S9014
S9014
    YONGYUTAI(永裕泰)
    SOT-23
    SOT-23 45V 0.1A
S9014 数据手册
S9014 SOT-23 Plastic-Encapsulate Transistors S9014 TRANSISTOR (NPN) FEATURES Complimentary to S9015 MARKING:J6 MAXIMUM RATINGS (TA=25℃ unless otherwise noted) Symbol Parameter Value Units (符号) (参数名称) (额定值) (单位) VCBO Collector-Base Voltage (集电极-基极电压) 50 V VCEO Collector-Emitter Voltage (集电极-发射极电压) 45 V VEBO Emitter-Base Voltage (发射极-基极电压) 5 V IC Collector Current -Continuous (集电极电流) 0.1 A PC Collector Power Dissipation (耗散功率) 0.2 W Tj Junction Temperature (结温) 150 ℃ Tstg Storage Temperature (储存温度) -55-150 ℃ ELECTRICAL CHARACTERISTICS (Tamb=25℃unless otherwise specified) Parameter (参数名称) Symbol (符号) Test conditions (测试条件) MIN TYP MAX (最小值) (典型值) (最大值) UNIT (单位) Collector-base breakdown voltage 集电极-基极击穿电压 V(BR)CBO IC= 100μA, IE=0 50 V Collector-emitter breakdown voltage 集电极-发射极击穿电压 V(BR)CEO IC= 1mA, IB=0 45 V Emitter-base breakdown voltage 发射极-基极击穿电压 V(BR)EBO IE=100μA, IC=0 5 V Collector cut-off current 集电极-基极截止电流 ICBO VCB=50 V , IE=0 1 μA Collector cut-off current 集电极-发射极截止电流 ICEO VCE=35V , 10 μA Emitter cut-off current 发射极-基极截止电流 IEBO VEB=5V , IC=0 1 μA DC current gain 直流电流增益 hFE VCE=5V, IC= 1mA Collector-emitter saturation voltage 集电极-发射极饱和压降 VCE(sat) IC=100mA, IB= 5mA 0.3 V Base-emitter saturation voltage 发射极-基极饱和压降 VBE(sat) IC=100mA, IB= 5mA 1 V CLASSIFICATION OF Range www.yongyutai.com 80-200 IB=0 80 600 hFE 200-400 300-400 400-600 PAGE 1 S9014 Typical Characteristics www.yongyutai.com PAGE 2
S9014 价格&库存
很抱歉,暂时无法提供与“S9014”相匹配的价格&库存,您可以联系我们找货
S9014
    • 50+0.05934
    • 600+0.04805
    • 1200+0.04733
    • 3000+0.03781
    库存:14856
    S9014
    • 1+0.16610
    • 200+0.05544
    • 1500+0.03465
    • 3000+0.02750
    库存:9816
    S9014
      • 1+0.02100
      • 100+0.01960
      • 300+0.01820
      • 500+0.01680
      • 2000+0.01610
      • 5000+0.01568
      库存:12
