SMW-B Series
Wire-wound Common Mode Filter
Pb
◆ Features
1
、Powerful component with composite co-fired
material to solve EMI problem for high-speed
differential signal transmission line as USB,
IEEE1394 and LVDS, without distortion to
high speed signal transmission
、High coupling constant : 0.99
3、Small size and low profile
4、Various common mode impedance items
2
of 67 to 220 ohm can be used, considering
noise level and signal frequency
5 Small dimension enable higher density packaging
6 RoHS Compliant.
◆ Application
1 Common mode noise suppression of signal lines in
high speed and high density digital equipment
2 USB2.0/3.0 of PC, peripheral equipments, small
digital AV equipments, etc
◆ PRODUCT IDENTIFICATION
SMW 2012 B 900 D T
(1)
(2)
(3) (4) (5) (6)
E
(7)
(1) Series Type
(2) Chip Size mm :Length X Width
◆ Equivalent Circuit Diagram
(3)
Material type : With maganetic shield(B/D/H)
(4)
Nominal Impedance:900=90Ω
101=100Ω
(5)
Rated Curren
:A=250mA; B=300mA;C=350mA;
D=400mA; H=1000mA;I=1500mA
L=3000mA
(6) Company Code
(7) Packaging: P – Embossed paper tape, 7" reel
E – Embossed plastic tape, 7" reel
T – Tape & reel
◆ Impedance :
Measured by using Agilent E4991A RF Impedance Analyzer
Rev.03
Page 1 of 9
www. sunltech.com
SMW-B Series
◆ Dimensions
Unit: mm
Series
A(mm)
B(mm)
C(mm)
D1(mm)
D2(mm)
E(mm)
SMW1608
1.6 ± 0.1
0.8 ± 0.1
1.1 ± 0.1
0.33±0.1
0.25±0.1
0.12±0.1
SMW2012
2.0±0.2
1.2±0.2
1.2±0.2
0.55±0.1
0.46±0.1
0.15±0.1
SMW3216
3.2±0.2
1.6±0.2
1.9±0.2
0.6±0.1
0.6±0.1
0.17±0.1
SMW4532
4.5±0.2
3.2±0.2
2.8±0.2
1.2±0.1
1.0±0.1
0.19±0.1
◆ Specifications
Part Number
SMW1608B Series
SMW1608B670BTE
SMW1608B900BTE
SMW1608B121ATE
SMW1608B161ATE
SMW1608B221ATE
SMW2012B Series
SMW2012B300DTE
SMW2012B670DTE
SMW2012B750DTE
SMW2012B900DTE
SMW2012B121DTE
SMW2012B161CTE
SMW2012B181CTE
SMW2012B201CTE
SMW2012B221CTE
SMW2012B261BTE
SMW2012B361BTE
SMW2012B371BTE
Rev.03
Common mode
Impedance
Z( )
Ω
90±25%
120±25%
160±25%
220±25%
67 25%
67±25%
75±25%
90±25%
120±25%
160±25%
180±25%
200±25%
220±25%
260±25%
360±25%
370±25%
30 25%
Test
Frequency
MHz
DC
Resistance
( ) max.
Rated
Current
(mA)
Rated Volt.
(Vdc)
Withstand
Volt. (Vdc)
100
0.30
300
50
125
10M
100
0.30
300
50
125
10M
100
0.36
250
50
125
10M
100
0.40
250
50
125
10M
100
0.42
250
50
125
10M
100
0.20
450
50
125
10M
100
0.25
400
50
125
10M
100
0.25
400
50
125
10M
100
0.30
400
50
125
10M
100
0.30
400
50
125
10M
100
0.35
350
50
125
10M
100
0.35
350
50
125
10M
100
0.35
300
50
125
10M
100
0.35
300
50
125
10M
100
0.40
300
50
125
10M
100
0.45
300
50
125
10M
100
0.45
300
50
125
10M
Page 2 of 9
Ω
IR
Ω) min.
www. sunltech.com
SMW-B Series
◆ Specifications
Part Number
Common mode
Impedance
Z( )
Ω
Test
Frequency
MHz
DC
Resistance
( ) max.
Rated
Current
(mA)
Rated Volt.
(Vdc)
Withstand
Volt. (Vdc)
Ω
IR
Ω) min.
SMW3216B Series
SMW3216B900DTE
90±25%
100
0.30
450
50
125
20M
SMW3216B121DTE
120±25%
100
0.35
400
50
125
10M
SMW3216B161CTE
160±25%
100
0.40
350
50
125
10M
SMW3216B201CTE
200±25%
100
0.45
350
50
125
10M
SMW3216B221BTE
220±25%
100
0.45
300
50
125
10M
SMW3216B261BTE
260±25%
100
0.50
300
50
125
10M
SMW3216B361BTE
360±25%
100
0.60
300
50
125
10M
SMW3216B601ATE
600±25%
100
0.80
250
50
125
10M
SMW3216B102ATE
1000±25%
100
1.00
250
50
125
10M
SMW3216B222ATE
2200±25%
100
1.20
250
50
125
10M
SMW4532B800LTE
80±25%
100
0.07
3000
50
125
10M
SMW4532B900LTE
90±25%
100
0.07
3000
50
125
10M
SMW4532B121LTE
120±25%
100
0.07
3000
50
125
10M
SMW4532B601ITE
600±25%
100
0.30
1500
50
125
10M
SMW4532B102HTE
1000±25%
100
0.40
1000
50
125
10M
SMW4532B142HTE
1400±25%
100
0.20
1000
50
125
10M
SMW4532B Series
◆ General Technical Data
Operating Temperature Range
Storage Condition
Rev.03
℃ ~ +85℃
20°C ~ 25°C and 65% RH (For Reference)
-25
Page 3 of 9
www. sunltech.com
SMW-B Series
◆ Recommended soldering conditions
◆ Characteristics
SMW1608B670B_
Rev.03
SMW1608B900B_
Page 4 of 9
www. sunltech.com
SMW-B Series
SMW1608B161A_
SMW1608B121A_
SMW2012B670D_
SMW1608B221A_
◆ Characteristics
SMW2012B900D_
SMW2012B750D_
Rev.03
Page 5 of 9
www. sunltech.com
SMW-B Series
SMW2012B161C_
SMW2012B121D_
SMW2012B221C_
SMW2012B161C_
SMW2012B361C_
SMW2012B261C_
Rev.03
Page 6 of 9
www. sunltech.com
SMW-B Series
SMW2012B371C_
SMW3216B900D_
SMW3216B160C_
SMW3216B261B_
Rev.03
SMW3216B601B_
Page 7 of 9
www. sunltech.com
SMW-B Series
SMW3216B222A_
SMW3216B102A_
SMW4532B800G_
SMW4532B900G_
SMW4532B121G_
Rev.03
SMW4532B601G_
Page 8 of 9
www. sunltech.com
SMW-B Series
SMW4532B102E_
SMW4532B142F_
◆ Package
Rev.03
Size EIA (EIA)
1608
(0603)
2012
(0805)
3216
(1206)
4532
(1812)
Standard Packing
Quantity (pcs / reel)
2,000
2,000
2,000
2,000
Page 9 of 9
www. sunltech.com
很抱歉,暂时无法提供与“SMW2012B221CTE”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.42767
- 100+0.35711
- 300+0.32183
- 国内价格
- 10+0.47132
- 100+0.39356
- 300+0.35468
