CXA-028224-4X6D00
CXA-028224-4X6D00
    AKER(安碁科技)
    SMD4025_4P
    无源晶振 SMD4025_4P
CXA-028224-4X6D00 数据手册
Customer Name : Customer P/N : Frequency : Aker Approved P/N: Aker MPN : Rev. : ISSUE DATE 28.224000 MHz CXA-028224-4X6D00 CXA-028224-4X6D00 1 : Jan.25.2019 APPROVED CHECKED Xtal PREPARED Kiku APPROVED BY CUSTOMER AKER TECHNOLOGY CO., LTD. ADDRESS : NO 11-3, Jianguo Rd., T.E.P.Z ,Tanzi Dist., Taichung City 427, Taiwan. TEL:886-4-25335978 FAX : 886-4-25336011 Web: www.aker.com.tw RoHS compliant CUST. P/N Aker Approved P/N APPROVED PREPARED : : : : CXA-028224-4X6D00 Xtal SHEET : 1 of 9 Kiku REV . : 1 Rev. Date Reviser Revise contents 1 2019/1/25 Kiku Initial Released CUST. P/N Aker Approved P/N APPROVED PREPARED : : : : CXA-028224-4X6D00 Xtal SHEET : 2 of 9 Kiku REV . : 1 SMD CRYSTAL SPECIFICATION 1 . ELECTRICAL CHARACTERISTICS Standard atmospheric conditions Unless otherwise specified , the standard range of atmospheric conditions for making measurement and tests are as follow : Ambient temperature : 25±5℃ Relative humidity : 40%~70% If there is any doubt about the results , measurement shall be made within the following limits : Ambient temperature : 25±3℃ Relative humidity : 40%~70% AKER Model : CXA-421 Oscillation Model : Fundamental Cutting Model : AT CUT Measurement Equipment : 350A(Measured FL) Insulation Resistance : More than 500M ohms at DC 100V Electrical Spec Parameters Nominal Frequency Symbol Min. FL Typ. Max. 28.224000 Units. Notes MHz Frequency Tolerance ±30 ppm at 25℃ ± 3℃ Frequency Stability ±20 ppm Operating Temp (Refer 25℃) Load Capacitance CL 18 Aging pF ±3 ppm First Year Operating Temperature -10 ~ 70 ℃ Storage Temperature Range -55 ~ 125 ℃ Drive Level DL 100 uW Effective Resistance Rr Rr 40 Ω Shunt Capacitance C0 5 pF *Please kindly be noted that AKER DO NOT guarantee parts quality which involves human security application.* CUST. P/N Aker Approved P/N APPROVED PREPARED : : : : CXA-028224-4X6D00 Xtal SHEET : 3 of 9 Kiku REV . : 1 2 . MARKING : 28.224 AKER AA FREQUENCY Year/Month Code:Please make refer to following tables. Production line code 3 . DIMENSION : ( Unit : mm ) < TO P > < S ID E> 4.0 ± 0.15 2.5 ± 0.15 #4 C eram ic B ase M etal Lid #3 AKER #1 #2 0.8 M ax. < B O T TO M > < SU G G ES TE D L A Y O U T > 3.0 2.0 #2 #4 #3 0.9 #2:G N D #4:G N D 1.2 0.8 1.7 0.7 #1 1.4 CUST. P/N Aker Approved P/N APPROVED PREPARED : : : : CXA-028224-4X6D00 Xtal SHEET : 4 of 9 Kiku REV . : 1 4 . STRUCTURE ILLUSTRATION A C B D G N I K R A M E CUST. P/N Aker Approved P/N APPROVED PREPARED : : : : CXA-028224-4X6D00 Xtal SHEET : 5 of 9 Kiku REV . : 1 5 . PACKING : TAPE SPECIFICATION 1.75 ± 0.10 1.55 ± 0.05 2.0 ± 0.05 ( Unit : mm ) 4.0 ± 0.10 0.30 ± 0.05 8.0 ± 0.10 1.50 (MIN) B B-B SECTION A 4.30 ± 0.10 A 5° (max) 12.0 ± 0.10 5.50 ± 0.05 B 1.0 ± 0.10 2.80 ± 0.10 5° (max) A-A SECTION OUTLINE DIMENSION ( Unit : mm ) CUST. P/N Aker Approved P/N APPROVED PREPARED : : : : 6. COVER TAPE ADHESION STRENGTH: 7 . SOLDERING REFLOW PROFILE CXA-028224-4X6D00 Xtal SHEET : 6 of 9 Kiku REV . : 1 CUST. P/N Aker Approved P/N APPROVED PREPARED : : : : CXA-028224-4X6D00 Xtal SHEET : 7 of 9 Kiku REV . : 1 8. PACKING : 185mm 183mm 36mm BOX = 1000 PCS / REEL Stuff 210mm 625mm 390mm SMD product packs 32 BOX = The outside box packs ( 1000 PCS * 32 BOX = 32000 PCS )(MAX) CUST. P/N Aker Approved P/N APPROVED PREPARED : : : : CXA-028224-4X6D00 Xtal SHEET : 8 of 9 Kiku REV . : 1 9 . MECHANICAL PERFORMANCE TEST ITEMS TEST METHODS AND TEST CONDITION 9.1 Drop Test The specimen is measured for its frequency and resistance before the test. It is then dropped from a hight of 100 cm or more as a free fall object onto a hard wooden plate of 30mm or more in thickness. ( in accordance with JIS-C0044 ) 9.2 Vibration Test The specimen is measured for its frequency and resistance before the test. Most them into X,Y and Z axes, respectively, for the vibration test. Vibration condition: Frequency range ; 20~2000HZ Peak to peak amplitude : 1.52 mm Peak acceleration : 20G Sweep time : 20 minute / axis Pendicular total test time : 4 hours ( in accordance with MIL-STD-883F : 2007.3 ) The specimen is measured for its frequency and resistance before the test. Place the specimen on the belt of the converynace and let it pass through the reflow with the presetted temperature condition. After passing twice the reflow place,the specimen under the referee condition for -~2 hours and then measure its electrical performance. Temperature Condition of IR Simulation: The temperature range of the preheated section is setted at 150~180℃ for 60~120 sec. For the next section the temperature range is setted at 217~260℃ for 45~90 sec. and within this time range the specimen should be able to sustain at the peak temperature, 260+/-3℃ , for 10 sec long. ( in accordance with JESD22-B106-B ) Place the specimen in a pressurized container and pressurize it with the detection gas ( mixed gas consisting of 95% or more helium ) for at least 2 hours. Complete the measurement of the concentration of helium within 30 min after taking it out from the pressurized container. 9.3 Resistance to Soldering Test 9.4 Fine Leak Test ( in accordance with MIL-STD-883F : 1014.11 ) The referee condition . Temperature 25 ± 2 ℃ Humidity 44 ~ 55 % Pressure 86 ~ 106 kPa ( in accordance with MIL-STD-883E : 1014. 9 ) CUST. P/N : PERFORMANCE To satisfy the electrical performance . Less than 1.0 * 10 - 8 atm .c.c. / sec, Helium Aker Approved P/N : APPROVED : PREPARED : CXA-028224-4X6D00 Xtal SHEET : 9 of 9 Kiku REV . : 1 10 . CLIMATIC RESISTANCE TEST ITEMS 10.1 Low Temp Exposure Test TEST METHODS AND TEST CONDITION The specimen is measured for its frequency and resistance before the test . Place the specimen in the chamber and kept it at the temperature of - 40 ± 3℃ for 168 ± 6 hours . Take the specimen out of the chamber and measure itselectrical performance after leaving 1~2 hours under the referee condition. ( in accordance with JIS-C0020 ) 10.2 Aging Test The specimen is measured for its frequency and resistance before the test . Place the specimen in the testing chamber and keep it at the temperature of + 125 ± 3℃ for 720 ± 48 hours. And then take the specimen out of the chamber and measure its electrical performance after leaving for 1 ~ 2 hours under the referee condition . ( in accordance with JIS-C0021 ) 10.3 High Temperature & High Humidty The specimen is measured for its frequency and resistance before the test . Place the specimen in the testing chamber and kept it at the temperature of + 85 ± 5 ℃ and humidity of 85 ± 5 % for 168 ± 6 hours.and then take the specimen out and measure its electrical performance after leaving for 1~2 hours under the referee condition. ( in accordance with MIL-STD-883F : 1004.7 ) 10.4 Temperature Cycle Test The specimen is measured for its frequency and resistance before the test . Subject the specimen to the 100 cycles of temperature ranges stated below . High temp . + 125 ± 3 ℃ (15± 3 min). 2~3 min. 2~3 min. Low temp . -55 ±3 ℃ (15± 3 min). Measure its electrical performance after leaving it for 1 ~ 2 hours under the referee condition . ( in accordance with MIL-STD-883F : 1010.8 ) PERFORMANCE To satisfy the electrical performance .
CXA-028224-4X6D00 价格&库存
很抱歉,暂时无法提供与“CXA-028224-4X6D00”相匹配的价格&库存,您可以联系我们找货
CXA-028224-4X6D00
    • 1+1.14372
    • 10+0.68256
    • 30+0.32076
    • 100+0.30024
    • 500+0.28836
    • 1000+0.28296
    库存:689
