MPCA-0530-R68-M
MPCA-0530-R68-M
    MAZO(玛冀)
    SMD,5.4x5.2mm
    功率电感 SMD
MPCA-0530-R68-M 数据手册
Kun Shan MAZO tech Co., Ltd Page : 1/8 昆山瑪冀電子有限公司 High Current, Power Inductors MPCA-0530-XXX-M Power Choke Applications • Voltage Regulator Module (VRM) • Multi-phase regulators • Point-of-load modules • Smart phone POL modules • SSD modules Description • Notebook regulators • Halogen Free • Battery power systems • 125°C maximum total temperature operation • Graphics cards • 5.7 x 5.4 x 3.0mm maximum surface mount package • Data networking and storage systems • Powder iron core material Environmental Data • Magnetically shielded, low EMI •Storage temperature range: -55°C to +125 °C • High current carrying capacity, Low core losses •Operating temperature range: -55°C to +125°C • Frequency range up to 5MHz (ambient plus self-temperature rise) • RoHS compliant •Solder reflow temperature: J-STD-020D compliant Description MPCA-0530-1R0-M 1.0μH ±20 % Model Inductance Value Inductance Tolerance Global Part Number M P C Product Series A 0 5 3 Dimensions 0 1 R 0 Inductance Value M Tol. Kun Shan MAZO tech Co., Ltd Page : 2 / 9 昆山瑪冀電子有限公司 Part No. Inductance DC Resistance Heating Rating Current Saturation Current L0 (μH) DCR (mΩ) Idc (A) Isat (A) ±20 %, 100 kHz, 1V TYP. MAX. TYP. TYP. MPCA-0530-R10-M 0.10 2.4 3.0 25.0 33.0 MPCA-0530-R20-M 0.20 3.5 3.9 14.0 14.5 MPCA-0530-R33-M 0.33 4.5 5.5 14.0 18.0 MPCA-0530-R47-M 0.47 7.4 8.5 11.0 12.0 MPCA-0530-R68-M 0.68 11.0 12.0 9.0 11.5 MPCA-0530-1R0-M 1.0 13.0 14.0 8.5 11.0 MPCA-0530-1R2-M 1.2 15.0 16.0 8.5 11.0 MPCA-0530-1R5-M 1.5 20.0 25.0 8.2 8.5 MPCA-0530-2R2-M 2.2 25.0 29.0 7.0 7.5 MPCA-0530-3R3-M 3.3 32.0 38.0 5.5 6.0 MPCA-0530-4R7-M 4.7 50.0 60.0 4.5 5.0 MPCA-0530-6R8-M 6.8 75.0 90.0 3.5 4.0 MPCA-0530-100-M 10.0 110.0 125.0 3.2 3.5 Notes 1. All test data is referenced to 25 °C ambient 2. Operating temperature range - 55 °C to + 125 °C 3. Idc(A):DC current (A) that will cause an approximate ΔT of 40 °C(reference ambient temperature is 25 °C) 4. Isat(A):DC current (A) that will cause L0 to drop approximately30 % 5. The part temperature (ambient + temp rise) should not exceed 125 °C under worst case operating conditions. Circuit design, component placement, PWB trace size and thickness, airflow and other cooling provisions all affect the part temperature. Part temperature should be verified in the end application. Kun Shan MAZO tech Co., Ltd Page : 3 / 9 昆山瑪冀電子有限公司 •Dimensions-mm Marking The inductor is marked with a 3-digit code Example - -1.0→1R0 Note:Using Ink for marking Kun Shan MAZO tech Co., Ltd Page : 4 / 9 昆山瑪冀電子有限公司 Performance Graphs Test Instruments Test Condition Temperature: 26 ± 3℃ Wayne kerr 3260B/G LCR Meter Humidity: < 70% RH Wayne kerr 3265B Bias Current Source Frequency: 100 KHz, 1.0V 0.06 80 0.16 60 INDUCTANCE(μH) 40 0.02 20 0 0 80 TEMP RISE(℃) 0.12 0.08 40 0.04 20 0 0 0 2 4 6 8 10 12 14 16 18 20 22 24 DC BIAS(Amps) 5 10 15 20 25 30 35 40 45 50 DC BIAS(Amps) MPCA-0530-R47-M 100 0.47 0.264 80 0.376 TEMP RISE(℃) 0.198 60 INDUCTANCE(μH) 0.132 40 0.066 20 0 INDUCTANCE(μH) 0.33 TEMP RISE(℃) INDUCTANCE(μH) MPCA-0530-R33-M 3 6 100 80 TEMP RISE(℃) 0.282 60 INDUCTANCE(μH) 0.188 40 0.094 20 0 0 0 0 0 9 12 15 18 21 24 27 30 33 2 4 6 MPCA-0530-R68-M 0.408 60 INDUCTANCE(μH) 40 0.136 20 0 0 0 2 4 6 8 10 12 DC BIAS(Amps) 14 16 INDUCTANCE(μH) 80 TEMP RISE(℃) 0.272 10 12 14 16 18 MPCA-0530-1R0-M 1 100 TEMP RISE(℃) INDUCTANCE(μH) 0.544 8 DC BIAS(Amps) DC BIAS(Amps) 0.68 60 INDUCTANCE(μH) TEMP RISE(℃) 0 100 0.8 100 80 TEMP RISE(℃) 0.6 60 INDUCTANCE(μH) 0.4 40 0.2 20 0 0 0 2 4 6 8 10 12 DC BIAS(Amps) 14 16 TEMP RISE(℃) 0.04 MPCA-0530-R20-M TEMP RISE(℃) TEMP RISE(℃) 0.2 INDUCTANCE(μH) INDUCTANCE(μH) 0.08 100 TEMP RISE(℃) MPCA-0530-R10-M 0.1 Kun Shan MAZO tech Co., Ltd Page : 5 / 9 昆山瑪冀電子有限公司 80 1.2 TEMP RISE(℃) 0.72 60 INDUCTANCE(μH) 0.48 40 0.24 20 0 INDUCTANCE(μH) 1.5 TEMP RISE(℃) 4 6 8 10 12 14 80 TEMP RISE(℃) 0.9 60 INDUCTANCE(μH) 0.6 40 0.3 20 0 0 16 2 4 DC BIAS(Amps) 3.3 80 2.64 TEMP RISE(℃) 1.32 60 INDUCTANCE(μH) 0.88 40 0.44 20 0 INDUCTANCE(μH) 100 TEMP RISE(℃) INDUCTANCE(μH) 1.76 0 1 2 3 4 5 6 7 8 80 TEMP RISE(℃) 1.98 60 INDUCTANCE(μH) 1.32 40 0.66 20 0 9 10 0 0 1 2 3 6.8 80 5.44 60 INDUCTANCE(μH) 40 0.94 20 0 0 0 1 2 3 4 5 6 DC BIAS(Amps) 7 8 INDUCTANCE(μH) 2.82 100 TEMP RISE(℃) INDUCTANCE(μH) TEMP RISE(℃) 1.88 4 5 6 7 8 9 10 DC BIAS(Amps) MPCA-0530-4R7-M 3.76 14 100 DC BIAS(Amps) 4.7 12 MPCA-0530-3R3-M MPCA-0530-2R2-M 2.2 0 6 8 10 DC BIAS(Amps) TEMP RISE(℃) 2 100 0 0 0 MPCA-0530-1R5-M MPCA-0530-6R8-M 100 80 TEMP RISE(℃) 4.08 60 INDUCTANCE(μH) 2.72 40 1.36 20 0 0 0 1 2 3 4 5 DC BIAS(Amps) 6 7 TEMP RISE(℃) INDUCTANCE(μH) 0.96 100 TEMP RISE(℃) MPCA-0530-1R2-M 1.2 Kun Shan MAZO tech Co., Ltd Page : 6 / 9 昆山瑪冀電子有限公司 MPCA-0530-100-M 100 8 80 TEMP RISE(℃) 6 60 INDUCTANCE(μH) 4 40 2 20 0 0 0 0.5 1 1.5 2 2.5 3 3.5 4 4.5 5 DC BIAS(Amps) TEMP RISE(℃) INDUCTANCE(μH) 10 Kun Shan MAZO tech Co., Ltd Page : 7 / 9 昆山瑪冀電子有限公司 Mechanical Reliability Item Solderability Specification and Requirement Test Method The surface of terminal immersed shall Solder heat proof: be minimum of 95% covered with a new 1. Preheating: 160 ± 10 ℃ coating of solder 2. Retention time: 245 ± 5 ℃ for 2 ± 0.5 seconds 1. Vibration frequency: Inductance change: Within ± 10% Vibration Without mechanical damage such as break (10 Hz to 55 Hz to 10Hz) in 60 seconds as a period 2. Vibration time: Period cycled for 2 hours in each of 3 mutual perpendicular directions. 3. Amplitude: 1.5 mm max. Inductance change: Within ± 10% Shock Without mechanical damage such as break 1. Peak value: 100 G 2. Duration of pulse: 11ms 3. 3 times in each positive and negative direction of 3 mutual perpendicular directions Endurance Reliability Item Specification and Requirement Test Method 1. Repeat 100 cycles as follow: (-55 ± 2 ℃; 30 ± 3 min) Thermal Shock Inductance change: Within ± 10% Without distinct damage in appearance →(Room temp., 5 min) → (+125 ± 2 ℃, 30 ± 3 min) → (Room temp., 5 min) 2. Recovery: 48 + 4 / -0 hours of recovery under the standard condition after the test. High Temperature Resistance Inductance change: Within ± 10% Without distinct damage in appearance 1. Environment condition: 85 ± 2 ℃ Applied Current: Rated current 2. Duration: 1000 + 4 / -0 hours 1. Environment condition: 60 ± 2 ℃ Humidity Resistance Inductance change: Within ± 10% Humidity: 90–95% Without distinct damage in appearance Applied Current: Rated current 2. Duration: 1000 + 4 / -0 hours Low Temperature Store High Temperature Store Inductance change: Within ± 10% Store temperature: Without distinct damage in appearance -55 ± 2 ℃,1000 + 4 / -0 hours Inductance change: Within ± 10% Store temperature: Without distinct damage in appearance +125 ± 2 ℃,1000 + 4 / -0 hours Kun Shan MAZO tech Co., Ltd Page : 8 / 9 昆山瑪冀電子有限公司 Tape Packaging Dimensions Reel Dimensions A0 B0 K0 t 5.7 ± 0.10 5.9 ± 0.10 3.3 ± 0.15 0.35 ± 0.05 Kun Shan MAZO tech Co., Ltd Page : 9 / 9 昆山瑪冀電子有限公司 • Peel force of top cover tape The peel speed shall be about 300mm/minute The peel force of top cover tape shall be between 0.1 to 1.3 N • Numbers of taping 2000pieces/reel • Label making The following items shall be marked on the production and shipping Label on the reel • Production Label • Part No • Description • Quantity • Produce No • Taping No • Shipping Label (1)*Customer's name (2)*Customer's part No (3)Manufacturer's part No (4)Manufacturer's name (5) Manufacturer's country
MPCA-0530-R68-M
物料型号:MPCA-0530-XXX-M,其中XXX代表不同的电感值。
器件简介: - 应用于电压调节模块(VRM)、多相调节器、点对点模块、智能手机POL模块、SSD模块等。 - 包括笔记本电脑调节器、无卤素、电池电源系统、最大操作温度125°C、图形卡、数据网络和存储系统。 - 使用粉末铁芯材料,具有磁屏蔽、低EMI特性,频率范围高达5MHz。
引脚分配:未明确提及,但通常电感器的引脚分配会在其数据手册中详细说明。
参数特性: - 电感值(Inductance Value):不同型号有不同的电感值,如0.10μH、0.20μH等。 - 直流电阻(DC Resistance,DCR):电感器的直流电阻值,如MPCA-0530-R10-M型号为2.4 mΩ。 - 额定电流(Heating Rating Current Idc):在25°C环境温度下,电感器可以承受的直流电流,如MPCA-0530-R10-M型号为25.0A。 - 饱和电流(Saturation Current Isat):导致电感值下降约30%的直流电流,如MPCA-0530-R10-M型号为33.0A。
功能详解: - 电感器具有高电流承载能力、低核心损耗。 - 电感器的存储温度范围为-55°C至+125°C,工作温度范围为-55°C至+125°C。
应用信息: - 适用于需要高电流和低损耗的应用,如电源模块、电池管理系统等。
封装信息: - 电感器的最大表面贴装封装尺寸为5.7 x 5.4 x 3.0mm。 - 电感器的标记为3位数字代码,例如“1.0→1R0”,使用墨水进行标记。
性能图表:提供了不同型号电感器在不同直流偏置下的电感值与温度上升的关系图。
机械可靠性:包括焊接性、振动、冲击、耐热性、耐湿性、低温存储和高温存储等测试方法和要求。
胶带包装尺寸:提供了电感器胶带包装的尺寸信息。
卷轴尺寸:提供了电感器卷轴的尺寸信息。
MPCA-0530-R68-M 价格&库存
很抱歉,暂时无法提供与“MPCA-0530-R68-M”相匹配的价格&库存,您可以联系我们找货
