P4SMA6.8(C)A THRU P4SMA550(C)A
Stand-off Voltage - 6.8 to 550 Volts
Peak Pulse Power - 400 W
SURFACE MOUNT TRANSIENT VOLTAGE SUPPRESSOR
Features
DO-214AC/SMA
400W Peak Pulse Power Dissipation
6.8V - 550V Standoff Voltages
Uni- and Bi-Directional Versions Available Excellent Clamping Capability
Glass Passivated Die Construction
Low inductance
Fast Response Time
Plastic Material: UL Flammability Classification Rating 94V-0
0.110(2.80)
0.100(2.54)
0.067 (1.70)
0.051 (1.30)
0.177(4.50)
0.157(3.99)
Mechanical Data
0.012(0.305)
0.006(0.152)
Case : SMA Molded plastic body
Terminals : Solderable per MIL-STD-750,Method 2026
Polarity Indicator: Cathode Band(Note:Bi-directional deviced have no
polarity indicator)
Making: Data Code and Marking Code
Weight : 0.00095ounce, 0.027grams
0.096(2.42)
0.078(1.98)
0.060(1.52)
0.030(0.76)
0.008(0.203)MAX.
0.208(5.28)
0.188(4.80)
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25℃ ambient temperature unless otherwise specified.
Parameter
Value
Symbol
Unit
PPPM
400
W
Peak Forward Surge Current (Note 3,Fig4 )
IFSM
60
A
Peak Pulse Current on 10/1000 us waveform (Note 1)
IPPM
see Table 1
A
Peak Pulse Power Dissipation on TA=25°C (Note 1,2,4, Fig1)
ESD Voltage per IEC6100-4-2
Contact
VESD1
Air
VESD2
Typical Thermal Resistance Junction to Ambient(Note 2)
Operating Junction Temperature and Storage Temperature Range)
30
30
kV
RθJA
100
°C/W
Tj, Tstg
-55 ~ +150
°C
NOTES:
1. Non-repetitive current pulse, per Fig.3 and derated above TA = 25°C per Fig. 2.
2. Mounted on 5mm2 copper pads to each terminal.
3. Peak Forward Surge Current : 8.3ms single half sine-wave Superimposed on rated load (JEDEC method).
4.
Peak pulse power waveform is 10/1000μS.
http://www.microdiode.com
Rev:2024A2
Page :1
Peak Pulse Power - 400W
Characteristics at Ta = 25°C
Reverse
Stand-off
Voltage
Type
UNI
P4SMA6.8A
Table 1
Breakdown
Voltage
V BR @ I T
Reverse
Leakage
Max. Clamp
Voltage
IT
I R @ V RWM
V C @ I PP
I PP
Test
Current
Package
Peak Pulse
Current
SMA
Device Marking Ccode
V RMW
Min
Max
BI
V
V
V
mA
μA
V
A
UNI
BI
P4SMA6.8CA
5.8
6.45
7.14
10
1000
10.5
39.0
6V8A
6V8C
P4SMA7.5A
P4SMA7.5CA
6.4
7.13
7.88
10
500
11.3
36.3
7V5A
7V5C
P4SMA8.2A
P4SMA8.2CA
7.02
7.79
8.61
10
200
12.1
33.9
8V2A
8V2C
P4SMA9.1A
P4SMA9.1CA
7.78
8.65
9.55
1
50
13.4
30.6
9V1A
9V1C
P4SMA10A
P4SMA10CA
8.55
9.5
10.5
1
10
14.5
28.3
10A
10C
P4SMA11A
P4SMA11CA
9.4
10.5
11.6
1
5
15.6
26.3
11A
11C
P4SMA12A
P4SMA12CA
10.2
11.4
12.6
1
5
16.7
24.6
12A
12C
P4SMA13A
P4SMA13CA
11.1
12.4
13.7
1
1
18.2
22.5
13A
13C
P4SMA15A
P4SMA15CA
12.8
14.3
15.8
1
1
21.2
19.3
15A
15C
P4SMA16A
P4SMA16CA
13.6
15.2
16.8
1
1
22.5
18.2
16A
16C
P4SMA18A
P4SMA18CA
15.3
17.1
18.9
1
1
25.5
16.1
18A
18C
P4SMA20A
P4SMA20CA
17.1
19
21
1
1
27.7
14.8
20A
20C
P4SMA22A
P4SMA22CA
18.8
20.9
23.1
1
1
30.6
13.4
22A
22C
P4SMA24A
P4SMA24CA
20.5
22.8
25.2
1
1
33.2
12.3
24A
24C
P4SMA27A
P4SMA27CA
23.1
25.7
28.4
1
1
37.5
10.9
27A
27C
P4SMA30A
P4SMA30CA
25.6
28.5
31.5
1
1
41.4
9.9
30A
30C
P4SMA33A
P4SMA33CA
28.2
31.4
34.7
1
1
45.7
9.0
33A
33C
P4SMA36A
P4SMA36CA
30.8
34.2
37.8
1
1
49.9
8.2
36A
36C
P4SMA39A
P4SMA39CA
33.3
37.1
41
1
1
53.9
7.6
39A
39C
P4SMA43A
P4SMA43CA
36.8
40.9
45.2
1
1
59.3
6.9
43A
43C
P4SMA47A
P4SMA47CA
44.7
49.4
1
1
64.8
6.3
47A
47C
P4SMA51A
P4SMA51CA
40.2
43.6
48.5
53.6
1
1
70.1
5.8
51A
51C
P4SMA56A
P4SMA56CA
47.8
53.2
58.8
1
1
77.0
5.3
56A
56C
P4SMA62A
P4SMA62CA
53
58.9
65.1
1
1
85.0
4.8
62A
62C
P4SMA68A
P4SMA68CA
58.1
64.6
71.4
1
1
92.0
4.5
68A
68C
P4SMA75A
P4SMA75CA
64.1
71.3
78.8
1
1
103.0
4.0
75A
75C
P4SMA82A
P4SMA82CA
70.1
77.9
86.1
1
1
113.0
3.6
82A
82C
P4SMA91A
P4SMA91CA
77.8
86.5
95.5
1
1
125.0
3.3
91A
91C
P4SMA100A
P4SMA100CA
85.5
95
105
1
1
137.0
3.0
100A
100C
P4SMA110A
P4SMA110CA
94
105
116
1
1
152.0
2.7
110A
110C
P4SMA120A
P4SMA120CA
102
114
126
1
1
165.0
2.5
120A
120C
P4SMA130A
P4SMA130CA
111
124
137
1
1
179.0
2.3
130A
130C
P4SMA150A
P4SMA150CA
128
143
158
1
1
207.0
2.0
150A
150C
P4SMA160A
P4SMA160CA
136
152
168
1
1
219.0
1.9
160A
160C
P4SMA170A
P4SMA170CA
145
162
179
1
1
234.0
1.8
170A
170C
P4SMA180A
P4SMA180CA
154
171
189
1
1
246.0
1.7
180A
180C
P4SMA200A
P4SMA200CA
171
190
210
1
1
274.0
1.5
200A
200C
P4SMA220A
P4SMA220CA
185
209
231
1
1
328.0
1.3
220A
220C
P4SMA250A
P4SMA250CA
214
237
263
1
1
344.0
1.2
250A
250C
P4SMA300A
P4SMA300CA
256
285
315
1
1
414.0
1.0
300A
300C
P4SMA350A
P4SMA350CA
300
332
368
1
1
482.0
0.9
350A
350C
P4SMA400A
P4SMA400CA
342
380
420
1
1
548.0
0.8
400A
400C
P4SMA440A
P4SMA440CA
376
418
462
1
1
602.0
0.7
440A
440C
P4SMA480A
P4SMA480CA
408
456
504
1
1
658.0
0.6
480A
480C
P4SMA510A
P4SMA510CA
434
485
535
1
1
698.0
0.6
510A
510C
P4SMA530A
P4SMA530CA
451
503.5
556.5
1
1
725.0
0.6
530A
530C
P4SMA540A
P4SMA540CA
460
513
567
1
1
740.0
0.5
540A
540C
P4SMA550A
P4SMA550CA
468
522.5
577.5
1
1
760.0
0.5
550A
550C
Rev:2024A2
Page :2
Stand-off Voltage - 6.8to 550 Volts
Ratings and Characteristic Curves TA =25°C unless otherwise noted
Fig.1 Peak Pulse Power Rating Curve
Fig.2 Forward Current Derating Curve
100
ulse.Wavefom
PEAK PULSE POWER(PPP)OR CURRENT(IPP)
DERATINGIN PERCENTAGE%
Non-Repetive
e
Shown in Figure.3
PPPM,PEAK PULSE FORWARD ,kW
TA=25°C
10
1.0
Mounted
o 5.0m
m
Copper Lann Areas
d
0.1
100
80
60
40
10
1
100
1000
25
10000
td,PULSE WIDTH ,us
Pulse
Width (td) is Defined
as the Point where the Peak.
Ippm,Peak Pulse Current (%)
Value
Current Decayst to 50% of Ipp
Ippm
80
Half Value-Ipp/2
60
10/1000usec Waveform as Defined bye R.E.A.
40
2.0
T,TIME,ms
3.0
4.0
IFSM,PEAK FORWARD SURGE CURRENT, AMPERES
TA=25°C
Peak
k
125
150
175
Fig.4 Maximum Non-Repetitive Peak
120
100
100
TA,AMBIENT TEMPERATURE,°C
Fig.3 Pulse Waveform
tf=10usec
75
50
60
50
40
30
TJ=TJmax
8.3ms Single Half Sinepwave
JEDEC Method
1
100
Number of Cycles at 60Hz
Rev:2024A2
Page :3
很抱歉,暂时无法提供与“P4SMA6.8CA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.66500
- 100+0.39670
- 500+0.27770
- 5000+0.19840
- 10000+0.18850
- 50000+0.17460
- 国内价格
- 1+0.17999
- 100+0.16799
- 300+0.15599
- 500+0.14399
- 2000+0.13799
- 5000+0.13439
