信昌電子陶瓷股份有限公司
Prosperity Dielectrics Co., Ltd.
No.220-1, Sec. 2, Nanshan Rd., Lujhu, Taoyuan 33860, Taiwan, R.O.C.
Tel.:886-3-3224471
Fax:886-3-3212216
SPECIFICATION FOR APPROVAL
DATE:
CUSTOMER:
PART NAME:
High-Power Low Resistance Lead Free & Halogen Free Chip Resistors
CUSTOMER'S DWG. NO.
CUSTOMER'S PART NO.
PDC PART NO.
FBF SERIES APPROVED
DESCRIPTION.
ACTION
RESULT
" ˇ"
CUSTOMER'S
SIGNATURE
NOTE
FULL APPROVED
CONDITIONAL APPROVED
REJECTED
OUR ACTION
SIGNATURE
PREPARED BY
Jenny Tseng
CHECKED BY
Tony Chou
APPROVED BY
Byron Tsai
Edition :
FBF-Rev.8.0.G38
CUSTOMER SIGNATURE FOR ACCEPTANCE
Serial Number : K
PDC
FBF series. (Metal Paste)
Current Sensing Resistors
Thick-film Chip Resistors
1.
Features ………………………………………..……………..…….2
2.
Applications…..…..………………………………..………………. 2
3.
Dimension and construction ………………………..……………..2
4.
Power Derating Curve …..…………………………….…………..3
5.
Rating ……………………………………………………………….4
6.
Part Number ………………………………..………………………5
7.
Resistance Marking / Soldering
8.
Reliability Performance…………………………………………….7
9.
Packing ………………………………………………….…………..8
9.1 Peel Strength of Top Cover Tape……………………………….8
9.2 Tape Packaging Dimensions……………………………………8
9.3 Reel Dimensions………………………………………………....9
………………………………..5
10. Storage / Handling ……………………………………….…………..9
1/9
FBF-REV.8.0.G38
PDC
1. Features
Low resistance and high precision (1%).
Excellent reliability and suitable cost.
Suitable for lead free soldering.
RoHS compliant & Halogen Free.
2. Applications
Consumer electronics, M/B.
Battery pack, BTC.
Notebook, Tablet PC.
Portable Device, Electronic Equipment.
3. Dimensions and Constructions
Unit:mm
T
Type 1.
L
W
C
D
FBF03
1.60±0.10
0.80±0.10
0.30±0.20
0.30±0.20
0.45±0.10
FBF05
2.00±0.10
1.25±0.10
0.40±0.20
0.40±0.20
0.50±0.10
FBF06
3.10±0.10
1.60±0.10
0.50±0.25
0.50±0.25
0.55±0.10
FBF12
3.10±0.10
2.60±0.10
0.50±0.25
0.50±0.25
0.55±0.10
FBF20
5.00±0.20
2.50±0.20
0.60±0.25
0.60±0.25
0.60±0.10
FBF25
6.30±0.20
3.10±0.20
0.60±0.25
0.90±0.25
0.60±0.15
Type 2.
L
W
C
D
T
FBF03
1.60±0.10
0.80±0.10
0.30±0.20
0.50±0.20
0.50±0.10
FBF05
2.00±0.10
1.25±0.10
0.40±0.20
0.65±0.20
0.60±0.10
FBF06
3.10±0.10
1.60±0.10
0.50±0.25
0.90±0.25
0.65±0.10
FBF12
3.10±0.10
2.60±0.10
0.50±0.25
0.90±0.25
0.65±0.10
FBF20
5.00±0.20
2.50±0.20
0.60±0.25
1.25±0.25
0.65±0.10
FBF25
6.30±0.20
3.10±0.20
0.60±0.25
1.90±0.25
0.65±0.15
2/9
FBF-REV.8.0.G38
PDC
Type 1. Resistance ≧ 40mΩ
Type 2. Resistance ≦ 39mΩ
4. Power Derating Curve
Operating Temperature Range: -55 to +155 deg.C
3/9
FBF-REV.8.0.G38
PDC
5. Rating
Normal Type
Power
Rating
Type
FBF03
Size
0603
at 70℃
1/8W
Max.
RCWV
(mV)
337
Max.
Resistance Temperature Resistance Range Standard
Overload
(mΩ)
Tolerance Coefficient
Resistance
Voltage
(TCR; ppm/℃)
Values
Min.
Max.
(mV)
754
±1、±2、±5
±200
40
91
±100
100
910
±200
10
46
±100
47
910
±200
10
46
±100
47
910
±200
10
46
±100
47
910
±200
10
46
±100
47
910
±200
10
46
±100
47
910
E-24
FBF05
0805
1/4W
477
1067
±1、±2、±5
FBF06
1206
1/3W
551
1232
±1、±2、±5
FBF12
1210
2/3W
779
1742
±1、±2、±5
FBF20
2010
3/4W
826
1847
±1、±2、±5
FBF25
2512
1W
954
2133
±1、±2、±5
Max.
Max.
RCWV
Overload
(mΩ)
Resistance
Power Type
Power
Rating
Type
FBF03
Size
0603
at 70℃
1/4W
Voltage
(mV)
(mV)
477
1067
±1、±2、±5
FBF05
0805
1/2W
675
1508
±1、±2、±5
FBF06
1206
3/4W
826
1847
±1、±2、±5
FBF12
1210
3/4W
826
1847
±1、±2、±5
FBF20
2010
1W
954
2133
±1、±2、±5
FBF25
2512
2W
1349
3017
±1、±2、±5
4/9
(TCR; ppm/℃)
Min.
Max.
±200
40
91
±100
100
910
±200
10
46
±100
47
910
±200
10
46
±100
47
910
±200
10
46
±100
47
910
±200
10
46
±100
47
910
±200
10
46
±100
47
910
E-24
E-24
E-24
E-24
E-24
Values
E-24
E-24
E-24
E-24
E-24
E-24
FBF-REV.8.0.G38
PDC
Note:
1. RCWV = (P×R)1/2 or Max. RCWV listed above, whichever is lower.
RCWV:Rated Continue Working Voltage(V),P:Rated Power(W),R:Resistance Value(Ω)
2. Special resistance value request please contact factory.
6. Part Number
Type
FBF
Size
Tolerance
03 :0603
F :±1%
05 :0805
G :±2%
06 :1206
J :±5%
Packing
Paper Tape:
Power
R Value
Code
(GM)
XXXX
0603.0805.1206
As Normal
4 digit
1210
Type Rating
12 :1210
T : 5Kpcs
20 :2010
V : 10Kpcs
P:
25 :2512
W : 20Kpcs
As Power
Plastic Tape:
Type Rating
2010.2512
P : 4Kpcs
X : 8Kpcs
Y : 16Kpcs
Example:
FBF06FT-R100
1206 size, tolerance 1%, paper tape, 100mΩ.
7. Marking/Soldering
Resistance value identify:
0805/1206/1210/2010/2512
Top Marking. ( 4 Digits marking to identify the resistance value. )
R068
R068=68mΩ,R120=120mΩ
0603
Top Marking. ( 3 Digits marking to identify the resistance value. )
R12
R12=120mΩ,68M=68mΩ
5/9
FBF-REV.8.0.G38
PDC
Soldering Reference:
R12
Recommend Solder Pad Dimensions:
Type
W
D
L
FBF03
0.90
1.00
3.00
FBF05
1.30
1.15
3.50
FBF06
1.80
1.30
4.70
FBF12
3.00
1.30
4.70
FBF20
3.00
1.50
6.80
FBF25
3.70
1.60
7.60
Unit:mm
6/9
FBF-REV.8.0.G38
PDC
8. Reliability Performance
Test Item
Specification
DC Resistance F:±1%
G:±2%
Test Method
IEC 60115-1 / JIS C 5201-1 , Clause 4.5
J:±5%
Measure the resistance Value.
Resistance
to
Solder Heat
∆R≦±(1%+0.5mΩ)
IEC 60115-1, Clause 4.18
F:∆R≦±(0.5%+0.5mΩ)
Solder dipping @ 260℃±5℃ for 10sec.±1sec.
Solder Ability
Over 95% of termination
IEC 60115-1, Clause 4.17
must be covered with
After immersing flux, dip in the
Solder.
245±2℃ molten solder bath for 3±0.5 sec.
No mechanical damage
Short
∆R≦±(2%+0.5mΩ)
Time Overload F:∆R≦±(1%+0.5mΩ)
IEC 60115-1, Clause 4.13
5 × Rated power for 5 seconds
Temperature
Coefficient of
Resistance
(TCR)
Within the spec.
Load Life
∆R≦±(3%+0.5mΩ)
IEC 60115-1, Clause 4.25
F:∆R≦±(1%+0.5mΩ)
Rated voltage for 1.5 hours for followed
IEC 60115-1, Clause 4.8
T1
T2
Test temperature: 25℃~ 155℃
TCR(ppm/℃) = (R2-R1)/R1×1 / (T2-T1)×106
by a pause 0.5 hour at 70±2℃.
Cycle repeated 1000 hours.
Bending
strength
∆R≦ ±(1%+0.5mΩ)
IEC 60115-1 / JIS C 5201-1 ,Clause 4.33
F:∆R≦ ±(0.5%+0.5mΩ)
Resistance variance after bended on the 90mm
No mechanical damage.
PCB. Bending width:3mm for 0603 0805
2mm for 1206 2010 2512
Insulation
Resistance
Between termination and
IEC 60115-1, Clause 4.6
coating must over 1000MΩ Test voltage:100±15V
7/9
FBF-REV.8.0.G38
PDC
9. PACKAGING
The peel speed shall be about 300 mm/min
The peel force of top cover tape shall between 0.1 to 0.7N
unit:mm
Size
A
B
W
F
E
P1
P2
P0
D
0603 1.10±0.20 1.90±0.20 8.00±0.30 3.50±0.05 1.75±0.10 4.00±0.10 2.00±0.05 4.00±0.10
1.50+0.10/-0
0805 1.65±0.20 2.40±0.20 8.00±0.30 3.50±0.05 1.75±0.10 4.00±0.10 2.00±0.05 4.00±0.10
1.50+0.10/-0
1206 2.00±0.20 3.60±0.20 8.00±0.30 3.50±0.05 1.75±0.10 4.00±0.10 2.00±0.05 4.00±0.10
1.50+0.10/-0
1210 3.00±0.20 3.60±0.20 8.00±0.30 3.50±0.05 1.75±0.10 4.00±0.10 2.00±0.05 4.00±0.10
1.50+0.10/-0
2010 2.80±0.20 5.50±0.20 12.00±0.30 5.50±0.05 1.75±0.10 4.00±0.10 2.00±0.05 4.00±0.10
1.50+0.10/-0
2512 3.50±0.20 6.70±0.20 12.00±0.30 5.50±0.05 1.75±0.10 4.00±0.10 2.00±0.05 4.00±0.10
1.50+0.10/-0
8/9
FBF-REV.8.0.G38
PDC
9.3 Reel Dimensions
unit:mm
Size
0603
0805
1206
1210
2010
2512
Packaging
Q’ty
A
N
C
D
B
G
T
5kpcs/Reel 178.0±2.0 60.0±0.5 13.0±0.5 20(Min.)
2.0±0.5 10.0±1.5 14.9max.
10kpcs/Reel 254.0±2.0 100.0±1.0 13.5±0.5 20(Min.)
20kpcs/Reel 330.0±2.0 100.0±1.0 13.5±0.5 20(Min.)
4kpcs/Reel 178.0±2.0 60.0±0.5 13.0±0.5 20(Min.)
2.0±0.5 13.8±1.5 16.7max.
8kpcs/Reel 254.0±2.0 100.0±0.5 13.5±0.5 20(Min.)
2.0±0.5 13.8±1.5 20.0max.
16kpcs/Reel 330.0±2.0 100.0±1.0 13.5±0.5 20(Min.)
10. Storage &. Handling
… Products are recommended to be used up within one year as ensured shelf life.
Check solder ability in case shelf life extension is needed.
… To store products with following condition:
Temperature:5 to 40℃;Humidity: 20 to 70% relative humidity.
※ All product specification and data are subject to change without notice.
9/9
FBF-REV.8.0.G38
PDC
很抱歉,暂时无法提供与“FBF25FP-R250”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.35799
- 100+0.30066
- 国内价格
- 10+0.39453
- 100+0.33135
- 300+0.29981
- 1000+0.27616
- 4000+0.24376
- 8000+0.23426
