MLW1608-33N(F)
MLW1608-33N(F)
    MELED(美莱)
    IND-2P_1.8X1.25MM_SM
    固定电感器
MLW1608-33N(F) 数据手册
SPECIFICATION FOR APPROVAL CUSTOMER PART NO. 10NJ 12NJ 15NJ (f)/1R0K DESCRIPTION SMD CHIP INDUCTORS(ROHS) CUS.REV SAMPLE LOT NO P/N. MLW 1608 SERIES DATE Important Note to Customer If you approve this sample , please sign on the line below and return this page to: Customer Signature: TEST BY Date: CHECK BY APPROVED BY pass pass pass 2008-07-08 2008-07-08 2008-07-08 L.T.G J.D. Y.L. SPECIFICATION FOR APPROVAL CUSTOMER CUSTOMER P/N REV. SPL. LOT NO. PAGE ORIG PART NAME P/N REV. SMD CHIP INDUCTOR (ROHS) MLW 1608 SERIES 1/3 Q'TY DATE OF ISSUE ORIG EA 1. SCOPE : THIS SPECIFICATION APPLIES TO WIRE WOUND CHIP INDUCTORS. 2. PART NUMBERING : PRODUCT IDENTIFICTION MLW 1608 C - □□□ □ TOLERANCE INDUCTRANCE MATERIAL CODE DIMENSIONS PRODUCT SYMBOL 3. PART DIMENSION: F UNIT:mm SERIES MLW1608 4. A 1.80(MAX) B 1.12(MAX) C 1.02(MAX) D 0.64(MAX) RATING TEMPERATURE : OPERATING TEMPERATURE : -40℃ ~ 125℃ STORAGE TEMPERATURE : -40℃ ~ 125℃ 5. MARKING : IDENTIFIER(GRAY) Ex :MLW1608C10NJ MARKING : GRAY COLOR CODE MARK COLOR CODE IN COMPOSITE SPECIFICATION 10 E 0.64 F 1.02 SPECIFICATION FOAPPROVAL CUSTOMER CUSTOMER P/N REV. SPL. LOT NO. PAGE ORIG PART NAME P/N SMD CHIP INDUCTOR (ROHS) MLW 1608 SERIES 6. REV. 2/3 Q'TY DATE OF ISSUE ORIG EA STRUCTURE : 1 3 2 4 7. 8. MATERIAL LIST: ITEM PART DESCRIPTION 1 WIRE POLYSOL 155 2 CORE CERAMIC CORE 3 UV UV 4. TERMINAL PLATEING AgPd+Au+Ni TEST INSTRUMENT: 8-1 L、Q TEST BY HP4291B 8-2 SRF TSET BY HP 8753E 8-2 DCR TEST BY ZENTECH 502BC UL NO. E143312 SPECIFICATION FOR APPROVAL CUSTOMER CUSTOMER P/N REV. SPL. LOT NO. PAGE 3/3 ORIG PART NAME P/N SMD CHIP INDUCTOR (ROHS) 9. REV. Q'TY DATE OF ISSUE ORIG MLW 1608 SERIES EA SPECIFICATION: Part No. ML W 1608-1N6 ML ML ML ML ML W 1608–1N8 W 1608–2N2 W 1608–3N3 W 1608-3N6 W 1608-3N9 MLW1608-4N3 MLW1608-4N7 MLW1608-5N1 MLW1608-5N6 MLW1608-6N8 MLW1608-7N5 MLW1608-8N2 MLW1608-8N7 MLW1608-9N5 MLW1608-10N MLW1608-11N MLW1608-12N MLW1608-15N MLW1608-16N MLW1608-18N MLW1608-22N MLW1608-23N MLW1608-24N MLW1608-27N MLW1608-30N MLW1608-33N MLW1608-36N MLW1608-39N MLW1608-43N MLW1608-47N MLW1608-51N MLW1608-56N MLW1608-68N MLW1608-72N MLW1608-82N MLW1608-R10 MLW1608-R11 MLW1608-R12 MLW1608-R15 MLW1608-R18 MLW1608-R20 MLW1608-R21 MLW1608-R22 MLW1608-R25 MLW1608-R27 MLW1608-R33 MLW1608-1R0K Ind. (nH) Test Freq. (MHz) Inductance Tolerance 1.6 1.8 250 250 2.2 3.3 3.6 3.9 4.3 4.7 5.1 5.6 6.8 7.5 8.2 8.7 9.5 10 11 12 15 16 18 22 23 24 27 30 33 36 39 43 47 51 56 68 72 82 100 110 120 150 180 200 210 220 250 270 330 1UH Q Min SRF (MHz) Min DCR (Ohms) Max RATED CURRENT (mA) K,J K,J 24 16 12500 12500 0.030 0.045 700 700 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 200 200 200 200 150 150 150 150 150 150 100 100 100 100 100 100 K,J K,J K,J K,J K,J K,J K,J K , J, G K , J, G K , J, G K , J, G K , J, G J, G J, G J, G J, G J, G J, G J, G J, G J, G J, G J, G J, G J, G J, G J, G J, G J, G J, G J, G J, G J, G J, G J, G J, G J, G J, G J, G J, G J, G J, G J, G J, G 12 20 22 22 22 20 20 18 27 28 28 28 28 31 33 35 35 35 35 38 38 37 37 37 37 38 40 39 38 35 38 37 34 34 34 32 32 28 25 25 27 25 25 24 12500 5900 5900 6900 5900 5800 5700 5700 5800 4800 4700 4600 5400 4800 4000 4000 4000 3300 3100 3000 2850 2650 2800 2250 2300 2080 2200 2000 2000 1900 1900 1700 1700 1700 1400 1350 1300 990 990 900 895 900 822 520 0.04 8 0.055 0.063 0.08 0.063 0.106 0.109 0.115 0.115 0.116 0.118 0.129 0.135 0.13 0.13 0.13 0.17 0.16 0.17 0.19 0.195 0.20 0.21 0.22 0.23 0.24 0.25 0.28 0.28 0.27 0.31 0.34 0.49 0.54 0.58 0.61 0.75 0.92 1.25 1.98 2.06 2.1 2.3 2.6 700 600 600 600 500 500 500 500 400 400 400 400 400 400 400 400 400 400 300 300 300 300 300 300 300 300 300 250 250 250 250 250 250 250 250 250 250 250 200 200 200 200 190 170 100 7.9 J, G K.J, G 24 10 500 700 3.33 0.94 160 2800 Tolerance:M:±20%、K:±10%、J:±5%、G:±2% REMARK ENGINEERING DATA CUSTOMER: PART NO.: DESCRIPTION: REV NO.: SMD CHIP INDUCTORS(ROHS) PART NO.: DATE OF ISSUE: SAMPLE LOT NO.: QTY: L(nH) Q DCR MEAS @250MHZ @250MHZ (mΩ) ITEM SPEC TOL+ TOL- -20dBm -20dBm 10 31 130 2 5% 5% 10.3 9.70 Min 44 46 101 100 3 9.90 45 102 4 6 10.1 9.80 10.2 46 45 44 101 101 102 7 10.1 45 100 8 9.80 10.2 9.90 44 46 45 101 102 101 1 5 9 10 Max 11 12 13 14 15 16 17 18 19 20 21 22 24 25 REMARK: 1: Agilent4287A(16197A) 2: 温度为 23.5℃ 湿度为 65% TEST BY CHECKED BY APPROVED BY ML W 1608-10NJ 10Pcs ENGINEERING DATA CUSTOMER: PART NO.: DESCRIPTION: REV NO.: SMD CHIP INDUCTORS(ROHS) PART NO.: DATE OF ISSUE: SAMPLE LOT NO.: QTY: L(nH) Q DCR MEAS @250MHZ @250MHZ (mΩ) ITEM SPEC TOL+ TOL- -20dBm -20dBm 12 35 130 2 5% 5% 12.2 11.7 Min 43 45 110 108 3 12.1 44 109 4 6 12.3 12.2 11.8 45 46 45 108 111 108 7 11.6 44 109 8 11.9 12.1 12.4 44 46 46 107 110 107 1 5 9 10 Max 11 12 13 14 15 16 17 18 19 20 21 22 24 25 REMARK: 1: Agilent4287A(16197A) 2: 温度为 23.5℃ 湿度为 65% TEST BY CHECKED BY APPROVED BY ML W 1608-12NJ 10Pcs ENGINEERING DATA CUSTOMER: PART NO.: DESCRIPTION: REV NO.: SMD CHIP INDUCTORS(ROHS) PART NO.: DATE OF ISSUE: SAMPLE LOT NO.: QTY: L(nH) Q DCR MEAS @250MHZ @250MHZ (mΩ) ITEM SPEC TOL+ TOL- -20dBm -20dBm 15 35 170 2 5% 5% 15.5 14.8 Min 51 49 141 140 3 14.7 48 142 4 6 15.2 14.9 15.4 49 50 51 141 140 143 7 15.1 49 139 8 14.9 15.3 15.6 48 49 47 140 141 140 1 5 9 10 Max 11 12 13 14 15 16 17 18 19 20 21 22 24 25 REMARK: 1: Agilent4287A(16197A) 2: 温度为 23.5℃ 湿度为 65% TEST BY CHECKED BY APPROVED BY ML W 1608-15NJ 10Pcs
MLW1608-33N(F) 价格&库存
很抱歉,暂时无法提供与“MLW1608-33N(F)”相匹配的价格&库存,您可以联系我们找货
