TXC CORPORATION
4F, NO. 16, Sec. 2 Chung Yang S Rd., Peitou, Taipei, Taiwan.
TEL : 886-2-2894-1202 , 886-2-2895-2201 FAX : 886-2-2894-1206 , 886-2-2895-6207
www.txccorp.com
SPECIFICATION FOR APPROVAL
CUSTOMER
PRODUCT TYPE
SMD SEAM SEALING X'TAL 2.5 × 2.0
NOMINAL FREQ.
24.000000MHz
TXC P/N
8Z24000017
REVISION
A2
CUSTOMER P/N
PM / SALES
DATE
CUSTOMER SIGNATURE & Date
(1) TXC requires one copy returned with signature and title of authorized individual that signifies acceptance
of the attached specifications.
(2) Orders received and accepted by TXC after return of signed copy of specification will be produced per
these specifications.
(3) Any changes to these specifications must be agreed upon by both parties and new revision of the
Product Specification Sheet will be issued.
(4) Any issuance of purchase order prior to consigning back the Approval page of "Specification Sheets"
from customers will be regarded as the agreement on the contents of these specifications.
Attachment: Product Specification Sheet
1
2
3
4
5
FMT-DOC024
RoHS Compliant
Issue Date: 12.15'08 VER.E
TXC CORPORATION
www.txccorp.com
PRODUCT SPECIFICATION SHEET
PRODUCT TYPE
NOMINAL FREQ.
24.000000MHz
TXC P/N
8Z24000017
REVISION
A2
PE/RD
QA
MFG
Robin Huang
Samson Xiong
Jake Liu
4-Aug-14
4-Aug-14
4-Aug-14
NOTE:
(1)Lead Free Products are "Directive 2002/95/EC of The European Parliament of 27 January 2003
on the restriction of the use of certain hazardous substances (RoHS) in electrical and
electronic equipment" Compliant (Attachment: SGS Test Report).
(2)Revision "Sx" is for engineering samples only. PE/RD's approval required.
(3)Revision "Ax" is production ready. PE, QA and MFG's approval required
RoHS Compliant
FMT-DOC024
TXC CORPORATION
Rev
Revise page
S1
N/A
A1
N/A
A2
4
FMT-DOC024
TXC P/N:
8Z24000017
REVISION: A2
PAGE: 1
Date
Ref.No.
Reviser
Initial released
20-Jul-12
N/A
Xiaoyan Jiang
S Turn A
28-Nov-13
N/A
Xiaoyan Jiang
Dimensions Change
4-Aug-14
ECR-14N080101
Xiaoyan Jiang
Revise contents
TXC CORPORATION
TXC P/N:
8Z24000017
REVISION:
A2
PAGE: 2
Spec Sheet Contents
No.
Content
Page
1
ELECTRICAL SPECIFICATIONS
P.3
2
FACTORY LOCATION
P.3
3
DIMENSIONS
P.4
4
MARKING
P.4
5
SUGGESTED REFLOW PROFILE& MANUAL SOLDER CONDITION
P.4
6
STRUCTURE ILLUSTRATION
P.5
7
EMBOSS CARRIER TAPE & REEL
P.6
8
PACKING
P.7
9
RELIABILITY SPECIFICATIONS&HANDING CAUTIONS
FMT-DOC024
P.8~9
TXC CORPORATION
8Z24000017
TXC P/N:
REVISION: A2
PAGE: 3
■ ELECTRICAL SPECIFICATIONS
Standard atmospheric conditions
Unless otherwise specified, the standard range of atmospheric conditions for making measurement
and tests are as follow:
Ambient temperature :
25±10℃
Relative humidity
40%~70%
If there is any doubt about the results, measurement shall be made within the following limits:
25±3℃
Relative humidity
40%~70%
Measure equipment
Electrical characteristics measured by S&A250B or equivalent.
Crystal cutting type
The crystal is using AT CUT (thickness shear mode).
Unit Weight:
0.009±0.001 g/pcs
Parameters
1 Nominal Frequency
Symbol
Electrical Spec.
Min.
Typ.
Max.
Notes
Units
FL
24.000000
MHz
Fundamental
CL
12
pF
4 Frequency Tolerance
±20
ppm
at 25 ℃ ± 3 ℃
5 Frequency Stability
±20
ppm
Over Operating Temp. Range (Reference 25℃)
6 Operating Temperature
7 Aging
2 Oscillation Mode
3 Load Capacitance
-20
70
±3
ppm
1st Year
8 Drive Level
DL
100
uW
9 Equivalent Series Resistance
Rr
50
Ω
10 Insulation Resistance
500
MΩ
11 Storage Temperature Range
-40
85
FMT-DOC024
at DC 100V
TXC CORPORATION
■ DIMENSIONS
8Z24000017
TXC P/N:
REVISION:
A2
PAGE: 4
2.50±0.10
(Unit:mm)
4
GND
4
3
2.00±0.10
3
2
2
4
GND
1.00
0.85
0.65 0.90
1
Connection
0.70±0.10
0.65±0.10
0.80±0.10
2
1
0.55MAX
1
3
0.9±0.10
■ MARKING
T□□□
TXC Logo
Pin 1 Location
Frequency Code
Ex. 24.000000 MHz =
240
Lot Code
Date Code
Line Code
Date Code:
MONTH
YEAR
JAN FEB MAR APR MAY JUN JUL AUG SEP OCT NOV DEC
2005
2009
2013
2017
A
B
C
D
E
F
G
H
J
K
L
M
2006
2010
2014
2018
N
P
Q
R
S
T
U
V
W
X
Y
Z
2007
2011
2015
2019
a
b
c
d
e
f
g
h
j
k
l
m
2008
2012
2016
2020
n
p
q
r
s
t
u
v
w
x
y
z
*This date code will be cycled every four years
Production location:Taiwan&Ningbo
■ SUGGESTED REFLOW PROFILE
Total time : 200 sec. Max.
Solder melting point :220 ℃
■ SUGGESTED MANUAL SOLDER CONDITION
Temperature: 350 ± 10 ℃
Time: 3 sec.
Re-solder times: twice
FMT-DOC024
TXC CORPORATION
TXC P/N:
8Z24000017
REVISION:
A2
PAGE: 5
■ STRUCTURE ILLUSTRATION
4
5
3
1
2
NO
COMPONENTS
MATERIALS
FINISH/SPECIFICATIONS
1 Lid
Kovar (Fe/Co/Ni)
2 Base(Package)
Ceramic (AI2O3) + Kovar (Fe/Co/Ni)+Pad(Au)
Tungsten metalize
+ Ni plating
+ Au plating
3 Crystal blank
SiO2
4 Conductive adhesive
Resin+Ag
5 Electrode
Noble Metal
FMT-DOC024
TXC CORPORATION
TXC P/N:
8Z24000017
REVISION: A2
PAGE: 6
■ PACKING
DIMENSIONS
A
B
C
D
E
F
G
H
1.05
2.70
2.25
4.00
8.00
4.00
1.55
1.75
(UNIT : mm)
REMARK :
DIMENSIONS
FMT-DOC024
L
L1
W
W1
178
13
11.5
8
pcs / Reel (UNIT : mm)
Standard Reel Quantity is 3,000 pcs per reel
TXC CORPORATION
TXC P/N:
8Z24000017
REVISION:
A2
PAGE:
7
■ PACKING
Reel Quantity :
1. Reel X 6 (6 Reels)
2. Reel X 12 (12 Reels)
3. Reel X 25 (12 Reels + 13 Reels)
4. Reel X 50 ( 12 Reelsx2 + 13 Reelsx2 )
Label B
Box Size:
1. L200 X W200 X H140mm
2. L200 X W200 X H250mm
3. L400 X W200 X H250mm
4. L400 X W400 X H280mm
Tape
Tape
Label A
Label B
QA Pass
(Label A) Size:100 X 100mm
(Lable B) Size:80 X 40mm
[STORAGE]
1.The storage time to be 1 year maximum.
2.Don't be caught in the rain.
3.The storage environment shall be 5℃ ~40℃ temperature and 30% ~ 75%RH humidity and free from the sun shine.
4.If customers have special requirements, we can paste labels according to it.
FMT-DOC024
TXC CORPORATION
TXC P/N:
8Z24000017
REVISION: A2
PAGE: 8
■ RELIABILITY SPECIFICATIONS
1.Mechanical Endurance
No.
Test Item
1 Drop Test
Test Methods
Test Criteria
A.C
150 cm height, 3 times on concrete floor.
1 Mechanical Shock
1 Vibration
Device are shocked to half sine wave ( 1000 G ) three mutually
perpendicular axes each 3 times. 0.5m sec. duration time
Frequency range
10 ~ 2000 Hz
Amplitude
1.52 mm/20G
Sweep time
20 minutes
perpendicular axes each test time
4 Hrs
A.C
A.C
(Total test time 12 Hrs)
1 Solder ability
Temperature
240 ℃ ± 5℃
Immersing depth
0.5 mm minimum
Immersion time
5 ± 1 seconds
Flux
Rosin resin methyl alcohol
E
solvent ( 1 : 4 )
2.Environmental Endurance
No.
Test Methods
Test Item
2 Resistance To Soldering Heat
Pre-heat temperature
125 ℃
Pre-heat time
60 ~ 120 sec.
Test temperature
260 ± 5 ℃
Test time
10 ± 1 sec.
2 High Temp. Storage
+ 125 ℃ ± 3 ℃ for 500 ± 12 Hrs
2 Low Temp. Storage
- 40 ℃ ± 3 ℃ for 500 ± 12 Hrs
Test Criteria
B.C.D
B.C.D
Total 100 cycles of the following temperature cycle
2 Thermal Shock
3 High Temp&Humidity
FMT-DOC024
B.C.D
85℃ ± 3℃, RH 85% , 500Hrs
B.C.D
TXC CORPORATION
TXC P/N:
8Z24000017
REVISION: A2
PAGE: 9
Specifications
A
Frequency change: Within ±5ppm or in customer's specification.
B
Frequency change: Within ±10ppm or in customer's specification.
C
Equivalent series resistance(E.S.R) change: Within ±15% or 10Ω(larger value).
D
After conditioning , quartz crystal units shall be subjected to standard atmospheric conditions for 2 hour, and
measured.
E
Minimum 95% of immersed terminal shall be covered with new uniform solder.
Measurement condition
FMT-DOC024
很抱歉,暂时无法提供与“8Z24000017”相匹配的价格&库存,您可以联系我们找货
