www.jghcorp.com
【深圳市晶光华电子有限公司】
Extremely small SMD seam sealed clock oscillator unit;
Tri-State function available;
Low current consumption;
Small supply voltage shift;
Main application :Application for smart phone, sip module,
variety of compact portable consumer products;
RoHS Compliant / Pb Free。
Crystals specifications
ITEMS(项目)
PARAMETER(规格说明) O22
Output Type(输出模式)
CMOS
Output Load(输出负载条件)
15 pF , or specify
Oscillation Mode(振荡模式)
Fundamental
Supply Voltage(电源电压)
Frequency Range(输出频率范围)
1.8±10%V ; 2.5±10%V ;
3.3±10%V
4 ~ 54MHz
Frequency Stability
± 25 ppm ,± 50 ppm
Operating Temperature Range(工作温度)
- 10 ~ + 70 ℃ , - 40 ~ + 85 ℃
Storage Temperature Range(储存温度)
- 55 ~ + 125 ℃
Oscillating voltage(振荡电压)
Voltage Vol ( Max. )
10 % VCC Max.
Voltage Voh ( Min. )
90 % VCC Min
Rise ( Tr ) / Fall ( Tf ) Time:上升/下降时间
5 ns Max.
Current Consumption(功耗)
5 mA Max.
Symmetry(占空比)
40 ~ 60 %
Start-up Time(振荡启动时间)
5 ms Max.
Phase Jitter ( 12 KHz ~ 20 MHz )
Dimensions
1 ps Max.
Aging ( at 25 ℃ )频率老化
± 3 ppm / year Max.
Packing Unit(包装单位)
3,000pcs/Reel
很抱歉,暂时无法提供与“O2237125153350”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2.04768
- 10+1.62000
- 30+1.43856
- 100+1.21176
- 500+1.10808
- 1000+1.04976
