SLB1345P1R1MTT
1.Drawing(UNIT:mm)
ASSEMBLY
SCHEMATICS
1
2
2.ELECTRICAL CHARACTERISTICS@25℃
ITEM
SPEC. RANGE
L(0A)
1.1µH±20%
L(24A)
L(24A) 88%
TEST CONDITION
TEST INSTRUMENTS
DU-6021
100KHZ/1V
(Mode 1)
WK3260B&WK3265B
DU-6021
Rev.01
DCR
4.2 mOHM (MAX)
IR(COIL-CORE)
100MOHM MIN
DC 200V
DU-332
HIPOT(COIL-CORE)
1mA MAX
AC 250V(6S)
DU-332
Page 1 of 5
DU-5010
www.sunltech.com
SLB1345P1R1MTT
3.TEST DATA
ITEM
L(0A)
TEST CON.
L(24A)
DCR
100KHz/1V
L(24A)
4.2mOHM
≥88%
(COIL-CORE)
HIPOT
(COIL-CORE)
DC 200V
AC 250V(6S)
100MOHM
MIN
1mA MAX
IR
SPEC
1.1µH±20%
MAX
1.32
MIN
0.88
1
1.11
93.86%
3.73
OK
OK
2
1.10
93.88%
3.76
OK
OK
3
1.09
95.02%
3.78
OK
OK
4
1.14
92.79%
3.74
OK
OK
5
1.15
92.67%
3.70
OK
OK
MAX
4.2
1
100
REMARK:
Rev.01
Page 2 of 5
www.sunltech.com
SLB1345P1R1MTT
4.MATERIAL LIST
NO.
PART
NAME
DISCRIPTION
SUPPLIER
1
E CORE
AT0527-68
YZ
2
I CORE
AB0510P
YZ
3
COPPER
0.24*4.5TS
PREJECTION
4
EPOXY
S-T3
5
SOLDER
Sn96.5Ag3Ca0.5
REMARK
5. L VS IDC
L(uH)
L vs IDC
1.15
1.1
1.05
1
0.95
0.9
0.85
0.8
0.75
0.7
1.11
1.06
1.01
0.95
0.85
0A
8A
16A
24A
32A
current(A)
Rev.01
Page 3 of 5
www.sunltech.com
SLB1345P1R1MTT
6.PACKAGE
W
C
P
Carrier Dimensions:
P=20.0mm
C=11.5
11.5mm
C=
11.5
mm
W=24.0mm
Quantity per Reel: 400pcs
Reel Size:330mm
7.IR Profile
Temp(
C)
275
Rate of Rise:
2-3C/Sec Max.
Pre-Heat:
150C/90 Sec Max
220
165
Soak:
150-170C/60-90 Sec
110
Time Above217C:
45-75 Sec
cool down:
4C Max./Sec
55
120
180
240
300 360
Time(Seconds)
Rev.01
Page 4 of 5
www.sunltech.com
SLB1345P1R1MTT
8.GENERAL CHARACTERISTICS
Operating Temperature
-30 to+100℃(Contain Heating Coil)
Appearance Inspection
Terminal Strength
No external defects by visual inspection
After soldering,between copper plane and terminals
of coil,push in two directions of X ,Y with
X
standing as below conditions.
terminal should not peel off.
(refer to figure at left)
Y
HEAT endurance of
flow soldering
Isulating resistance
Dielectric Strength
Temperature characteristics
Humidity characteristics
Vibration resistance
Refer to figure (7.IR Profile)
Over 100MΩ at 200V D.C.between wire and core.
NO dielectric breakdown at 100V D.C. for 1minute
Inductance coefficient (0~2,000)x10 6/℃ (-25~+80℃)
Inductance deviation within±5%,after 96 hours
in 90~95% relative humidity at 40±2℃ and 1
hour drying under normal condition.
inductance deviation within±5%,after vibration for 1 hour.
In each of three orienations at sweep vibration
( 10~55~10Hz) with 1.5mm p-p amplitude.
Rev.01
Page 5 of 5
www.sunltech.com
