MM1Z Series
SOD-123 Plastic-Encapsulate Zener Diode
SOD-123
特征 Features
齐纳击穿阻抗低; Low Zener Impedance
最大功率耗散 500mW; Power Dissipation of 500mW
高稳定性和可靠性。High Stability and High Reliability
机械数据 Mechanical Data
封装: SOD-123 封装 SOD-123 Small Outline Plastic Package
极性: 色环端为负极 Polarity: Color band denotes cathode end
环氧树脂 UL 易燃等级 Epoxy UL: 94V-0
安装位置: 任意 Mounting Position: Any
极限值和温度特性(TA = 25℃ 除非另有规定)
Maximum Ratings & Thermal Characteristics (Ratings at 25℃ ambient temperature unless otherwise specified.)
参数 Parameters
符号 Symbol
数值 Value
单位 Unit
功率消耗 Power Dissipation
Pd
500
1)
mW
正向压降 Forward Voltage @IF=10mA
Vf
0.9
2)
V
存储温度 Storage temperature range
Ts
-65-+150
RthA
400
K/W
Thermal resistance junction to ambient air Warmewiderstand Sperrschicht
1)
–umgebende Luft
1)
2)
3)
Device mounted on ceramic PCB: 7.6mm x 9.4mm x 0.87mm with pad areas 25mm²
Short duration test pulse used to minimize self-heating effect
f=1KHz
电特性 (TA = 25℃ 除非另有规定)
Electrical Characteristics (Ratings at 25℃ ambient temperature unless otherwise specified).
Zener Voltage Range
Device
Marking
Vz@Izt
Izt
Nom(V)
Min(V)
Max(V)
mA
Maximum Zener
3)
Impedance
Zzt
Zzk
Izk
@Izt
@Izk
mA
Ω
Maximum
Reverse Current
IR
VR
uA
V
Typical
Temperature
coefficent @
IZTC=mV/℃
Min
Max
Test
Current
IZTC
mA
MM1Z2V0
WY
2.0
1.80
2.15
5
150
600
1.0
100
1.0
-3.5
MM1Z2V4
WX
2.4
2.2
2.6
5
100
600
1.0
50
1.0
-3.5
MM1Z2V7
W1
2.7
2.5
2.9
5
100
600
1.0
-3.5
MM1Z3V0
W2
3.0
2.8
3.2
5
95
600
1.0
10
1.0
-3.5
MM1Z3V3
W3
3.3
3.1
3.5
5
95
600
1.0
5
1.0
-3.5
MM1Z3V6
W4
3.6
3.4
3.8
5
90
600
1.0
5
1.0
-3.5
MM1Z3V9
W5
3.9
3.7
4.1
5
90
600
1.0
3
1.0
-3.5
MM1Z4V3
W6
4.3
4.0
4.6
5
90
600
1.0
3
1.0
-3.5
MM1Z4V7
W7
4.7
4.4
5.0
5
80
500
1.0
3
2.0
-3.5
0.2
5
MM1Z5V1
W8
5.1
4.8
5.4
5
60
480
1.0
2
2.0
-2.7
1.2
5
MM1Z5V6
W9
5.6
5.2
6.0
5
40
400
1.0
1
2.0
-2.0
2.5
5
MM1Z6V2
WA
6.2
5.8
6.6
5
10
150
1.0
3
4.0
0.4
3.7
5
MM1Z6V8
WB
6.8
6.4
7.2
5
15
80
1.0
2
4.0
1.2
4.5
5
MM1Z7V5
WC
7.5
7.0
7.9
5
15
80
1.0
1
5.0
2.5
5.3
5
MM1Z8V2
WD
8.2
7.7
8.7
5
15
80
1.0
0.7
5.0
3.2
6.2
5
MM1Z9V1
WE
9.1
8.5
9.6
5
15
100
1.0
0.5
6.0
3.8
7.0
5
MM1Z10
WF
10
9.4
10.6
5
1.0
0.2
7.0
4.5
8.0
5
www.yongyutai.com
PAGE 1
MM1Z Series
Zener Voltage Range
Device
Marking
Vz@Izt
Izt
Nom(V)
Min(V)
Max(V)
mA
Maximum Zener
Impedance
Zzt
Zzk
Izk
@Izt
@Izk
mA
Ω
Maximum
Reverse Current
IR
VR
uA
V
Typical
Temperature
coefficent @
IZTC=mV/℃
Min
Max
Test
Current
IZTC
mA
MM1Z11
WG
11
10.4
11.6
5
1.0
0.1
8.0
5.4
9.0
5
MM1Z12
WH
12
11.4
12.7
5
25
150
1.0
0.1
8.0
6.0
10.0
5
MM1Z13
WI
13
12.4
14.1
5
30
170
1.0
0.1
8.0
7.0
11.0
5
MM1Z15
WJ
15
13.8
15.6
5
30
200
1.0
0.1
10.5
9.2
13.0
5
MM1Z16
WK
16
15.3
17.1
5
40
200
1.0
0.1
11.2
10.4
14.0
5
MM1Z18
WL
18
16.8
19.1
5
45
225
1.0
0.1
12.6
12.4
16.0
5
MM1Z20
WM
21.2
5
55
225
1.0
0.1
14.0
14.4
18.0
5
MM1Z22
WN
22
20.8
23.3
5
55
250
1.0
0.1
15.4
16.4
20.0
5
MM1Z24
WO
24
22.8
25.6
5
70
250
1.0
0.1
16.8
18.4
22.0
5
MM1Z27
WP
27
25.1
28.9
2
80
300
0.5
0.1
18.9
21.4
25.3
2
MM1Z30
WQ
30
28.0
32.0
2
80
300
0.5
0.1
21.0
24.4
29.4
2
MM1Z33
WR
33
31.0
35.0
2
80
325
0.5
0.1
23.1
27.4
33.4
2
MM1Z36
WS
36
34.0
38.0
2
90
350
0.5
0.1
25.2
30.4
37.4
2
MM1Z39
WT
39
37.0
41.0
2
130
350
0.5
0.1
27.3
33.4
41.2
2
MM1Z43
WU
43
40.0
46.0
2
100
700
1.0
0.1
32.0
10.0
12.0
5
MM1Z47
WV
47
44.0
50.0
2
100
750
1.0
0.1
35.0
10.0
12.0
5
MM1Z51
WW
51
48.0
54.0
2
125
750
1.0
0.1
38.0
10.0
12.0
5
MM1Z56
XW
56
52.0
60.0
2
135
700
1.0
0.1
39.0
10.0
12.0
5
MM1Z62
6E
62
58.0
66.0
2
200
1000
1.0
0.2
47.0
10.0
12.0
5
MM1Z68
6F
68
64.0
72.0
2
250
1000
1.0
0.2
52.0
10.0
12.0
5
MM1Z75
6H
75
70.0
79.0
2
300
1000
1.0
0.2
57
10.0
12.0
5
Breakdown characteristics
at Tj=constant (pulsed)
Forward characteristics
www.yongyutai.com
Admissible power dissipation versus ambient temperature
PAGE 2
MM1Z Series
Pulse thermal resistance versus pulse duration
Dynamic resistance versus Zener current
Capacitance versus Zener voltage
Thermal differential resistance versus Zener voltage
www.yongyutai.com
PAGE 3
MM1Z Series
Dynamic resistance versus Zener voltage
Temperature dependence of Zener voltage versus Zener voltage
Change of Zener voltage versus junction temperature
Change of Zener voltge from turn-on up to the point of thermal
equilibrium versus Zener voltage
www.yongyutai.com
PAGE 4
MM1Z Series
SOD-123 PACKAGE OUTLINE Plastic surface mounted package
θ
θ
焊盘设计参考
Precautions: PCB Design
Recommended land dimensions for SOD-123 diode. Electrode patterns for PCBs
技术要求:
3.24
1.0
中心距:
3.24
1, 塑封体尺寸: 2.70 X 1.60
脚
宽:
0.55
2: 未注公差为: ±0.05
焊盘宽:
1.00
3, 所有单位: mm
脚
长:
0.50
焊盘长:
0.80
0.8
www.yongyutai.com
PAGE 5
很抱歉,暂时无法提供与“MM1Z5V1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.23760
- 200+0.07931
- 1500+0.04961
- 3000+0.03938
- 国内价格
- 1+0.06900
- 100+0.06440
- 300+0.05980
- 500+0.05520
- 2000+0.05290
- 5000+0.05152
- 国内价格
- 10+0.08280
- 100+0.06619
- 300+0.05705
- 3000+0.04987
- 6000+0.04504
- 9000+0.04248
