MM3Z5V1
MM3Z5V1
    YONGYUTAI(永裕泰)
    SOD-323
    稳压二极管 2uA@2V 60Ω Single 4.8V~5.4V 200mW 5.1V SOD-323
MM3Z5V1 数据手册
MM3Z Series SOD-323 Plastic-Encapsulate Zener Diode SOD-323 特征 Features  齐纳击穿阻抗低; Low Zener Impedance  最大功率耗散 200mW; Power Dissipation of 200mW  高稳定性和可靠性。High Stability and High Reliability 机械数据 Mechanical Data    封装: SOD-323 封装 SOD-323 Small Outline Plastic Package 极性: 色环端为负极 Polarity: Color band denotes cathode end 安装位置: 任意 Mounting Position: Any 极限值和温度特性(TA = 25℃ 除非另有规定) Maximum Ratings & Thermal Characteristics (Ratings at 25℃ ambient temperature unless otherwise specified.) 参数 Parameters 符号 Symbol 数值 Value 单位 Unit Pd 200 mW 功率消耗 Power Dissipation 1) Vf 0.9 2) V 正向压降 Forward Voltage @IF=10mA Ts -65-+150 存储温度 Storage temperature range ℃ Device mounted on ceramic PCB: 7.6mm x 9.4mm x 0.87mm with pad areas 25mm² Short duration test pulse used to minimize self-heating effect f=1KHz 电特性 (TA = 25℃ 除非另有规定) 1) 2) 3) Electrical Characteristics (Ratings at 25℃ ambient temperature unless otherwise specified). Zener Voltage Range Device Marking Vz@Izt Izt Nom(V) Min(V) Max(V) mA Maximum Zener 3) Impedance Zzt Zzk Izk @Izt @Izk mA Ω Maximum Reverse Current IR VR uA V Typical Temperature coefficent @ IZTC=mV/℃ Min Max Test Current IZTC mA MM3Z2V0 WY 2.0 1.80 2.15 5 150 600 1.0 100 1.0 -3.5 0 5 MM3Z2V4 WX 2.4 2.2 2.6 5 100 600 1.0 50 1.0 -3.5 0 5 MM3Z2V7 W1 2.7 2.5 2.9 5 100 600 1.0 20 1.0 -3.5 0 5 MM3Z3V0 W2 3.0 2.8 3.2 5 95 600 1.0 10 1.0 -3.5 0 5 MM3Z3V3 W3 3.3 3.1 3.5 5 95 600 1.0 5 1.0 -3.5 0 5 MM3Z3V6 W4 3.6 3.4 3.8 5 90 600 1.0 5 1.0 -3.5 0 5 MM3Z3V9 W5 3.9 3.7 4.1 5 90 600 1.0 3 1.0 -3.5 0 5 MM3Z4V3 W6 4.3 4.0 4.6 5 90 600 1.0 3 1.0 -3.5 0 5 MM3Z4V7 W7 4.7 4.4 5.0 5 80 500 1.0 3 2.0 -3.5 0.2 5 MM3Z5V1 W8 5.1 4.8 5.4 5 60 480 1.0 2 2.0 -2.7 1.2 5 MM3Z5V6 W9 5.6 5.2 6.0 5 40 400 1.0 1 2.0 -2.0 2.5 5 MM3Z6V2 WA 6.2 5.8 6.6 5 10 150 1.0 3 4.0 0.4 3.7 5 MM3Z6V8 WB 6.8 6.4 7.2 5 15 80 1.0 2 4.0 1.2 4.5 5 MM3Z7V5 WC 7.5 7.0 7.9 5 15 80 1.0 1 5.0 2.5 5.3 5 MM3Z8V2 WD 8.2 7.7 8.7 5 15 80 1.0 0.7 5.0 3.2 6.2 5 MM3Z9V1 WE 9.1 8.5 9.6 5 15 100 1.0 0.5 6.0 3.8 7.0 5 MM3Z10 WF 10 9.4 10.6 5 20 150 1.0 0.2 7.0 4.5 8.0 5 MM3Z11 WG 11 10.4 11.6 5 20 150 1.0 0.1 8.0 5.4 9.0 5 MM3Z12 WH 12 11.4 12.7 5 25 150 1.0 0.1 8.0 6.0 10.0 5 MM3Z13 WI 13 12.4 14.1 5 30 170 1.0 0.1 8.0 7.0 11.0 5 www.yongyutai.com PAGE 1 MM3Z Series Zener Voltage Range Device Marking Vz@Izt Izt Maximum Zener Impedance Zzt Zzk Izk @Izt @Izk mA Ω Maximum Reverse Current IR VR Typical Temperature coefficent @ IZTC=mV/℃ Min Max Test Current IZTC Nom(V) Min(V) Max(V) mA uA V MM3Z15 WJ 15 13.8 15.6 5 30 200 1.0 0.1 10.5 9.2 13.0 mA 5 MM3Z16 WK 16 15.3 17.1 5 40 200 1.0 0.1 11.2 10.4 14.0 5 MM3Z18 WL 18 16.8 19.1 5 45 225 1.0 0.1 12.6 12.4 16.0 5 MM3Z20 WM 20 18.8 21.2 5 55 225 1.0 0.1 14.0 14.4 18.0 5 MM3Z22 WN 22 20.8 23.3 5 55 250 1.0 0.1 15.4 16.4 20.0 5 MM3Z24 WO 24 22.8 25.6 5 70 250 1.0 0.1 16.8 18.4 22.0 5 MM3Z27 WP 27 25.1 28.9 2 80 300 0.5 0.1 18.9 21.4 25.3 2 MM3Z30 WQ 30 28.0 32.0 2 80 300 0.5 0.1 21.0 24.4 29.4 2 MM3Z33 WR 33 31.0 35.0 2 80 325 0.5 0.1 23.1 27.4 33.4 2 MM3Z36 WS 36 34.0 38.0 2 90 350 0.5 0.1 25.2 30.4 37.4 2 MM3Z39 WT 39 37.0 41.0 2 130 350 0.5 0.1 27.3 33.4 41.2 2 MM3Z43 WU 43 40.0 46.0 2 100 700 1.0 0.1 32.0 10.0 12.0 5 MM3Z47 WV 47 44.0 50.0 2 100 750 1.0 0.1 35.0 10.0 12.0 5 MM3Z51 WW 51 48.0 54.0 2 100 750 1.0 0.1 38.0 10.0 12.0 5 MM3Z56 XW 56 52.0 60.0 2 135 700 1.0 0.1 39.0 10.0 12.0 5 MM3Z62 6E 62 58.0 66.0 2 200 1000 1.0 0.2 47.0 10.0 12.0 5 MM3Z68 6F 68 64.0 72.0 2 250 1000 1.0 0.2 52.0 10.0 12.0 5 MM3Z75 6H 75 70.0 79.0 2 300 1000 1.0 0.2 57 10.0 12.0 5 Breakdown characteristics at Tj=constant (pulsed) Forward characteristics www.yongyutai.com Admissible power dissipation versus ambient temperature PAGE 2 MM3Z Series Pulse thermal resistance versus pulse duration Dynamic resistance versus Zener current Capacitance versus Zener voltage Dynamic resistance versus Zener current Dynamic resistance versus Zener current Thermal differential resistance versus Zener voltage www.yongyutai.com PAGE 3 MM3Z Series Dynamic resistance versus Zener voltage Temperature dependence of Zener voltage versus Zener voltage Temperature dependence of Zener voltage versus Zener Change of Zener voltage versus junction temperature voltage Change of Zener voltage versus junction temperature Change of Zener voltge from turn-on up to the point of thermal equilibrium versus Zener voltage www.yongyutai.com PAGE 4 MM3Z Series SOD-323 PACKAGE OUTLINE Plastic surface mounted package SOD-323 Symbol Min.(mm) 1.000 A A1 0.000 0.100 A2 0.800 0.900 b 0.250 0.350 c 0.080 0.150 D 1.200 1.400 E 1.600 1.800 E1 2.500 2.700 0.475REF L www.yongyutai.com Max.(mm) L1 0.250 0.400 θ 0º 8º PAGE 5
MM3Z5V1 价格&库存
很抱歉,暂时无法提供与“MM3Z5V1”相匹配的价格&库存,您可以联系我们找货
MM3Z5V1
  • 50+0.08500
  • 500+0.06588
  • 3000+0.05660
  • 6000+0.05022
  • 24000+0.04472
  • 51000+0.04180
库存:48
MM3Z5V1
  • 1+0.06450
  • 100+0.06020
  • 300+0.05590
  • 500+0.05160
  • 2000+0.04945
  • 5000+0.04816
