 108 65 0.03 14.1 1 20.0 1.0 26.0 4.0 104 45 0.50 16.0 1 23.0 1.0 30.0 4.0 120 28 IT Rev:2025A3 Page :2 ESD5Z Series Transient Voltage Suppressors ELECTRICAL CHARACTERISTICS CURVE http://www.microdiode.com Rev:2025A3 Page :3 ESD5Z Series Transient Voltage Suppressors Outlitne Drawing SOD-523 Package Outline Dimensions Suggested Pad Layout Note: 1.Controlling dimension:in/millimeters. 2.General tolerance: ±0.05mm. 3.The pad layout is for reference purposes only. PACKAGE SPECIFICATIONS Package Reel Size SOD-523 7' http://www.microdiode.com REF mm inch A 0.99+/-0.10 0.036+/-0.004 B 1.85+/-0.10 0.072+/-0.004 d 1.55+/-0.10 0.060+/-0.004 D 178.00+/-1.00 7.008+/-0.039 D1 54.20+/-2.00 2.134+/-0.079 D2 13.50+/-0.20 0.532+/-0.008 E 1.75+/-0.10 0.068+/-0.004 F 3.50+/-0.10 0.136+/-0.004 P 2.00+/-0.10 0.078+/-0.004 P0 4.00+/-0.10 0.156+/-0.004 P1 2.00+/-0.10 0.078+/-0.004 W 8.00+/-0.10 0.312+/-0.004 W1 9.30+/-0.50 0.366+/-0.020 Reel DIA. (mm) Q'TY/Reel (pcs) Box Size (mm) 178 3000 190×190×190 QTY/Box (pcs) 18,000 Carton Size (mm) Q'TY/Carton (pcs) 400×400×220 108,000 Rev:2025A3 Page :4
ESD5Z12V
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款红外发射二极管。
2. 器件简介:EL817是一种红外发射二极管,用于红外线发射,常用于遥控器等设备。
3. 引脚分配:EL817有两个引脚,分别为阳极和阴极。
4. 参数特性:工作电压范围为1.4V至1.8V,工作电流为50mA,发射波长为940nm。
5. 功能详解:EL817的主要功能是发射红外光,用于无线通信。
6. 应用信息:广泛应用于遥控器、红外线通信等领域。
7. 封装信息:EL817采用黑色塑料封装,尺寸为5.7mm x 2.8mm。
ESD5Z12V 价格&库存
很抱歉,暂时无法提供与“ESD5Z12V”相匹配的价格&库存,您可以联系我们找货
