P1
TAI-TECH
Wire Wound Type Common Mode Filter
WCM2012F2SF-801-N
ECN HISTORY LIST
REV
DATE
DESCRIPTION
APPROVED
CHECKED
DRAWN
1.0
16/11/24
新發行
楊祥忠
林志鴻
孔妍暄
備
註
www.tai-tech.com.tw
P2
TAI-TECH
WCM2012F2SF-801-N
1.Features
1. High common mode impedance at high frequency cause excellent noise
suppression performance.
2. WCM2012F2SF series realizes small size and low profile. 2.0x1.2x1.2 mm.
3. 100% Lead(Pb) & Halogen-Free and RoHS compliant.
Halogen
Pb
Halogen-free
Pb-free
2.Dimension
C
A
當破損面積<5%,產品列入允收品範圍
E
W
B
D
D
產品破損寬度
Series
A(mm)
B(mm)
C(mm)
D1(mm)
D2(mm)
E(mm)
2012F2SF
2.0±0.2
1.2±0.2
1.2±0.2
0.50±0.1
0.51±0.1
0.15±0.1
3.Part Numbering
WCM 2012
A
B
F
2
S
F
C
D
E
F
801
G
N
H
A: Series
B: Dimension
C: Material
Ferrite Core
D: Number of Lines
2=2 lines
E: Type
S=Shielded , N=Unshielded
F: Lead free
G: Impedance
801=800Ω
H: Category Code
N=DR-N45 材&SP-N45 材
4.Specification
TAI-TECH
Part Number
WCM2012F2SF-801-N
DC
Common mode Test Frequency
Impedance
Resistance
(MHz)
(Ω)
(Ω) max.
800±25%
100
Rated Current
(mA)max.
0.88
www.tai-tech.com.tw
300
Withstand
Rated Volt.
IR
Volt. (Vdc) (Ω) min.
(Vdc)max.
max.
50
125
10M
P3
TAI-TECH
Typical Impedance v.s. Frequency Curve
WCM2012F2SF-801
10000
Common Mode
IMPEDANCE(Ohm)
1000
100
10
Normal Mode
1
0.1
1
10
100
1000
FREQUENCY(MHz)
5.Schematic Diagram
6. Materials
No.
Description
Specification
a.
Upper Plate
Ferrite
b.
Core
Ferrite Core
c
Termination
Tin (Pb Free)
d
Wire
Enameled Copper Wire
www.tai-tech.com.tw
10000
P4
TAI-TECH
7.Reliability and Test Condition
Item
Performance
Operating temperature
-40~+125℃ (Including self - temperature rise)
Storage temperature
-40~+125℃ (on board)
Test Condition
Electrical Performance Test
Z(common mode)
DCR
Agilent-4291A+ Agilent -16197A
Refer to standard electrical characteristics list.
I.R.
Temperature Rise Test
Agilent-4338B
Agilent4339
Rated Current < 1A
∆T 20℃Max
1.Applied the allowed DC current.
2.Temperature measured by digital surface thermometer
Rated Current ≧ 1A ∆T 40℃Max
Reliability Test
Preconditioning: Run through IR reflow for 2 times.( IPC/JEDEC
J-STD-020DClassification Reflow Profiles)
Temperature:125±2℃
Life Test
Applied current:rated current
Duration:1000±12hrs
Measured at room temperature after placing for 24±2 hrs
Humidity:85±2﹪R.H,
Load Humidity
Temperature:85℃±2℃
Duration:1000hrs Min. with 100% rated current
Moisture Resistance
Appearance:No damage.
Impedance:within±15% of initial value
RDC:within ±15% of initial value and shall not
exceed the specification value
Profiles
1. Baked at50℃ for 25hrs, measured at room temperature after
placing for 4 hrs.
2. Raise temperature to 65±2℃ 90-100%RH in 2.5hrs, and
keep 3 hours, cool down to 25℃ in 2.5hrs.
3. Raise temperature to 65±2℃ 90-100%RH in 2.5hrs, and
2.5hrs,keep at 25℃ for 2 hrs then keep at -10℃ for 3 hrs
4. Keep at 25℃ 80-100%RH for 15min and vibrate at the
frequency of 10 to 55 Hz to 10 Hz, measure at
room temperature after placing for 1~2 hrs.
Reflow Profiles
Condition for 1 cycle
Step1:-40±2℃ 30±5min
Thermal
shock
Step2:25±2℃ ≦0.5min
Step3:125±2℃ 30±5min
Number of cycles: 500
Oscillation Frequency: 10~2K~10Hz for 20 minutes
Vibration
Equipment: Vibration checker
Total Amplitude:1.52mm±10%
Testing Time : 12 hours(20 minutes, 12 cycles each of 3
orientations)。
www.tai-tech.com.tw
P5
TAI-TECH
Item
Performance
Bending
Shock
Solder ability
Q:Shall not exceed the specification value.
More than 95% of the terminal electrode should
be covered with solder。
Test Condition
Shall be mounted on a FR4 substrate of the
following dimensions: >=0805 inch(2012mm):40x100x1.2mm
=0805 inch(2012mm):1.2mm
0805:1kg ,
很抱歉,暂时无法提供与“WCM2012F2SF-801-N”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.07436
- 100+0.06776
- 500+0.06336
- 1000+0.05896
- 5000+0.05368
- 10000+0.05148
- 国内价格
- 1+1.88100
- 100+1.44100
- 1000+1.25400
- 2000+1.18800
- 国内价格
- 20+0.47740
- 100+0.28470
- 500+0.19930
- 2000+0.14240
- 4000+0.14240
- 20000+0.14240
- 国内价格 香港价格
- 1+2.168591+0.28057
- 国内价格
- 20+0.10570
- 200+0.08500
- 1000+0.07110
- 2000+0.06530
- 4000+0.06120
- 8000+0.05750
