TLA 450V150 25.4*30
TLA 450V150 25.4*30
    SAMYOUNG(韩国三莹)
    插件,D25.4xL30mm
    贴片铝电解电容 AEC_D25.4X30MM_TM
TLA 450V150 25.4*30 数据手册
APPROVAL NO. 697-031 ALUMINUM ELECTROLYTIC CAPACITOR PAGE: 1 OF 5 DATE: 2016.11.01 Specifications of TLA Series Item Characteristics 160 ~ 500 VDC Rated Voltage Range Operating Temperature Range -25 ~ +105℃ ±20 % (M) Capacitance Tolerance (at 20℃, 120Hz) After 5 minutes, I = 0.02CV or 3mA, whichever is smaller Leakage Current Where, I : Leakage current(μA) (at 20℃) C: Nominal capacitance(μF) Dissipation Factor(TANδ) Rated voltage(VDC ) 160~500 (20℃,120Hz) Tanδ(Max) 0.20 Temperature Characteristics (at 120Hz,20℃) Rated voltage(V DC ) 160~400 420~500 Z-25℃/Z+20℃ 4 8 (Max.Impedance radio ) V : Rated voltage( VDC) (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage is applied for 3,000 hours at 105℃. Load Life Capacitance change: ≤±20% of the initial value Tanδ ≤200% of the initial specified value Leakage current ≤The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them at 105℃ for 1,000 hours without voltage applied. The rated voltage shall be appled to the capacitors for a minimum of 30 minutes,at least 24 Shelf Life hours and not more than 48 hours before the measurements. Capacitance change: ≤±20% of the initial value Others Tanδ ≤200% of the initial specified value Leakage current ≤The initial specified value Satisfied characteristics KS C IEC 60384-4 ※For capacitors with CV products>100,000, higher Tanδ value may apply. When the capacitance exceeds 1,000μF,0.01 shall be added every 1,000μF increase. DIMENSIONS OF TLA Series MARKING: BROWN SLEEVE, SILVER INK PC BOARD PIN-OUT 10±0.1 SAFETY VENT TLA 450V 82μF (M)105℃ LOT NO. Φ D+1 MAX SLEEVE 2-Φ2±0.1 MAX L± 2.0 5.8±1.0(VN) ※4.0±0.5(VS) FRONT VIEW OF BACK VIEW OF CAPACITOR CAPACITOR ← 李波 SamYoung Electronics Co., Ltd. ← ← 立范 波 阿吕 勇 PAGE: 2 OF 5 APPROVAL NO.: ALUMINUM ELECTROLYTIC CAPACITOR 697-031 RATINGS OF TLA Series WV (VDC ) CAP (μF) 330 390 470 560 680 820 160 1000 Case Size Ripple Current WV (mm) (Arms 105 ℃ (VDC) Φ×L /120Hz) 22×25 22×25 25.4×25 1.20 1.30 1.26 22×30 25.4×25 22×35 25.4×30 1.55 1.55 1.67 1.67 30×25 22×40 25.4×30 1.67 1.82 1.82 30×25 1.82 22×45 25.4×35 30×30 35×25 22×50 2.04 2.04 2.04 2.04 2.25 25.4×40 30×30 35×25 2.25 2.25 2.25 25.4×45 2.49 30×35 35×30 25.4×60 30×40 35×30 30×45 35×35 30×60 35×45 22×25 2.49 2.49 2.97 2.84 2.84 3.32 3.00 3.86 3.50 1.10 22×30 25.4×25 22×30 25.4×25 22×35 22×40 25.4×30 30×25 22×45 25.4×30 30×25 22×45 25.4×35 1.25 1.25 1.35 1.35 1.35 1.67 1.50 1.50 1.67 1.67 1.67 1.78 1.78 470 560 680 250 820 1000 1200 1500 1800 315 1200 1500 1800 2200 270 330 390 470 560 680 200 820 1000 1200 1500 1800 2200 180 CAP (μF) 390 470 680 1000 82 100 120 150 180 330 30×30 35×25 22×50 1.65 1.65 1.67 25.4×40 30×30 35×25 25.4×50 30×35 30×40 35×30 25.4×60 30×40 35×35 30×50 35×40 30×60 35×45 35×45 35×50 35×60 1.80 1.80 1.80 2.00 2.00 2.00 2.00 2.20 2.30 2.30 2.47 2.47 2.85 2.60 2.60 3.00 3.42 25.4×40 30×40 30×50 35×45 22×25 22×25 22×30 25.4×25 22×35 25.4×30 30×25 22×40 25.4×30 30×25 22×45 25.4×35 0.80 1.20 1.50 1.95 0.55 0.69 0.75 0.75 0.82 0.83 0.82 0.92 0.92 0.90 1.05 1.04 30×30 35×25 22×50 25.4×40 1.02 1.04 1.16 1.18 30×30 35×25 25.4×45 30×35 35×30 25.4×50 30×40 35×35 1.17 1.20 1.29 1.34 1.22 1.51 1.51 1.47 CAP (μF) 330 390 400 470 560 680 820 68 82 100 30×30 1.78 35×25 25.4×45 30×30 1.78 2.04 2.04 35×25 25.4×50 30×35 2.04 2.30 2.30 35×30 25.4×60 30×40 35×35 2.30 2.66 2.65 2.65 30×50 35×40 30×60 35×45 35×50 22×25 3.08 3.08 3.49 3.48 3.78 0.78 350 120 390 470 25.4×60 1.66 30×45 35×35 30×50 1.65 1.69 1.85 150 420 180 220 270 35×40 30×60 35×50 35×60 22×25 22×25 22×30 25.4×25 1.90 2.15 1.99 2.70 0.55 0.64 0.70 0.70 22×35 25.4×25 30×25 22×40 25.4×25 25.4×30 30×25 22×45 25.4×30 25.4×35 30×30 35×25 22×50 0.75 0.75 0.80 0.88 0.84 0.88 0.88 0.98 0.90 0.98 0.98 0.98 1.10 25.4×40 1.10 330 390 470 56 68 82 560 680 1000 68 82 100 120 150 22×25 1.00 25.4×25 22×30 25.4×25 22×35 25.4×25 25.4×35 0.95 1.18 1.18 1.30 1.18 1.30 30×25 1.30 30×30 1.10 22×35 22×40 25.4×35 1.37 1.49 1.49 35×25 25.4×45 30×35 1.00 1.22 1.22 30×25 22×45 1.49 1.65 180 400 100 120 150 180 450 220 270 220 250 330 370 390 390 470 270 35×30 1.22 25.4×50 1.44 560 470 25.4×35 1.65 330 Ripple Current WV (Arms105 ℃ (V DC) /120Hz) 30×30 30×40 35×30 25.4×50 25.4×60 30×45 35×35 30×50 35×35 35×40 30×60 35×45 35×50 35×60 35×60 22×25 22×25 25.4×25 22×30 25.4×25 1.10 1.44 1.44 1.46 1.51 1.60 1.60 1.90 1.75 1.90 2.10 2.12 2.15 2.27 2.36 0.50 0.64 0.58 0.70 0.70 22×35 25.4×30 30×25 0.75 0.75 0.73 CAP (μF) 56 68 82 100 500 120 150 220 270 270 330 Case Size (mm) Φ×L 180 220 220 270 Case Size Ripple Current WV (mm) (Arms105 ℃ (VDC) Φ×L /120Hz) 500 680 820 56 22×40 0.88 25.4×35 30×25 22×45 25.4×35 30×30 35×25 22×50 25.4×45 30×35 35×25 25.4×45 25.4×50 30×40 35×30 25.4×60 0.88 0.88 0.95 0.95 0.95 0.94 1.10 1.10 1.10 1.10 1.18 1.22 1.22 1.22 1.41 30×45 35×35 30×50 35×40 30×60 35×45 22×25 22×30 25.4×20 25.4×25 22×30 25.4×25 22×35 25.4×25 25.4×30 30×25 22×30 22×40 25.4×30 30×25 35×25 22×45 25.4×30 25.4×35 30×30 35×25 22×50 25.4×40 30×30 25.4×40 25.4×45 30×30 30×35 35×30 25.4×50 30×40 35×30 35×35 25.4×50 30×40 30×50 35×30 35×35 35×40 30×60 35×40 30×50 30×60 35×35 35×40 35×50 35×45 35×50 35×50 35×70 22×35 1.45 1.45 1.55 1.55 1.79 1.90 0.40 0.53 0.46 0.50 0.64 0.64 0.69 0.67 0.69 0.64 0.70 0.80 0.80 0.80 0.73 0.88 0.84 0.88 0.88 0.75 1.00 1.00 1.00 1.06 1.12 1.06 1.12 1.12 1.18 1.28 1.20 1.28 1.18 1.38 1.45 1.20 1.33 1.45 1.51 1.55 1.45 1.51 1.60 1.64 1.85 1.70 1.85 1.85 2.60 0.46 SamYoung Electronics Co., Ltd. 330 470 Case Size (mm) Φ×L Ripple Current (Arms105 ℃ /120Hz) 25.4×30 30×30 22×40 0.46 0.48 0.45 25.4×35 30×30 22×45 25.4×35 0.53 0.55 0.56 0.58 30×35 22×45 25.4×40 30×35 25.4×45 0.58 0.62 0.65 0.66 0.75 30×40 0.76 35×30 30×45 35×35 30×50 35×30 35×40 30×60 35×35 35×45 35×50 35×50 35×60 35×60 0.78 0.80 0.81 0.90 0.78 0.93 1.10 0.85 1.11 1.28 1.28 1.50 1.50 PAGE: 3 OF 5 APPROVAL NO. ALUMINUM ELECTROLYTIC CAPACITORS 697-031 STRUCTURE and MATERIALS AL RIVET AL TAB TERMINAL AL FOIL BAKE AL FOIL AL TAB AL CASE ADHESIVE TAPE SLEEVE ELEMENT SEPARATOR BOTTOM PLATE SAFETY VENT ※ LARGE SIZED TYPE CAPACITORS COMPONENT PART NAME AL RIVET TERMINAL BAKE AL TAB SLEEVE MATERIALS ALUMINUM 99.9 % SPCC (Pb-FREE) RUBBER + PAPER LAMINATE ALUMINUM 99.9 % OVER P.E.T(Poly Ethlylene Terephthalate Resin) BOTTOM PLATE P.P(Polypropylene) AL CASE ALUMINUM 99.5 % VENDER KYUNG-WON MECTRON/TNS (KOREA) (KOREA/CHINA) NAN TONG CHUANG JIA KYUNG-WON MECTRON/TNS NAN TONG CHUANG JIA JIANGYIN JINMA LVYE (CHINA) (KOREA) (KOREA/CHINA) ISOVOLTA FINE POLYMER NAN TONG CHUANG JIA TNS KISTRON SAMYOUNG (AUSTRIA) (KOREA) NANTONG HUIFENG DONG YANG MOODEUNG YUNLIN PLASTIC SHUN PENG PLASTIC SUZHOU QILIAN SUNG NAM D.N TECH/DONG NAM LINAN AOXING NANTONG XINLIAN/HAI BANG CHUANGJIA ELETROMECHANICAL NANTONG CHUANGJIA PONTIGGIA SAMYOUNG K.D.K/JCC/MATSUSHITA BECROMAL AL FOIL + AL FOIL - SEPARATOR ADHESIVE TAPE FORMED ALUMINUM 99.9 % OVER ETCHED ALUMINUM 99.8 % OVER INSULATION PAPER POLY PROPYLENE OR POLY IMIDE FILM (CHINA) (CHINA) (KOREA) (JAPAN) (KOREA) (CHINA) (KOREA) (KOREA) (CHINA) (ITALIA) (KOREA) (JAPAN) (ITALY) SATMA HUAFENG/NANTONG/RAOIO HEC XINJIANG JOINWORLD LUXON/LITON K.D.K (FRANCE) K-JCC AFT/INCULCU/SHENGHONG ELECON/WU JIANG FEILO N.K.K SPO (KOREA) LUNAN PAPER/KAN DAEIL/SWECO NICHIBAN SamYoung Electronics Co., Ltd. (CHINA) (TAIWAN) (JAPAN) (CHINA) (JAPAN) (GERMANY) (CHINA) (KOREA) (JAPAN) PAGE: 4 OF 5 When using aluminum electrolytic capacitors,pay strict attention to the following: 1. Electrolytic capacitors for DC application require polarization. Confirm the polarity.If used in reversed polarity,the circuit life may be shortened or the capacitor may be damaged.For use on circuits whose polarity is occasionally reversed,or whose polarity is unknown,use bi-polarized capacitors (BPseries).Also,note that the electrolytic capacitor cannot be used for AC application. 2. Do not apply a voltage exceeding the capacitor`s voltage rating. If a voltage execeeding the capacitor`s voltage rating is applied,the capacitor may be damaged as leakage current increases. When using the capacitor with AC voltage superimposed on DC voltage,care must be exercised that the peak value of AC voltage does not exceed the rated voltage. 3. Do not allow excessive ripple current to pass. Use the electrolytic capacitor at current values within the permissible ripple range.If the ripple current exceeds the specified value,request capacitors for high ripple current applications. 4. Ascertain the operating temperature range. Use the electrolytic capacitors according to the specified operating temperature range.Usage at room temperature will ensure longer life. 5. The electrolytic capacitor is not suitable for circuits in which charge and discharge are frequently repeated. If used in circuits in which charge and discharge are frequently repeated,the capacitance value may drop,or the capacitor may be damaged.Please consult our engineering department for assistance in these applications. 6. Apply voltage treatment to the electrolytic capacitor which has been allowed to stand for a long time. If the electrolytic capacitor is allowed to stand for a long time,its withstand voltage is liable to drop,resulting in increased leakage current.If the rated voltage is applied to such a product,a large leakage current occurs and this generates internal heat,which damaged the capacitor.If the electrolytic capacitor is allowed to stand for a long time,therefore,use it after giving voltage treatment (Note 1).(However,no voltage treatment is required if the electrolytic capacitor is allowed to stand for less than 2 or 3 years at normal temperature.) 7. Be careful of temperature and time when soldering. When soldering a printed circuit board with various,components,care must be taken that the soldering temperature is not too high and that the dipping time is not too long.Otherwise,there will be adverse effects on the electrical characteristics and insulation sleeve of electrolytic capacitors in the case of small-sized electrolytic capacitors,nothing abnormal will occur if dipping is performed at less than 260℃ for less than 10 seconds. 8. Do not place a soldering iron on the body of the capacitor. The electrolytic capacitor is covered with a vinyl sleeve.If the soldering iron comes in contact with the electrolytic capacitor body during wiring,damage to the vinyl sleeve and/or case may result in defective insulation,or improper protection of the capacitor element. 9. Cleaning circuit boards after soldering. Some solvents have adverse effects on capacitors. Please refer to the next page. 10.Do not apply excessive force to the lead wires or terminals. If excessive force is applied to the lead wires and terminals,they may be broken or their connections with the internal elements may be affectde.(For strength of terminals,refer to KS C IEC 60384-4(JIS C5101-1,JIS C5101-4) 11.Care should be used in selecting a storage area. If electrolytic capacitors are exposed to high temperatures caused by such things as direct sunlight,the life of the capacitor may be adversely affected.Storage in a high humidity atmosphere may affect the solderability of lead wires and terminals. 12.Surge voltage. The surge voltage rating is the maximum DC over-voltage to which the capacitor may be subjected for short periods not exceeding approximately 30 seconds at infrequent intervals of not more than six minutes.According to KS C IEC 60384 -4,the test shall be conducted 1000 cycles at room temperature for the capacitors of characteristic KS C IEC 60384-4 or at the maximum operating temperature for the capacitors of characteristics B and C of KS C IEC 60384-4 with voltage applied through a series resistance of 1000 ohms without discharge.The electrical characteristics of the capacitor after the test are specified in KS C IEC 60384-4.Unless otherwise specified,the rated surge voltage are as follows: Rated Voltage(V) 2 4 6.3 10 16 25 35 50 63 80 100 160 200 250 315 350 400 450 500 Rated Surge Voltage(V) 2.5 5 8 13 20 32 44 63 79 100 125 200 250 300 365 400 450 500 550 Note 1 Voltage treatment … Voltage treatment shall be performed by increasing voltage up to the capacitor`s voltage rating gradually while lowering the leakage current.In this case,the impressed voltage shall be in the range where the leakage current of the electrolytic capacitor is less than specified value.Meanwhile,the voltage treatment time may be effectively shortened if the ambient temperature is increased (within the operating temperature range). Note 2 For methods of testing, refer to KS C IEC 60384-4,(JIS C 5101-1,JIS C 5101-4) SamYoung Electronics Co., Ltd. PAGE: 5 OF 5 CLEANING CONDITIONS Aluminum electrolytic capacitors that have been exposed to halogenated hydrocarbon cleaning and defluxing solvents are susceptible to attack by these solvents.This exposure can result in solvent penetration into the capacitors, leading to internal corrosion and potential failure. Common type of halogenated cleaning agents are listed below. Structural Formula Chemical Nam e Representatice Brand Name Trichlorotrifluoroethane C 2CI3F3 Freon TF,Daiflon S-3 Fluorotrichlorom ethane CCI3F Freon-11,Daiflon S-1 1,1,1-Trichloroethane F2H3CI3 Chloroethane Trichloroethylene C 2HCI3 Trichiene Methyl Chloride CH 3CI MC We would like to recommend you the below cleaning materials for your stable cleaning condition taking the place of previous materials. ◎Isopropyl Alcohol(IPA) or Water Cleaning method: One of immersion, ultrasonic or vapor cleaning. Maximum cleaning time: 5 minutes(Chip type: 2 minutes) ※Do not use AK225AES Aluminum electrolytic capacitors are easily affeceted by halogen ions,particularly by chloride ions. Excessive amounts of halogen ions,if happened to enter the inside of the capacitors, will give corrosion accidents-rapid capacitance drop and vent open. The extent of corrosion accidents varies with kinds of electrolytes and seal-materials. Therefore, the prevention of halogen ion contamination is the most improtant check point for quality control in our procuction lines. At present, halogenated hydrocarboncontained organic solvents such as Trichloroethylene, 1,1,1-Trichloroethane, and Freon are used to remove flux from circuit boards. If electroytic capacitors are cleaned with such solvents,they may gradually penetrate the seal portion and cause the eosion.When using latex-based adhesive on the capacitors rubber end seal for adhesion to a PCB, corrosion may occur depending on the kind of solvent in the adhesive. Select an adhesive as an organic solvent with dissolved polymer that is not halogenated hydrocarbon. Hot air drying is required for eliminating the solvent between the product and the PCB at 50℃~80℃ after coating. Followings are the penetration path of the halogenated solvent. ① Penetration between the rubber and the aluminum case ② Penetration between the rubber and the lead wire ③ Penetration through the rubber The inside of the capacitors,the mechanism of corrosion of aluminum electrolytic capacitors by halogen ions can be explainedas follows: Halides(RX) are absorbed and diffused into the seal portion. The halides then enter the inside of the capacitors and contact with the electrolyte of the capacitors. Where by halogen ions are made free by a hydrolysis with water in the electrolyte: + - RX + H2O → ROH + H + X - The halogen ions (X ) react with the dielectric substance(Al2O3) of aluminum electrolytic capacitors: + - AI2O3 + 6H + 6X →2ALX3 + 3H2O AIX3 is dissociated with water: + - ALX3 + 3H2O → AL(OH)3 + 3H + 3X ※MANUFACTURING SITE ﹣SamYoung Electronics Co.,Ltd.(Korea/China) SamYoung Electronics Co., Ltd.
TLA 450V150 25.4*30 价格&库存
很抱歉,暂时无法提供与“TLA 450V150 25.4*30”相匹配的价格&库存,您可以联系我们找货
TLA 450V150 25.4*30
  • 1+16.36200
  • 10+14.24520
  • 30+12.92760
库存:1
