S3ABF THRU S3MBF
Reverse Voltage - 50 to 1000 Volts
Forward Current - 3.0 Ampere
SURFACE MOUNT GENERAL PURPOSE SILICON RECTIFIER
Features
SMBF
For surface mounted applications
Low profile package
0.146(3.70)
0.138(3.50)
0.086 (2.20)
0.075 (1.90)
Glass Passivated Chip Junction
Easy to pick and place
Lead free in comply with EU RoHS 2011/65/EU diretives
0.173(4.40)
0.165(4.20)
0.051(1.30)
0.043(1.10)
Mechanical Data
0.010(0.26)
0.007(0.18)
0.048(1.20)
0.031(0.80)
0.216(5.50)
0.200(5.10)
Case: JEDEC 60B) molded plastic body
Terminals: Solderable per MIL-STD-750,Method 2026
Polarity: Polarity symbol marking on body
Mounting Position: Any
Weight : 0.002 ounce, 0.057 grams
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
SYMBOLS
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
at TL=115℃
Peak forward surge current
8.3ms single half sine-wave
superimposed onrated load (JEDEC Method)
Maximum instantaneous forward voltage at 3.0A
VRRM
VRMS
VDC
S3DBF S3GBF
S3JBF
S3KBF S3MBF
S3ABF
S3BBF
MDD
S3AB
MDD
S3BB
MDD
S3DB
MDD
S3GB
MDD
S3JB
MDD
S3KB
MDD
S3MB
50
35
50
100
70
100
200
140
200
400
280
400
600
420
600
800
560
800
1000
700
1000
UNITS
V
V
V
I(AV)
3
A
IFSM
80
A
VF
1.1
V
μA
Typical junction capacitance (NOTE 1)
CJ
5
150
35
Typical thermal resistance (NOTE 2)
RJA
RθJC
45
15
℃/W
-55 to +150
Maximum DC reverse current
at rated DC blocking voltage
TA=25℃
TA=125℃
IR
Operating junction and storage temperature range TJ,TSTG
pF
Note: 1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2.P.C.B. mounted with 2.0”x2.0”(5.0x5.0cm) copper pad areas
http://www.microdiode.com
Rev:2024A2
Page :1
S3ABF THRU S3MBF
Typical Characterisitics
Fig.2 Typical Reverse Characteristics
3.0
2.0
1.0
Single phase half-wave 60 Hz
0.0
25
50
75
100
125
150
175
Instaneous Reverse Current(μ A)
Average Forward Current (A)
Fig.1 Forward Current Derating Curve
100
T J =125°C
10
1.0
T J =25°C
0.1
00
Case Temperature (°C)
40
60
80
100
120
140
percent of Rated Peak Reverse Voltage (%)
Fig.4 Typical Junction Capacitance
Fig.3 Typical Forward Characteristic
10
Junction Capacitance (pF)
Instaneous Forward Current (A)
T J =25°C
100
10
T J =25°C
0.1
0.4
1
0.6
0.8
1.0
1.2
1.4
1.6
1.8
0.1
1.0
10
100
Reverse Voltage (V)
Instaneous Forward Voltage (V)
Peak Forward Surge Current (A)
Fig.6 Maximum Non-Repetitive Peak
120
100
80
60
40
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
100
Number of Cycles
The curve above is for reference only.
Rev:2024A2
Page :2
S3ABF THRU S3MBF
Packing information
unit:mm
P0
P1
d
Item
Symbol
Tolerance
SMBF
Carrier width
Carrier length
Carrier depth
Sprocket hole
13" Reel outside diameter
13" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
A
B
C
d
D
D1
D2
E
F
P
P0
P1
T
W
Reel width
W1
0.1
0.1
0.1
0.05
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
3.81
5.61
1.60
1 50
330.00
50.00
13.00
1.75
5.50
4.00
4.00
2.00
0.30
12.00
12.30
E
F
B
A
W
P
D2
T
D1
C
W1
D
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
REEL SIZE
REEL
(pcs)
COMPONENT
SPACING
(mm)
BOX
(pcs)
INNER
BOX
(mm)
REEL
DIA,
(mm)
SMBF
13"
5,000
4.0
10,000
190*190*41
330
CARTON
SIZE
(mm)
365*365*360
CARTON
(pcs)
80,000
APPROX.
GROSS WEIGHT
(kg)
14.0
Suggested Pad Layout
Symbol
Unit (mm)
A
2.54
0.100
B
1.8
0.071
C
4.8
0.189
D
3.0
0.118
E
6.6
0.260
Unit (inch)
Rev:2024A2
Page :3
很抱歉,暂时无法提供与“S3MBF”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.14159
- 100+0.10712
- 1000+0.09002
- 国内价格
- 1+0.25067
- 10+0.19527
- 30+0.16449
- 100+0.14602
- 500+0.13004
- 1000+0.12140
