SLB1360P100MTT
SLB1360P100MTT
    SUNLTECH(顺磁)
    SMD
    功率电感 SMD
SLB1360P100MTT 数据手册
SLB1360P100MTT 1.Drawing(UNIT:mm) ASSEMBLY SCHEMATICS 1 2 2.ELECTRICAL CHARACTERISTICS @25℃ ℃ Rev.01 ITEM SPEC. RANGE L(0A) 10.0µH±20% L(10A) L(10A)≥70% DCR 13mOHM (MAX) IR(COIL-CORE) 100MOHM MIN DC 200V DU-332 HIPOT(COIL-CORE) 1mA MAX AC 250V(6S) DU-332 Page 1 of 5 TEST CONDITION TEST INSTRUMENTS DU-6021 100KHZ/1V (Mode 1) WK3260B&WK3265B DU-5010 www.sunltech.com SLB1360P100MTT 3.TEST DATA ITEM L(0A) TEST CON. L(10A) 温 升 DCR 100KHz/1V L(10A)≥70% 13mOHM IR(COIL-CORE) HIPOT (COIL-CORE) DC 200V AC 250V(6S) 100MOHM MIN 1mA MAX SPEC 10.0µH±20% MAX 12 MIN 8 1 9.0 84.42 65 11.15 OK OK 2 10.5 79.78 65 11.09 OK OK 3 10.11 79.89 65 11.12 OK OK 4 10.6 78.83 65 11.08 OK OK 5 9.1 84.32 65 11.14 OK OK 9(A) MAX 13 1 100 REMARK: Rev.01 Page 2 of 5 www.sunltech.com SLB1360P100MTT 4.MATERIAL LIST NO. PART NAME DESCRIPTION SUPPLIER 1 I CORE AT0510P YZ 2 E CORE AB0546-10 YZ 3 COPPER 0.2*2.4 PRJ. 4 EPOXY S-T3 SH 5 SOLDER Sn96.5Ag3Ca0.5 JX 6 Mar King screen printing ink(white) SGS No. 5. L VS IDC 0A 2A 4A 6A 10A 15A L vs IDC 9.4 9.19 9.01 8.78 8.47 8.02 10.50 10.20 9.90 L(u H) 9.60 9.40 9.19 9.30 9.01 8.78 9.00 8.47 8.70 8.40 8.02 8.10 7.80 0A 2A 4A 6A 10A 15A CURRENT(A) Rev.01 Page 3 of 5 www.sunltech.com SLB1360P100MTT 6.PACKAGE W C P Carrier Dimensions: Quantity per Reel:4 Reel:400pcs P=20 P=20.0mm 20.0mm C=1 3.0mm Reel Size:330mm C= 13.0 mm W=24 W=24.0mm 24.0mm 7.IR Profile Temp( C) 275 Rate of Rise: 2-3C/Sec Max. Pre-Heat: 150C/90 Sec Max 220 165 Soak: 150-170C/60-90 Sec 110 Time Above217C: 45-75 Sec cool down: 4C Max./Sec 55 0 60 120 180 240 300 360 Time(Seconds) Rev.01 Page 4of 5 www.sunltech.com SLB1360P100MTT 8.GENERAL CHARACTERISTICS Operating Temperature -30 to+100℃(Contain Heating Coil) Appearance Inspection No external defects by visual inspection Terminal Strength After soldering,between copper plane and terminals of coil,push in two directions of X ,Y with X standing as below conditions. terminal should not peel off. (refer to figure at left) Y HEAT endurance of Refer to figure 7(IR Profile) flow soldering Isulating resistance Over 100MΩ at 200V D.C.between wire and core. Dielectric Strength NO dielectric breakdown at 100V D.C. for 1minute Temperature characteristics between wire and core. Inductance coefficient (0~2,000)x10 6/℃ (-25~+80℃) Humidity characteristics Inductance deviation within±5%,after 96 hours in 90~95% relative humidity at 40±2℃ and 1 hour drying under normal condition. Vibration resistance inductance deviation within±5%,after vibration for 1 hour. In each of three orienations at sweep vibration ( 10~55~10Hz) with 1.5mm p-p amplitude. Rev.01 Page 5 of 5 www.sunltech.com
SLB1360P100MTT
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款光耦器件。
2. 器件简介:EL817是一种通用型晶体管输出光耦器件,具有较高的输入输出隔离电压和快速响应时间。
3. 引脚分配:EL817共有6个引脚,分别为1脚阳极,2脚阴极,3脚集电极,4脚发射极,5脚GND,6脚Vcc。
4. 参数特性:主要参数包括输入电流IFmax为50mA,输出电流Io为50mA,隔离电压VISO为5000Vrms。
5. 功能详解:EL817通过光电效应实现电信号的隔离传输,适用于需要电气隔离的场合。
6. 应用信息:广泛应用于通信设备、工业控制、医疗设备等领域。
7. 封装信息:采用DIP-6封装形式。
