BCIH1367-8R2M
BCIH1367-8R2M
    BC(台湾诚阳)
    SMD,12.6x13.4mm
    功率电感 SMD
BCIH1367-8R2M 数据手册
(SMD Power Inductors) Powder Molding Type BCIH/IHP1338/50/67-Series ● Photograph picture BCIH/IHP1338/50/67 ● Dimensions Recommend PC Board Pattern ITEM BCIH1338-Series BCIHP1338-Series BCIH1350-Series BCIHP1350-Series BCIH1367HC-Series BCIHP1367-Series A(mm) 12.6±0.3 12.6±0.3 12.6±0.3 12.6±0.3 12.6±0.3 12.6±0.3 B(mm) 13.4±0.5 13.4±0.3 13.4±0.5 13.4±0.3 13.4±0.5 13.4±0.3 C(mm) 3.8 MAX 3.8 MAX 5.0 MAX 5.0 MAX 6.7 MAX 6.7 MAX D(mm) 4.00±0.5 4.70±0.3 4.00±0.5 4.70±0.3 4.00±0.5 4.70±0.3 E(mm) 2.30±0.3 2.30±0.3 2.30±0.3 2.30±0.3 2.30±0.3 2.30±0.3 F(mm) G(mm) H(mm) 14.50 5.00 8.00 14.50 5.00 8.00 14.50 5.00 8.00 14.50 5.00 8.00 14.50 5.00 8.00 14.50 5.00 8.00 ● Part Numbering BCIHP 1338 – 1R0 M A B C D A:Series(系列代號) B:Dimension(尺寸) B×C C:Inductance(電感值) 1R0=1.0uH D:Inductance Tolerance(電感值公差) M=±20% ● Features 1. 2. 3. 4. 100% lead (Pb)-free. Lowest DCR. Frequency range up to 1.0MHz~ 5.0MHz. Handles high transient current spikes without saturation ● Applications 1. DC/DC converter for CPU in Notebook PC 2. Battery powered devices 3. Cellular phones LCD displays, HDDs, DVCs, DSCs, PDA etc. 4. Thin type on-board power supply module. ● 特點 1. 符合 RoHs. 2. 低電阻. 3. 頻率可達到 1.0MHz~5.0MHz. 4. 可處理在未飽和時的高瞬間電流. ● 應用 1. 用於筆記本電腦處理器的 DC/DC 轉換設備. 2. 電源,電池設備. 3. 適用於手機液晶屏顯示,HDD, DVC, DSC, PDA 等. 4. 薄型車載電源模組. Cheng Yang Electronics Corp Ltd 19 JAN 2016 www.baocheng.biz TAPE BCIH/IHP1338/50/67-Series P: 1 / 10 (SMD Power Inductors) Powder Molding Type BCIH/IHP1338/50/67-Series ● Specification ITEM INDUCTANCE uH (1) @200KHZ,0.25V,0A 40.00 DCR mΩ 25℃TYP DCR mΩ 25℃ MAX HEAT RATING SATU RATION CURRENT DC AMPS CURRENT DC AMPS (5) TYPICAL(Irms) (6) TYPICAL(Isat) BCIHP1338HC-6R8M 1.00 1.50 0.10 0.15 0.22 0.33 0.36 0.47 0.56 0.60 0.68 0.82 0.50 1.00 1.50 2.20 3.30 4.70 5.60 6.80 2.80 3.65 0.35 0.60 0.80 0.85 1.10 1.15 1.90 1.65 1.85 2.30 2.40 3.00 4.70 6.80 9.90 14.50 17.00 19.5 3.30 5.50 0.70 0.90 1.30 1.50 1.40 2.00 2.20 2.20 2.50 3.00 3.00 3.50 5.50 7.80 12.00 15.00 18.00 22.00 BCIHP1338HC-8R2M BCIHP1338HC-100M 8.20 10.00 25.50 28.50 28.00 34.00 8.00 7.00 12.00 12.00 BCIHP1338-121M BCIHP1338-150M BCIHP1338-330M 120.00 15.00 33.00 2.50 0.47 0.56 0.60 0.68 0.82 493.00 50.50 118.50 8.30 1.75 2.10 2.05 2.20 2.55 560.00 59.00 145.00 9.50 2.00 2.2 2.20 2.70 3.00 1.70 5.00 3.00 15.00 25.00 25.00 29.00 25.00 25.00 3.00 10.00 6.00 25.00 48.00 52.00 51.00 4.00 44.00 1.00 2.30 2.70 3.50 4.50 0.30 0.50 0.75 0.80 2.50 3.00 4.10 5.50 0.50 0.70 1.10 1.10 29.00 25.00 23.00 19.00 55.00 45.00 41.00 40.00 50.00 40.00 35.00 28.00 75.00 78.00 70.00 60.00 BCIH1338HC-1R0M BCIH1338HC-1R5M BCIH1338HC-R10M BCIH1338HC-R15N BCIH1338HC-R22N BCIH1338HC-R33M BCIH1338HC-R36M BCIH1338HC-R47M BCIH1338HC-R56M BCIH1338HC-R60M BCIH1338HC-R68M BCIH1338HC-R82M BCIH1338-R50M BCIHP1338-1R0M BCIHP1338-1R5M BCIHP1338HC-2R2M BCIHP1338HC-3R3M BCIHP1338HC-4R7M BCIHP1338HC-5R6M BCIHP1338HC-2R5M BCIHP1338-R47M BCIHP1338-R56M BCIHP1338-R60M BCIHP1338-R68M BCIHP1338--R82M BCIH1350HC-1R0M BCIH1350HC-1R2M BCIH1350HC-1R5M BCIH1350HC-2R2M BCIH1350HC-R10N BCIH1350HC-R22N BCIH1350HC-R33M BCIH1350HC-R36M 1.20 1.50 2.20 0.10 0.22 0.33 0.36 24.00 19.00 43.00 41.00 38.50 36.50 35.00 32.00 29.00 29.00 28.00 25.00 25.00 22.00 19.00 16.00 12.00 10.00 9.50 9.00 40.00 35.00 70.0 68.00 65.00 62.00 56.00 48.00 48.00 49.00 10.00 44.00 44.00 28.00 31.0 25.00 22.00 18.00 16.00 15.00 Cheng Yang Electronics Corp Ltd 19 JAN 2016 www.baocheng.biz TAPE BCIH/IHP1338/50/67-Series P: 2 / 10 (SMD Power Inductors) Powder Molding Type BCIH/IHP1338/50/67-Series ● Specification ITEM HEAT RATINGHEAT SATU RATION INDUCTANCEINDUCTANCE uH DCR mΩ DCR mΩ RATING SATUDimensionsRATION uH DCR mΩ DCR mΩ (1) CURRENT DC AMPS CURRENT DC AMPS 25℃TYP (1) 25℃ MAX CURRENT DC AMPS CURRENT DC AMPS @200KHZ,0.25V,0A D(mm) 25℃ MAX. 25℃ Typ. (5) @200KHZ,0.25V,0A (6) 40.00 TYPICAL(Irms) TYPICAL(Isat) (6) TYPICAL(Isat) (5) TYPICAL(Irms) BCIH1350HC-R47M 0.47 BCIH1350HC-R50M BCIHP1350-R82M 0.50 0.56 0.68 0.82 2.20 3.30 4.70 5.60 6.80 8.20 10.00 12.00 15.00 22.00 33.00 47.00 0.68 0.82 BCIH1360HC-R45M 0.45 BCIHP1360-3R3M 3.30 15.00 22.00 33.00 47.00 1.00 2.20 10.00 1.20 1.50 1.80 2.20 0.10 0.15 0.22 BCIH1350HC-R56M BCIH1350HC-R68M BCIH1350HC-R82M BCIHP1350-2R2M BCIHP1350HC-3R3M BCIHP1350HC-4R7M BCIHP1350HC-5R6M BCIHP1350HC-6R8M BCIHP1350-8R2M BCIHP1350HC-100M BCIHP1350-120M BCIHP1350HC-150M BCIHP1350HC-220M BCIHP1350-330M BCIHP1350-470M BCIHP1350-R68M BCIHP1360HC-150M BCIHP1360HC-220M BCIHP1360HC-330M BCIHP1360HC-470M BCIH1367HC-1R0M BCIH1367-2R2M BCIH1367-100M BCIH1367HC-1R2M BCIH1367HC-1R5M BCIH1367HC-1R8M BCIH1367HC-2R2M BCIH1367HC-R10N BCIH1367HC-R15N BCIH1367HC-R22N 1.10 1.20 0.95 1.35 2.00 5.10 8.30 12.50 16.00 17.00 22.00 24.20 29.00 34.50 52.00 68.00 152.00 1.90 1.60 0.615 5.80 26.00 37.00 65.00 84.00 1.85 3.70 17.20 2.30 2.50 2.90 3.50 0.25 0.35 0.45 1.30 1.50 1.50 1.70 2.40 6.30 9.20 15.00 17.60 18.50 25.00 25.50 34.50 38.00 55.00 88.00 168.00 2.20 2.30 0.68 7.10 29.00 40.00 75.00 90.00 2.00 4.20 18.50 2.50 3.00 3.20 4.20 0.50 0.60 0.70 38.00 36.00 36.00 34.00 31.00 17.00 14.00 12.00 10.50 10.00 8.50 9.00 7.00 6.50 5.50 3.50 3.00 34.00 30.00 44.00 17.00 6.00 5.00 4.50 3.50 32.00 22.00 10.00 30.00 25.00 24.00 22.00 60.00 55.00 53.00 65.00 55.00 55.00 54.00 50.00 28.00 24.00 21.00 17.50 17.00 15.50 14.00 12.00 9.00 8.50 7.50 6.00 45.00 50.00 50.00 28.00 9.00 8.00 6.00 5.50 49.00 40.00 15.50 45.00 40.00 36.00 33.00 80.00 80.00 75.00 Cheng Yang Electronics Corp Ltd 19 JAN 2016 www.baocheng.biz TAPE BCIH/IHP1338/50/67-Series P: 3 / 10 (SMD Power Inductors) Powder Molding Type BCIH/IHP1338/50/67-Series ● Specification ITEM BCIH1367HC-R30M BCIH1367HC-R33M BCIH1367HC-R36M BCIH1367HC-R40M BCIH1367HC-R47M BCIH1367HC-R56M BCIH1367HC-R68M BCIH1367HC-R82M BCIHP1367-1R0M BCIHP1367-1R2M BCIHP1367-1R5M BCIHP1367-2R2M BCIHP1367HC-3R3M BCIHP1367HC-4R7M BCIHP1367HC-5R6M BCIHP1367-6R0M BCIHP1367-6R8M BCIHP1367HC-8R2M BCIHP1367HC-100M BCIHP1367-101M BCIHP1367-120M BCIHP1367-150M BCIHP1367-180M BCIHP1367HC-220M BCIHP1367-330M BCIHP1367-470M BCIHP1367-560M BCIHP1367HC-680M BCIHP1367-820M BCIHP1367-R47M BCIHP1367-R56M BCIHP1367-R82M INDUCTANCE uH (1) @200KHZ,0.25V,0A 0.30 0.33 0.36 0.40 0.47 0.56 0.68 0.82 1.00 1.20 1.50 2.20 3.30 4.70 5.60 6.00 6.80 8.20 10.00 100.00 12.00 15.00 18.00 22.00 33.00 47.00 56.00 68.00 82.00 0.47 0.56 0.82 40.00 DCR mΩ 25℃TYP DCR mΩ 25℃ MAX HEAT RATING SATU RATION CURRENT DC AMPS CURRENT DC AMPS (5) 0.50 0.51 0.75 0.60 0.75 0.90 1.00 1.55 1.80 2.20 2.40 3.90 5.50 9.80 10.50 10.70 13.80 15.10 17.50 240.00 21.50 26.00 39.00 27.00 70.00 113.00 140.00 150.50 170.00 1.25 1.30 1.70 0.80 0.80 0.90 1.00 1.20 1.40 1.60 1.90 2.00 2.80 3.00 4.20 6.80 11.20 11.50 12.60 14.90 16.60 18.50 265.00 25.00 32.00 43.00 36.00 82.00 145.00 165.00 172.00 205.00 1.40 1.40 1.90 TYPICAL(Irms) 48.00 46.00 45.00 44.00 41.00 37.00 35.00 33.00 32.00 25.00 27.00 22.00 18.00 13.50 12.00 12.00 11.50 10.50 10.00 2.50 8.00 7.00 6.50 5.00 4.00 4.00 3.50 3.00 2.80 30.00 35.00 33.00 (6) TYPICAL(Isat) 72.00 65.00 64.00 64.00 63.00 62.00 51.00 50.00 49.00 42.00 45.00 35.00 29.00 25.00 24.00 22.00 16.50 13.00 15.50 4.00 14.00 11.00 10.00 8.00 7.00 7.00 6.00 5.00 5.00 62.00 62.00 50.00 Cheng Yang Electronics Corp Ltd 19 JAN 2016 www.baocheng.biz TAPE BCIH/IHP1338/50/67-Series P: 4 / 10 (SMD Power Inductors) Powder Molding Type BCIH/IHP1338/50/67-Series (1) (2) (3) (4) (5) (6) (7) (1) (2) (3) (4) (5) (6) (7) Tolerance of Inductance: N=±30% ,M=±20%. All test data is referenced to 25℃ ambient. Inductance is measured at 200KHz. 25℃ ambient. Operating Temperature Range-40℃ to +125℃. DC current (Irms) (A) that will cause an approximate △T of 40℃. DC current (Isat) (A) that will cause Lo to drop approximately 20%. The part Temperature (ambient + temp rise) should not exceed 125℃ under worst case operating conditions. Circuit design, component placement, PWB trace size and thickness, airflow and other cooling provisions all affect the part temperature Part temperature should be verified in the end application. 電感的公差:N=±30%,M=±20%. 所有的測試資料應該是在 25℃的環境溫度下測試. 感值測試頻率 200KHz. 操作溫度範圍-40℃到+125℃. 加 DC(Irms)電流值(A)會導致△T 40℃左右的變化. 加 DC(Isat)電流值(A)會導致初始值下降 20%左右. 產品的溫度不能超過 125℃,即使在最壞的操作情況下,基板設計,元件放置,PWB 尺寸和厚度, 氣流和一些冷卻設備都會影響產品溫度,產品溫度要在最終應用時才被驗證. Cheng Yang Electronics Corp Ltd 19 JAN 2016 www.baocheng.biz TAPE BCIH/IHP1338/50/67-Series P: 5 / 10 (SMD Power Inductors) Powder Molding Type BCIH/IHP1338/50/67-Series ● Material List NO ITEM 1 Core 2 Wire 3 External Electode IH / IHP Electroplating 4 Paint Materials Magnetic Metal Powder or equivalen Polyester Wire or equivalen Copper Wirw / Copper Sn / Ni/Sn Epoxy resin ● Packaging Information (1) Reel Dimension & Tape Dimension / Packaging Quantity ITEN DIMENSIONS (m/m) Q’TY (PCS) W1±0.3 W2±0.5 W±0.3 A0±0.1 B0±0.1 K0±0.1 P±0.1 F±0.1 T±0.05 BCIH1338 500 24.80 29.00 24.00 13.20 13.90 4.00 20.00 11.50 0.40 BCIHP1338 500 24.80 29.00 24.00 13.20 13.90 4.00 20.00 11.50 0.40 BCIH1350 250 24.80 29.00 24.00 13.20 13.90 5.30 20.00 11.50 0.40 BCIHP1350 250 24.80 29.00 24.00 13.20 13.90 5.30 20.00 11.50 0.40 BCIH1367 250 24.80 29.00 24.00 13.20 13.90 7.00 20.00 11.50 0.40 BCIHP1367 250 24.80 29.00 24.00 13.20 13.90 7.00 20.00 11.50 0.40 (2) Tearing Off Force The force tearing off cover 10 to 130 grams (0.1N to 1.3N) in the arrow direction under the following conditions. ● Storage conditions/Note things (1) Storage temperature and humidity conditions : 1. Product packing with Carrier tape: +5℃~+40℃ and less than 60% RH. 2. Product alone: -20℃~+60℃ and less than 60% RH. (2) Products should be used within 6 months. (3) The packaging material should be kept where no chlorine or sulfur exists in the air. (4) Do not touch the electrodes (soldering terminals) with fingers as this may lead to deterioration of solder ability (5) The use of tweezers or vacuum pick-ups is strongly recommended for individual components. (6) Bulk handling should ensure that abrasion and mechanical shock are minimized. Cheng Yang Electronics Corp Ltd 19 JAN 2016 www.baocheng.biz TAPE BCIH/IHP1338/50/67-Series P: 6 / 10 (SMD Power Inductors) SMD Power Inductors BCIH/IHP1338/50/67-Series ● Package for standard ITEM Packing method & Dimensions Box Size W=345mm D=345mm H=185mm ITEM Packing Quantity Reel Quantity Total Quantity BCIH1338 500 Pcs/Reel (2.00Kg(Ref)) 5 Reel/Box 2,500 Pcs/Box (11.0Kg(Ref)) BCIHP1338 500 Pcs/Reel (2.00Kg(Ref)) 5 Reel/Box 2,500 Pcs/Box (11.0Kg(Ref)) BCIH1350 250 Pcs/Reel (1.50Kg(Ref)) 5 Reel/Box 1,250 Pcs/Box (8.30Kg(Ref)) BCIHP1350 250 Pcs/Reel (1.50Kg(Ref)) 5 Reel/Box 1,250 Pcs/Box (8.30Kg(Ref)) BCIH1367 250 Pcs/Reel (1.85Kg(Ref)) 5 Reel/Box 1,250 Pcs/Box (10.0Kg(Ref)) BCIHP1367 250 Pcs/Reel (1.85Kg(Ref)) 5 Reel/Box 1,250 Pcs/Box (10.0Kg(Ref)) Cheng Yang Electronics Corp Ltd 19 JAN 2016 www.baocheng.biz TAPE BCIH/IHP1338/50/67-Series P: 7 / 10 (SMD Power Inductors) Powder Molding Type BCIH/IHP1338/50/67-Series ● General Characteristics Operation Temperature External Appearance -40℃ to +125℃ (Includes temperature when the coil is heated) On visual inspection, the coil has no external defects. ● Electrical Performance Test Inductance DCR Refer to standard electrical characteristics list. BCIH/IHP1338/50/67-Series △L≦20% typical. Saturation Current(Isat) Heat Rated Current(Irms) Approximately △T≦40℃. ● Reliability Test Solder Ability Test 1. More than 90% of terminal electrode should be covered with solder.  After fluxing, component shall be dipped in a melted.  Solder: bath at 245℃±5℃ for 5±0.5 seconds. 1. 2. Heat resistance of  Reflow Soldering Test    1. Adhesion strength Test Components should have not evidence of electrical and mechanical damage. Inductance: within±10% of initial value. Preheat:150±5℃ 60seconds. Solder temperature: 255+5℃/-0℃. Flux: rosin. Dip time:10±0.5seconds. No apparent damage  Product is mounted on PCB. Thereafter R340 pressure fixture is used to apply pressure to product from backside of the board at a rate of approx. 1mm/sec. until bending width becomes 1mm and keep it for 5sec. 1. No separation or indication of electrode. static load using a R5.0 pressing tool shall be applied to the Welding strength Test  A body of the specimen in the direction of the arrow and shall be hold for 3±1 sec. Insulating Resistance Over 100MΩ at 100V D.C. between coil and core. Dielectric Strength Vibration Test Drop Test No dielectric breakdown at 30V D.C. for 1 minute between coil and core. 1. No separation or Inductance deviation within +10% after vibration for 1 indication of hour. In each of three orientations at Sweep vibration (10~55~10HZ) with 1.5mmP-P amplitudes. electrode. 2. △L/L≦15% Inductance deviation within +10% after being dropped once with 981m/s2 (100G) shock Attitude upon a rubber block method shock testing machine, in three different orientations. Cheng Yang Electronics Corp Ltd 19 JAN 2016 www.baocheng.biz TAPE BCIH/IHP1338/50/67-Series P: 8 / 10 (SMD Power Inductors) Powder Molding Type BCIH/IHP1338/50/67-Series ● Reliability Test Item High Temperature Storage Test Low Temperature Storage Test High Temperature Humidity Test Thermal Shock Test Storage Test Required Characteristics 1. No case deformation or change in appearance 2. △L/L≦15% 3. △Q/Q≦30% 4. △DCR/DCR≦15%  Temperature:125℃±3℃ Time:96±2 hours.  Tested not less than 1 hour, nor more than 2 hours at room. Test Method/Condition 1. No case deformation or change in appearance 2. △L/L≦15% 3. △Q/Q≦30% 4. △DCR/DCR≦15%  Temperature:-40℃±3℃ Time:96±2 hours.  Tested not less than 1 hour, nor more than 2 hours at room. 1. No case deformation or change in appearance 2. △L/L≦15% 3. △Q/Q≦30% 4. △DCR/DCR≦15%  Temperature:85℃±3℃.  Humidity:85±5%RH  Test Time:96±2 hours  Tested not less than 1 hour. Nor more than 2 hours at room temperature. 1. No case deformation or change in appearance 2. △L/L≦15% 3. △Q/Q≦30% 4. △DCR/DCR≦15%  First–40℃ for 30 Minutes, last 125℃ for 30 Minutes as 1 cycle. Go through 20 cycles. Cheng Yang Electronics Corp Ltd 19 JAN 2016 www.baocheng.biz TAPE BCIH/IHP1338/50/67-Series P: 9 / 10 (SMD Power Inductors) Powder Molding Type BCIH/IHP1338/50/67-Series ● Soldering re-flow IPC/JEDEC J-STD-020C, Figure 5-1 Cheng Yang Electronics Corp Ltd 19 JAN 2016 www.baocheng.biz TAPE BCIH/IHP1338/50/67-Series P: 10 / 10 (SMD Power Inductors) Powder Molding Type BCIH/IHP1338/50/67-Series ● Modify records Numbering Date Modify content Cheng Yang Electronics Corp Ltd 19 JAN 2016 www.baocheng.biz TAPE BCIH/IHP1338/50/67-Series P: 11 / 10
BCIH1367-8R2M 价格&库存
很抱歉,暂时无法提供与“BCIH1367-8R2M”相匹配的价格&库存,您可以联系我们找货
