LVS606045-680M-AU
LVS606045-680M-AU
    CHILISIN(奇力新)
    SMD,6x6mm
    功率电感 68µH ±20% 6045 4.70mm 6.00 x 6.00mm 330mΩ 900mA
LVS606045-680M-AU 数据手册
DE SI GN Cautions and Warnings Please be noted that this spec is only for reference if you have projects NE W designed with the product number listed in. If you are looking for new project design-in, please find AWVS Series specification/datasheet on Chilisin website. Or you may find our sales contact for more information on FO R old part number at your convenience. Appreciated your attention and NO T understanding. Note: Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. Automotive Power Inductor LVS Series AEC-Q200 RoHS Compliant Halogen Free ■ Part Numbering 606045 LVS Internal Code L Low DCR - 1R0 Inductance (uH) R47 0.47 1R0 1.0 101 100 M - Tolerance M T AU Internal Code ±20% ±30% NO T FO R NE W Series Name L Dimensions Code (mm) 404012 4.0x4.0x1.2 404018 4.0x4.0x1.8 505020 5.0x5.0x2.0 505040 5.0x5.0x4.0 606020 6.0x6.0x2.0 606028 6.0x6.0x2.8 606045 6.0x6.0x4.5 606045L 6.0x6.0x4.5 808040 8.0x8.0x4.0 808040L 8.0x8.0x4.0 DE SI GN REACH Compliant www.chilisin.com.tw Automotive Power Inductor LVS Series AEC-Q200 LVS404012 - AU Type ■ Recommended Land Pattern unit:mm ■ Electrical Characteristics Inductance Test Freq. (uH) LVS404012-1R0□-AU LVS404012-1R5□-AU LVS404012-2R2□-AU LVS404012-3R3□-AU LVS404012-4R7□-AU LVS404012-6R8□-AU LVS404012-100□-AU LVS404012-150□-AU LVS404012-220□-AU LVS404012-330□-AU LVS404012-470□-AU 1.0 1.5 2.2 3.3 4.7 6.8 10 15 22 33 47 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V unit:mm RDC (mΩ)±30% Isat(A) Typ.(Max) Irms(A) Typ.(Max) Tolerance (±%) Marking 48 58 65 90 110 135 190 250 400 600 930 2.50(2.20) 2.10(1.80) 1.70(1.50) 1.30(1.10) 1.10(0.90) 0.90(0.81) 0.78(0.70) 0.65(0.58) 0.52(0.46) 0.44(0.39) 0.35(0.31) 1.70(1.50) 1.60(1.40) 1.50(1.30) 1.40(1.20) 1.20(1.00) 1.00(0.94) 0.90(0.81) 0.85(0.76) 0.75(0.67) 0.70(0.63) 0.50(0.45) 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 1R0 1R5 2R2 3R3 4R7 6R8 100 150 220 330 470 NE W Part No. DE SI GN ■ Dimensions Note: When ordering, please specify tolerance code. Tolerance: M=±20% / T=±30% 1. Operating temperature range -40℃~125℃ NO T FO R 2. Isat for Inductance drop 30% from its value without current 3. Irms for a 40℃ temperature rise from 25℃ ambient with current 4. Measure Equipment: L: Agilent HP4284A+Agilent HP42841A RDC: DIGITAL MILLINHM METER CHROMA 16502, or equivalent Isat: Agilent HP4284A Irms: Agilent HP4284A Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. www.chilisin.com.tw Automotive Power Inductor LVS Series AEC-Q200 LVS404012 - AU Type ■ Characteristics Graph Inductance vs. DC Current DE SI GN 50 45 40 470 35 330 25 20 220 15 150 10 NE W L(uH) 30 100 6R8 5 0 0 0.5 1 4R7 3R3 2R2 1.5 1R5 2 1R0 2.5 3 3.5 4 DC Current(A) FO R Temperature Change vs. DC Current 70 60 470 150 50 T 6R8 220 100 0.8 1 4R7 3R3 2R2 1R0 1R5 △T(℃) NO 40 30 20 10 0 0 0.2 0.4 0.6 1.2 1.4 1.6 1.8 2 DC Current(A) Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. www.chilisin.com.tw Automotive Power Inductor LVS Series AEC-Q200 LVS404018 - AU Type ■ Recommended Land Pattern unit:mm ■ Electrical Characteristics Inductance Test Freq. (uH) 1 1.5 1.8 2.2 2.3 3.3 3.6 3.9 4.7 6.8 8.2 10 15 22 33 47 68 100 150 220 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V FO R LVS404018-1R0□-AU LVS404018-1R5□-AU LVS404018-1R8□-AU LVS404018-2R2□-AU LVS404018-2R3□-AU LVS404018-3R3□-AU LVS404018-3R6□-AU LVS404018-3R9□-AU LVS404018-4R7□-AU LVS404018-6R8□-AU LVS404018-8R2□-AU LVS404018-100□-AU LVS404018-150□-AU LVS404018-220□-AU LVS404018-330□-AU LVS404018-470□-AU LVS404018-680□-AU LVS404018-101□-AU LVS404018-151□-AU LVS404018-221□-AU unit:mm RDC (mΩ)±20% Isat(A) Typ.(Max) Irms(A) Typ.(Max) Tolerance (±%) Marking 32 40 55 60 60 70 75 75 90 110 155 170 250 350 530 720 1000 1500 2500 4000 4.10(3.60) 3.30(2.90) 2.80(2.50) 2.80(2.50) 2.80(2.50) 2.20(1.90) 2.10(1.80) 2.10(1.80) 2.00(1.80) 1.60(1.40) 1.50(1.30) 1.40(1.20) 1.00(0.90) 0.90(0.81) 0.80(0.72) 0.70(0.63) 0.56(0.50) 0.46(0.41) 0.35(0.31) 0.28(0.25) 2.80(2.50) 2.60(2.30) 2.50(2.20) 2.50(2.20) 2.50(2.20) 2.10(1.80) 1.90(1.70) 1.90(1.70) 1.70(1.50) 1.50(1.30) 1.30(1.10) 1.20(1.00) 1.00(0.90) 0.85(0.76) 0.70(0.63) 0.56(0.50) 0.45(0.40) 0.38(0.34) 0.30(0.27) 0.23(0.20) 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 1R0 1R5 1R8 2R2 2R3 3R3 3R6 3R9 4R7 6R8 8R2 100 150 220 330 470 680 101 151 221 NE W Part No. DE SI GN ■ Dimensions T Note: When ordering, please specify tolerance code. Tolerance: M=±20% / T=±30% 1. Operating temperature range -40℃~125℃ NO 2. Isat for Inductance drop 30% from its value without current 3. Irms for a 40℃ temperature rise from 25℃ ambient with current 4. Measure Equipment: L: Agilent HP4284A+Agilent HP42841A RDC: DIGITAL MILLINHM METER CHROMA 16502, or equivalent Isat: Agilent HP4284A Irms: Agilent HP4284A Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. www.chilisin.com.tw Automotive Power Inductor LVS Series AEC-Q200 LVS404018 - AU Type ■ Characteristics Graph Inductance vs. DC Current DE SI GN 30 25 L(uH) 20 220 15 150 10 NE W 100 6R8 5 4R7 3R3 0 0 0.5 1 1.5 2 2.5 2R2 3 1R0 3.5 4 4.5 5 DC Current(A) 70 60 FO R Temperature Change vs. DC Current 220 100 6R8 4R7 150 2R2 40 NO △T(℃) T 50 1R0 3R3 30 20 10 0 0 0.5 1 1.5 2 2.5 3 3.5 4 DC Current(A) Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. www.chilisin.com.tw Automotive Power Inductor LVS Series AEC-Q200 LVS505020 - AU Type ■ Recommended Land Pattern unit:mm ■ Electrical Characteristics Inductance Test Freq. (uH) 1.0 1.2 1.5 2.2 2.7 3.3 4.7 5.6 6.8 10 15 22 33 47 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V RDC (mΩ)±20% Isat(A) Typ.(Max) Irms(A) Typ.(Max) Tolerance (±%) Marking 21 21 26 35 38 48 60 82 90 120 190 260 460 580 5.10(4.50) 4.80(4.30) 4.20(3.70) 3.40(3.00) 3.40(3.00) 3.05(2.70) 2.20(1.90) 2.05(1.80) 2.00(1.80) 1.60(1.44) 1.30(1.17) 1.00(0.90) 0.80(0.72) 0.65(0.58) 4.00(3.60) 3.80(3.40) 3.50(3.10) 3.20(2.80) 3.20(2.80) 2.80(2.50) 2.90(2.60) 2.00(1.80) 1.80(1.60) 1.60(1.40) 1.20(1.00) 1.00(0.90) 0.75(0.67) 0.65(0.58) 20,30 30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 1R0 1R2 1R5 2R2 2R7 3R3 4R7 5R6 6R8 100 150 220 330 470 FO R LVS505020-1R0□-AU LVS505020-1R2□-AU LVS505020-1R5□-AU LVS505020-2R2□-AU LVS505020-2R7□-AU LVS505020-3R3□-AU LVS505020-4R7□-AU LVS505020-5R6□-AU LVS505020-6R8□-AU LVS505020-100□-AU LVS505020-150□-AU LVS505020-220□-AU LVS505020-330□-AU LVS505020-470□-AU unit:mm NE W Part No. DE SI GN ■ Dimensions Note: When ordering, please specify tolerance code. Tolerance: M=±20% / T=±30% 1. Operating temperature range -40℃~125℃ NO T 2. Isat for Inductance drop 30% from its value without current 3. Irms for a 40℃ temperature rise from 25℃ ambient with current 4. Measure Equipment: L: Agilent HP4284A+Agilent HP42841A RDC: DIGITAL MILLINHM METER CHROMA 16502, or equivalent Isat: Agilent HP4284A Irms: Agilent HP4284A Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. www.chilisin.com.tw Automotive Power Inductor LVS Series AEC-Q200 LVS505020 - AU Type ■ Characteristics Graph Inductance vs. DC Current DE SI GN 55 50 45 470 40 L(uH) 35 30 330 25 20 220 NE W 15 150 10 100 6R8 5 0 0 0.5 1 1.5 4R7 2 2.5 3R3 3 2R2 3.5 1R5 4 1R0 4.5 5 5.5 6 DC Current(A) FO R Temperature Change vs. DC Current 60 470 330 50 150 220 100 6R8 4R7 3R3 2R2 1R5 1R0 △T(℃) NO T 40 30 20 10 0 0 1 2 3 4 5 DC Current(A) Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. www.chilisin.com.tw Automotive Power Inductor LVS Series AEC-Q200 LVS505040 - AU Type ■ Recommended Land Pattern unit:mm ■ Electrical Characteristics Inductance Test Freq. (uH) 1.0 1.2 1.5 2.2 3 3.3 3.6 4.7 6.8 10 15 22 27 33 47 68 100 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V FO R LVS505040-1R0□-AU LVS505040-1R2□-AU LVS505040-1R5□-AU LVS505040-2R2□-AU LVS505040-3R0□-AU LVS505040-3R3□-AU LVS505040-3R6□-AU LVS505040-4R7□-AU LVS505040-6R8□-AU LVS505040-100□-AU LVS505040-150□-AU LVS505040-220□-AU LVS505040-270□-AU LVS505040-330□-AU LVS505040-470□-AU LVS505040-680□-AU LVS505040-101□-AU unit:mm RDC (mΩ)±30% Isat(A) Typ.(Max) Irms(A) Typ.(Max) Tolerance (±%) Marking 14 15 16 21 21 26 31 32 50 60 90 135 180 190 310 540 800 7.5(6.70) 7.4(6.60) 7.1(6.30) 5.7(5.10) 4.8(4.30) 4.8(4.30) 4.2(3.70) 4.2(3.70) 3.3(2.90) 2.8(2.50) 2.3(2.00) 1.8(1.60) 1.6(1.40) 1.5(1.30) 1.2(1.00) 1.0(0.90) 0.7(0.60) 4.6(4.10) 4.5(4.00) 4.4(3.90) 3.7(3.30) 3.5(3.10) 3.5(3.10) 3.3(2.90) 3.2(2.80) 2.4(2.10) 2.2(1.90) 1.8(1.60) 1.4(1.20) 1.2(1.00) 1.1(0.99) 0.9(0.81) 0.78(0.7) 0.6(0.50) 30 30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 1R0 1R2 1R5 2R2 3R0 3R3 3R6 4R7 6R8 100 150 220 270 330 470 680 101 NE W Part No. DE SI GN ■ Dimensions Note: When ordering, please specify tolerance code. Tolerance: M=±20% / T=±30% 1. Operating temperature range -40℃~125℃ NO T 2. Isat for Inductance drop 30% from its value without current 3. Irms for a 40℃ temperature rise from 25℃ ambient with current 4. Measure Equipment: L: Agilent HP4284A+Agilent HP42841A RDC: DIGITAL MILLINHM METER CHROMA 16502, or equivalent Isat: Agilent HP4284A Irms: Agilent HP4284A Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. www.chilisin.com.tw Automotive Power Inductor LVS Series AEC-Q200 LVS505040 - AU Type ■ Characteristics Graph Inductance vs. DC Current DE SI GN 50 45 470 40 35 330 25 270 20 220 15 150 10 NE W L(uH) 30 100 5 0 0 1 2 6R8 3 4R7 3R6 3R3 2R2 4 5 1R5 6 7 1R0 8 9 10 DC Current(A) FO R Temperature Change vs. DC Current 70 470 60 220 6R8 100 150 4R7 3R63R3 2R2 330 270 1R0 T 50 1R5 △T(℃) NO 40 30 20 10 0 0 0.5 1 1.5 2 2.5 3 3.5 4 4.5 5 5.5 6 DC Current(A) Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. www.chilisin.com.tw Automotive Power Inductor LVS Series AEC-Q200 LVS606020 - AU Type ■ Recommended Land Pattern unit:mm ■ Electrical Characteristics Inductance Test Freq. (uH) LVS606020-R50□-AU LVS606020-R90□-AU LVS606020-1R0□-AU LVS606020-1R5□-AU LVS606020-2R2□-AU LVS606020-3R3□-AU LVS606020-4R7□-AU LVS606020-6R8□-AU LVS606020-100□-AU LVS606020-150□-AU LVS606020-220□-AU 0.5 0.9 1.0 1.5 2.2 3.3 4.7 6.8 10 15 22 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V unit:mm RDC (mΩ)±30% Isat(A) Typ.(Max) Irms(A) Typ.(Max) Tolerance (±%) Marking 13 18 19 26 34 40 58 85 125 190 260 8.0(7.20) 6.3(5.60) 6.2(5.50) 5.0(4.50) 4.2(3.70) 3.2(2.80) 2.5(2.20) 2.2(1.90) 2.0(1.80) 1.3(1.10) 1.1(0.99) 5.3(4.7) 4.2(3.7) 4.1(3.6) 3.6(3.2) 3.2(2.8) 2.7(2.4) 2.2(1.9) 1.8(1.6) 1.6(1.4) 1.3(1.1) 1.1(0.99) 30 30 30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 R50 R90 1R0 1R5 2R2 3R3 4R7 6R8 100 150 220 NE W Part No. DE SI GN ■ Dimensions Note: When ordering, please specify tolerance code. Tolerance: M=±20% / T=±30% 1. Operating temperature range -40℃~125℃ NO T FO R 2. Isat for Inductance drop 30% from its value without current 3. Irms for a 40℃ temperature rise from 25℃ ambient with current 4. Measure Equipment: L: Agilent HP4284A+Agilent HP42841A RDC: DIGITAL MILLINHM METER CHROMA 16502, or equivalent Isat: Agilent HP4284A Irms: Agilent HP4284A Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. www.chilisin.com.tw Automotive Power Inductor LVS Series AEC-Q200 LVS606020 - AU Type ■ Characteristics Graph Inductance vs. DC Current 20 DE SI GN 25 220 L(uH) 15 150 10 100 5 NE W 6R8 4R7 0 0 0.5 1 1.5 2 2.5 3 3R3 3.5 2R2 4 1R5 4.5 5 R90 5.5 6 6.5 7 DC Current(A) 80 70 150 6R8 R90 4R7 100 2R2 1R5 3R3 220 T 60 FO R Temperature Change vs. DC Current △T(℃) NO 50 40 30 20 10 0 0 1 2 3 4 5 6 DC Current(A) Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. www.chilisin.com.tw Automotive Power Inductor LVS Series AEC-Q200 LVS606028 - AU Type ■ Recommended Land Pattern unit:mm ■ Electrical Characteristics Inductance Test Freq. (uH) 1 1.5 2.2 2.7 3.3 4.7 6 6.8 10 15 22 33 47 68 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V FO R LVS606028-1R0□-AU LVS606028-1R5□-AU LVS606028-2R2□-AU LVS606028-2R7□-AU LVS606028-3R3□-AU LVS606028-4R7□-AU LVS606028-6R0□-AU LVS606028-6R8□-AU LVS606028-100□-AU LVS606028-150□-AU LVS606028-220□-AU LVS606028-330□-AU LVS606028-470□-AU LVS606028-680□-AU LVS606028-101□-AU 100 unit:mm RDC (mΩ)±30% Isat(A) Typ.(Max) Irms(A) Typ.(Max) Tolerance (±%) Marking 13 16 20 26 28 38 45 50 65 95 135 220 320 420 7.60(6.80) 6.30(5.60) 5.40(4.80) 4.90(4.40) 4.30(3.80) 3.70(3.30) 3.30(2.90) 3.10(2.70) 2.50(2.20) 2.00(1.80) 1.60(1.40) 1.30(1.10) 1.10(0.99) 0.98(0.88) 5.20(4.60) 4.80(4.30) 4.00(3.60) 3.70(3.30) 3.50(3.10) 3.20(2.80) 2.80(2.50) 2.70(2.40) 2.30(2.00) 1.80(1.60) 1.50(1.30) 1.40(1.20) 1.00(0.90) 0.90(0.81) 20,30 30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 1R0 600 0.82(0.73) 0.8(0.72) 20,30 101 NE W Part No. DE SI GN ■ Dimensions 100kHz,1V 1R5 2R2 2R7 3R3 4R7 6R0 6R8 100 150 220 330 470 680 Note: When ordering, please specify tolerance code. Tolerance: M=±20% / T=±30% 1. Operating temperature range -40℃~125℃ NO T 2. Isat for Inductance drop 30% from its value without current 3. Irms for a 40℃ temperature rise from 25℃ ambient with current 4. Measure Equipment: L: Agilent HP4284A+Agilent HP42841A RDC: DIGITAL MILLINHM METER CHROMA 16502, or equivalent Isat: Agilent HP4284A Irms: Agilent HP4284A Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. www.chilisin.com.tw Automotive Power Inductor LVS Series AEC-Q200 LVS606028 - AU Type ■ Characteristics Graph Inductance vs. DC Current DE SI GN 25 20 L(uH) 220 15 150 10 NE W 100 6R0 5 4R7 3R3 0 0 1 2 3 4 2R2 5 1R5 1R0 7 8 6 9 DC Current(A) FO R Temperature Change vs. DC Current 70 220 60 6R0 100 4R7 3R3 2R2 1R0 1R5 T 50 150 △T(℃) NO 40 30 8 20 10 0 0 1 2 3 4 5 6 7 DC Current(A) Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. www.chilisin.com.tw Automotive Power Inductor LVS Series AEC-Q200 LVS606045 - AU Type ■ Recommended Land Pattern unit:mm ■ Electrical Characteristics Inductance Test Freq. (uH) 1.0 1.2 1.5 1.8 2.2 2.3 3 3.3 3.6 3.9 4.5 4.7 5.1 5.6 6.3 6.8 8.2 10 15 18 22 27 33 47 56 68 100 220 330 1000 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V NO T FO R LVS606045-1R0□-AU LVS606045-1R2□-AU LVS606045-1R5□-AU LVS606045-1R8□-AU LVS606045-2R2□-AU LVS606045-2R3□-AU LVS606045-3R0□-AU LVS606045-3R3□-AU LVS606045-3R6□-AU LVS606045-3R9□-AU LVS606045-4R5□-AU LVS606045-4R7□-AU LVS606045-5R1□-AU LVS606045-5R6□-AU LVS606045-6R3□-AU LVS606045-6R8□-AU LVS606045-8R2□-AU LVS606045-100□-AU LVS606045-150□-AU LVS606045-180□-AU LVS606045-220□-AU LVS606045-270□-AU LVS606045-330□-AU LVS606045-470□-AU LVS606045-560□-AU LVS606045-680□-AU LVS606045-101□-AU LVS606045-221□-AU LVS606045-331□-AU LVS606045-102□-AU unit:mm RDC (mΩ)±30% Isat(A) Typ.(Max) Irms(A) Typ.(Max) Tolerance (±%) Marking 12 13 15 17 18 19 22 24 24 26 31 31 33 40 40 43 53 57 80 100 125 160 165 245 310 330 500 1300 1800 6000 12.2(10.50) 10.6(9.50) 10.4(9.30) 9.6(8.60) 8.8(7.90) 8.8(7.90) 7.8(7.00) 7.5(6.70) 7.5(6.70) 7.0(6.30) 6.7(6.00) 6.7(6.00) 6.0(5.40) 5.5(4.90) 5.5(4.90) 5.3(4.70) 4.6(4.10) 4.5(4.00) 3.4(3.00) 3.1(2.70) 3.0(2.70) 2.5(2.20) 2.3(2.00) 1.9(1.70) 1.7(1.50) 1.6(1.40) 1.3(1.10) 0.82(0.73) 0.7(0.63) 0.4(0.36) 6.5(5.80) 5.9(5.30) 5.9(5.30) 5.6(5.00) 5.1(4.50) 5.0(4.50) 4.4(3.90) 4.3(3.80) 4.3(3.80) 4.0(3.60) 3.9(3.50) 3.9(3.50) 3.5(3.10) 3.3(2.90) 3.3(2.90) 3.2(2.80) 2.9(2.60) 2.7(2.40) 2.2(1.90) 1.8(1.60) 1.9(1.70) 1.3(1.10) 1.4(1.20) 1.2(1.00) 1.1(0.99) 1.0(0.90) 0.8(0.72) 0.38(0.34) 0.35(0.31) 0.22(0.19) 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 1R0 1R2 1R5 1R8 2R2 2R3 3R0 3R3 3R6 3R9 4R5 4R7 5R1 5R6 6R3 6R8 6R8 100 150 180 220 270 330 470 560 680 101 221 331 102 NE W Part No. DE SI GN ■ Dimensions Note: When ordering, please specify tolerance code. Tolerance: M=±20% / T=±30% 1. Operating temperature range -40℃~125℃ 2. Isat for Inductance drop 30% from its value without current 3. Irms for a 40℃ temperature rise from 25℃ ambient with current 4. Measure Equipment: L: Agilent HP4284A+Agilent HP42841A RDC: DIGITAL MILLINHM METER CHROMA 16502, or equivalent Isat: Agilent HP4284A Irms: Agilent HP4284A Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. www.chilisin.com.tw Automotive Power Inductor LVS Series AEC-Q200 LVS606045 - AU Type ■ Characteristics Graph Inductance vs. DC Current 90 DE SI GN 100 101 80 70 680 50 470 40 330 30 NE W L(uH) 60 220 20 150 10 0 0 1 2 3 4 100 6R8 5 6 1R8 7 8 9 1R0 10 11 12 13 14 15 DC Current (A) 80 70 FO R Temperature Change vs. DC Curent 101 680 470 330 220 4R5 6R8 150 3R0 2R3 1R8 1R0 T 60 100 △T(℃) NO 50 40 30 . 20 10 0 0 1 2 3 4 5 6 7 8 DC Current (A) Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. www.chilisin.com.tw Automotive Power Inductor LVS Series AEC-Q200 LVS606045L - AU Type ■ Recommended Land Pattern unit:mm ■ Electrical Characteristics Inductance Test Freq. (uH) LVS606045L-R50□-AU LVS606045L-2R2□-AU LVS606045L-3R3□-AU LVS606045L-4R7□-AU LVS606045L-6R8□-AU LVS606045L-100□-AU LVS606045L-150□-AU LVS606045L-220□-AU LVS606045L-330□-AU LVS606045L-101□-AU 0.5 2.2 3.3 4.7 6.8 10 15 22 33 100 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V unit:mm RDC (mΩ)Max. Isat(A) Typ.(Max) Irms(A) Typ.(Max) Tolerance (±%) Marking 9 17 24 30 40 50 80 120 170 595 11(9.90) 6.8(6.10) 5.5(4.90) 4.6(4.10) 4.0(3.60) 3.2(2.80) 2.6(2.30) 2.1(1.80) 1.7(1.50) 0.95(0.85) 8.0(7.20) 5.5(4.90) 4.7(4.20) 4.0(3.60) 3.5(3.10) 3.2(2.80) 2.5(2.20) 2.0(1.80) 1.6(1.40) 0.92(0.82) 30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 R50 2R2 3R3 4R7 6R8 100 150 220 330 101 NE W Part No. DE SI GN ■ Dimensions Note: When ordering, please specify tolerance code. Tolerance: M=±20% / T=±30% 1. Operating temperature range -40℃~125℃ NO T FO R 2. Isat for Inductance drop 30% from its value without current 3. Irms for a 40℃ temperature rise from 25℃ ambient with current 4. Measure Equipment: L: Agilent HP4284A+Agilent HP42841A RDC: DIGITAL MILLINHM METER CHROMA 16502, or equivalent Isat: Agilent HP4284A Irms: Agilent HP4284A Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. www.chilisin.com.tw Automotive Power Inductor LVS Series AEC-Q200 LVS606045L - AU Type ■ Characteristics Graph Inductance vs. DC Current DE SI GN 40 35 330 L(uH) 30 25 20 220 15 150 10 NE W 100 6R8 5 0 0 1 2 3 4R7 4 5 3R3 2R2 6 7 8 9 DC Current(A) 70 FO R Temperature Change vs. DC Current 330 60 100 6R8 4R7 3R3 2R2 T 50 220 150 △T(℃) NO 40 30 20 10 0 0 1 2 3 4 5 6 7 8 DC Current(A) Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. www.chilisin.com.tw Automotive Power Inductor LVS Series AEC-Q200 LVS808040 - AU Type ■ Recommended Land Pattern unit:mm ■ Electrical Characteristics Inductance Test Freq. (uH) 0.9 1.0 1.4 1.5 2 2.2 2.5 3.3 3.9 4.7 5.6 6.8 10 12 15 18 22 33 47 68 100 120 150 180 220 270 820 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V NO T FO R LVS808040-R90□-AU LVS808040-1R0□-AU LVS808040-1R4□-AU LVS808040-1R5□-AU LVS808040-2R0□-AU LVS808040-2R2□-AU LVS808040-2R5□-AU LVS808040-3R3□-AU LVS808040-3R9□-AU LVS808040-4R7□-AU LVS808040-5R6□-AU LVS808040-6R8□-AU LVS808040-100□-AU LVS808040-120□-AU LVS808040-150□-AU LVS808040-180□-AU LVS808040-220□-AU LVS808040-330□-AU LVS808040-470□-AU LVS808040-680□-AU LVS808040-101□-AU LVS808040-121□-AU LVS808040-151□-AU LVS808040-181□-AU LVS808040-221□-AU LVS808040-271□-AU LVS808040-821□-AU unit:mm RDC (mΩ)±30% Isat(A) Typ.(Max) Irms(A) Typ.(Max) Tolerance (±%) Marking 7 8 9 10 11 12 13 15 18 18 23 25 38 45 50 68 80 110 160 240 340 425 480 650 670 900 2800 13.8(12.00) 13.0(11.50) 10.8(9.50) 10.0(9.00) 9.60(8.50) 9.20(8.10) 8.20(7.20) 7.50(6.60) 6.10(5.40) 6.00(5.30) 5.70(5.00) 5.40(4.70) 4.30(3.70) 3.80(3.30) 3.60(3.10) 3.10(2.60) 2.80(2.40) 2.30(2.00) 1.90(1.60) 1.70(1.40) 1.40(1.10) 1.10(0.95) 1.00(0.88) 0.98(0.88) 0.94(0.80) 0.83(0.73) 0.40(0.35) 8.05(7.10) 7.95(7.00) 7.80(6.90) 7.70(6.80) 7.40(6.50) 7.20(6.30) 6.30(5.50) 6.00(5.30) 5.50(4.90) 5.50(4.80) 5.20(4.50) 5.10(4.40) 3.80(3.30) 3.50(3.00) 3.20(2.70) 2.70(2.30) 2.60(2.20) 2.00(1.70) 1.75(1.40) 1.45(1.20) 1.10(0.95) 1.00(0.80) 0.90(0.75) 0.70(0.63) 0.60(0.50) 0.55(0.45) 0.38(0.30) 30 30 30 30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 R90 1R0 1R4 1R5 2R0 2R2 2R5 3R3 3R9 4R7 5R6 6R8 100 120 150 180 220 330 470 680 101 121 151 181 221 271 821 NE W Part No. DE SI GN ■ Dimensions Note: When ordering, please specify tolerance code. Tolerance: M=±20% / T=±30% 1. Operating temperature range -40℃~125℃ 2. Isat for Inductance drop 30% from its value without current 3. Irms for a 40℃ temperature rise from 25℃ ambient with current 4. Measure Equipment: L: Agilent HP4284A+Agilent HP42841A RDC: DIGITAL MILLINHM METER CHROMA 16502, or equivalent Isat: Agilent HP4284A Irms: Agilent HP4284A Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. www.chilisin.com.tw Automotive Power Inductor LVS Series AEC-Q200 LVS808040 - AU Type ■ Characteristics Graph Inductance vs. DC Current DE SI GN 40 35 30 330 L(uH) 25 20 220 15 150 10 NE W 100 6R8 5 0 0 2 4 4R7 6 3R3 2R0 8 R90 1R4 10 12 14 16 DC Current(A) 80 70 470 680 101 220 150 100 6R8 4R7 330 3R3 2R0 T 60 FO R Temperature Change vs. DC Current 1R4 R90 NO △T(℃) 50 40 30 20 10 0 0 1 2 3 4 5 6 7 8 9 10 DC Current(A) Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. www.chilisin.com.tw Automotive Power Inductor LVS Series AEC-Q200 LVS808040L - AU Type ■ Recommended Land Pattern unit:mm ■ Electrical Characteristics Inductance Test Freq. (uH) LVS808040L-1R0□-AU LVS808040L-2R2□-AU LVS808040L-3R3□-AU LVS808040L-4R7□-AU LVS808040L-8R2□-AU LVS808040L-100□-AU LVS808040L-150□-AU LVS808040L-220□-AU 1.0 2.2 3.3 4.7 8.2 10 15 22 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V unit:mm RDC (mΩ)Max. Isat(A) Typ.(Max) Irms(A) Typ.(Max) Tolerance (±%) Marking 10 12 19 22 37 42 58 85 9.5(8.40) 7.2(6.30) 5.6(4.99) 4.4(3.80) 3.6(3.10) 3.1(2.60) 2.5(2.10) 2.0(1.70) 8.5(7.50) 7.3(6.40) 6.0(5.30) 5.0(4.40) 3.8(3.30) 3.5(3.00) 3.0(2.60) 2.5(2.10) 30 20,30 20,30 20,30 20,30 20,30 20,30 20,30 1R0 2R2 3R3 4R7 8R2 100 150 220 NE W Part No. DE SI GN ■ Dimensions Note: When ordering, please specify tolerance code. Tolerance: M=±20% / T=±30% 1. Operating temperature range -40℃~125℃ NO T FO R 2. Isat for Inductance drop 30% from its value without current 3. Irms for a 40℃ temperature rise from 25℃ ambient with current 4. Measure Equipment: L: Agilent HP4284A+Agilent HP42841A RDC: DIGITAL MILLINHM METER CHROMA 16502, or equivalent Isat: Agilent HP4284A Irms: Agilent HP4284A Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. www.chilisin.com.tw Automotive Power Inductor LVS Series AEC-Q200 LVS808040L - AU Type ■ Characteristics Graph Inductance vs. DC Current DE SI GN 30 25 L(uH) 20 220 15 150 10 100 NE W 8R2 4R7 5 0 0 1 2 3 4 5 2R2 6 7 8 9 DC Current(A) 60 2R2 150 100 8R2 40 NO △T(℃) 4R7 220 T 50 FO R Temperature Change vs. DC Current 70 30 20 10 0 0 1 2 3 4 5 6 7 8 9 DC Current(A) Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. www.chilisin.com.tw Automotive Power Inductor LVS Series AEC-Q200 ■ Packaging DE SI GN Tape Dimensions FO R NE W Reel Dimensions Dimensions in mm TYPE Tape Dimensions Reel Dimensions Quantity A0 B0 K0 D E F W P P0 P2 A B C D PCS / Reel 4.25 4.25 1.3 1.55 1.75 5.5 12 8.1 4 2 180 60 13 13.2 1000 4.25 4.25 2.10 1.55 1.75 5.5 12 8.1 4 2 178 60 13 13.2 800 LVS505020 5.25 5.25 2.2 1.55 1.75 5.5 12 8.1 4 2 330 100 13 13.4 2000 LVS505040 5.2 5.2 4.2 1.55 1.75 5.5 12 8.1 4 2 330 100 13 13.4 1500 LVS606020 6.25 6.25 2.2 1.55 1.75 7.5 16 12 4 2 330 100 13 16.0 2000 LVS606028 6.25 6.25 3.00 1.55 1.75 7.5 16 12 4 2 330 100 13 16.0 1500 LVS606045 6.25 6.25 4.65 1.55 1.75 7.5 16 12 4 2 330 100 13 16.0 1000 LVS808040 8.25 8.25 4.15 1.55 1.75 7.5 16 12 4 2 330 100 13 16.0 1000 LVS404012 NO T LVS404018 www.chilisin.com.tw
LVS606045-680M-AU 价格&库存
很抱歉,暂时无法提供与“LVS606045-680M-AU”相匹配的价格&库存,您可以联系我们找货
LVS606045-680M-AU
  • 10+0.93379
  • 100+0.84679
  • 500+0.75979
  • 1000+0.67279
  • 2000+0.61479
  • 4000+0.59739
