RD50T5561J
RD50T5561J
    TA-I(大毅)
    插件,D4xL10.5mm
    插件电阻 560Ω ±5% 500mW
RD50T5561J 数据手册
製品仕様書 SPECIFICATIONS 客戶名稱: Customer: 客戶料號: Part Number: 產品名稱: 碳素皮膜固定電阻器 Product: Carbon Film Fixed Resistor 大益料號: Part Number: 碳素皮膜固定電阻器系列 RD シリーズ/RD series RoHS 対応品 RoHS Compliant product HF 対応品 Halogen Free product TAI ELECTRONIC CO.,LTD. (TAIWAN) ADD:NO. 133 NAN-KANN RD. SEC. 1, TAIWAN R.O.C. TEL:+886-3-322-1988~9 FAX:+886-3-352-4879 Website:http://www.taiohm.com.tw DONGGUAN TAI ELECTRONIC CO.,LTD. (CHINA) ADD:LIHENG INDUSTRIAL ESTATE QINGXI TOWN, DONGGUAN CITY, GUANGDONG PROVINCE, CHINA TEL:+86-769-8731-3175~7 FAX:+86-769-8731-3179 Website:http://www.taiohm.com.tw TAI-OHM ELECTRONICS (M) SDN. BHD ADD:PLOT 564-D, LORONG PERUSAHAAN BARU 2,KAWASAN PERUSAHAAN PERAI, 13600 PERAI, SEBERANG PERAI, SPT, PULAU PINANG, MALAYSIA. TEL:+604-390-0480 FAX:+604-390-1481 Website:http://www.taiohm.com.my TA-I TECHNOLOGY (SU ZHOU) CO.,LTD. (CHINA) ADD:SOUTH ZHAN-HONG BRIDGE, LU-XIANG NORTH ROAD, SONG-LING TOWN, WU-JIANG CITY, JIANG-SU, CHINA TEL:+86-512-6345-7879 FAX:+86-512-6345-7869 Website:http://www.tai.com.tw P.T.TAI ELECTRONIC INDONESIA ADD:BLOK T1 E, F, Jl. Jababeka IV Cikarang Industrial Estate Bekasi 17530, Indonesia TEL:+62-21-8983-0123 FAX:+62-21-8983-0703 Website:pttai@cbn.net.id TA-I TECHNOLOGY (DongGuan) CO.,LTD. (CHINA) ADD:11 TEAM, SHIEM-MA CHUN, CHING-PING TOWN, DONGGUAN CITY, GUANGTON PROVINCE R.O.C. TEL:+86-769-8339-4790 FAX:+86-769-8339-4794 Website:http://www.tai.com.tw TA-I TECHNOLOGY CO.,LTD. (TAIWAN) ADD:NO. 26, LANE 470, SEC 2. NANSHAN RD. LUJHU TOWNSHIP, TAOYUAN, TAIWAN, R.O.C. TEL:+886-3-324-6169 FAX:+886-3-324-6167 Website:http://www.tai.com.tw 客戶承認章 Approval By 承認 檢印 担当者 TAI ELECTRONIC CO.,LTD. 承認 張華隆 檢印 担当者 徐傑瓊 2018/5/22 表單編號: QR-031 Document No. Document TAI-RD-5006-A Name Edition Carbon Film Fixed Resistor RD series 2018-1 -Revision records- Edition Page Clause 1 Revised content /Reason First issue Revision Date Approved Prepared 2010/11/16 唐春秀 徐傑瓊 2015-1 年度版本更新 2015/1/1 李明 徐 瓊 2016-1 年度版本更新 2016/1/4 李明 徐傑瓊 2017-1 年度版本更新 2017/1/2 李明 徐傑瓊 增加電阻阻值測量點標示 2017/7/4 李明 徐傑瓊 年度版本更新 2018/1/2 李明 徐傑瓊 2017-2 2018-1 8 3.2 TAI ELECTRONIC CO., LTD PAGE-1 Document No. TAI-RD-5006-A Document RD series Name Carbon Film Fixed Resistor Edition 2018-1 Carbon Film Fixed Resistor Table of Contents 1. Specifications -----------------------------------------------------------------------------------3 2. Performance -------------------------------------------------------------------------------------5 3. Construction & Dimension -------------------------------------------------------------------7 4. Color Coding Drawing ------------------------------------------------------------------------12 5. Axial Taping Specification -------------------------------------------------------------------13 6. Dimension of Axial Operation --------------------------------------------------------------14 7. Axial Taping Box --------------------------------------------------------------------------------15 8. Marking of Packing Box -----------------------------------------------------------------------15 9. Recommend having the tin condition ------------------------------------------------------16 10. Notice -----------------------------------------------------------------------------16 11. QC Diagram ---------------------------------------------------------------------------17 12. Part Number Table-----------------------------------------------------------------------------18 TAI ELECTRONIC CO., LTD PAGE-2 Document No. Document TAI-RD-5006-A Name Edition Carbon Film Fixed Resistor RD series 2018-1 1 -Specifications- 1.1 -Scope- This specification applies to the Carbon Film Fixed Resistors made by TAI ELECTRONIC CO., LTD For resistance values below 10 ohms, it shall only be applied to Nickel Metal Film. 1.2 -Type designation- Types are designated as follows. RD 25 Type Power Rating RD: Carbon Film Fixed Resistors 16:1/6W, 1/8W 25:1/4W 50:1/2W 1W:1W 2W:2W 3W:3W 25S:1/4WS 50S:1/2WS T2 Packaging Forming T2: 26m/m Taping T5: 52m/m Taping T6: 63m/m Taping T7: 73m/m Taping Bulk: P: P-Type F: F-Type FK: FK-Type FFK: FFK-Type FKK: FKK-Type H: H-Type HB: HB-Type HK: HK-Type 102 J (B) Nominal Value of Resistance Resistance Tolerance Dimension 100: 10Ω 101: 100Ω 102: 1KΩ 103: 10KΩ 104: 100KΩ 105: 1MΩ G: 2% J: 5% TAI’s Code 1.3 -Rating- The ratings of resistors are described in the following Sections. The rating of each type of resistor is indicated in each associated Tables. -Table.1 Rating TableItems Contents Type 1/8W 1/4 1/2W 1W 1/4WS 1/2WS 1WS 2WS 3WS Rated Wattage 1/8W 1/4W 1/2W 1W 1/4W 1/2W 1W 2W 3W Max. Operational Voltage 250 300 350 500 250 300 300 350 350 Max. Overload Voltage 400 600 700 1000 400 500 500 600 600 Max. Intermittence Overload Voltage Dielectric Withstanding Voltage 400 750 1000 1000 500 600 600 600 600 300 500 700 1000 250 300 500 500 500 Rated Ambient Temperature 70℃ Operating Temperature Range Resistance Tolerance -55℃to 155℃ Class J ±5% / Class G ±2% 1Ω ~ 3.3MΩ Resistance Value Range TAI ELECTRONIC CO., LTD PAGE-3 Document No. Document TAI-RD-5006-A Name Edition Carbon Film Fixed Resistor RD series 2018-1 1.3.1 -Rated Wattage- The rated wattage is the maximum continuous power to be applied at operating temperature range. However, for the temperature above 70℃, the rated wattage shall be derated per Fig.1. -Fig.1 Derating curve1.3.2 -Rated Voltage- The rated voltage is denoted as D.C. or rms A.C. voltage which is calculated according to the following formula. However, it is limited to the maximum applicable voltage. E  PR E:Rated voltage (V) P:Rated wattage (W) R:Rated Resistance (Ω) 1.3.3 -Rated Resistance- (1). The rated resistance is specified in accordance with the E24 Series Numbers as shown in Table2. (2). The manufacturing resistance range is shown in each associated rating Tables. (3). The resistance tolerance is shown in each associated rating Tables. -Table.2 E-24 Series resistance ValueEffective Numerical Values of Rated Resistance 1.0 1.1 1.2 1.3 1.5 1.6 1.8 2.0 2.2 2.4 2.7 3.0 3.3 3.6 3.9 4.3 4.7 5.1 5.6 6.2 6.8 7.5 8.2 9.1 TAI ELECTRONIC CO., LTD PAGE-4 Document No. Document TAI-RD-5006-A Name Edition Carbon Film Fixed Resistor RD series 2018-1 2 -Performance- No. Item Spec. Level Test Method (JIS-C-5202) Within the tolerance Par. 5.1 Applicable voltage Category A. 2 Temperature characteristics of resistance See the rating Tables Par. 5.2 measured at the room temperature and + 100℃. Designations of T.C.R. are shown in Par. 5.2.2(2) (a). 3 Short time overload Tolerable change within ±(1% + 0.05Ω). No visual damage & marking be legible. Par. 5.5 Condition A (2.5 times, 5sec). Maximum overload voltages are shown in the rating Tables. 4 Dielectric withstanding voltage Flash over, burning or insulation damages should not be observed. Par. 5.7 Condition A (V-blocks). Test voltage is shown in the rating Tables. Load period: 5sec. Tolerable change within ±(1% + 0.05Ω) & marking be legible Par. 5.8 Applicable only to 100Ω or higher. The pulse voltage applied is 4 times of the rated voltage. The maximum pulse voltage is shown in the rating Tables. Pulse frequency : 10,000±200 cycles. Lead broken or terminal loosen should not be observed. Par. 6.1.2(1) Not applicable to formed leads. Force applied for 1 6 to 5 sec. 1 Resistance Value 5 6 Pulse Terminal Strength Pull Par.6.1.2(4) Not applicable to formed leads. Bend 7 8 Resistance to soldering heat Solderability Tolerable change within ±(1% + 0.05Ω). No mechanical damage & no notable damage be observed in appearance Par. 6.4 Select from the following conditions: Normally condition A is used. Temp Time A 350±10℃ 3.5±0.5 Sec B 260±5℃ 10±1 Sec Dipping be continuously applied from one lead to others. Cooling after dipping should be 3Hrs. 4/5 area of circular surface be wet with new solder. Par. 6.5 Solder temperature: 245±5℃. Dip period: 3±0.5 Sec. Dipping is applied for one terminal at a time. Pre-treatment should not be made. Examined visually. TAI ELECTRONIC CO., LTD PAGE-5 Document No. TAI-RD-5006-A No. 9 10 11 Item Temperature cycling Document Name Edition Carbon Film Fixed Resistor RD series Spec. Level △ R≦ ±(1% + 0.05Ω). No mechanical damage be observed & marking be legible. 2018-1 Test Method (JIS-C-5202) Par. 7.4 Temperature:-55±3℃to 155±2℃ Cycles: 5 times. Humidity load life No remarkable abnormalities on appearance. Marking shall be Legible Variation of resistance(5% + 0.1Ω) Temperature: 85±2℃ Relative humidity:85% to90% Duration:500 +24 –0 h Load life No remarkable abnormalities on appearance. Marking shall be Legible Variation of resistance(5% + 0.1Ω) Par. 7.10 Ambient temp: 70±2℃. Testing period: 1,000 + 48 Hrs. 1,000 - 0 Hrs. 12 Solvent test No notable change in appearance & marking be legible. JIS-C-5202 does not specify this item. Solvent used: Trichloride ethane (1:1:1) or Freon TE Ultra sonic used: 28KHz,200W. Dip time period: 1 Min. 13 Terminal Strength (A) Tensile Strength (B) Bending Strength (C) Tensional Strength ±(1% + 0.05Ω) No cap missing and terminal wire breakage shall occur ±(1% + 0.05Ω) No terminal wire loosening and breakage shall occur ±(1% + 0.05Ω) No terminal wire loosening and breakage shall occur Tensile strength 2.5KG is maintained for 30 seconds Bending strength 500g load 90°reciprocation twice Tensional strength 360° 5 times 14 Packaging Drop Down Experiment Packaging box and isolation coating resistor didn’t broken. Resistance value variation ± (3% +0.05Ω). From height 30 cm, falling the goods and repeat 3 times 15 Resistance value change per year The resistor in the room temperature for 1 year. Resistance value variation
RD50T5561J 价格&库存
很抱歉,暂时无法提供与“RD50T5561J”相匹配的价格&库存,您可以联系我们找货
RD50T5561J
    • 50+0.02699
    • 500+0.01426
    • 2000+0.00610
    • 4000+0.00548
    • 24000+0.00494
    库存:458
