BZT52C12S
BZT52C12S
    YONGYUTAI(永裕泰)
    SOD-323
    稳压二极管 Vz=12V P=200mW SOD323
BZT52C12S 数据手册
BZT52CxxS Series SOD-323 Plastic-Encapsulate Zener Diode SOD-323 特征 Features  齐纳击穿阻抗低; Low Zener Impedance  最大功率耗散 200mW; Power Dissipation of 200mW  高稳定性和可靠性。High Stability and High Reliability 机械数据 Mechanical Data    封装: SOD-323 封装 SOD-323 Small Outline Plastic Package 极性: 色环端为负极 Polarity: Color band denotes cathode end 安装位置: 任意 Mounting Position: Any 极限值和温度特性(TA = 25℃ 除非另有规定) Maximum Ratings & Thermal Characteristics (Ratings at 25℃ ambient temperature unless otherwise specified.) 参数 Parameters 符号 Symbol 数值 Value 单位 Unit Pd 200 mW 功率消耗 Power Dissipation 1) Vf 0.9 2) V 正向压降 Forward Voltage @IF=10mA Ts -65-+150 存储温度 Storage temperature range ℃ Device mounted on ceramic PCB: 7.6mm x 9.4mm x 0.87mm with pad areas 25mm² Short duration test pulse used to minimize self-heating effect f=1KHz 电特性 (TA = 25℃ 除非另有规定) 1) 2) 3) Electrical Characteristics (Ratings at 25℃ ambient temperature unless otherwise specified). Zener Voltage Range Device Marking Vz@Izt Izt Nom(V) Min(V) Max(V) mA Maximum Zener 3) Impedance Zzt Zzk Izk @Izt @Izk mA Ω Maximum Reverse Current IR VR uA V Typical Temperature coefficent @ IZTC=mV/℃ Min Max Test Current IZTC mA BZT52C2V0S WY 2.0 1.80 2.15 5 150 600 1.0 100 1.0 -3.5 0 5 BZT52C2V4S WX 2.4 2.2 2.6 5 100 600 1.0 50 1.0 -3.5 0 5 BZT52C2V7S W1 2.7 2.5 2.9 5 100 600 1.0 20 1.0 -3.5 0 5 BZT52C3V0S W2 3.0 2.8 3.2 5 95 600 1.0 10 1.0 -3.5 0 5 BZT52C3V3S W3 3.3 3.1 3.5 5 95 600 1.0 5 1.0 -3.5 0 5 BZT52C3V6S W4 3.6 3.4 3.8 5 90 600 1.0 5 1.0 -3.5 0 5 BZT52C3V9S W5 3.9 3.7 4.1 5 90 600 1.0 3 1.0 -3.5 0 5 BZT52C4V3S W6 4.3 4.0 4.6 5 90 600 1.0 3 1.0 -3.5 0 5 BZT52C4V7S W7 4.7 4.4 5.0 5 80 500 1.0 3 2.0 -3.5 0.2 5 BZT52C5V1S W8 5.1 4.8 5.4 5 60 480 1.0 2 2.0 -2.7 1.2 5 BZT52C5V6S W9 5.6 5.2 6.0 5 40 400 1.0 1 2.0 -2.0 2.5 5 BZT52C6V2S WA 6.2 5.8 6.6 5 10 150 1.0 3 4.0 0.4 3.7 5 BZT52C6V8S WB 6.8 6.4 7.2 5 15 80 1.0 2 4.0 1.2 4.5 5 BZT52C7V5S WC 7.5 7.0 7.9 5 15 80 1.0 1 5.0 2.5 5.3 5 BZT52C8V2S WD 8.2 7.7 8.7 5 15 80 1.0 0.7 5.0 3.2 6.2 5 BZT52C9V1S WE 9.1 8.5 9.6 5 15 100 1.0 0.5 6.0 3.8 7.0 5 BZT52C10S WF 10 9.4 10.6 5 20 150 1.0 0.2 7.0 4.5 8.0 5 BZT52C11S WG 11 10.4 11.6 5 20 150 1.0 0.1 8.0 5.4 9.0 5 BZT52C12S WH 12 11.4 12.7 5 25 150 1.0 0.1 8.0 6.0 10.0 5 BZT52C13S WI 13 12.4 14.1 5 30 170 1.0 0.1 8.0 7.0 11.0 5 www.yongyutai.com PAGE 1 BZT52CxxS Series Zener Voltage Range Maximum Zener Impedance Zzt Zzk Izk @Izt @Izk mA Ω Maximum Reverse Current Typical Temperature coefficent @ IZTC=mV/℃ Min Max Test Current IZTC Device Marking Nom(V) Min(V) Max(V) mA uA V BZT52C15S WJ 15 13.8 15.6 5 30 200 1.0 0.1 10.5 9.2 13.0 5 BZT52C16S WK 16 15.3 17.1 5 40 200 1.0 0.1 11.2 10.4 14.0 5 BZT52C18S WL 18 16.8 19.1 5 45 225 1.0 0.1 12.6 12.4 16.0 5 BZT52C20S WM 20 18.8 21.2 5 55 225 1.0 0.1 14.0 14.4 18.0 5 BZT52C22S WN 22 20.8 23.3 5 55 250 1.0 0.1 15.4 16.4 20.0 5 BZT52C24S WO 24 22.8 25.6 5 70 250 1.0 0.1 16.8 18.4 22.0 5 BZT52C27S WP 27 25.1 28.9 2 80 300 0.5 0.1 18.9 21.4 25.3 2 BZT52C30S WQ 30 28.0 32.0 2 80 300 0.5 0.1 21.0 24.4 29.4 2 BZT52C33S WR 33 31.0 35.0 2 80 325 0.5 0.1 23.1 27.4 33.4 2 BZT52C36S WS 36 34.0 38.0 2 90 350 0.5 0.1 25.2 30.4 37.4 2 BZT52C39S WT 39 37.0 41.0 2 130 350 0.5 0.1 27.3 33.4 41.2 2 BZT52C43S WU 43 40.0 46.0 2 100 700 1.0 0.1 32.0 10.0 12.0 5 BZT52C47S WV 47 44.0 50.0 2 100 750 1.0 0.1 35.0 10.0 12.0 5 BZT52C51S WW 51 48.0 54.0 2 100 750 1.0 0.1 38.0 10.0 12.0 5 BZT52C56S XW 56 52.0 60.0 2 135 700 1.0 0.1 39.0 10.0 12.0 5 BZT52C62S 6E 62 58.0 66.0 2 200 1000 1.0 0.2 47.0 10.0 12.0 5 BZT52C68S 6F 68 64.0 72.0 2 250 1000 1.0 0.2 52.0 10.0 12.0 5 BZT52C75S 6H 75 70.0 79.0 2 300 1000 1.0 0.2 57 10.0 12.0 5 Vz@Izt Izt IR VR mA Breakdown characteristics at Tj=constant (pulsed) Forward characteristics www.yongyutai.com Admissible power dissipation versus ambient temperature PAGE 2 BZT52CxxS Series Pulse thermal resistance versus pulse duration Dynamic resistance versus Zener current Capacitance versus Zener voltage Dynamic resistance versus Zener current Dynamic resistance versus Zener current Thermal differential resistance versus Zener voltage www.yongyutai.com PAGE 3 BZT52CxxS Series Dynamic resistance versus Zener voltage Temperature dependence of Zener voltage versus Zener voltage Temperature dependence of Zener voltage versus Zener Change of Zener voltage versus junction temperature voltage Change of Zener voltage versus junction temperature Change of Zener voltge from turn-on up to the point of thermal equilibrium versus Zener voltage www.yongyutai.com PAGE 4 BZT52CxxS Series SOD-323 PACKAGE OUTLINE Plastic surface mounted package SOD-323 Symbol Min.(mm) 1.000 A A1 0.000 0.100 A2 0.800 0.900 b 0.250 0.350 c 0.080 0.150 D 1.200 1.400 E 1.600 1.800 E1 2.500 2.700 0.475REF L www.yongyutai.com Max.(mm) L1 0.250 0.400 θ 0º 8º PAGE 5
BZT52C12S 价格&库存
很抱歉,暂时无法提供与“BZT52C12S”相匹配的价格&库存,您可以联系我们找货
BZT52C12S
  • 50+0.06865
  • 500+0.05304
  • 3000+0.04545
  • 6000+0.04033
  • 24000+0.03581
  • 51000+0.03334
库存:2874
BZT52C12S
  • 3000+0.04010
库存:300000
BZT52C12S
  • 1+0.06450
  • 100+0.06020
  • 300+0.05590
  • 500+0.05160
  • 2000+0.04945
  • 5000+0.04816
