AS02FTE3002
AS02FTE3002
    VIKING(光颉)
    贴片电阻 0402
AS02FTE3002 数据手册
Data Sheet Customer: Product: Anti-Sulfurated Thick Film Chip Resistor - AS Series Size: 0201/0402/0603/0805/1206/1210/2010/2512 Issued Date: 12-Jan-18 Edition: REV.B6 VIKING TECH CORPORATION VIKING TECH CORPORATION KAOHSIUNG BRANCH VIKING ELECTRONICS (WUXI) CO., LTD. ( ) No.70 Guangfu N. Rd., Hukou Township, Hsinchu County 303, Taiwan No.248-3, Sin-Sheng Rd., Cian-Jhen Dist., Kaohsiung, 806, Taiwan TEL:886-3-5972931 FAX:886-3-5972935•886-3-5973494 E-mail:sales@viking.com.tw TEL:886-7-8217999 FAX:886-7-8228229 E-mail:sales@viking.com.tw No.22 Xixia Road, Machinery & Industry Park, National Hi-Tech Industrial Development Zone of Wuxi, Wuxi, Jiangsu Province, China Zip Code:214028 TEL:86-510-85203339 FAX:86-510-85203667•86-510-85203977 E-mail:china@viking.com.tw Produced by (QC) Checked (QC) Approved by (QC) Prepared by (Sales) 12-Jan-18 12-Jan-18 12-Jan-18 12-Jan-18 Susan Huang J.C. Liu J.C. Liu Accepted by (Customer) Anti-Sulfurated Thick Film Chip Resistor AS Series Anti-Sulfurated Thick Film Chip Resistor Scope This specification applies to all sizes of rectangular-type fixed chip resistors with Ruthenium-base as material. Features Special construction to prevent sulfuration in a sulfur containing environment Construction Applications High-end Computer L Industrial Equipment D1 Automatic Equipment Controller Medical Equipment     W T    High-end Multimedia Electronics Outdoor Electronic Applications  D2  Alumina Substrate  Bottom Electrode  Top Electrode  Edge Electrode  Barrier Layer  External Electrode  Resistor Layer  Primary Overcoat  Secondary Overcoat Dimensions D1 D2 (mm) T (mm) (mm) (mm) Weight (g) (1000pcs) 0.60±0.03 0.30±0.03 0.23±0.03 0.15±0.05 0.15±0.05 0.150 0402 1.00±0.05 0.50±0.05 0.35±0.05 0.20±0.10 0.20±0.10 0.620 AS03 0603 1.60±0.10 0.80±0.10 0.45±0.10 0.30±0.20 0.30±0.20 2.042 AS05 0805 2.00±0.10 1.25±0.10 0.50±0.10 0.35±0.20 0.40±0.20 4.368 AS06 1206 3.10±0.10 1.55±0.10 0.55±0.10 0.50±0.25 0.50±0.20 8.947 AS10 1210 3.10±0.10 2.60±0.15 0.55±0.10 0.50±0.25 0.50±0.20 15.959 AS0A 2010 5.00±0.10 2.50±0.15 0.55±0.10 0.60±0.25 0.50±0.20 24.241 AS12 2512 6.35±0.10 3.10±0.15 0.55±0.10 0.60±0.25 0.50±0.20 39.448 Type Size (Inch) L W (mm) AS01 0201 AS02 www.viking.com.tw For detail questions, contact sales@viking.com.tw 1 Edition: REV.B6 Revision: 12-Jan-2018 AS Series Anti-Sulfurated Thick Film Chip Resistor Part Numbering AS 03 F T E Product Type Dimensions Resistance Tolerance Packaging Code TCR (PPM/°C) 01: 0201 02: 0402 03: 0603 05: 0805 06: 1206 10: 1210 0A: 2010 12: 2512 D: ±0.5% F: ±1% J: ±5% T: Taping Reel 1003 Power Resistance Rating E: ±100 F: ±200 : Standard L: 1/12W X: 1/10W W: 1/8W V: 1/4W O: 1/3W U: 1/2W T: 1W - : No Specified R0R0: 0Ω 0010: 1Ω 1000: 100Ω 1002: 10KΩ 2201: 2.2KΩ 1003: 100KΩ 1004: 1MΩ Derating Curve Derating Curve Recommend Land Pattern 100 C B A Power ratio (%) . AS02 AS03 AS05 AS06 AS10 AS0A AS12 80 60 40 AS01 20 0 Type A (mm) B (mm) C (mm) AS01 0.30 0.25 0.30 AS02 0.50 0.45 0.60 AS03 0.90 0.60 0.90 AS05 1.20 0.70 1.30 AS06 2.00 0.90 1.60 AS10 2.00 0.90 2.80 AS0A 3.80 0.90 2.80 AS12 4.90 1.60 3.50 0 20 40 60 80 100 120 140 160 Ambient Temperature ( ℃ ) Soldering Condition IR Reflow Soldering Wave Soldering (Flow Soldering) (1) Time of IR reflow soldering at maximum temperature point 260C:10s (2) Time of wave soldering at maximum temperature point 260C:10s (3) Time of soldering iron at maximum temperature point 410C:5s www.viking.com.tw For detail questions, contact sales@viking.com.tw 2 Edition: REV.B6 Revision: 12-Jan-2018 AS Series Anti-Sulfurated Thick Film Chip Resistor Standard Electrical Specifications Power Rating at 70C Jumper Rated Current Item Type 1/20W AS01 (0201) Jumper: 1A Operating Temp. Range -55 ~ +125C 1/16W AS02 (0402) Max. Operating Voltage Max. Overload Voltage 25V 50V Resistance Range ±0.5% 1Ω - 9.76Ω 10Ω - 1MΩ 1.02MΩ - 10MΩ 100V 50V 1Ω - 9.76Ω 10Ω - 1MΩ 1.02MΩ - 10MΩ 100V Jumper: 1A 1/8W AS05 (0805) 150V 1Ω - 9.76Ω 10Ω - 1MΩ 1.02MΩ - 10MΩ 300V Jumper: 2A 1/4W AS06 (1206) -55 ~ +155C 200V 1Ω - 9.76Ω 10Ω - 1MΩ 1.02MΩ - 10MΩ 400V Jumper: 2A 1/3W AS10 (1210) 200V 1Ω - 9.76Ω 10Ω - 1MΩ 1.02MΩ - 10MΩ 400V Jumper: 2.5A 3/4W AS0A (2010) 200V 1Ω - 9.76Ω 10Ω - 1MΩ 1.02MΩ - 10MΩ 400V Jumper: 3.5A 1W AS12 (2512) 250V 1Ω - 9.76Ω 10Ω - 1MΩ 1.02MΩ - 10MΩ 500V Jumper: 4A ±200 ±100 ±200 0Ω (
AS02FTE3002 价格&库存
很抱歉,暂时无法提供与“AS02FTE3002”相匹配的价格&库存,您可以联系我们找货
