1XXB16369MBA
1XXB16369MBA
    KDS(大真空)
    SMD2520_4P
    有源晶振 SMD2520_4P
1XXB16369MBA 数据手册
High-precision SMD VC-TCXO/TCXO〈For Automotive〉 DSA1612SDN/DSA211SDN/DSA221SDN/DSA321SDN DSB1612SDN/DSB211SDN/DSB221SDN/DSB321SDN/DSB1612SDNB/DSB211SDNB/DSB221SDNB/DSB321SDNB ■ Features ● Low phase noise ● Single packaged structure ● Moisture prevention packing is unnecessary. Moisture Sensitivity Level: LEVEL 1 (IPC/JEDEC J-STD-033) ● AEC-Q100 Compliant ■ Applications ● Telematics, Satellite radio Actual size DSA1612SDN   DSA211SDN ■ Standard Specification Item Frequency Range 16 to 60MHz 12.288 to 52MHz TCXO TCXO(Stand-by Function) Size DSB1612SDN DSB1612SDNB 1612 size DSA211SDN DSB211SDN DSB211SDNB 2016 size DSA221SDN DSB221SDN DSB221SDNB 2520 size DSA321SDN DSB321SDN DSB321SDNB 3225 size TCXO DSA221SDN DSA321SDN DSB1612SDN DSB211SDN 9.6 to 52MHz 16 to 60MHz 12.288 to 52MHz DSB221SDN DSB321SDN 9.6 to 52MHz DSB1612SDNB DSB211SDNB DSB221SDNB DSB321SDNB (Standーby Function)(Standーby Function)(Standーby Function) (Standーby Function) 16 to 60MHz 12.288 to 52MHz 9.6 to 52MHz 19.2MHz/26MHz/38.4MHz/40MHz/52MHz 16.3676MHz/16.367667MHz/16.368MHz/16.369MHz/16.8MHz/26MHz/33.6MHz +1.68 to +3.5V Supply Voltage Range +1.8V/+2.6V/+2.8V/+3.0V/+3.3V Supply Voltage(VCC) Current Consumption VC-TCXO DSA1612SDN VC-TCXO DSA1612SDN DSA211SDN Standard Frequency RoHS/ELV Compliant [Type] DSA221SDN    DSA321SDN Type Pb-Free +1.5mA max.(f≦26MHz)/+2.0mA max.(26MHz<f≦52MHz)/+2.5mA max.(f≦60MHz) − Stand-by Current +3μA max. Output Level 0.8Vp-p min.(f≦52MHz) (Clipped Sinewave/DC-coupled) Output Load 10kΩ//10pF Frequency Stability Tolerance ±1.5×10-6 max.(After 2 reflows) vs. Temperature ±0.5×10-6 max./-40 to +85℃ vs. Supply Voltage ±0.2×10-6 max.(Vcc ±5%) vs. Load Variation ±0.2×10-6 max.(10kΩ//10pF±10%) ±1.0×10-6 max./year vs. Aging Frequency Control Control Sensitivity Response Slope ±3.0×10-6 to ±5.0×10-6/Vcont=+1.4V±1V @Vcc≧+2.6V ±3.0×10-6 to ±5.0×10-6/Vcont=+0.9V±0.6V @Vcc=+1.8V − Positive − 2.0ms max. Start up Time − Output Enable Time Phase Noise Offset Offset Offset Offset 100Hz 1kHz 10kHz 100kHz Reliability Packing Unit [f≦26MHz] -115dBc/Hz -130dBc/Hz -150dBc/Hz -155dBc/Hz 2.0ms max. [26MHz<f≦40MHz] -110dBc/Hz -130dBc/Hz -150dBc/Hz -155dBc/Hz [40MHz<f≦52MHz] -105dBc/Hz -125dBc/Hz -145dBc/Hz -150dBc/Hz AEC-Q100 DSA1612SDN/DSA211SDN/DSA221SDN, DSB1612SDN/DSB211SDN/DSB221SDN, DSB1612SDNB/DSB211SDNB/DSB221SDNB: 3000pcs./reel(φ180) DSA321SDN, DSB321SDN, DSB321SDNB: 2000pcs./reel(φ180) Consult our sales representative for other specifications. High-precision SMD VC-TCXO/TCXO〈For Automotive〉 For Automotive Applications ■ Dimensions [mm] ■ DSA1612SDN/DSB1612SDN/DSB1612SDNB ■ DSA211SDN/DSB211SDN/DSB211SDNB Model Code Model Code Pin Connections Pin No. Connection A:VC-TCXO(DSA1612SDN) B:TCXO(DSB1612SDN) #1 C:TCXO (DSB1612SDNB Stand-by Function) Vcont(VC-TCXO)/GND(TCXO) ENABLE/DISABLE(Stand-by Function) GND Output Vcc #2 #3 #4 1.6±0.1 Model Code Frequency #4 2.0±0.15 Model Code GND Output VCC Frequency 1.6±0.15 AN 26.0 D 701 D 701 #2 #1 Index <Top View> 0.15 #4 0.90 1.20 0.60 0.95 0.35 1.80 0.60 #2 #3 #4 #3 0.35 <Top View> 0.40 (Index) #1 0.50 #2 0.40 0.40 0.40 #1 ■ Recommended Land Pattern 0.80 0.14 (Index) ■ Recommended Land Pattern Lot No. Logo 0.7±0.1 Lot No. 0.49±0.06 Logo 0.55 #1 0.40 1.2±0.1 #2 #3 #4 #3 A 26.0 #1 Index Pin Connections Pin No. Connection AN : VC-TCXO (DSA211SDN) Vcont(VC-TCXO)/GND(TCXO) BN : TCXO (DSB211SDN) #1 ENABLE/DISABLE(Stand-by Function) CN : TCXO (DSB211SDNB Stand-by Function) 1.20 1.40 ■ DSA221SDN/DSB221SDN/DSB221SDNB ■ DSA321SDN/DSB321SDN/DSB321SDNB Model Code Model Code Lot No. 1.90 #2 0.62 #4 #1 Index Logo #3 Lot No. 0.9±0.1 ■ Recommended Land Pattern <Top View> 1.95 0.75 #2 #3 #4 Vcont(VC-TCXO)/GND(TCXO) ENABLE/DISABLE(Stand-by Function) GND Output VCC AN 701 #1 #2 #4 0.40 ■ Recommended Land Pattern <Top View> 0.78 1.52 □0.20 (Index) 1.27 #1 □0.20 (Index) #1 Frequency 0.82 Logo Pin Connections Pin No. Connection 3.2±0.15 2.5±0.15 701 0.8±0.1 0.50 Model Code 0.85 2.0±0.15 #1 Index Vcont(VC-TCXO)/GND(TCXO) ENABLE/DISABLE(Stand-by Function) GND Output VCC Frequency 2.5±0.15 AN #2 #3 #4 1.35 Model Code #1 AN : VC-TCXO (DSA321SDN) BN : TCXO (DSB321SDN) CN : TCXO(DSB321SDNB Stand-by Function) 1.40 AN : VC-TCXO (DSA221SDN) BN : TCXO (DSB221SDN) CN : TCXO(DSB221SDNB Stand-by Function) 0.90 Pin Connections Pin No. Connection #3 2.64 3.02
1XXB16369MBA 价格&库存
很抱歉,暂时无法提供与“1XXB16369MBA”相匹配的价格&库存,您可以联系我们找货
