(SMD Power Inductors)
Powder Molding Type
BCIHP1770HC-Series (IHLP-6767GZ-11/IHLP-6767GZ-01)
● Photograph picture
BCIHP1770
● Dimensions
Recommend PC Board Pattern
ITEM
BCIHP1770HC-Series
BCIH11735HC-Series
BCIH11740HC-Series
A(mm)
B(mm) C(mm)
17.0±0.30[1] 18.0±0.3 7.0 MAX
7.3
11.3
3.5
7.3
11.3
3.5
D(mm) E(mm) F(mm) G(mm) H(mm)
12.0±0.3 2.50±0.3 20.5
12.5
10.0
2.5±0.5 2.5±0.3
2.5±0.5 2.5±0.3
● Part Numbering
BCIHP
1770HC – 1R0
M – T01
A
B
C
D E
A/E:Series(系列代號)
B:Dimension(尺寸)
B×C
C:Inductance(電感值)
1R0=1.0uH
D:Inductance Tolerance(電感值公差) M=±20%
● Features
1.
2.
3.
4.
Compliance with RoHs.
Lowest DCR.
Frequency range up to 1.0MHz.
Handles high transient current spikes without saturation
● Applications
1. DC/DC converter for CPU in Notebook PC
2. Battery powered devices
3. Cellular phones LCD displays, HDDs, DVCs, DSCs,
PDA etc.
4. Thin type on-board power supply module.
TEL:+86-756-3383909
TAX:+86-756-3380704
● 特點
1. 符合 RoHs.
2. 低電阻.
3. 頻率可達到 1.0 MHz.
4. 可處理在未飽和時的高瞬間電流.
● 應用
1. 用於筆記本電腦處理器的 DC/DC 轉換設備.
2. 電源,電池設備.
3. 適用於手機液晶屏顯示,HDD, DVC, DSC,
PDA 等.
4. 薄型車載電源模組.
Bao Cheng Electronics Corp Ltd
www.baocheng.biz
19 JAN 2016
TAPE BCIHP1770HC-Series P: 1 / 9
Powder Molding Type
BCIHP1770HC-Series
● Specification
ITEM
BCIHP1770HC-1R0M-T02[IHLP-6767GZ-11]
BCIHP1770HC-1R5M-T02[IHLP-6767GZ-11]
BCIHP1770HC-2R2M-T02[IHLP-6767GZ-11]
BCIHP1770HC-3R3M-T02[IHLP-6767GZ-11]
BCIHP1770HC-4R7M-T02[IHLP-6767GZ-11]
BCIHP1770HC-5R6M-T02[IHLP-6767GZ-11]
BCIHP1770HC-6R8M-T02[IHLP-6767GZ-11]
BCIHP1770HC-8R2M-T02[IHLP-6767GZ-11]
BCIHP1770HC-100M-T02[IHLP-6767GZ-11]
BCIHP1770HC-150M-T02[IHLP-6767GZ-11]
BCIHP1770HC-220M-T02[IHLP-6767GZ-11]
BCIHP1770HC-330M-T02[IHLP-6767GZ-11]
BCIHP1770HC-470M-T02[IHLP-6767GZ-11]
BCIHP1770HC-560M-T02[IHLP-6767GZ-11]
BCIHP1770HC-680M-T02[IHLP-6767GZ-11]
BCIHP1770HC-820M-T02[IHLP-6767GZ-11]
BCIHP1770HC-101M-T02[IHLP-6767GZ-11]
BCIH11735HC-R22M
BCIH11740HC-R15N
BCIH11740HC-R22M
TEL:+86-756-3383909
TAX:+86-756-3380704
INDUCTANCE uH
@100KHZ,1.0V,0A
1.00
1.50
2.20
3.30
4.70
5.60
6.80
8.20
10.00
15.00
22.00
33.00
47.00
56.00
68.00
82.00
100.00
0.22
0.15
0.22
(1)
DCR mΩ
25℃ TYP
1.27
1.62
1.98
2.93
4.18
4.60[2]
6.15
8.10
9.33
14.40
21.00
37.00
42.70
57.80
75.70
91.70
110.00
7.35
HEAT RATING
1.21
1.54
1.85
2.79
3.98
4.45[2]
5.86
7.71
8.89
13.70
20.00
35.10
40.70
55.00
72.10
87.30
105.00
4.9
TYPICAL(Irms)
0.35±7%
0.55
SATU RATION
DCR mΩ
CURRENT DC AMPS CURRENT DC AMPS
25℃ MAX (5)
(6)
0.6
www.baocheng.biz
55.50
48.00
43.50
35.00
30.00
28.00
22.50
21.00
19.00
14.00
12.00
10.70
8.70
7.20
6.10
5.50
5.00
13.0
00
50.0
00
TYPICAL(Isat)
32.00
31.00
28.00
27.00
21.00
21.00
18.50
18.00
17.00
12.00
9.50
9.00
8.60
4.20
4.50
4.50
4.00
45.00
65.00
60.00
19 JAN 2016
TAPE BCIHP1770HC-Series P: 2 / 9
Powder Molding Type
BCIHP1770HC-Series
Note:
(1)
(2)
(3)
(4)
(5)
(6)
(7)
(1)
(2)
(3)
(4)
(5)
(6)
(7)
Tolerance of Inductance: N=±30% ,M=±20%.
All test data is referenced to 25℃ ambient.
Inductance is measured at 100KHz. 25℃ ambient.
Operating Temperature Range-40℃ to +125℃.
DC current (Irms) (A) that will cause an approximate △T of 40℃.
DC current (Isat) (A) that will cause Lo to drop approximately 30%.
The part Temperature (ambient + temp rise) should not exceed 125℃ under worst case operating
conditions. Circuit design, component placement, PWB trace size and thickness, airflow and other
cooling provisions all affect the part temperature Part temperature should be verified in the end
application.
電感的公差:N=±30%,M=±20%.
所有的測試資料應該是在 25℃的環境溫度下測試.
感值測試頻率 100KHz.
操作溫度範圍-40℃到+125℃.
加 DC(Irms)電流值(A)會導致△T 40℃左右的變化.
加 DC(Isat)電流值(A)會導致初始值下降 30%左右.
產品的溫度不能超過 125℃,即使在最壞的操作情況下,基板設計,元件放置,PWB 尺寸和厚度,
氣流和一些冷卻設備都會影響產品溫度,產品溫度要在最終應用時才被驗證.
TEL:+86-756-3383909
TAX:+86-756-3380704
www.baocheng.biz
19 JAN 2016
TAPE BCIHP1770HC-Series P: 3 / 9
Powder Molding Type
BCIHP1770HC-Series
● Material List
NO
1
2
ITEM
Core
Wire
External Electode
3
Electroplating
4
Paint
Materials
Magnetic Metal Powder or equivalen
Polyester Wire or equivalen
Copper
Ni/Sn
Epoxy resin
● Packaging Information
(1) Reel Dimension & Tape Dimension / Packaging Quantity
ITEN
BCIHP1770
Q’TY (PCS) W1±0.3 W2±0.5
300
32.80
40.20
DIMENSIONS (m/m)
W±
A0±
B0±
32.00
17.80
18.60
K0±
P±
F±
7.30
24.00
15.50
T±0.05
0.40
(2) Tearing Off Force
The force tearing off cover 10 to 130 grams
(0.1N to 1.3N) in the arrow direction under the
following conditions.
● Storage conditions/Note things
(1) Storage temperature and humidity conditions :
1. Product packing with Carrier tape: +5℃~+40℃ and less than 60% RH.
2. Product alone: -20℃~+60℃ and less than 60% RH.
(2) Products should be used within 6 months.
(3) The packaging material should be kept where no chlorine or sulfur exists in the air.
(4) Do not touch the electrodes (soldering terminals) with fingers as this may lead to deterioration of
solder ability
(5) The use of tweezers or vacuum pick-ups is strongly recommended for individual components.
(6) Bulk handling should ensure that abrasion and mechanical shock are minimized.
TEL:+86-756-3383909
TAX:+86-756-3380704
www.baocheng.biz
19 JAN 2016
TAPE BCIHP1770HC-Series P: 4 / 9
SMD Power Inductors
BCIHP1770HC-Series
● Package for standard
ITEM
Packing method & Dimensions
Box Size
W=345mm
D=345mm
H=185mm
ITEM
BCIHP1770
TEL:+86-756-3383909
TAX:+86-756-3380704
Packing Quantity
300 Pcs/Reel (3.5Kg(Ref))
Reel Quantity
4 Reel/Box
www.baocheng.biz
Total Quantity
1,200 Pcs/Box (14.8Kg(Ref))
19 JAN 2016
TAPE BCIHP1770HC-Series P: 5 / 9
Powder Molding Type
BCIHP1770HC-Series
● General Characteristics
Operation Temperature
External Appearance
-40℃ to +125℃ (Includes temperature when the coil is heated)
On visual inspection, the coil has no external defects.
● Electrical Performance Test
Inductance
DCR
Refer to standard electrical characteristics list.
Saturation Current(Isat)
BCIHP1770HC-Series △L≦30% typical.
Heat Rated Current(Irms)
Approximately △T≦40℃.
● Reliability Test
Solder Ability Test
1. More than 90% of terminal electrode should be covered with solder.
After fluxing, component shall be dipped in
a melted.
Solder: bath at 245℃±5℃ for 5±0.5
seconds.
1.
2.
Heat resistance of
Reflow Soldering Test
1.
Adhesion strength
Test
Components should have not evidence of electrical and mechanical damage.
Inductance: within±10% of initial value.
Preheat:150±5℃ 60seconds.
Solder temperature: 255+5℃/-0℃.
Flux: rosin.
Dip time:10±0.5seconds.
No apparent damage
Product is mounted on PCB. Thereafter R340
pressure fixture is used to apply pressure to product
from backside of the board at a rate of approx.
1mm/sec. until bending width becomes 1mm and
keep it for 5sec.
1. No separation or indication of electrode.
A static load using a R5.0 pressing tool shall be applied to the
Welding strength Test
body of the specimen in the direction of the arrow and shall
be hold for 3±1 sec.
Insulating Resistance Over 100MΩ at 100V D.C. between coil and core.
Dielectric Strength
Vibration Test
Drop Test
TEL:+86-756-3383909
TAX:+86-756-3380704
No dielectric breakdown at 30V D.C. for 1 minute between coil and core.
1. No separation or
Inductance deviation within +10% after vibration for 1
hour. In each of three orientations at Sweep vibration
indication of
(10~55~10HZ) with 1.5mmP-P amplitudes.
electrode.
2. △L/L≦15%
Inductance deviation within +10% after being dropped
once with 981m/s2 (100G) shock Attitude upon a rubber
block method shock testing machine, in three different
orientations.
www.baocheng.biz
19 JAN 2016
TAPE BCIHP1770HC-Series P: 6 / 9
Powder Molding Type
BCIHP1770HC-Series
● Reliability Test
Item
High Temperature
Storage Test
Low Temperature
Storage Test
High Temperature
Humidity Test
Thermal Shock Test
Storage Test
Required Characteristics
1. No case deformation or change in appearance
2. △L/L≦15%
3. △Q/Q≦30%
4. △DCR/DCR≦15%
Test Method/Condition
Temperature:125℃±3℃ Time:96±2 hours.
Tested not less than 1 hour, nor more than 2
hours at room.
2. △L/L≦15%
3. △Q/Q≦30%
4. △DCR/DCR≦15%
Temperature:-40℃±3℃ Time:96±2 hours.
hours at room.
2. △L/L≦15%
3. △Q/Q≦30%
4. △DCR/DCR≦15%
Temperature:85℃±3℃.
Humidity:85±5%RH
Test Time:96±2 hours
Tested not less than 1 hour. Nor more than 2
hours at room temperature.
2. △L/L≦15%
3. △Q/Q≦30%
4. △DCR/DCR≦15%
First–40℃ for 30 Minutes, last 125℃ for 30
Minutes as 1 cycle. Go through 20 cycles.
TEL:+86-756-3383909
TAX:+86-756-3380704
www.baocheng.biz
19 JAN 2016
TAPE BCIHP1770HC-Series P: 7 / 9
Powder Molding Type
BCIHP1770HC-Series
● Soldering re-flow
IPC/JEDEC J-STD-020C, Figure 5-1
TEL:+86-756-3383909
TAX:+86-756-3380704
www.baocheng.biz
19 JAN 2016
TAPE BCIHP1770HC-Series P: 8 / 9
Powder Molding Type
BCIHP1770HC-Series
● Modify records
Numbering
[1]
[2]
[3]
Date
Modify content
2015/3/28 Dimensions A:17.0 ±0.15 has been changed to A:17.0 ± 0.30
2015/4/17 BCIHP1770-5R6M-T01 DCR:4.44mΩ MAX has been changed to DCR:4.60mΩ MAX.
DCR:4.23mΩ Typ has been changed to DCR:4.45mΩ Typ.
2016/10/27 BCIHP1770-xxx-T01 change for BCIHP1770HC-xxx-T02
TEL:+86-756-3383909
TAX:+86-756-3380704
BCIHP1770HC-xxx-T02 change for BCIHP1770HC-xxx-T03
www.baocheng.biz
19 JAN 2016
TAPE BCIHP1770HC-Series P: 9 / 9
很抱歉,暂时无法提供与“BCIHP1770-100M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+12.20400
- 10+10.38960
- 30+9.24480
