BCRH8D43-220N-NL
BCRH8D43-220N-NL
    BC(台湾诚阳)
    SMD
    功率电感 SMD
BCRH8D43-220N-NL 数据手册
承 認 書 SPECIFICATION FOR APPROVAL CUSTOMER: CUSTOMER P/N PART NO: DESCRIPTION: PRODUCTS NO: PRODUCTS REV: DATE: SMD POWER INDUCTORS BCRH8D43-220N 1 2018-6-7 PURCHASER CONFIRMED REMARK PROVIDER ENGINEER DEPT. APPROVAL BY CHECK BY DRAWN BY Eng Y asir chenlinli 誠陽實業有限公司 TAIWAN CHENG YANG COMPONENT CORP TAIPEI OFFICE 2F-1, NO. 176, Chine-Yi Road., Zhonghe TAIWAN(R.O.C) 新北市中和區建一路176號2樓之一 District, New Taipei City, POSTAL CODE: 23500 TEL NO.:+886-2- 8228-0930 FAX NO.:+886-2-8228-0929 Email:h21803@ms29.hinet.net 寶誠電子有限公司 CHINA FACTORY ZHUHAI BAO CHENG ELECTRONICSCO.,LTD Guan Tang Industrial Park, Tang Jia Wan Town, Zhuhai City, Guangdong Province, CHINA 中國廣東省珠海市塘家灣鎮官塘工業區 POSTAL CODE: 519085 TEL NO:86-756-3383187 FAX NO:86-756-3380704 E-mail: baocheng@baocheng.biz 昆山誠陽電子有限公司 CHINA FACTORY KUNSHAN CHENG YANG ELECTRONICSCO.,LTDP Qiang-An Road., High-Tech. Industrial Park, Kunshan City, Jiangsu Province, 江蘇省昆山市高科技工業園區強安路38號 China POSTAL CODE: 215300 TEL NO:86-512-57823500 FAX NO:86-512-57823503 E-mail: kscy@taiwan-chengyang.com.tw REVISION NOTES NO. Date Description of Revision 1 2018-6-7 首次送樣 ROHS Compliant TEST DATA DIMENSION&ELECTRIC CHARACTER CUSTOMER: PART NO.: CUSTOMER : SMD INDUCTOR SERIES NO: BCRH8D43-220N 1.MECHANICAL DIMENSION A1 UNIT:mm 220 2R2 2.RECOMMEND LAND PATTERN DIMENSIONS A 8.3MAX A1 10.0MAX B 8.3MAX C 4.7MAX D 6.3REF E 2.5REF F 1.2REF G H I 3.SEPCIFICATIONS Part Number L(0A) Rdc (mOHM) Inductance 22uH±30% Typical Max @100KHZ 0.25V BCRH8D43-220N 22.0 67.8 75.0 Heat Rating Current DC Amps.Idc(A) Saturation Current DC Amps.ldc(A) Typical Typical 2.43 2.10 (1). All test data is referenced to 25℃ ambient. (2). Operating Tenperature Rangr-30℃ to +100℃. (3). DC current(2.43A)that will cause an approaimate△T of 40℃. (4). DC current(2.1A)that will cause Lo to drop approximately25%. (5). The part temperature(ambient+temp rise)should not exeed 100℃ under worst case operating conditions.Circuit design,component placement,PWB trace size and thickness,airflow and oter aooting provisions all affsct the part temperature part temperature should be verified in the end appliation. 4.PACKAGING INFORMATION paets are packaged on 13"reels 800 parts per reel. A0= 10.0mm+0.1/-0 220 B0= 8.3mm+0.1/-0 K0= 4.7mm+0.1/-0 APPROVED BY: Vincent CHECKED BY: Yasir BC019S0009 DRAWN BY: chenlinli Rohs Compliant KUNSHAN CHENG YAN ELECTRONICS CO.,LTD TEST DATA FOR PREPRODUCTION SAMPLE CUSTOMER: CUSTOMER P/N: CUSTOMER REV: 2018-6-7 PART NAME: SMD INDUCTOR BC PART NO:BCRH8D43-220N BC REV: QUANTITY:5PCS TEST ITEM A A1 B C 8.30 10.00 8.30 4.70 MAX MAX MAX MAX 01 7.93 9.61 8.06 4.32 02 7.84 9.62 7.91 4.38 03 7.91 9.53 7.91 4.34 04 7.96 9.56 7.97 4.34 05 7.92 9.59 7.96 4.32 X 7.91 9.58 7.96 4.34 σ 0.040 0.033 0.055 0.022 Cpk 3.26 12.91 19.80 66.03 SPEC. D E F G H I 06 07 08 09 10 11 12 13 14 15 APPROVED BY CHECKED BY PREPARED BY Vincent Yasir chenlinli BWIEG0002-06A BC019S0009 J Rohs Compliant KUNSHAN CHENG YAN ELECTRONICS CO.,LTD TEST DATA FOR PREPRODUCTION SAMPLE CUSTOMER P/N: PART NAME: SMD INDUCTOR BC PART NO:BCRH8D43-220N TEST ITEM L(0A) L(2.1A) DCR(S-F) CUSTOMER REV: 2018-6-7 BC REV: QUANTITY:5PCS TEST 100KHZ 0.25V CONDITION SPEC. 22uH ±30% ≥65% AT DC 2.1A 75mΩ MAX 01 24.96 89% 67.18 02 24.82 91% 67.76 03 22.02 95% 67.28 04 23.84 91% 67.70 05 24.53 90% 68.82 06 07 08 09 10 11 12 13 14 15 X 24.03 67.75 σ 1.078 0.582 Cpk 1.41 4.15 1. TEST INSTRUMENTS: □HP-4284A METER □HP-4285A METER □HP-4191A METER □VR113+VR712 METER □VR116+VR7220 METER □CH-3200 METER □CH-310 METER □CH-3305 METER ■CD1068+CD1320 METER ■WK3260B+WK3265B METER □VR562 METER ■CH-502B DCR METER 2.CONDITION TEMPERATURE: 25 ℃ BWIEG0002-07A APPROVED BY CHECKED BY PREPARED BY Vincent Yasir chenlinli BC019S0009 ROHS Compliant ELECTRONICS CHARACTER TEST CHART CUSTOMER: CUSTOMER : SMD INDUCTOR CUSTOMER P/N: TEST DATE: 2018-6-7 CY PN: BCRH8D43-220N-NL SAMPLE CO: CD1068+CD1320METER 1.CURVES OF TEMPERATURE AND INDUCTANCE VARIED WITH TP CURRENT TEMPERATURE RISE CURRENT DC:2.43A TEST INSTRUMENTS TEST TEST TERM: 100KHZ 0.25V 2.INDUCTANCE VS CURRENT TEST INSTRUMENTS: WK3260B+WK3265B METER ● Saturated Current point ■DTL=-35% ▲DTL=-50% CURRENT (A) TEST TERM: 0.25V 3.INDUCTANCE VS FREQUENCUY TEST INSTRUMENTS: WK3260B METER FREQUENCY(Hz) 1.TEST CONDITION TEMPERATURE: 25℃ HUMIDITY: ≦ 65% RH APPROVED BY CHECKED BY PREPARED BY Vincent ChenFei ZhaoQian BC019S0009 TEST
BCRH8D43-220N-NL 价格&库存
很抱歉,暂时无法提供与“BCRH8D43-220N-NL”相匹配的价格&库存,您可以联系我们找货
BCRH8D43-220N-NL
    • 5+0.77566
    • 50+0.41043
    • 150+0.18235
    • 800+0.15383
    • 2400+0.14113
    • 4800+0.13350
    库存:376
