FP1F-5M-Z
FP1F-5M-Z
    NIDEC(尼得科)
    插件
    按动开关 3万次 插件 双刀双掷 400mA -40℃~+85℃
FP1F-5M-Z 数据手册
FP ■ Terminal Pins: Kinked ■ Actuator Color: Yellow Ultra-Miniature Pushbutton Switches Washable RoHS Compliant ■Features ■ Specification 1. Ultra-miniature pushbutton switch for high density mounting. 2. Washable. Rating 3. Terminal pin pitch: 2.54 mm. Initial contact resistance 100mΩmax.  4. Independent detent mechanism ensures light operational feel. 5. Clip contact mechanism for long-term contact reliability. 6. Gold-plated contacts. Max. 0.4VA(28VDC max.) Min. 1μA 20mVDC 250V AC 1 minute Insulation resistance 500MΩ min.       (250VDC) Electrical life 10,000 operations at max.rating, 30,000 operations at min.rating, Mechanical life 30,000 cycles Operating force 1.47±0.98N Operating temperature range Storage temperature range ■Part Numbering F Series code P Actuator shape 2 F Number of poles Code Type Fig. Number of poles P Pushbutton 1 1 pole 2 2 poles 2 Switching function Code Switching function F ON -(ON) (1.5mA 200μVAC) Dielecteic strength −40∼+85℃ −40∼+85℃ M Terminal style Z Actuator shape Fig. Terminal style Code Actuator shape 2 P/C M Standard 5 Right angle 4 Vertical mounting FP SPDT Switching function PC Part No. 5-φ0.8~1.0 FP1F−2M−Z ON (ON) Connecting terminals 2−3 2−1 プリント基板孔あけ寸法図(Top view) PC Hole Layouts Terminal numbers are not shown on the switch. DPDT PC Switching function Part No. ★FP2F−2M−Z 6-φ0.8~1.0 Connecting terminals ON 2−3 5−6 (ON) 2−1 5−4 プリント基板孔あけ寸法図(Top view) PC Hole Layouts Terminal numbers are not shown on the switch. SPDT R/A Switching function Part No. 5-φ0.8~1.0 FP1F−5M−Z ON (ON) Connecting terminals 2−3 2−1 ON 2−3 5−6 (ON) 2−1 5−4 Top view) PC Hole Layouts Terminal numbers are not shown on the switch. DPDT R/A Switching function Part No. ★FP2F−5M−Z 8-φ0.8~1.0 Connecting terminals PC Hole Layouts Terminal numbers are not shown on the switch. ■Optional Accessories Part Name Dimension Gloss finish Color Cap ABS resin :Optional Accessories. 《Sold separately》 Color Part Number White 140000481453 Red 140000481452 Black 140000481451 Gray 140000481450 The blue line shows the outline of the switch. ■Color Cap Mounting (ON) :Momentary. ★:Made to order products. FP SPDT Switching function V/M Part No. FP1F−4M−Z ON (ON) Connecting terminals 2−3 2−1 ON 2−3 5−6 (ON) 2−1 5−4 5-φ0.8~1.0 Terminal numbers are not shown on the switch. (Top view) PC Hole Layouts DPDT V/M Switching function Part No. ★FP2F−4M−Z Connecting terminals 8-φ0.8~1.0 Terminal numbers are not shown on the switch. (Top view) PC Hole Layouts ■Handling Precautions(FP, FT, FL) 1. Soldering Specifications ⑴Manual Soldering Device:Soldering iron 380° C, Max.; 3 seconds, Max. ⑵Auto soldering Device:Jet wave type or dip type 275° C, Max.; 6 seconds, Max. ・Pre-heating should be done at temperatures from 80 to 120° C and within 120 seconds. ⑶When soldering two or more terminals to the common land, use solder resist to solder them independently. 2. Flux Cleaning ⑴Solvents :Fluorine or Alcohol type ⑵ Cleaning after soldering should be done after the PC board is exposed to room temperature (30℃ or below) for 1 to 2 hours. ⑶Do not use ultrasonic cleaning. ■Packaging Specifications Plastic Pack 100 pcs./pack U 15 OK SO IS JI FU J FU KU 231 The blue line shows the outline of the switch. (ON) :Momentary. ★:Made to order products. 196
FP1F-5M-Z 价格&库存
很抱歉,暂时无法提供与“FP1F-5M-Z”相匹配的价格&库存,您可以联系我们找货
FP1F-5M-Z
  • 1+18.33960
  • 10+16.86060
  • 30+16.56480
