SR04X1001FTL
SR04X1001FTL
    WALSIN(华新科)
    贴片电阻 0402
SR04X1001FTL 数据手册
Approval sheet SR12, SR10, SR08, SR06, SR04 1%, 5% Thick Film High Grade General Purpose Chip Resistors Size 1206, 1210, 0805, 0603, 0402 Automotive & Military Qualified Anti-Sulfuration *Contents in this sheet are subject to change without prior notice. Page 1 of 9 ASC_SR_V05 JAN 2018 Approval sheet FEATURE 1. High reliability and stability ±1% 2. Sulfuration resistant ASTM B-809 105’C 750hrs 3. Automotive AEC Q-200 & Military MIL-STD qualified 4. 100% CCD inspection 5. RoHS compliant and Halogen free products APPLICATION  Automotive application  Consumer electrical equipment  EDP, Computer application  Telecom application DESCRIPTION The resistors are constructed in a high grade ceramic body (aluminum oxide). Internal metal electrodes are added at each end and connected by a resistive paste that is applied to the top surface of the substrate. The extra protective metal film is added onto top side electrodes to protect termination from sulfuration. The composition of the paste is adjusted to give the approximate resistance required and the value is trimmed to within tolerance by laser cutting of this resistive layer. The resistive layer is covered with a protective coat. Finally, the two external end terminations are added. For ease of soldering the outer layer of these end terminations is a Tin (lead free) alloy. Fig 1. Construction of a Chip-R Page 2 of 9 ASC_SR_V05 JAN 2018 Approval sheet QUICK REFERENCE DATA Item General Specification Series No. SR10 SR12 SR08 SR06 SR04 Size code 1210(3225) 1206(3216) 0805(2012) 0603(1608) 0402(1005) Resistance Range 1~10M (5% tolerance), Jumper 1~10M (1% tolerance) Resistance Tolerance 1% 5% 1% 5% 1% 5% 1% 5% 1% 5% E96/E24 E24 E96/E24 E24 E96/E24 E24 E96/E24 E24 E96/E24 E24 TCR (ppm/C) R > 1M   200   200   200   200   200 10 < R ≦ 1M   100   100   100   100   100 -200~+400 -200~+400 -200~+400 -200~+400 -200~+400 Max. dissipation @ Tamb=70C 1/2 W 1/4 W 1/4 W 1/10 W 1/10 W Max. Operation Voltage (DC or RMS) 200V 200V 150V 75V 50V Max. Overload Voltage (DC or RMS) 400V 400V 300V 150V 100V R ≦ 10 Operation temperature -55 ~ +155C Note : 1. Max. Operation Voltage : So called RCWV (Rated Continuous Working Voltage) is determined by RCWV  RatedPower  Resistance Value or Max. RCWV listed above, whichever is lower. DIMENSIONS (unit : mm) SR10 SR12 SR08 SR06 SR04 L 3.10  0.10 3.10  0.10 2.00  0.10 1.60  0.10 1.00  0.05 W 2.60  0.10 1.60  0.10 1.25  0.10 0.80  0.10 0.50  0.05 t 0.55  0.10 0.60  0.15 0.50  0.15 0.45  0.15 0.35  0.05 d 0.50  0.20 0.45  0.20 0.40  0.20 0.30  0.15 0.25  0.10 c 0.50  0.20 0.50  0.20 0.40  0.20 0.30  0.10 0.20  0.10 Page 3 of 9 ASC_SR_V05 JAN 2018 Approval sheet MARKING 5% 1% 1210/1206/0805 3-digits marking 4-digits marking 0603 (1608) 3-digits marking 3-digits marking Size \ Nr. Of digit of code\tolerance N0 MARKING 0402(1005) 3-digits marking(5% : 1210 & 1206 & 0805 & 0603 ) Each resistor is marked with a three digits code on the protective coating to designate the nominal resistance value. 3-digits marking(1% : 0603) Nominal resistance Description 1.E-24 series As 0603 WR06X 5%. 2.E-96 series The 1st two digit codes are referring to the CODE on the table, the 3rd code is the index of resistance value : Y=10-2,X=10-1,A=100,B=101,C=102,D=103,E=104,F=105 EX : 17.8Ω=25X,178Ω=25A,1K78 =25B 17K8=25C, 178K=25D, 1M78=25E 3. Remark There is no marking for the items are not under E-24 and E-96 series CODE R_value CODE R_value CODE R_Value CODE R_value CODE R_value CODE R_value CODE R_value CODE R_value 01 100 13 133 25 178 37 237 49 316 61 422 73 562 85 750 02 102 14 137 26 182 38 243 50 324 62 432 74 576 86 768 03 105 15 140 27 187 39 249 51 332 63 442 75 590 87 787 04 107 16 143 28 191 40 255 52 340 64 453 76 604 88 806 05 110 17 147 29 196 41 261 53 348 65 464 77 619 89 825 06 113 18 150 30 200 42 267 54 357 66 475 78 634 90 845 07 115 19 154 31 205 43 274 55 365 67 487 79 649 91 866 08 118 20 158 32 210 44 280 56 374 68 499 80 665 92 887 09 121 21 162 33 215 45 287 57 383 69 511 81 681 93 909 10 124 22 165 34 221 46 294 58 392 70 523 82 698 94 931 11 127 23 169 35 226 47 301 59 402 71 536 83 715 95 953 12 130 24 174 36 232 48 309 60 412 72 549 84 732 96 976 4-digits marking(1% : 1210/1206/0805) Each resistor is marked with a four digits code on the protective coating to designate the nominal resistance value. Example RESISTANCE 10 12 100 6800 47000 3-digits marking(1210/1206/0805/0603 5% ) 100 120 101 682 473 10R0 12R0 1000 6801 4702 4-digits marking Page 4 of 9 ASC_SR_V05 JAN 2018 Approval sheet FUNCTIONAL DESCRIPTION Product characterization Standard values of nominal resistance are taken from the E24 series for resistors with a tolerance of 5%, and E96 series for resistors with a tolerance of 1%. The values of the E24/E96 series are in accordance with “IEC publication 60063” Derating The power that the resistor can dissipate depends on the operating temperature; see Fig.2 Figure 2 Maximum dissipation in percentage of rated power as a function of the ambient temperature MOUNTING Due to their rectangular shapes and small tolerances, Surface Mountable Resistors are suitable for handling by automatic placement systems. Chip placement can be on ceramic substrates and printed-circuit boards (PCBs). Electrical connection to the circuit is by individual soldering condition. The end terminations guarantee a reliable contact. Page 5 of 9 ASC_SR_V05 JAN 2018 Approval sheet SOLDERING CONDITION The robust construction of chip resistors allows them to be completely immersed in a solder bath of 260C for 10 seconds. Therefore, it is possible to mount Surface Mount Resistors on one side of a PCB and other discrete components on the reverse (mixed PCBs). Surface Mount Resistors are tested for solderability at 235C during 2 seconds. The test condition for no leaching is 260C for 30 seconds. Typical examples of soldering processes that provide reliable joints without any damage are given in Fig 3. Fig 3. Infrared soldering profile for Chip Resistors CATALOGUE NUMBERS The resistors have a catalogue number starting with . SR12 Automotive code SR10 : 1210 SR12 : 1206 SR08 : 0805 X 472_ T L Type code Resistance code Tolerance Packaging code Termination code X: 5%, E24: 2 significant digits F : 1% T L = Sn base Jumper followed by no. of J : 5% Q : 10” Reeled taping 5%, 1 ~ 10M zeros and a blank P : Jumper G : 13” Reeled taping 1%, 10 ~ 1M 220 = 221_ W: (“_” means a blank) SR06 : 0603 SR04: 0402 J 1%, < 10; >1M B : 7” Reeled taping (lead free) : Bulk 1%, E24+E96: 3 significant digits followed by no. of zeros E24: 102 = 1020 E96: 37.4K = 3742 * Anti-Sulfur test conditions: ASTM B-809 105’C, RH 90%, 750hrs, acceptance criteria: +/-2.0%. SR10, SR12, SR08, SR06: 1. Reeled tape packaging : 8mm width paper taping 5000pcs per 7” reel, 10kpcs per 10” reel, 20kpcs per 13” reel. 2. Bulk packaging : 5000pcs per poly-bag SR04: 1. Reeled tape packaging : 8mm width paper taping 10,000pcs per reel. 2. Bulk packaging Page 6 of 9 : 10,000pcs per poly-bag ASC_SR_V05 JAN 2018 Approval sheet TEST AND REQUIREMENTS Essentially all tests are carried out according to the schedule of IEC publication 115-8, category LCT/UCT/56(rated temperature range : Lower Category Temperature, Upper Category Temperature; damp heat, long term, 56 days). The testing also meets the requirements specified by EIA, EIAJ and JIS. The tests are carried out in accordance with IEC publication 68, “Recommended basic climatic and mechanical robustness testing procedure for electronic components” and under standard atmospheric conditions according to IEC 60068-1, sub-clause 5.3. Unless otherwise specified, the following value supplied : Temperature: 15°C to 35°C. Relative humidity: 45% to 75%. Air pressure: 86kPa to 106 kPa (860 mbar to 1060 mbar). All soldering tests are performed with midly activated flux. TEST Electrical Characteristics - DC resistance values measurement JISC5201-1: 1998 Clause 4.8 REQUIREMENT PROCEDURE / TEST METHOD Resistor 0 Within the specified tolerance - Temperature Coefficient of Resistance (T.C.R) Refer to “QUICK REFERENCE Natural resistance change per change in degree centigrade. DATA” R2  R1  106 R1 t2  t1  (ppm/C) t1 : 20°C+5°C-1°C R1 : Resistance at reference temperature R2 : Resistance at test temperature Resistance to soldering Un-mounted chips completely immersed for 10±1second in a SAC R/R max. (0.5%+0.05) heat (R.S.H) solder bath at 270℃±5ºC No visible damage
SR04X1001FTL 价格&库存
很抱歉,暂时无法提供与“SR04X1001FTL”相匹配的价格&库存,您可以联系我们找货
