RJA100M2ASA-0611
RJA100M2ASA-0611
    LELON(立隆电子)
    插件,D6.3xL11mm
    直插铝电解电容 AEC_D6.3X11MM_TM
RJA100M2ASA-0611 数据手册
Aluminum Electrolytic Capacitors RJA Features ‧ 105℃, wide temperature range ‧ Suitable for high reliability products ‧ RoHS Compliance Sleeve & Marking Color: Deep Purple & White SPECIFICATIONS Items Category Temperature Range Capacitance Tolerance Leakage Current (at 20℃) Performance -55℃ ~ +105℃ ±20% I = 0.01CV or 3 (μ A) whichever is greater (after 2 minutes) Where, C = rated capacitance in μF V = rated DC working voltage in V Dissipation Factor (Tanδ at 120 Hz, 20℃) (at 120Hz, 20℃) Rated Voltage 6.3 10 16 25 35 50 63 100 Tanδ(max) 0.23 0.20 0.16 0.14 0.12 0.10 0.09 0.08 When the capacitance exceeds 1,000μ F, 0.02 shall be added every 1,000μ F increase. Impedance ratio shall not exceed the values given in the table below. Rated Voltage 6.3 10 16 25 35 50 63 Z(-25℃) φD<16 4 3 3 2 2 2 2 Impedance /Z(+20℃) φD≧16 5 4 3 2 2 2 2 Z(-40℃) φD<16 Ratio 8 6 4 4 4 3 3 /Z(+20℃) φD≧16 12 8 6 4 3 3 3 Low Temperature Characteristics (at 120Hz) 100 2 3 3 6 Test Time 2,000 Hrs Within ±20%of initial value Capacitance Change Dissipation Factor Less than 200% of specified value Leakage Current Within specified value * The above specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage applied with rated ripple current for 2,000 hours at 105℃. Endurance Test Time 1,000 Hrs Within ±20%of initial value Capacitance Change Dissipation Factor Less than 200% of specified value Leakage Current Within specified value * The above specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 105℃ without voltage applied. Shelf Life Test Freq.(Hz) Cap.(μ F) Under 100 100 < C ≦ 1,000 Ripple Current & Frequency Multipliers 1,000 up above 60 (50) 120 500 1k 10k up 0.70 0.75 0.80 1.00 1.00 1.00 1.30 1.20 1.10 1.40 1.30 1.12 1.50 1.35 1.15 DIAGRAM OF DIMENSIONS Sleeve 2011 Version φD+βmax LEAD SPACING AND DIAMETER φD P 15 min 4 min P±0.5 L+α max φd Ven≧6.3φ φd α β 5 2.0 6.3 2.5 0.5 8 3.5 10 5.0 0.6 Unit: mm 12.5 5.0 16 7.5 18 7.5 0.8 1.0 1.5 0.5 22 10 1.0 2.0 Aluminum Electrolytic Capacitors Dimension: φD × L(mm) Ripple Current: mA/rms at 120 Hz, 105°C DIMENSION & PERMISSIBLE RIPPLE CURRENT V. DC µF 10 Contents 100 6.3V (0J) φD×L mA *φD×L 10V (1A) mA φD×L RJA mA *φD×L 16V (1C) mA φD×L mA 5×11 25V (1E) φD×L mA 36 5×11 40 *φD×L mA 22 220 5×11 58 5×11 68 33 330 5×11 71 5×11 78 47 470 5×11 97 100 101 5×11 103 6.3×11 142 220 221 6.3×11 160 5×11 330 331 8×11.5 219 6.3×11 470 471 8×11.5 261 6.3×11 1,000 102 10×12.5 455 8×11.5 2,200 222 10×20 750 3,300 332 12.5×20 920 10×20 4,700 472 16×25 1,330 12.5×20 φD×L mA mA V. DC µF Contents 5×11 76 5×11 90 5×11 105 6.3×11 133 5×11 110 140 6.3×11 175 5×11 150 8×11.5 215 6.3×11 180 190 8×11.5 245 6.3×11 200 8×11.5 260 230 8×11.5 290 6.3×11 250 10×12.5 370 8×11.5 380 10×16 550 10×12.5 460 10×20 640 12.5×20 860 10×20 760 12.5×25 840 12.5×20 1,100 1,090 16×25 1,400 12.5×25 1,260 φD×L mA mA φD×L mA 35V (1V) *φD×L 8×11.5 236 335 8×11.5 330 310 10×16 440 10×12.5 380 10×16 560 12.5×20 770 10×20 680 1,000 12.5×20 920 16×25 1,170 12.5×25 1,090 16×25 1,300 12.5×25 1,170 16×31.5 1,460 16×25 1,400 16×31.5 1,600 16×25 1,480 18×35.5 1,780 16×31.5 1,710 mA φD×L mA 63V (1J) *φD×L 100V (2A) *φD×L mA 66 6.3×11 54 111 6.3×11 93 183 8×11.5 144 0.1 0R1 5×11 1.3 5×11 2.1 5×11 2.4 0.22 R22 5×11 2.9 5×11 3.2 5×11 3.8 0.33 R33 5×11 4.3 5×11 5.4 5×11 5.8 0.47 R47 5×11 7.1 5×11 7.1 5×11 7.1 1 010 5×11 13 5×11 15 5×11 15 2.2 2R2 5×11 20 5×11 30 5×11 26 3.3 3R3 5×11 30 5×11 31 5×11 31 4.7 4R7 5×11 33 5×11 36 6.3×11 40 10 100 5×11 45 5×11 50 5×11 54 8×11.5 22 220 5×11 71 5×11 78 6.3×11 86 8×11.5 33 330 6.3×11 90 6.3×11 96 5×11 90 8×11.5 141 6.3×11 100 10×12.5 6.3×11 117 6.3×11 129 5×11 85 47 470 6.3×11 105 5×11 90 8×11.5 130 100 101 8×11.5 170 6.3×11 150 8×11.5 188 220 221 10×12.5 300 8×11.5 270 10×20 355 10×16 330 331 10×16 400 10×12.5 350 10×20 460 470 471 10×20 520 10×16 460 12.5×25 1,000 102 12.5×25 920 12.5×20 830 2,200 222 16×31.5 1,340 16×25 3,300 332 18×35.5 1,650 16×35.5 4,700 472 18×40 1,900 18×35.5 1,900 mA 10×12.5 50V (1H) *φD×L *φD×L 8×11.5 151 10×12.5 235 10×16 193 10×12.5 204 12.5×20 320 10×20 335 10×20 400 10×16 285 360 16×25 507 13×25 10×16 410 12.5×20 520 440 10×20 490 16×31.5 674 16×25 610 10×20 530 12.5×25 478 720 12.5×20 665 18×35.5 880 16×31.5 16×25 1,080 12.5×25 980 16×31.5 688 1,260 16×25 1,190 1,260 18×35.5 1,530 16×35.5 1,470 1,610 22×40 1,707 18×35.5 1,650 2011 Verison
RJA100M2ASA-0611 价格&库存
很抱歉,暂时无法提供与“RJA100M2ASA-0611”相匹配的价格&库存,您可以联系我们找货
