MMBT3906
MMBT3906
    YONGYUTAI(永裕泰)
    SOT-23
    SOT-23 -40V -0.2A 300mW 300MHz
MMBT3906 数据手册
MMBT3906 SOT-23 Plastic-Encapsulate Transistors MMBT3906 TRANSISTOR (PNP) FEATURES Complimentary to MMBT3904 MARKING:2A MAXIMUM RATINGS (TA=25℃ unless otherwise noted) Symbol Parameter Value Units (符号) (参数名称) (额定值) (单位) VCBO Collector-Base Voltage (集电极-基极电压) -40 V VCEO Collector-Emitter Voltage (集电极-发射极电压) -40 V VEBO Emitter-Base Voltage (发射极-基极电压) -6 V IC Collector Current -Continuous (集电极电流) -0.2 A PC Collector Power Dissipation (耗散功率) 0.3 W Tj Junction Temperature (结温) 150 ℃ Tstg Storage Temperature (储存温度) -55-150 ℃ ELECTRICAL CHARACTERISTICS (Tamb=25℃unless otherwise specified) Parameter (参数名称) Symbol (符号) Test conditions (测试条件) MIN TYP MAX (最小值) (典型值) (最大值) UNIT (单位) Collector-base breakdown voltage 集电极-基极击穿电压 V(BR)CBO IC= -100μA, IE=0 -40 V Collector-emitter breakdown voltage 集电极-发射极击穿电压 V(BR)CEO IC= -1mA, IB=0 -40 V Emitter-base breakdown voltage 发射极-基极击穿电压 V(BR)EBO IE=-100μA, IC=0 -6 V Collector cut-off current 集电极-基极截止电流 ICBO VCB=-40 V , IE=0 -1 μA Collector cut-off current 集电极-发射极截止电流 ICEO VCE=-35V , -10 μA Emitter cut-off current 发射极-基极截止电流 IEBO VEB=-5V , IC=0 -1 μA DC current gain 直流电流增益 hFE VCE=-1V, IC= -10mA IB=0 100 400 Collector-emitter saturation voltage 集电极-发射极饱和压降 VCE(sat) IC=-50mA, IB= -5mA -0.3 V Base-emitter saturation voltage 发射极-基极饱和压降 VBE(sat) IC=-50mA, IB= -5mA -1 V fT VCE=-20V IC=-10mA f=100MHZ Transition frequency 特征频率 CLASSIFICATION OF Range www.yongyutai.com 100-200 300 MHZ hFE 200-400 400-600 PAGE1 MMBT3906 Typical Characteristics www.yongyutai.com PAGE2
MMBT3906 价格&库存
很抱歉,暂时无法提供与“MMBT3906”相匹配的价格&库存,您可以联系我们找货
MMBT3906
    • 1+0.01950
    • 100+0.01820
    • 300+0.01690
    • 500+0.01560
    • 2000+0.01495
    • 5000+0.01456
    库存:2199
    MMBT3906
    • 1+0.12320
    • 200+0.04103
    • 1500+0.02563
    • 3000+0.02035
    库存:10167
    MMBT3906
    • 50+0.04125
    • 500+0.03418
    • 3000+0.02617
    • 6000+0.02381
    • 24000+0.02176
    • 51000+0.02063
    库存:125475
    MMBT3906
      • 1+0.01930
      • 100+0.01860
      库存:150
      MMBT3906
      • 5+0.03400
      • 50+0.02840
      • 150+0.02440
      • 500+0.02230
      • 3000+0.02160
      库存:17865
