AHP201610TF-R68M-1
AHP201610TF-R68M-1
    TAI-TECH(台庆)
    SMD
    功率电感 SMD
AHP201610TF-R68M-1 数据手册
P1 TAI-TECH Power Inductor AHP201610TF-SERIES ECN HISTORY LIST REV DATE DESCRIPTION APPROVED CHECKED DRAWN 1.0 15/02/16 新 發 行 楊祥忠 詹偉特 林宜蕰 備 註 www.tai-tech.com.tw P2 TAI-TECH Power Inductor AHP201610TF-SERIES 1. Features 1. This specification applies Low Profile Power Inductor. 2. 100% Lead(Pb) & Halogen-Free and RoHS compliant. 2. Dimension Halogen Pb Halogen-free Pb-free B A D E D C 3. Part Numbering AHP 201610 TF A B - C R24 M D E A: Series B: Dimension C: Lead Free Material D: Inductance E: Inductance Tolerance R24=0.24uH M=±20% 4. Specification TAI-TECH Part Number Inductance Tolerance (uH) (%) DCR (Ω) typ. DCR (Ω) Max. I sat (A) typ. I sat (A) Max. I rms (A) typ I rms (A) MAX AHP201610TF-R24M-1 0.24 ±20 0.026 0.032 6.80 5.90 4.20 3.70 AHP201610TF-R33M-1 0.33 ±20 0.032 0.038 6.00 5.50 4.0 3.60 AHP201610TF-R47M-1 0.47 ±20 0.035 0.044 5.20 4.30 3.60 3.20 AHP201610TF-R68M-1 0.68 ±20 0.056 0.064 4.20 3.60 2.90 2.60 AHP201610TF-1R0M-1 1.00 ±20 0.070 0.085 3.10 2.70 2.45 2.20 AHP201610TF-1R5M-1 1.50 ±20 0.105 0.125 2.90 2.60 2.30 2.00 AHP201610TF-2R2M-1 2.2 ±20 0.140 0.170 2.20 1.90 1.85 1.65 Note: 1. Test frequency : L : 1MHz /1.0V 2. Isat:Based on inductance change (△L/L0:≦-30%)@ ambient temp. 25℃ 3. Irms:Based on temperature rise (△T:40℃.)Max www.tai-tech.com.tw P3 TAI-TECH AHP201610TF-R24 0.4 0.45 Inductance(uH) Inductance(uH) 0.3 0.2 0.1 0 0 2 4 DCcurrent(mA) 6 8 0 AHP201610TF-R47 0.8 1.5 3 DCcurrent(mA) 4.5 6 3 4 AHP201610TF-R68 1.2 0.9 Inductance(uH) 0.6 Inductance(uH) 0.3 0.15 0 0.4 0.2 0.6 0.3 0 0 0 1 2 3 4 DCcurrent(mA) 5 0 1 AHP201610TF-1R0 2 2 DCcurrent(mA) AHP201610TF-1R5 3 1.5 2.4 Inductance(uH) Inductance(uH) AHP201610TF-R33 0.6 1 0.5 1.8 1.2 0.6 0 0 1 2 DCcurrent(mA) 3 4 0 0 AHP201610TF-2R2 4 Inductance(uH) 3 2 1 0 0 0.5 1 1.5 DCcurrent(mA) 2 2.5 www.tai-tech.com.tw 0.6 1.2 1.8 DCcurrent(mA) 2.4 3 P4 TAI-TECH 5. Material List No. Description Specification a. Core Metal Magnetic Core b. Coating Epoxy with Magnetic powder c Termination Tin (Pb Free) d Wire Enameled Copper Wire Appearance of exposed wire tolerance limit: 1. Width direction(dimension a):Acceptable when a≦w/2 Nonconforming when a>w/2 2. Length direction(dimension b):Dimension b is not specified. 3. The total area of exposed wire occurring to each sides is not greater than 50% of coating resin area, and is acceptable. 6. Reliability and Test Condition Item Operating Temperature Performance Test Condition -40~+125℃ Storage Temperature (on board) Electrical Performance Test Agilent-4291, Agilent-4287 Inductance L Refer to standard electrical characteristic list Agilent-4338 DC Resistance Rated Current Temperature Rise Test Base on temp. rise & △L/L0A≦30%. Saturation DC Current (Isat) will cause L0 to drop approximately △L(%). ΔT 40℃Max Heat Rated Current (Irms) will cause the coil temperature rise approximately △T(℃) without core loss. 1.Applied the allowed DC current. 2.Temperature measured by digital surface thermometer Mechanical Performance Test Appearance:No damage. Inductance:within±10% of initial value Solder Heat Resistance Temperature (°C) Time (s) Temperature ramp/immersion and emersion rate 260 ±5 (solder temp) 10 ±1 25mm/s±6 mm/s RDC:within ±15% of initial value and shall not exceed the specification value Depth: completely cover the termination www.tai-tech.com.tw Number of heat cycles 1 P5 TAI-TECH Item Solderability Test Performance More than 95% of terminal electrode should be covered with solder. Test Condition Preheat: 150℃,60sec.。 Solder: Sn99.5%-Cu0. 5%。 Temperature: 245±5℃。 Flux for lead free: Rosin. 9.5%。 Dip time: 4±1sec。 Depth: completely cover the termination Reliability Test Preconditioning:Run through IR reflow for 2 times.( IPC/JEDEC J-STD-020DClassification Reflow Profiles Temperature: 85±2℃ Life Test Applied current:rated current Duration:1000±12hrs Measured at room temperature after placing for 24±2 hrs Preconditioning:Run through IR reflow for 2 times.( IPC/JEDEC J-STD-020DClassification Reflow Profiles Step1:-40±2℃ 30±5min Step2:25±2℃ ≦0.5min Thermal shock Step3:105±2℃ 30±5min Number of cycles: 500 Measured at room temperature after placing for 24±2 hrs Appearance:No damage. Inductance:within±10% of initial value RDC:within ±15% of initial value and shall not exceed the specification value Preconditioning:Run through IR reflow for 2 times.( IPC/JEDEC J-STD-020DClassification Reflow Profiles Humidity:85±2﹪R.H, Humidity Resistance Test Temperature:85℃±2℃ Duration:1000hrs Min. with 100% rated current Measured at room temperature after placing for 24±2 hrs Preconditioning:Run through IR reflow for 2 times.( IPC/JEDEC J-STD-020DClassification Reflow Profiles Oscillation Frequency: 10~2K~10Hz for 20 minutes Equipment: Vibration checker Total Amplitude:1.52mm±10% Testing Time : 12 hours(20 minutes, 12 cycles each of 3 orientations)。 Vibration Test www.tai-tech.com.tw P6 TAI-TECH 7. Soldering and Mounting 7-1. Soldering Mildly activated rosin fluxes are preferred. TAI-TECH terminations are suitable for all wave and re-flow soldering systems. If hand soldering cannot be avoided, the preferred technique is the utilization of hot air soldering tools. 7-1.1 Solder re-flow: Recommended temperature profiles for re-flow soldering in Figure 1. 7-1.2 Soldering Iron(Figure 2): Products attachment with a soldering iron is discouraged due to the inherent process control limitations. In the event that a soldering iron must be employed the following precautions are recommended. ‧Preheat circuit and products to 150℃ ‧355℃ tip temperature (max) ‧Never contact the ceramic with the iron tip ‧1.0mm tip diameter (max) Reflow Soldering ‧Use a 20 watt soldering iron with tip diameter of 1.0mm ‧Limit soldering time to 4~5 sec. Iron Soldering PR E-HEATING SO LDERING N ATU RAL C O O LING PRE-HEATING SOLDERING within 4~5s TEMPERATURE(°C) TP(260 ℃ / 10s m ax.) TEMPERATURE(°C) tp(245° C / 20~40s.) 217 60~150s 200 150 60~180s 350 150 Gradual cooling Over 60s 480s m ax. 25 NATURAL COOLING Reflow times: 3 times max. TIME(sec.) TIM E( sec.) Iron Soldering times: 1 times max. Fig.1 Fig.2 7-2. Recommended PC Board Pattern H L L(mm) G(mm) H(mm) 2.3 0.7 1.7 G www.tai-tech.com.tw P7 TAI-TECH 8. Packaging Information 8-1. Reel Dimension C B D A Type A(mm) B(mm) C(mm) D(mm) 7”x8mm 8.4±1.0 50 min. 13±0.8 178±2 7"x8mm 8-2. Tape Dimension / 8mm t P Ao Bo Po:4±0.1 W:8.0±0.1 P2:2±0.05 Series Size AHP 201610 Bo(mm) Ao(mm) Ko(mm) P(mm) 2.5±0.1 2.0±0.1 1.40±0.1 4.0±0.1 t(mm) 0.23±0.05 Ko 8-3. Packaging Quantity Chip size 201610 Chip / Reel 2000 8-4. Tearing Off Force F Top cover tape The force for tearing off cover tape is 15 to 80 grams in the arrow direction under the following conditions. 165° to180° Base tape Room Temp. Room Humidity Room atm Tearing Speed (℃) (%) (hPa) mm/min 5~35 45~85 860~1060 300 Application Notice ‧Storage Conditions(component level) To maintain the solderability of terminal electrodes: 1. TAI-TECH products meet IPC/JEDEC J-STD-020D standard-MSL, level 1. 2. Temperature and humidity conditions: Less than 40℃ and 60% RH. 3. Recommended products should be used within 12 months form the time of delivery. 4. The packaging material should be kept where no chlorine or sulfur exists in the air. ‧Transportation 1. Products should be handled with care to avoid damage or contamination from perspiration and skin oils. 2. The use of tweezers or vacuum pick up is strongly recommended for individual components. 3. Bulk handling should ensure that abrasion and mechanical shock are minimized. www.tai-tech.com.tw
AHP201610TF-R68M-1 价格&库存
很抱歉,暂时无法提供与“AHP201610TF-R68M-1”相匹配的价格&库存,您可以联系我们找货
AHP201610TF-R68M-1
库存:73
