O11G2102M06EL23060
O11G2102M06EL23060
    WQC(威庆)
    插件,P=7.5mm
    安规电容 径向
O11G2102M06EL23060 数据手册
W Q C 東莞市威慶電子有限公司 DONGGUAN WEIQING ELECTRONIC CO., LTD SPEC NO.:2015102801 REV.:2015B 承 認 書 SPECIFICATION 客戶名稱(CUSTOMER): 1 立创 產品名稱(PRODUUCT NAME): Y1 安规电容 . 1 威慶料號(WEIQING PART NO.): O11G2102M06EL23010 102M/400V 承認規格(APPROVE ITEM): P=7.5MM L=23MM C216497 客戶料號(CUSTOMER PART NO): 。 . 送樣日期(SUBMIT THE SAMPLE DATE): 產品尺寸(PRODUUCT SIZE):1 樣品印字(SAMPLE PRINT): .. Y5V D*T=6*3.7MM 1 WQC 品牌 1 威 慶 確 認 表 WEIQING CONFIRM LIST APPROVED CHECKED PREPARED Base 陶贵能 陆丽 客 戶 承 認 結 果 CUSTOMER ACKNOWLEDGE THE RESULT 地址:中国东莞松山湖高新技术产业开发区科技十路 7 号 12 栋 Add: Building 12,No.7 Tenth Road of Science&Technology, DongGuan SongShan Loke High-tech Industrial SPEC NO.:2015102801 DONGGUAN WEIQING ELECTRONIC CO., LTD Approved/Recognized Type Related Standard Certificate NO Approved Monogram CQC (China) GB/T6346.14-2015 CQC18001201774(Y1) CQC18001201460(Y2) UL(USA) CSA(Canada) IEC 60384-14 E466405 ENEC (EU) EN 60384-14 ENEC-40049864 VDE (Germany) EN 60384-14 40050021(Y1) 40049864(Y2) KC(South Korea) KC60384-14(2015-09) KC60384-1(2015-09) SU03073-19002 (Y1) SU03073-19001 (Y2) Specifications Operating Temp.Range Applicable Standards Dielectric Withstanding Voltage Dissipation Factor (D.F) -40℃ +85℃, -40℃ UL, CSA, CQC, ENEC, VDE to +125℃ X1 Y1 440VAC 400VAC Rted Voltage Test Voltage 400VAC 4000 VAC for 1 min.漏电流小于 5MA Y5P,Y5U TANδ(DF) ≦2.5%,measured at 1KHz±10%,1.0 - 5.0 Vrms,25℃ Y5V TANδ(DF) ≦5.0%,measured at 1KHz±10%,1.0 - 5.0 Vrms,25℃ Range Capacitance(C) Tolerance Insulation Resiatance(IR) 10000 MΩ Temperature Characteristics to Type Code 10 pF , to 4700 pF. measured at 1KHz±10%, 1.0 - 5.0 Vrms, 25℃ ±10% Y5P ±20% Y5U,Y5V 1 min , 100 VDC Temp. Coeff. Temp. Range Y5P,Y5U ±10%, +22~-56% -40℃ to +85℃,-40℃ to +125℃ Y5V +30%~-80% -40℃ to +85℃,-40℃ to +125℃ 第 2 页 共 11 页 SPEC NO.:2015102801 DONGGUAN WEIQING ELECTRONIC CO., LTD Ceramic Capacitor Part number system The 18 digits part number is formed as follow: 1 2 3 4 5 6 7 8 O 1 1 Digit 1~3 G 2 1 0 9 2 M 10 11 0 12 6 E 13 L 14 2 15 3 16 0 17 18 1 0 Type Code Code Type Code Type Code Type Code O11 Y1 Y5V O21 NPO O25 Y5V O29 O12 Y2 Y5V O22 SL O26 N750 O30 O13 Y1 Y5P O23 Y5P O27 N3300 O31 O14 Y2 Y5P O24 Y5U O28 Y5R O32 Type Code explain: Code TYPE NOTS Ceramic Safety Capacitors O11 Y1 X1/440Vac Y1/400Vac O12 Y2 X1/400Vac Y2/300Vac Ceramic Capacitors O21 NPO 0+/-60m\ppm/ C O22 SL +100~-1000ppm/ C O23 Y5P +/-10% O24 Y5U +22%-56% O25 Y5V +22%-82% O26 N750 -750ppm/ C O27 N3300 -3300ppm/ C O28 Y5R +/-15% Digit 4~5 0 0 0 0 Rated Voltage Code A 1 B C D E 12 16 20 25 F G H J 50 63 K L M N 1100 2 100 125 160 200 250 315 400 500 630 800 120 3 1000 1250 1600 2000 2500 3000 4000 5000 6000 8000 1200 P Q R S T U V W X Y 1 240 300 330 440 540 600 700 850 900 2 275 305 350 450 520 3 280 310 1400 760 480 Explanation:Refer to JIS standard,Letter and then number indicate AC,but number and then Letter indicate DC,for example,2A indicate 100VDC,A2 indicate 100VAC. 第 3 页 共 11 页 SPEC NO.:2015102801 DONGGUAN WEIQING ELECTRONIC CO., LTD Digit 6~8 Capacitance Expressed in 3-digit code 3 Code The first 2digits indicate significant figures,and the third digit specifies the number of zero to follow. This gives the capacitance in picofarads. For examples: 102=10*102PF=1,000PF=1.0nF=0.001uF Digit 9 105=10*105PF=1,000,000PF=1000nF=1uF Capacitance Tolerance Code Tolerance ±0.25PF ±0.5PF ±5% ±10% ±20% +50%/-20% +80%/-20% +100%/-0% C D J K M S Z P Code Digit 10~11 Diameter Size Code Diameter Type Diameter max(mm)徑 5.0 6.0 7.0 8.0 9.0 10.0 11.0 12.0 13.0 … Case No. 05 06 07 08 09 10 11 12 13 *** Digit 12 Lead Spacing Code Pitch Case No. 2.5 5.0 7.5 10 A B E D Special Z Digit 13 Lead Form Code Lead Type Code Lead Type L Long line H K M O Short Inside of Outside of Double line bending bending curved P Before and afterbecome warped line R The bending line T Taping S Customer Special Require Digit 14~16 Lead Length(Straight) and Tolerance of Lead Length(straight) and Expreesed in 3-Letter Code Example:Code 035:35/10=3.5mm 230:230/10=23mm Digit 17~18 Internal use Color\material group\packing\ place of production 第 4 页 共 11 页 SPEC NO.:2015102801 DONGGUAN WEIQING ELECTRONIC CO., LTD Dimensions and Tolerance B=3.0mm max for AA L=3-30mm 编带详细参数看 P11. Approved Spec. Data Name specification Y5V 102M 400VAC D±0.5 mm F±0.5 mm L±0.5 mm T±0.5mm d B A 6 7.5 23 3.7 0.55
O11G2102M06EL23060 价格&库存
很抱歉,暂时无法提供与“O11G2102M06EL23060”相匹配的价格&库存,您可以联系我们找货
