ABS210
ABS210
    YONGYUTAI(永裕泰)
    ABS_5.2X4.5MM_SM
    VR=1KV IR=5μA SOP-4 Io=2A
ABS210 数据手册
ABS201 THRU ABS210 FEATURES: PINNING • Glass Passivated Chip Junction • Reverse Voltage - 100 to 1000 V PIN DESCRIPTION 1 Input Pin(~) • Forward Current - 2 A 2 Input Pin(~) • High Surge Current Capability 3 Output Anode(+) 4 Output Cathode(-) • Designed for Surface Mount Application MECHANICAL DATA 3 • Terminals: Solderable per MIL-STD-750, Method 2026 • A pprox. Weight: 88mg 0.0031oz 4 2 1 Maximum Ratings and Electrical characteristics Ratings at 25 °C ambient temperature unless otherwise specified. Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %. Symbols ABS201 ABS202 ABS204 ABS206 ABS208 ABS210 Units Maximum Repetitive Peak Reverse Voltage V RRM 100 200 400 600 800 1000 V Maximum RMS voltage V RMS 70 140 280 420 560 700 V Maximum DC Blocking Voltage V DC 100 200 400 600 800 1000 V Parameter Average Rectified Output Current at T L = 100 °C Peak Forward Surge Current 8.3 ms Single Half Sine Wave Superimposed on Rated Load (JEDEC Method) Forward Voltage per element @I F =2.0A Maximum DC Reverse Current at Rated DC Blocking Voltage @ T A =125 °C @ T A =25 °C Typical Junction Capacitance(Note1) Typical Thermal Resistance(Note2) Operating and Storage Temperature Range IO 2.0 A I FSM 50 A VF 1.0 V IR 5.0 100 μA Cj 25 pF RθJA 65 °C/W T j , T stg -55 ~ +150 °C Note: 1. Measured at 1MHz and applied reverse voltage of 4 V D.C. 2. Mounted on glass epoxy PC board with 4×(5×5mm 2 )copper pad. www.yongyutai.com PAGE 1 ABS201 THRU ABS210 Fig.2 Typical Reverse Characteristics 2.4 100LFM 2.0 1.6 1.2 0.8 Al. Substrate PC Board 0.4 Resistive or Inductive Load 0.0 25 50 75 100 125 150 175 Instaneous Reverse Current(μ A) Average Rectified Output Current (A) Fig.1 Average Rectified Output Current Derating Curve 100 T J =125°C 10 1.0 T J =25°C 0.1 00 T J =25°C 1.0 0.1 pulse with 300μs 1% duty cycle 0.01 0.0 40 60 80 100 120 140 Fig.4 Typical Junction Capacitance Junction Capacitance ( pF) Instaneous Forward Current (A) Fig.3 Typical Instaneous Forward Characteristics 10 20 percent of Rated Peak Reverse Voltage (%) Lead Temperature (°C) 100 T J =25°C 10 1 0.5 1.0 1.5 2.0 0.1 1.0 10 100 Reverse Voltage (V) Instaneous Forward Voltage (V) Peak Forward Surage Current (A) Fig.5 Maximum Non-Repetitive Peak Forward Surage Current 60 50 40 30 20 10 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 10 100 Number of Cycles www.yongyutai.com PAGE 2 ABS201 THRU ABS210 PACKAGE OUTLINE Plastic surface mounted package; 4 leads ∠ALL ROUND ∠ALL ROUND C A a L1 d L HE e D e E ABS/LBF mechanical data A C D E HE d e max 1.5 0.22 5.2 4.5 6.4 4.2 0.7 min 1.3 0.15 4.9 4.2 6.0 3.8 0.5 max 59 8.7 205 177 252 165 28 min 51 5.9 193 166 236 150 20 UNIT mm L L1 a 0.95 0.6 0.2 ∠ 7° 37 mil 24 4 The recommended mounting pad size 6.2 244 4.0 157 1.0 39 2.0 79 www.yongyutai.com mm Unit : (mil) PAGE 3
ABS210 价格&库存
很抱歉,暂时无法提供与“ABS210”相匹配的价格&库存,您可以联系我们找货
ABS210
  • 1+0.15750
  • 100+0.14700
  • 300+0.13650
  • 500+0.12600
  • 2000+0.12075
  • 5000+0.11760
