MUR405 THRU MUR4100
Reverse Voltage - 50 to 1000 Volts
Forward Current - 4.0 Ampere
ULTRA FAST RECTIFIERS
Features
DO-201AD
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
Ultra fast switching for high efficiency
1.0 (25.4)
MIN.
Low reverse leakage
High forward surge current capability
High temperature soldering guaranteed:
260℃/10 seconds,0.375”(9.5mm) lead length,
0.220(5.6)
0.197(5.0)
DIA.
0.375(9.5)
0.285(7.2)
5 lbs. (2.3kg) tension
Glass passivated chip junction
Mechanical Data
1.0 (25.4)
MIN.
Case : JEDEC DO-201AD Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.04 ounce, 1.10 grams
0.052(1.3)
0.048(1.2)
DIA.
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25°C ambient temperature unlss otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
SYMBOLS
Marking Code
VRRM
V RMS
V DC
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
at TA=55℃
Peak forward surge current
8.3ms single half sine-wave
superimposed onrated load (JEDEC Method)
MDD
MDD
MDD
MUR460
MUR480
MUR4100
50
100
200
400
600
800
1000
35
70
140
280
420
560
50
100
200
400
600
800
700
1000
UNITS
V
V
V
IFSM
125
A
trr
MDD
MUR440
A
Maximum reverse recovery time
Operating junction and storage temperature range
MDD
MUR420
4.0
VF
Typical thermal resistance (NOTE 2)
MDD
MUR410
I(AV)
Maximum instantaneous forward voltage at 4.0A
Maximum DC reverse current
TA=25℃
at rated DC blocking voltage
TA=100℃
(NOTE 1)
MDD
MUR405
0.89
0.95
1.3
1.7
5.0
50.0
IR
25
35
50
V
μA
75
ns
RθJA
28
℃/W
TJ,T STG
-55 to +150
Note: 1.Reverse recovery condition IF=0.5A,IR=1.0A,Irr=0.25A
2.Thermal resistance from junction to ambient at 0.375”(9.5mm)lead length,P.C.B. mounted
http://www.microdiode.com
Rev:2024A2
Page :1
MUR405 THRU MUR4100
FIG. 1- FORWARD CURRENT DERATING CURVE
4.0
3.2
2.4
Single Phase
Half Wave 60Hz
Resistive or
inductive Load
1.6
0.8
50
75
100
125
150
PEAK FORWARD SURGE CURRENT,
AMPERES
AVERAGE FORWARD RECTIFIED CURRENT,
AMPERES
Ratings And Characteristic Curves
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
125
100
75
50
25
175
8.3ms SINGLE HALF SINE-WAVE
(JEDEC Method)
1
AMBIENT TEMPERATURE, C
INSTANTANEOUS FORWARD
CURRENT,AMPERES
TJ=25 C
PULSE WIDTH=300 µs
1%DUTY CYCLE
1
0.1
MUR405-MUR420
MUR440-MUR460
MUR480-MUR4100
0.01
0.2
0.6
1.0
1.4
1.8
2.0
INSTANTANEOUS REVERSE CURRENT,
MICROAMPERES
NUMBER OF CYCLES AT 60 Hz
FIG. 3-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
10
FIG. 4-TYPICAL REVERSE CHARACTERISTICS
1,000
100
TJ=100 C
10
1
TJ=25 C
0.1
0.01
INSTANTANEOUS FORWARD VOLTAGE,
VOLTS
100
TJ=25 C
10
1.0
10
REVERSE VOLTAGE,VOLTS
TRANSIENT THERMAL IMPEDANCE,
C/W
JUNCTION CAPACITANCE, pF
FIG. 5-TYPICAL JUNCTION CAPACITANCE
0.1
60
80
100
PERCENT OF PEAK REVERSE VOLTAGE,%
200
1
100
10
FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE
100
10
1
0.1
0.01
0.1
1
10
100
100
t,PULSE DURATION,sec.
The curve above is for reference only.
Rev:2024A2
Page :2
MUR405 THRU MUR4100
Package Information
Taping Specifications
Item
Symbol
Specifications(mm)
Component Pitch
A
10.0±0.5
Inner Tape Pitch
B
52.4±1.5
Component alignment
Z
1.2 Max
Tape width
T
6.0±0.5
Exposed adhesive
E
0.8 Max
Body eccentricity
L1-L2
1.0 Max
Ammunition Package Specifications
Package
Inner Box Size
(mm)
QTY/Box
(pcs)
Carton Size
(mm)
Q'TY/Carton
(pcs)
DO - 201AD
255*74*145
1000
410*275*340
10000
Bulk Package Specifications
Package
Inner Box Size
(mm)
QTY/Box
(pcs)
Carton Size
(mm)
Q'TY/Carton
(pcs)
DO - 201AD
198*86*21
200
460*220*250
10000
Rev:2024A2
Page :3
很抱歉,暂时无法提供与“MUR4100”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.77491
- 50+0.63715
- 150+0.56822
- 1000+0.36635
- 2000+0.32497
- 5000+0.30434
- 国内价格
- 5+0.72491
- 50+0.59604
- 200+0.53155
- 400+0.52358
- 1000+0.34271
