High-precision SMD VC-TCXO/TCXO〈For Automotive〉
DSA1612SDN/DSA211SDN/DSA221SDN/DSA321SDN
DSB1612SDN/DSB211SDN/DSB221SDN/DSB321SDN/DSB1612SDNB/DSB211SDNB/DSB221SDNB/DSB321SDNB
■ Features
● Low phase noise
● Single packaged structure
● Moisture prevention packing is unnecessary.
Moisture Sensitivity Level: LEVEL 1 (IPC/JEDEC J-STD-033)
● AEC-Q100 Compliant
■ Applications
● Telematics, Satellite radio
Actual size DSA1612SDN DSA211SDN
■ Standard Specification
Item
Frequency Range
16 to 60MHz 12.288 to 52MHz
TCXO
TCXO(Stand-by Function)
Size
DSB1612SDN
DSB1612SDNB
1612 size
DSA211SDN
DSB211SDN
DSB211SDNB
2016 size
DSA221SDN
DSB221SDN
DSB221SDNB
2520 size
DSA321SDN
DSB321SDN
DSB321SDNB
3225 size
TCXO
DSA221SDN
DSA321SDN DSB1612SDN DSB211SDN
9.6 to 52MHz
DSB221SDN
DSB321SDN
9.6 to 52MHz
DSB1612SDNB DSB211SDNB DSB221SDNB
DSB321SDNB
(Standーby Function)(Standーby Function)(Standーby Function) (Standーby Function)
9.6 to 52MHz
19.2MHz/26MHz/38.4MHz/40MHz/52MHz 16.3676MHz/16.367667MHz/16.368MHz/16.369MHz/16.8MHz/26MHz/33.6MHz
+1.68 to +3.5V
Supply Voltage Range
+1.8V/+2.6V/+2.8V/+3.0V/+3.3V
Supply Voltage(VCC)
Current Consumption
VC-TCXO
DSA1612SDN
VC-TCXO
Standard Frequency
RoHS/ELV Compliant
[Type]
DSA221SDN DSA321SDN
Type
Pb-Free
+1.5mA max.(f≦26MHz)/+2.0mA max.(26MHz<f≦52MHz)/+2.5mA max.(f≦60MHz)
Stand-by Current
+3μA max.
Output Level
0.8Vp-p min.(f≦52MHz)
(Clipped Sinewave/DC-coupled)
Output Load
10kΩ//10pF
Frequency Stability
Tolerance
±1.5×10-6 max.(After 2 reflows)
vs. Temperature
±0.5×10-6 max./-40 to +85℃
vs. Supply Voltage
±0.2×10-6 max.(Vcc ±5%)
vs. Load Variation
±0.2×10-6 max.(10kΩ//10pF±10%)
±1.0×10-6 max./year
vs. Aging
Frequency Control
Control Sensitivity
Response Slope
±3.0×10-6 to ±5.0×10-6/Vcont=+1.4V±1V @Vcc≧+2.6V
±3.0×10-6 to ±5.0×10-6/Vcont=+0.9V±0.6V @Vcc=+1.8V
Positive
2.0ms max.
Start up Time
Output Enable Time
Phase Noise
Offset
Offset
Offset
Offset
100Hz
1kHz
10kHz
100kHz
Reliability
Packing Unit
[f≦26MHz]
-115dBc/Hz
-130dBc/Hz
-150dBc/Hz
-155dBc/Hz
2.0ms max.
[26MHz<f≦40MHz]
-110dBc/Hz
-130dBc/Hz
-150dBc/Hz
-155dBc/Hz
[40MHz<f≦52MHz]
-105dBc/Hz
-125dBc/Hz
-145dBc/Hz
-150dBc/Hz
AEC-Q100
DSA1612SDN/DSA211SDN/DSA221SDN, DSB1612SDN/DSB211SDN/DSB221SDN, DSB1612SDNB/DSB211SDNB/DSB221SDNB: 3000pcs./reel(φ180)
DSA321SDN, DSB321SDN, DSB321SDNB: 2000pcs./reel(φ180)
Consult our sales representative for other specifications.
For Automotive Applications
■ Dimensions
[mm]
■ DSA1612SDN/DSB1612SDN/DSB1612SDNB
■ DSA211SDN/DSB211SDN/DSB211SDNB
Model Code
Model Code
Pin Connections
Pin No. Connection
A:VC-TCXO(DSA1612SDN)
B:TCXO(DSB1612SDN)
#1
C:TCXO
(DSB1612SDNB Stand-by Function)
Vcont(VC-TCXO)/GND(TCXO)
ENABLE/DISABLE(Stand-by Function)
GND
Output
Vcc
#2
#3
#4
1.6±0.1
Model Code
Frequency
#4
2.0±0.15
Model Code
GND
Output
VCC
Frequency
1.6±0.15
AN 26.0
D 701
D 701
#2
#1 Index
<Top View>
0.15
#4
0.90
1.20
0.60
0.95
0.35
1.80
0.60
#2
#3
#4
#3
0.35
<Top View>
0.40
(Index)
#1
0.50
#2
0.40 0.40 0.40
#1
■ Recommended
Land Pattern
0.80
0.14
(Index)
■ Recommended
Land Pattern
Lot No.
Logo
0.7±0.1
Lot No.
0.49±0.06
Logo
0.55
#1
0.40
1.2±0.1
#2
#3
#4
#3
A 26.0
#1 Index
Pin Connections
Pin No. Connection
AN : VC-TCXO (DSA211SDN)
BN : TCXO (DSB211SDN)
#1
CN : TCXO
(DSB211SDNB Stand-by Function)
1.20
1.40
■ DSA221SDN/DSB221SDN/DSB221SDNB
■ DSA321SDN/DSB321SDN/DSB321SDNB
Model Code
Model Code
Lot No.
1.90
#2
0.62
#4
#1 Index
Logo
#3
Lot No.
0.9±0.1
■ Recommended Land Pattern
<Top View>
1.95
0.75
#2
#3
#4
GND
Output
VCC
AN
701
#1
#2
#4
0.40
<Top View>
0.78
1.52
□0.20
(Index)
1.27
#1
□0.20
(Index)
#1
Frequency
0.82
Logo
Pin Connections
Pin No. Connection
3.2±0.15
2.5±0.15
701
0.8±0.1
0.50
Model Code
0.85
2.0±0.15
#1 Index
GND
Output
VCC
Frequency
2.5±0.15
AN
#2
#3
#4
1.35
Model Code
#1
AN : VC-TCXO (DSA321SDN)
BN : TCXO (DSB321SDN)
CN : TCXO(DSB321SDNB Stand-by Function)
1.40
AN : VC-TCXO (DSA221SDN)
BN : TCXO (DSB221SDN)
CN : TCXO(DSB221SDNB Stand-by Function)
0.90
Pin Connections
Pin No. Connection
#3
2.64
3.02
很抱歉,暂时无法提供与“1XXB16368MAA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+6.02640
- 10+4.86000
- 30+4.27680
- 100+3.63032
- 500+3.29163
- 1000+3.11170
