SS210B
SS210B
    MDD(辰达半导体)
    SMB(DO-214AA)
    肖特基二极管 电压:100V 电流:2A SMB(DO-214AA)
SS210B 数据手册
SS22B THRU SS2200B Reverse Voltage - 20 to 200 Volts Forward Current - 2.0 Ampere SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER DO-214AA/SMB Features  The plastic package carries Underwriters Laboratory Flammability Classification 94V-0  For surface mounted applications  Metal silicon junction,majority carrier conduction  Low power loss,high efficiency 0.155(3.94) 0.130(3.30) 0.086 (2.20) 0.071 (1.80)  Built-in strain relief,ideal for automated placement 0.185(4.70) 0.160(4.06)  High forward surge current capability  High temperature soldering guaranteed: 0.012(0.305) 0.006(0.152) 250 °C/10 seconds at terminals 0.096(2.44) 0.084(2.13) 0.060(1.52) 0.030(0.76) 0.008(0.203)MAX. Mechanical Data 0.220(5.59) 0.200(5.08) Case: JEDEC DO-214AA/SMB molded plastic body Terminals: Solderable per MIL-STD-750,Method 2026 Polarity: Color band denotes cathode end Mounting Position: Any Weight : 0.003 ounce, 0.093 grams Dimensions in inches and (millimeters) Maximum Ratings And Electrical Characteristics Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%. Parameter SYMBOLS Marking Code Maximum repetitive peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage Maximum average forward rectified current at TL(see fig.1) VRRM VRMS VDC SS22 SS23 SS24 SS25 SS26 SS28 SS210 MDD SS22B MDD SS23B MDD SS24B MDD SS25B MDD SS26B MDD SS28B MDD SS210B MDD SS2150B MDD SS2200B 20 14 20 30 21 30 40 28 40 50 35 50 60 42 60 80 56 80 100 70 100 150 105 150 200 140 200 I(AV) SS2150 SS2200 2.0 UNITS V V V A Peak forward surge current 8.3ms single half sine-wave superimposed onrated load (JEDEC Method) IFSM Maximum instantaneous forward voltage at 2.0A VF Maximum DC reverse current at rated DCblocking voltage TA=25℃ TA=100℃ Typical junction capacitance (NOTE 1) 45 55 0.55 0.70 0.85 A 0.95 0.5 IR 0.3 5.0 3.0 CJ 220 V mA 110 pF Typical thermal resistance (NOTE 2) RJA 60 ℃/W Operating junction temperature range TJ -50 to +125 ℃ TSTG -50 to +150 ℃ Storage temperature range Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C. 2.P.C.B. mounted with 2.0”x2.0”(5.0x5.0cm) copper pad areas http://www.microdiode.com Rev:2024A2 Page :1 SS22B THRU SS2200B Reverse Voltage - 20 to 200 Volts Forward Current - 2.0 Ampere Typical Characterisitics Fig.2 Typical Reverse Characteristics Average Forward Current (A) 3.0 2.5 2.0 1.5 1.0 0.5 Single phase half-wave 60 Hz resistive or inductive load 0.0 25 50 75 100 125 150 Instaneous Reverse Current ( μA) Fig.1 F Fo or w a r d C Cu ur r e n t D De er a t i n g C Cu ur v e 10 4 T J =75°C 10 2 10 1 SS22B~SS26B 10 0 0 20 40 60 80 Fig.4 Typical Junction Capacitance T J =25°C 10 1.0 SS22B ~ SS25B SS26B SS28B/SS210B SS2150B/SS2200B 0.1 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 500 200 100 20 SS22B~SS26B SS28B~SS2200B 10 1 0.1 100 10 Instaneous Forward Voltage (V) Reverse Voltage (V) Fig.5 Maximum Non-Repetitive Peak Forward Surage Current Fig.6- Typical Transient Thermal Impedance 60 SS22B-SS26B SS28B-SS2200B 50 40 30 20 10 1000 1.8 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 10 Number of Cycles at 60Hz 100 Transient Thermal Impedance( °C /W) 0 Junction Capacitance (pF) T J =25°C 20 100 Percent of Rated Peak Reverse Voltage(%) Fig.3 Typical Forward Characteristic Instaneous Forward Current (A) SS28B~SS2200B T J =25°C Case Temperature (°C) Peak Forward Surage Current (A) T J =100°C 10 3 100 10 1 0.01 0.1 1 10 100 t, Pulse Duration(sec) The curve above is for reference only. http://www.microdiode.com Rev:2024A2 Page :2 SS22B THRU SS2200B Reverse Voltage - 20 to 200 Volts Forward Current - 2.0 Ampere Packing information unit:mm P0 P1 Item Symbol Tolerance SMB Carrier width Carrier length Carrier depth Sprocket hole 13" Reel outside diameter 13" Reel inner diameter Feed hole diameter Sprocket hole position Punch hole position Punch hole pitch Sprocket hole pitch Embossment center Overall tape thickness Tape width A B C d D D1 D2 E F P P0 P1 T W Reel width W1 0.1 0.1 0.1 0.05 2.0 min 0.5 0.1 0.1 0.1 0.1 0.1 0.1 0.3 1.0 3.81 5.41 2.42 1 50 . 330.00 50.00 13.00 1.75 5.55 8.00 4.00 2.00 0.30 12.00 12.30 d E F B A W P D2 T D1 C W1 D Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above. Reel packing PACKAGE REEL SIZE REEL (pcs) COMPONENT SPACING (mm) BOX (pcs) INNER BOX (mm) REEL DIA, (mm) SMB 13" 3,000 4.0 6,000 190*190*41 330 CARTON SIZE (mm) 365*365*360 CARTON (pcs) 48,000 APPROX. GROSS WEIGHT (kg) 14.0 Suggested Pad Layout http://www.microdiode.com Unit (inch) Symbol Unit (mm) A 2.8 0.110 B 0.094 C 2.4 4.6 0.181 D 2.2 0.086 E 7.0 0.276 Rev:2024A2 Page :3
SS210B 价格&库存
很抱歉,暂时无法提供与“SS210B”相匹配的价格&库存,您可以联系我们找货
SS210B
  • 20+0.28858
  • 300+0.21018
  • 1200+0.20703
  • 3000+0.14008
库存:10210
SS210B
  • 1+0.24970
  • 200+0.16170
  • 1500+0.14080
  • 3000+0.12430
库存:2495
SS210B
  • 10+0.31440
  • 100+0.25540
  • 300+0.22710
  • 3000+0.15130
  • 6000+0.13430
  • 9000+0.12590
库存:5578
