P1
TAI-TECH
Wire Wound Type Common Mode Filter
WCM4532F2SF-102T10
ECN HISTORY LIST
REV
DATE
DESCRIPTION
APPROVED
CHECKED
DRAWN
1.0
15/04/08
新發行
楊祥忠
林志鴻
林宜蕰
備
註
www.tai-tech.com.tw
P2
TAI-TECH
WCM4532F2SF-102T10
1. Features
1. High common mode impedance at high frequency cause excellent noise
suppression performance.
2. WCM4532F2SF series realizes small size and low profile. 4.5x3.2x2.8 mm.
3. 100% Lead(Pb) & Halogen-Free and RoHS compliant.
Halogen
Pb
Halogen-free
Pb-free
2. Dimension
Recommended PC Board Pattern
A
C
1
2
G2
B
H
3
4
G1
D
L
D
PC board should be designed so that products can prevent damage from
mechanical stress when warping the board.
Products shall be positioned in the sideway direction against the
mechanical stress to prevent failure.
D
D
Series
A(mm)
B(mm)
C(mm)
D1(mm)
D2(mm)
L(mm)
H(mm)
G1(mm)
G2(mm)
4532F2SF
4.5±0.2
3.2±0.2
2.8±0.2
1.0±0.1
1.2±0.1
4.8
3.8
2.5
0.7
Units: mm
3. Part Numbering
WCM 4532
A
B
F
2
S
F
C
D
E
F
102
T
10
G
H
I
A: Series
B: Dimension
C: Material
Ferrite Core
D: Number of Lines
2=2 lines
E: Type
S=Shielded , N=Unshielded
F: Lead free
G: Impedance
102=1000Ω
H: Packaging
I: Rated Current
T=Taping and Reel
10=1000mA
4. Specification
WCM4532F2SF-102T10
DC
Common mode
Impedance Test Frequency Resistance
(MHz)
(Ω)
(Ω) max.
1000±25%
100
Rated Current
(mA) max.
0.24
1000
WCM4532F2SF-102
10000
1000
IMPEDANCE(Ohm)
TAI-TECH
Part Number
Common Mode
100
10
Normal Mode
1
0.1
1
10
100
1000
FREQUENCY(MHz)
www.tai-tech.com.tw
Withstand
Rated Volt. Volt. (Vdc)
IR
(Vdc) max.
(Ω) min.
max.
50
125
10M
P3
TAI-TECH
5.Schematic Diagram
6. Materials
No.
Description
Specification
a.
Upper Plate
Ferrite
b.
Core
Ferrite Core
c
Termination
Tin (Pb Free)
d
Wire
Enameled Copper Wire
7. Reliability and Test Condition
Item
Performance
Test Condition
Electrical Characteristics Test
Agilent-4291A+ Agilent -16197A
Z(common mode)
DCR
Refer to standard electrical characteristics list.
Agilent-4338B
Agilent4339
I.R.
Operating Temperature
-40℃~+125℃
Storage Temperature(on board)
Temperature Rise Test
Rated Current < 1A
ΔT 20℃Max
Rated Current ≧ 1A ΔT 40℃Max
1.Applied the allowed DC current.
2.Temperature measured by digital
thermometer
surface
Mechanical Performance Test
Solderability Test
More than 95% of terminal electrode should be covered with solder.
Preheat: 150℃,60sec.。
Solder: Sn99.5%-Cu0. 5%。
Temperature: 245±5℃。
Flux for lead free: Rosin. 9.5%。
Dip time: 4±1sec。
Depth: completely cover the termination
Solder Heat Resistance
Temperature
(°C)
Time
(s)
Temperature
ramp/immersion
and emersion rate
Number
of heat
cycles
260 ±5
(solder temp)
10 ±1
25mm/s ±6 mm/s
1
Appearance:No damage.
Impedance:within±15% of initial value
RDC:within ±15% of initial value and shall not exceed the specification value
Preconditioning :Run through IR reflow for 2
times.( IPC/JEDEC J-STD-020DClassification Reflow
Profiles
With the component mounted on a PCB with the device
to be tested, apply a force (>0805:1kg ,
很抱歉,暂时无法提供与“WCM4532F2SF-102T10”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 500+1.00480
- 1500+0.97630
- 6500+0.94780
- 国内价格
- 10+3.28690
- 100+1.96070
- 300+1.37250
- 500+0.98040
- 1000+0.98040
- 5000+0.98040
- 国内价格
- 5+1.50596
- 50+1.17936
- 150+1.03940
- 国内价格
- 1+1.41580
- 10+1.12410
- 50+0.93200
- 150+0.86490
- 500+0.80680
- 1000+0.75600
