TAIPAQ
P1
SMD Power Inductor
HPC4030NF-Series
ECN HISTORY LIST
REV
DATE
DESCRIPTION
APPROVED
CHECKED
DRAWN
1.0
17/04/19
新發行
羅宜春
梁周虎
張光
備
注
TAIPAQ
P2
SMD Power Inductor
HPC4030NF-Series
1. Features
1. Magnetic-resin shielded construction reduces buzz noise to ultra-low levels
2. Metallization on ferrite core results in excellent shock resistance and damage-free durability
Halogen
Pb
Halogen-free
Pb-free
3. Closed magnetic circuit design reduces leakage flux and Electro Magnetic Interference (EMI)
4. 30% higher current rating than conventional nductors of equal size
5. Takes up less PCB real estate and save more power
2. Applications
1. LED Lighting
2. Next-generation mobile devices with multifunction such as mobile TV and digital movie cameras
3. Flat-screen TVs, blue-ray disc recorders, set top box
4. Notebooks, desktop computers, servers, graphic cards cards
5. Portable gaming devices, personal navigation systems, personal multimedia devices
6. Automotive systems
7. Telecomm base stations
Recommendend Land pattern
3. Dimension
100
Series
HPC4030NF
*A(mm) *B(mm)
4.0±0.2
E(mm)
a(mm)
b(mm)
c(mm)
4.0±0.2 3.0Max. 1.35±0.3 3.4±0.2
C(mm)
D(mm)
1.3Typ
1.5Typ
3.7Typ
*Dimensions are not including the termination. For maximum overall dimensions
with ternmination , add 0.1mm.
4. Part Numbering
HPC
4030
NF
A
B
C
A: Series
B: Dimension
C: Type
D: Inductance
E: Inductance Tolerance
100
M
D
E
Note: 1. The above PCB layout reference only.
2. Recommend solder paste thickness at
0.12mm and above.
A/B*C
1R0=1.00uh 100=10uh,101=100uh,102=1000uh
K=±10%, L=±15%,M=±20%,Y=±30%.
marking direction cannot decide polarity. Color: Black, unidirectional.
magnetic shielding
TAIPAQ
P3
5. Specification
Rated current
Tempetature
current
I rms (A)
Saturation
current
I sat (A)
DCR
(mΩ)
@25℃
±20%.
0.68
4.60
6.80
10
HPC4030NF-1R0M
1.00
4.20
5.30
14
HPC4030NF-1R5M
1.50
3.40
4.90
HPC4030NF-2R2M
2.20
3.00
4.90
30
HPC4030NF-3R3M
3.30
2.40
3.30
40
HPC4030NF-4R7M
4.70
2.05
2.90
60
HPC4030NF-5R6M
5.60
1.95
2.60
65
HPC4030NF-6R8M
6.80
1.80
2.75
90
HPC4030NF-8R2M
8.20
1.60
2.10
90
HPC4030NF-100M
10.0
1.50
2.00
100
HPC4030NF-120M
12.0
1.30
1.80
135
HPC4030NF-150M
15.0
1.20
1.70
190
HPC4030NF-180M
18.0
1.10
1.50
200
HPC4030NF-220M
22.0
1.00
1.30
225
HPC4030NF-330M
33.0
0.85
1.10
330
HPC4030NF-470M
47.0
0.72
0.95
445
Part Number
Inductance
L0 (uH)±20%
@0A
HPC4030NF-R68M
Note:
1. All test data referenced to 25℃ ambient , Ls:100KHz/1V.
2. Testing Instrument : HP4284A,CH11025,CH3302,CH1320 ,CH1320S LCR METER / Rdc:CH502BC MICRO OHMMETER.
3. Heat Rated Current (Irms) will cause the coil temperature rise approximately Δt of 40℃.
4. Saturation Current ( Isat ) will cause L0 to drop approximately 30%.
5. The part temperature (ambient + temp rise) should not exceed 125℃under worst case operating conditions.Circuit design,component,PCB trace size and
thickness,airflow and other cooling provisions all affect the part temperature. Part temperature should be verified in the end application.
6. Special inquiries besides the above common used types can be met on your requirement.
TAIPAQ
P4
5. Material List
e
b
a
c
d
NO
Items
Materials
a
Core
Ferrite Core
b
Wire
Enameled Copper Wire
c
Glue
Epoxy with magnetic powder
d
Terminal
Ag/Ni/Sn+ Sn Solder
e
Ink
Halogen-free ketone
6. Reliability and Test Condition
Item
Performance
Operating temperature
-40~+125℃ (Including self - temperature rise)
Storage temperature
1.-10~+40℃,50~60%RH (Product without taping)
2.-40~+125℃ (on board)
Test Condition
Electrical Performance Test
Inductance
Refer to standard electrical characteristics list.
DCR
HP4284A,CH11025,CH3302,CH1320,CH1320S
LCR Meter.
CH16502,Agilent33420A Micro-Ohm Meter.
Saturation Current (Isat)
Approximately △L30%.
Saturation DC Current (Isat) will cause L0
to drop △L(%)
Approximately △T40℃
△T(℃) without core loss.
1.Applied the allowed DC current.
2.Temperature measured by digital surface thermometer
Reliability Test
Life Test
Load Humidity
Moisture Resistance
Thermal
shock
Vibration
Appearance:No damage.
Inductance:within±10% of initial value
Q:Shall not exceed the specification value.
RDC:within ±15% of initial value and shall not
Preconditioning:
Run
through
IR
reflow
for
times.( IPC/JEDEC
J-STD-020DClassification Reflow Profiles)
Temperature: 125±2℃(Inductor)
Applied current:rated current
Duration:1000±12hrs
Measured at room temperature after placing for 24±2 hrs
2
Preconditioning:
Run
through
IR
reflow
for
times.( IPC/JEDEC
Humidity:85±2﹪R.H,
Temperature:85℃±2℃
Duration:1000hrs Min. with 100% rated current
2
Preconditioning:
Run
through
IR
reflow
for
2
times.( IPC/JEDEC J-STD-020DClassification Reflow
Profiles
1. Baked at50℃ for 25hrs, measured at room temperature
after placing for 4 hrs.
2. Raise temperature to 65±2℃ 90-100%RH in 2.5hrs, and
keep 3 hours, cool down to 25℃ in 2.5hrs.
3. Raise temperature to 65±2℃ 90-100%RH in 2.5hrs, and
2.5hrs,keep at 25℃ for 2 hrs then keep at -10℃ for 3 hrs
4. Keep at 25℃ 80-100%RH for 15min and vibrate at the
frequency of 10 to 55 Hz to 10 Hz, measure at
room temperature after placing for 1~2 hrs.
Preconditioning:
Run
through
IR
reflow
for
Reflow Profiles
Condition for 1 cycle
Step1:-40±2℃ 30±5min
Step2:25±2℃ ≦0.5min
Step3:125±2℃ 30±5min
Number of cycles: 500
Oscillation Frequency: 10~2K~10Hz for 20 minutes
Equipment: Vibration checker
Total Amplitude:1.52mm±10%
Testing Time : 12 hours(20 minutes, 12 cycles each of 3
orientations)。
2
TAIPAQ
P5
Item
Performance
Test Condition
Type
Peak
value
(g’s)
Normal
duration (D)
(ms)
SMD
1500
0.5
Half-sine
15.4
Lead
100
6
Half-sine
12.3
Shock
Bending
Solderability
More than 95% of the terminal electrode should
be covered with solder。
Wave
form
Velocity
change
(Vi)ft/sec
Shall be mounted on a FR4 substrate of the
following dimensions: >=0805:40x100x1.2mm
=0805:1.2mm
0805:1kg ,
很抱歉,暂时无法提供与“HPC4030NF-4R7M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.62252
- 100+0.49799
- 300+0.43578
