CMF3216F-601M-2P-T
CMF3216F-601M-2P-T
    EMTEK(兆欣)
    共模电感 1206
CMF3216F-601M-2P-T 数据手册
PRODUCT SPECIFICATION SPEC. NO: 新弘智 DATE: T-0602-015H Nov.27,2018 CUSTOMER'S PRODUCT NAME: EMTEK PRODUCT NAME: CMF3216F-M Series THIS SPECIFICATION IS: □ FULLY ACCEPTED □ DENIED □ ACCEPTED UNDER THE FOLLOWING CONDITIONS SIGNATURE: NAME(PRINT): TITLE: 本文件內容全部或部份,未經兆欣科技股份有限公 司同意不得以任何形式複製或其他用途 All rights reserved.This document or parts thereof,may not be reproduced by any means or used in any manner witout written permission of EMTEK CO.,LTD. DATE: FACTORY: 39,Chingao Rd.,(305)Hsinpu, Hsinchu Hsien,Taiwan,R.O.C TEL: 03-5894-433 FAX: 03-5894-523 1/9 PRODUCT SPECIFICATION SPEC. NO. T-0602-015H 1. Scope This specification applies ferrite Chip common mode filters CMF3216F-M Series to be delivered to user 2. Product Identification CMF 3216 F - 900 M - 2P - T (1) (2) (3) (4) (5) (6) (7) (1) Product name (2) Shapes and dimensions (3) Shielding Type (4) Impedance【 at 100MHz】 900:90Ω (5) Impedance Tolerance M : 20% (6) Number of Line 2P:2-Line (7) Taping Type 3. Shapes and Dimensions [Dimensions in mm] B A A : 3.2 ± 0.2 Epoxy C B : 1.6 ± 0.2 C : 1.8 ± 0.2 Terminations Wires ① ④ (0.6) (0.6) ② (0.6) ③ Equivalent circuit ① ④ ② ③ No Polarity (0.6) Drawn by Checked by Approved by 2/9 SPEC. NO. PRODUCT SPECIFICATION T-0602-015H 4. Electrical Characterisitics 4-1 Electrical Spec. Common-Mode DC Rated Current Impedance Resistance Idc(mA) Max. Z(Ω) at 100MHz Rdc(Ω) Max. 37 ±20% CMF3216F-370M-2P-T 0.12 1000 50 ±20% CMF3216F-500M-2P-T 0.20 500 67 ±20% CMF3216F-670M-2P-T 0.30 500 Our Product Part Number Rated Voltage Vdc(V) Withstanding Voltage Vdc(V) 50 50 50 125 125 125 Insulation Resistance (MΩ)Min. 10 10 10 CMF3216F-900M-2P-T 90 ±20% 0.30 500 50 125 10 CMF3216F-121M-2P-T 120±20% 0.30 370 50 125 10 CMF3216F-161M-2P-T 160 ±20% 0.40 340 50 125 10 CMF3216F-261M-2P-T 260±20% 0.50 310 50 125 10 CMF3216F-601M-2P-T 600±20% 0.80 260 50 125 10 CMF3216F-102M-2P-T 1000±20% 1.00 230 50 125 10 CMF3216F-222M-2P-T 2200±20% 1.20 200 50 125 10 4-2Characteristics(Reference) CMF3216F-370M-2P-T CMF3216F-670M-2P-T 1000 10000 Common mode Common mode Differential mode Differential mode 100 Z (ohm) Z ( ohm) 1000 100 10 10 1 1 1 10 Frequency(MHz) 100 1 10 100 Frequency(MHz) 1000 CMF3216F-161M-2P-T CMF3216F-900M-2P-T 10000 0.1 1000 1000 Common Mode Common Mode Differential Mode Differential Mode Impendance(OHM) Impedance(OHM) 1000 100 10 1 100 10 1 1 10 100 Frequency(MHz) 1000 1 10 100 Frequency(MHz) 1000 3/9 SPEC. NO. PRODUCT SPECIFICATION T-0602-015H 4-2Characteristics(Reference) CMF3216F-261M-2P-T 10000 CMF3216F-601M-2P-T Common Mode 10000 Common Mode Differential Mode Differential Mode 1000 Impedance(OHM) Impedance(OHM) 1000 100 10 100 10 1 1 10 100 1 1000 1 Frequency(MHz) 1000 CMF3216F-222M-2P-T 10000 Common Mode Common Mode Differential Mode Differential Mode 1000 Impedance(OHM) 1000 Impedance(OHM) 100 Frequency(MHz) CMF3216F-102M-2P-T 10000 10 100 100 10 10 1 1 1 1 10 100 Frequency(MHz) 1000 10 100 Frequency(MHz) 1000 4/9 PRODUCT SPECIFICATION SPEC. NO. 4-3 Test Equipment 4-3-1 Impedance Measured by using Agilent E4991A RF Impedance Analyzer. Measurement terminal ① ④ ② ③ 4-3-2 DC Resistance Measured by using Chroma 16502 mill ohm meter. Measurement terminal ① ④ ② ③ Measurement terminal 4-3-3 Insulation Resistance Measured by using Chroma 19073 Measurement voltage : 50v. Measurement terminal ① ④ ② ③ T-0602-015H 5/9 PRODUCT SPECIFICATION SPEC. NO. T-0602-015H 5. Reliability Test Operating temperature : -25 to +85℃ Specifications Item It can be connected on the Solder ability Terminal strength Storage temp and humidity : 20~25℃ ,60%RH max. Test conditions Apply cream solder to the test circuit board . Recommendation soldering condition. It is mounted on the recommendation soldering condition. The terminal electrode and the ferrite Solder a chip to test substrate , and then laterally apply a must not be damaged. load 0.9Kg in the arrow direction. φ1.0 Test Board Strength on The terminal electrode and the ferrite pc board must not be damaged. bending Soldering a chip to a test substrate , bend the substrate by 2mm and then return. 45 45 Width side 40 100 10 20 length Force Dimensions in mm R10 Test board : Glass base epoxy multiplayer board pc board pattern. PC board pattern : Recommended PC board pattern. 6/9 PRODUCT SPECIFICATION Specifications Item High Appearance : Ferrite shall not be temperature damaged. resistance Impedance : Within ±20% of the initial value. insulation resistance: >10(MΩ) DC resistance : standard value inside. Humidity resistance Thermal cycle SPEC. NO. T-0602-015H Test conditions Temperature : +85±2℃ Applied voltage : Rated voltage Applied current : Rated current Testing time : 50±12 hours Measurement : After placing for 24 hours min. Temperature : +85±2℃ Humidity : 90 to 95%RH Applied current : Rated current Applied voltage : Rated voltage Testing time : 500±12 hours Measurement : After placing for 24 hours min. Temperature : -25℃,+85℃ kept stabilized for 30 minutes each. Cycle : 5 cycle Measurement : After placing for 24 hours min. 1 cycle +85℃ -25℃ Low temperature resistance Vibration 30 min. 3 min 30 min. Temperature : -25±2℃ Testing time : 48±12 hours Measurement : After placing for 24 hours min. Appearance : Ferrite shall not be damaged. Frequency : 10 to 50 Hz Amplitude : 1.52 mm Dimension and times : X ,Y and Z directions for 2 hours each. 7/9 SPEC. NO. PRODUCT SPECIFICATION T-0602-015H 6.Packaging The packaging must be done not to receive any damage during transporting and storing 6-1 Tape dimensions Ko P1 P0 P W Bo t Ao ( Dimensions in mm; Tolerance:±0.1) Symbol Dimension W 8 P 4 P0 P1 4 2 Ao 1.75 Bo 3.45 Ko 2 t 0.23 6-2 Reel dimensions D ( Dimensions in mm ) Symbol C B A B C D E A E 6-3 Tapping figure Top cover tape Carrier tape Sprocket hole Cavity (chip insert) T 180 60 13 14.4 8.4 8/9 SPEC. NO. PRODUCT SPECIFICATION T-0602-015H 6-4 Packaging Form There shall not continuation more than two vacancies of the product. (360 mm) Blank Leader. Blank Chip (70 pitches) (50 pitches) ( ): Reference Material of carrier tape : Polystyrene Material of cover tape : Polyester 6-5 Cover Tape Peel Strength The force for tearing off cover tape is 0.05~0.69(N) in the arrow direction at the following conditions: Temperature : 5 ~ 35℃ Humidity : 45 ~ 85% Atmospheric pressure : 860 ~ 1060 hpa 160 ~ 180。 Top cover tape Base tape 6-6 Packing Quantity φ180 mm reel T type : 2000 pcs./reel 9/9 SPEC. NO. PRODUCT SPECIFICATION T-0602-015H 7. Recommended Soldering Conditions (Please use this product by reflow soldering) 7-1 Recommended Footprint Termination Number : Please refer to the equivalent circuit in chapter 3. 0.4 0.6 3.7 1.6 1.05 1.6 7-2 Recommended Reflow Pattern Reflow : until two times 10sec. Min. 255℃ 217℃ Natural cooling 150sec Max.. 150℃ 60sec. Min. 7-2 Iron Soldering Use a solder iron of less than 30W when soldering ,do not allow the soldering iron tip directly touch the ferrite body outside of terminal electrode. 5 seconds max. at 260℃. 8. Attention in Case of Using In case of using product ,please avoid following matters: Splashing water or salt water Dew condenses Toxic gas (Hydrogen sulfide, Sulfurous acid ,Chlorine, Ammonia) Vibrations or shocks which exceed the specified condition Please be careful for the stress to this product by board flexure or something after the mounting. 9. Other Recommended wire wound inductors should be used within 6 months from the time of delivery.
CMF3216F-601M-2P-T
物料型号:CMF3216F-M Series
器件简介:文档是关于EMTEK公司生产的共模滤波器的规格说明书。
引脚分配:共模滤波器有两个引脚,没有极性标识。
参数特性: - 阻抗:不同型号的共模滤波器在100MHz下的阻抗值不同,例如CMF3216F-370M-2P-T为37Ω,阻抗公差为±20%。 - DC电阻:最大值根据不同型号有所变化,例如CMF3216F-370M-2P-T为0.12Ω。 - 额定电流:最大值通常为500mA或1000mA。 - 额定电压:50V。 - 耐压:125V。 - 绝缘电阻:最小值为10MΩ。
功能详解:共模滤波器用于抑制电源线或信号线上的共模噪声,提高电磁兼容性。
应用信息:适用于需要电磁干扰抑制的电子设备。
封装信息:封装尺寸为3.2mm x 1.6mm x 1.8mm,环氧树脂封装。
CMF3216F-601M-2P-T 价格&库存
很抱歉,暂时无法提供与“CMF3216F-601M-2P-T”相匹配的价格&库存,您可以联系我们找货
