BC43-100K(CD)
BC43-100K(CD)
    BC(台湾诚阳)
    SMD,4.3x4.8mm
    功率电感 SMD
BC43-100K(CD) 数据手册
ROH S Compliant 承 認 書 SPECIFICATION FOR APPROVAL CUSTOMER: CUSTOMER P/N PART NO: DESCRIPTION: PRODUCTS NO: PRODUCTS REV: DATE: SMD POWER INDUCTORS BC43-100K 01 2018-6-11 PURCHASER CONFIRMED. APPROVAL BY CHECK BY DRAWN BY REMARK PROVIDER ENGINEER DEPT. APPROVAL BY CHECK BY chenlinli 誠 陽 實 業 有 限 公 司 TAIPEI OFF ICE TAIWAN CHENG YANG COMPONENT CORP 2F-1, NO. 176, Chine-Yi Road., Zhonghe District, New Taipei City, TAIWAN(R.O.C) 新北市中和區建一路 176 號 2 樓之一 POSTAL CODE: 23500 TEL NO.:+886-2- 8228-0930 FAX NO.:+886-2-8228-0929 E-mail:h21803@ms29.hinet.net 寶 誠 電 子 有 限 公 司 CHINA FACTORY ZHUHAI BAO CHENG ELECTRONICSCO.,LTD Guan Tang Industrial Park, Tang Jia Wan Town, Zhuhai City, Guangdong Province, CHINA 中國廣東省珠海市塘家灣鎮官塘工業區 POSTAL CODE: 519085 TEL NO:86-756-3383187 FAX NO:86-756-3380704 E-mail: baocheng@baocheng.biz 昆 山 誠 陽 電 子 有 限 公 司 CHINA FACTORY KUNSHAN CHENG YANG ELECTRONICSCO.,LTDP Qiang-An Road., High-Tech. Industrial Park, Kunshan City, Jiangsu Province, China 江蘇省昆山市高科技工業園區強安路 35 號 POSTAL CODE: 215300 TEL NO:86-512-57823500 FAX NO:86-512-57823503 E-mail: kscy@taiwan-chengyang.com.tw ROHS Compliant TEST DATA DIMENSION&ELECTRIC CHARACTER CUSTOMER: PART NO.: DESCRIPTION: SMD INDUCTOR SERIES NO: BC43-100K 1.MECHANICAL DIMENSION UNIT:mm 100 2.RECOMMEND LAND PATTERN DIMENSIONS A 4.3MAX B 3.5MAX C 4.8MAX D 1.2TYP E F G H I 3.SEPCIFICATIONS Part Number L(0A) Inductance 10(uH)±10% @2.52MHZ BC43-100K 10 Rdc (mOHM) Typical Max 149.53 182 Heat Rating Current DC Amps.Idc(A) Saturation Current DC Amps.ldc(A) Typical Typical 1.25 1.15 (1). All test data is referenced to 25℃ ambient. (2). Operating Tenperature Rangr-30℃ to +100℃. (3). DC current(1.25A)that will cause an approximate△T of 40℃. (4). DC current(1.15A)that will cause Lo to drop approximately 10%. (5). The part temperature(ambient+temp rise)should not exceed 100℃ under worst case operating conditions.Circuit design,component placement,PWB trace size and thickness,airflow and other cooting provisions all affsct the part temperature part temperature should be verified in the end appliation. 4.PACKAGING INFORMATION parts are packaged on 13"reels 1500 parts per reel. A0= 4.2mm B0= 4.8mm K0= 3.6mm APPROVED BY: CHECKED BY: Yasir DRAWN BY: chenlinli Rohs Compliant ZHUHAI BAOCHENG ELECTRONICS CO.,LTD TEST DATA FOR PREPRODUCTION SAMPLE CUSTOMER: CUSTOMER P/N: PART NAME: SMD INDUCTOR CY PART NO:BC43-100K TEST ITEM SPEC. A B C 4.30 3.50 4.80 E F TEST DATE:2018-6-11 CY REV: QUANTITY:20PCS G H I J MAX MAX MAX 01 4.08 3.20 4.26 02 4.08 3.18 4.27 03 4.07 3.17 4.28 04 4.08 3.18 4.28 05 4.08 3.21 4.27 06 4.06 3.19 4.28 07 4.07 3.18 4.27 08 4.07 3.17 4.27 09 4.07 3.19 4.28 10 4.09 3.17 4.28 11 4.06 3.19 4.28 12 4.07 3.18 4.27 13 4.07 3.17 4.27 14 4.07 3.19 4.28 15 4.09 3.17 4.28 X 4.07 3.18 4.27 σ 0.009 0.012 0.006 8.57 28.32 Cpk D CUSTOMER REV: 8.95 APPROVED BY CHECKED BY PREPARED BY Yasir chenlinli K Rohs Compliant ZHUHAI BAOCHENG ELECTRONICS CO.,LTD TEST DATA FOR PREPRODUCTION SAMPLE CUSTOMER P/N: CUSTOMER: CUSTOMER REV: TEST DATE:2018-6-11 PART NAME:SMD INDUCTOR CY PART NO:BC43-100K TEST ITEM L(0A) TEST 2.52MHZ 0.25V CONDITION L(1.15A)/L(0A)· 100% DCR(S-F) SPEC. 10uH ±10% ≥90% AT DC 1.15A 182mΩ MAX 01 9.78 99% 146.95 02 9.76 98% 146.71 03 9.81 98% 147.47 04 9.71 97% 146.07 05 9.72 98% 148.99 06 9.74 98% 153.79 07 9.88 98% 151.20 08 9.76 98% 148.28 09 9.78 98% 152.40 10 9.87 98% 150.51 11 9.74 98% 152.26 12 9.80 98% 148.54 13 9.75 98% 154.08 14 9.80 98% 147.55 15 9.88 98% 148.21 X 9.79 149.53 σ 0.053 2.551 Cpk 4.90 4.24 1. TEST INSTRUMENTS: □HP-4284A METER ■HP-4285A METER □HP-4191A METER □CH-3200 METER □CH-310 METER □CH-3305 METER ■ CD1068+CD1320 METER □ VR116+VR7220 METER □WK3260B+WK3265B METER □VR562 METER ■CH-502B DCR METER 2.CONDITION TEMPERATURE: 25 ℃ HUMIDITY: 65%RH CY REV: QUANTITY:20PCS CORE: DR4.5*3.2R B:2.1 F:1.5 DL5 WIRE: 0.18mm*22.5TS(REF) APPROVED BY CHECKED BY PREPARED BY chenlinli Y019S0009C ROHS Compliant ELECTRONICS CHARACTER TEST CHART CUSTOMER: PART NAME: SMD INDUCTOR TEMPERATURE RISE CURRENT CUSTOMER P/N: TEST DATE:2018-6-11 CY P/N:BC43-100K SAMPLE CO: DC:1.25A TEST INSTRUMENTS CD1068+CD1320 METER 80.0 14.0 64.0 11.2 48.0 8.4 32.0 5.6 16.0 2.8 0.0 TEMPERATURE(℃) INDUCTANCE(uH) 0min 3min 6min 9min 12min 15min 18min 20min 31.2 10.95 57.6 10.33 60.0 10.29 61.7 10.26 62.4 10.18 62.8 10.21 63.0 10.19 63.1 10.18 2.52MHZ 0.25V TEST TERM: 2.INDUCTANCE VS CURRENT TEST INSTRUMENTS: INDUCTANCE(uH) TEMPERATURE (℃) 1.CURVES OF TEMPERATURE AND INDUCTANCE VARIED WITH TP CURRENT 0.0 TIME WK3260B+WK3265B METER INDUCTANCE(uH) 14.0 ● Saturated Current point 11.2 8.4 ■DTL=-10% 5.6 2.8 0.0 INDUCTANCE ▲DTL=-50% 0A 10.179 0.23A 10.184 INDUCTANCE(uH) 0.25V TEST TERM: 3.INDUCTANCE VS FREQUENCUY 0.46A 10.182 0.69A 10.166 0.92A 10.140 TEST INSTRUMENTS: 1.15A 10.107 1.96A 9.178 2.7A CURRENT (A) 5.566 WK3260B+WK3265B METER 14.0 11.2 8.4 5.6 2.8 0.0 FREQUENCY(Hz INDUCTANCE 1KHz 10.840 1.TEST CONDITION TEMPERATURE: 25℃ HUMIDITY: ≦ 65% RH 10KHz 10.775 50KHz 10.496 100KHz 10.308 APPROVED BY 300KHz 10.128 500KHz 9.984 CHECKED BY 800KHz 9.796 1MHZ ( 9.653 PREPARED BY chenlinli
BC43-100K(CD) 价格&库存
很抱歉,暂时无法提供与“BC43-100K(CD)”相匹配的价格&库存,您可以联系我们找货
