SS52F THRU SS5200F
Reverse Voltage - 20 to 200 Volts
Forward Current - 5.0 Ampere
SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER
Features
SMAF
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
For surface mounted applications
Metal silicon junction,majority carrier conduction
Low power loss,high efficiency
0.106(2.70)
0.094(2.40)
0.063 (1.60)
0.051 (1.30)
0.146(3.70)
0.130(3.30)
Built-in strain relief,ideal for automated placement
High forward surge current capability
High temperature soldering guaranteed:
260 °C/10 seconds at terminals
0.047(1.20)
0.035(0.90)
0.008(0.20)
0.005(0.12)
0.047(1.20)
0.031(0.80)
0.193(4.90)
0.173(4.40)
Mechanical Data
Case: JEDEC SMAF molded plastic body
Terminals: Solderable per MIL-STD-750,Method 2026
Polarity: Color band denotes cathode end
Mounting Position: Any
Weight : 0.0018 ounce, 0.064 grams
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
SYMBOLS
Marking Code
Maximum repetitive peak reverse voltage
VRRM
Maximum RMS voltage
VRMS
VDC
Maximum DC blocking voltage
Maximum average forward rectified current
at TL(see fig.1)
Peak forward surge current
8.3ms single half sine-wave
superimposed onrated load (JEDEC Method)
Maximum instantaneous forward voltage at 5.0A
Maximum DC reverse current
at rated DC blocking voltage
TA=25℃
TA=125℃
Typical junction capacitance (NOTE 1)
Typical thermal resistance (NOTE 2)
Operating junction temperature range
Storage temperature range
SS52F
SS53F
SS54F
SS55F
SS56F
SS58F
SS510F
SS5150F
SS5200F
MDD
SS52F
MDD
SS53F
MDD
SS54F
MDD
SS55F
MDD
SS56F
MDD
SS58F
MDD
SS510F
MDD
SS5150F
MDD
SS5200F
UNITS
21
30
40
28
40
50
35
50
60
42
60
80
56
80
100
70
100
150
105
150
200
140
200
V
V
V
I(AV)
5.0
A
IFSM
150
A
VF
IR
0.55
0.70
0.5
20.0
CJ
RJA
TJ
TSTG
0.85
10.0
0.95
0.2
2.0
mA
200
pF
50.0
℃/W
-50 to +125
-50 to +150
-55 to +150
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2.P.C.B. mounted with 0.2x0.2”(5.0x5.0mm) copper pad areas
http://www.microdiode.com
V
Rev:2024A1
Page :1
SS52F THRU SS5200F
FIG. 1- FORWARD CURRENT DERATING CURVE
5.0
4.0
Single Phase
Half Wave 60Hz
Resistive or
inductive Load
3.0
2.0
SS52F-SS56F
SS58F-SS5200F
1.0
50
75
100
125
150
PEAK FORWARD SURGE CURRENT,
AMPERES
AVERAGE FORWARD RECTIFIED CURRENT,
AMPERES
Typical Characterisitics
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
150
120
90
60
30
175
8.3ms SINGLE HALF SINE-WAVE
(JEDEC Method)
1
10
AMBIENT TEMPERATURE, C
NUMBER OF CYCLES AT 60 Hz
50
INSTANTANEOUS FORWARD
CURRENT,AMPERES
TJ=25 C
10.0
1
SS52F-SS54F
SS55F-SS56F
SS58F-SS5150F
SS5200F
FIG. 4-TYPICAL REVERSE CHARACTERISTICS
INSTANTANEOUS REVERSE CURRENT,
MILLIAMPERES
FIG. 3-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
0.1
100
10
TJ=100 C
1
TJ=75 C
0.1
0.01
TJ=25 C
0.001
0.2
0.4
0.6
0.8
1.0
1.2
1.4
60
80
100
1.6
INSTANTANEOUS FORWARD VOLEAGE,
VOLTS
FIG. 5-TYPICAL JUNCTION CAPACITANCE
JUNCTION CAPACITANCE, pF
PERCENT OF PEAK REVERSE VOLTAGE,%
1000
TJ=25 C
100
TRANSIENT THERMAL IMPEDANCE,
C/W
0.01
100
FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE
100
10
1
0.1
0.01
0.1
1
10
100
10
0.1
1.0
10
REVERSE VOLTAGE,VOLTS
100
t,PULSE DURATION,sec.
The curve above is for reference only.
Rev:2024A1
Page :2
SS52F THRU SS5200F
Packing information
unit:mm
P0
P1
d
Item
E
F
B
A
Carrier width
Carrier length
Carrier depth
Sprocket hole
7" Reel outside diameter
7" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
Reel width
W
P
D2
T
D1
C
W1
D
Symbol
Tolerance
SMAF
A
B
C
d
D
D1
D2
E
F
P
P0
P1
T
W
W1
0.1
0.1
0.1
0.05
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
2.80
4.75
1.42
1.50
178.00
54.40
13.00
1.75
5.05
4.00
4.00
2.00
0.30
8.00
12.30
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
SMAF
REEL SIZE
7"
REEL
(pcs)
COMPONENT
SPACING
(m/m)
BOX
(pcs)
INNER
BOX
(m/m)
REEL
DIA,
(m/m)
CARTON
SIZE
(m/m)
CARTON
(pcs)
APPROX.
GROSS WEIGHT
(kg)
3,000
4.0
6,000
210*208*203
178
400*265*400
120,000
10.0
Suggested Pad Layout
Symbol
A
Unit (mm)
1.8
Unit (inch)
0.071
B
1.6
0.063
C
3.8
0.150
D
2.2
0.087
E
5.4
0.213
Important Notice and Disclaimer
Microdiode Electronics (Jiangsu) reserves the right to make changes to this document and its products and
specifications at any time without notice. Customers should obtain and confirm the latest product information and
specifications before final design,purchase or use.
Microdiode Electronics (Jiangsu) makes no warranty, representation or guarantee regarding the suitability of its
products for any particular purpose, not does Microdiode Electronics (Jiangsu) assume any liability for application
assistance or customer product design. Microdiode Electronics (Jiangsu) does not warrant or accept any liability with
products which are purchased or used for any unintended or unauthorized application.
No license is granted by implication or otherwise under any intellectual property rights of Microdiode
Electronics (Jiangsu).
Microdiode Electronics (Jiangsu) products are not authorized for use as critical components in life support
devices or systems without express written approval of Microdiode Electronics (Jiangsu).
Rev:2024A1
Page :3
很抱歉,暂时无法提供与“SS56F”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.33394
- 100+0.26763
- 300+0.23436
- 3000+0.20952
- 6000+0.18965
- 9000+0.17972
- 国内价格
- 1+0.30000
- 100+0.28000
- 300+0.26000
- 500+0.24000
- 2000+0.23000
- 5000+0.22400
