RS-06FL7--0R91
RS-06FL7--0R91
    VIKING(光颉)
    电流采样电阻 1206
RS-06FL7--0R91 数据手册
Data Sheet Customer: Product: Current Sensing Thick Film Chip Resistor - RS Series Size: 0402/0603/0805/1206/1210/2010/2512 Issued Date: 06-Mar-17 Edition: REV.B1 VIKING TECH CORPORATION VIKING TECH CORPORATION KAOHSIUNG BRANCH VIKING ELECTRONICS (WUXI) CO., LTD. ( ) No.70 Guangfu N. Rd., Hukou Township, Hsinchu County 303, Taiwan No.248-3, Sin-Sheng Rd., Cian-Jhen Dist., Kaohsiung, 806, Taiwan TEL:886-3-5972931 FAX:886-3-5972935•886-3-5973494 E-mail:sales@viking.com.tw TEL:886-7-8217999 FAX:886-7-8228229 E-mail:sales@viking.com.tw No.22 Xixia Road, Machinery & Industry Park, National Hi-Tech Industrial Development Zone of Wuxi, Wuxi, Jiangsu Province, China Zip Code:214028 TEL:86-510-85203339 FAX:86-510-85203667•86-510-85203977 E-mail:china@viking.com.tw Produced by (QC) Checked (QC) Approved by (QC) Prepared by (Sales) 06-Mar-17 06-Mar-17 06-Mar-17 06-Mar-17 Susan Huang J.C. Liu J.C. Liu Accepted by (Customer) RS Series Current Sensing Thick Film Chip Resistor Current Sensing Thick Film Chip Resistor Scope This specification applies to all sizes of rectangular-type fixed chip resistors with Ruthenium-base as material. Features Low inductance Highly reliable multilayer electrode construction Higher component and equipment reliability Reduced size of final equipment reliability RoHS Compliance Construction Applications Power Management Applications L Switching Power Supply D1 Over Current Protection in Audio Application Voltage Regulation Module (VRM) W     T DC-DC Converter, Battery Pack, Charger, Adaptor Automotive Engine Control Disk Driver      D2  Alumina Substrate  Edge Electrode  Resistor Layer  Bottom Electrode  Barrier Layer  Primary Overcoat  Top Electrode  External Electrode  Secondary Overcoat Dimensions L W T D1 D2 (mm) (mm) (mm) (mm) (mm) Weight (g) (1000pcs) 0402 1.00±0.05 0.50±0.05 0.35±0.05 0.20±0.10 0.20±0.10 0.620 RS-03 0603 1.60±0.10 0.80±0.10 0.45±0.10 0.30±0.20 0.30±0.20 2.042 RS-05 0805 2.00±0.10 1.25±0.10 0.50±0.10 0.35±0.20 0.40±0.20 4.368 RS-06 1206 3.10±0.10 1.55±0.10 0.55±0.10 0.50±0.25 0.50±0.20 8.947 RS-10 1210 3.10±0.10 2.60±0.15 0.55±0.10 0.50±0.25 0.50±0.20 15.959 RS-0A 2010 5.00±0.10 2.50±0.15 0.55±0.10 0.60±0.25 0.50±0.20 24.241 RS-12 2512 6.35±0.10 3.10±0.15 0.55±0.10 0.60±0.25 0.50±0.20 39.448 Type Size (Inch) RS-02 www.viking.com.tw For detail questions, contact sales@viking.com.tw 1 Edition : REV.B1 Revision: 06-Mar-2017 RS Series Current Sensing Thick Film Chip Resistor Part Numbering Part Number RS-03FL7-0R047 RS- 03 F Product Type Dimensions Resistance Tolerance F: ±1% J: ±5% RS 02: 0402 03: 0603 05: 0805 06: 1206 10: 1210 0A: 2010 12: 2512 L 7 Function Code L: Standard P: High Power Recommend Land Pattern - Packaging Code 4: 7” Reel 4Kpcs 6: 7” Reel 10Kpcs 7: 7” Reel 5Kpcs 9: 10” Reel 8Kpcs A: 10” Reel 10Kpcs B: 10” Reel 20Kpcs C: 13” Reel 40Kpcs D: 13” Reel 20Kpcs F: Bulk 0 R 0 4 7 Resistance - 0R047: 0.047Ω - - - 0R1: 0.1Ω “-“ to fill up 6 spaces Derating Curve Derating Curve 100 Power ratio(%) B . C A Type A (mm) B (mm) C (mm) RS-02 0.50 0.45 0.60 RS-03 0.90 0.60 0.90 RS-05 1.20 0.70 1.30 RS-06 2.00 0.90 1.60 RS-10 2.00 0.90 2.80 RS-0A 3.80 0.90 2.80 RS-12 3.80 1.60 3.50 80 60 40 20 0 0 20 40 60 80 100 120 140 160 180 Ambient Temperature(℃) Soldering Condition IR Reflow Soldering Wave Soldering (Flow Soldering) (1) Time of IR reflow soldering at maximum temperature point 260C:10s (2) Time of wave soldering at maximum temperature point 260C:10s (3) Time of soldering iron at maximum temperature point 410C:5s www.viking.com.tw For detail questions, contact sales@viking.com.tw 2 Edition : REV.B1 Revision: 06-Mar-2017 RS Series Current Sensing Thick Film Chip Resistor Standard Electrical Specifications Item Power Rating at 70C Operating Temp. Max. Operating Range Current Type Resistance Range (mΩ) ±1% TCR (PPM/C) ±5% RS-02 (0402) 1/16W -55 ~ +155C 1.11A 50 - 91 100 - 976 800 500 RS-03 (0603) 1/10W -55 ~ +155C 2.23A 20 - 47 50 - 91 100 - 976 1200 800 500 RS-05 (0805) 1/8W -55 ~ +155C 3.53A RS-06 (1206) 1/4W -55 ~ +155C 5.00A 10 - 18 20 - 47 50 - 91 100 - 976 1500 1200 800 500 RS-10 (1210) 1/3W -55 ~ +155C 5.77A RS-0A (2010) 3/4W -55 ~ +155C 8.66A 10 - 18 20 - 91 100 - 976 1500 800 500 RS-12 (2512) 1W -55 ~ +155C 10.0A Operating Voltage=√(P*R) ; Overload Voltage=2.5*√(P*R) High Power Electrical Specifications Item Type Power Rating at 70°C Operating Temp. Max. Operating Range Current Resistance Range (mΩ) ±1% TCR (PPM/°C) ±5% RS-02 (0402) 1/10W -55 ~ +155C 1.40A 50 - 91 100 - 976 800 500 RS-03 (0603) 1/8W -55 ~ +155C 2.50A 20 - 47 50 - 91 100 - 976 1200 800 500 RS-05 (0805) 1/4W -55 ~ +155C 5.00A RS-06 (1206) 1/2W -55 ~ +155C 7.07A 10 - 18 20 - 47 50 - 91 100 - 976 1500 1200 800 500 RS-10 (1210) 1/2W -55 ~ +155C 7.07A RS-0A (2010) 1W -55 ~ +155C 10.0A 10 - 18 20 - 91 100 - 976 1500 800 500 RS-12 (2512) 2W -55 ~ +155C 14.1A Operating Voltage=√(P*R) Overload Voltage=2.5*√(P*R) Operating Current=√(P/R) Viking is capable of manufacturing the optional spec based on customer’s requirement. www.viking.com.tw For detail questions, contact sales@viking.com.tw 3 Edition : REV.B1 Revision: 06-Mar-2017 RS Series Current Sensing Thick Film Chip Resistor Environmental Characteristics Requirement Item Temperature Coefficient of Resistance (T.C.R.) (1.0%+0.05Ω) Insulation Resistance 10G Damp Heat with Load Dry Heat JIS-C-5201-1 4.8 IEC-60115-1 4.8 As Spec. Short Time Overload Endurance Test Method 5% 1% (2.0%+0.05Ω) -55C~+125C, 25C is the reference temperature JIS-C-5201-1 4.13 IEC-60115-1 4.13 RCWV*2.5 or Max. Overload Voltage whichever is lower for 5 seconds, 2 seconds for High Power Series JIS-C-5201-1 4.6 IEC-60115-1 4.6 (1.0%+0.10Ω) (1.0%+0.10Ω) (1.0%+0.05Ω) (2.0%+0.10Ω) (2.0%+0.10Ω) (1.5%+0.10Ω) Max. Overload Voltage for 1 minute JIS-C-5201-1 4.25 IEC-60115-1 4.25.1 702C, RCWV for 1000 hrs with 1.5 hrs “ON” and 0.5 hr “OFF” JIS-C-5201-1 4.24 IEC-60115-1 4.24 402C, 90~95% R.H., RCWV for 1000 hrs with 1.5 hrs “ON” and 0.5 hr “OFF” JIS-C-5201-1 4.23 IEC-60115-1 4.23.2 at +155C for 1000 hrs Bending Strength (1.0%+0.05Ω) Solderability 95% min. coverage Resistance to Soldering Heat (0.5%+0.05Ω) Voltage Proof (1.0%+0.05Ω) (1.0%+0.05Ω) JIS-C-5201-1 4.33 IEC-60115-1 4.33 Bending once for 5 seconds 2010, 2512 sizes: 2mm Other sizes: 3mm JIS-C-5201-1 4.17 IEC-60115-1 4.17 2455C for 3 seconds JIS-C-5201-1 4.18 IEC-60115-1 4.18 2605C for 10 seconds JIS-C-5201-1 4.7 IEC-60115-1 4.7 No breakdown or flashover 1.42 times Max. Operating Voltage for 1 minute Leaching Rapid Change of Temperature Individual leaching area ≦5% JIS-C-5201-1 4.18 IEC-60068-2-58 8.2.1 Total leaching area ≦ 10% 2605C for 30 seconds JIS-C-5201-1 4.19 IEC-60115-1 4.19 -55C to +155C, 5 cycles (0.5%+0.05Ω) (1.0%+0.05Ω) RCWV(Rated Continuous Working Voltage)=√(P*R) or Max. Operating Voltage whichever is lower. ■ Storage Temperature: 15~28°C; Humidity < 80%RH www.viking.com.tw For detail questions, contact sales@viking.com.tw 4 Edition : REV.B1 Revision: 06-Mar-2017 RS Series Current Sensing Thick Film Chip Resistor Packaging Reel Specifications & Packaging Quantity Type RS-02 Paper RS-03 RS-05 RS-06 Paper RS-10 RS-0A RS-12 Tape Width Reel Diameter ΦA (mm) 10K 8mm 7 inch 178.5±1.5 20K 8mm 10 inch 254±1.0 40K 8mm 13 inch 330±1.0 5K 8mm 7 inch 178.5±1.5 10K 8mm 10 inch 254±1.0 20K 8mm 13 inch 330±1.0 4K 12mm 7 inch 178.5±1.5 8K 12mm 10 inch 250±1.0 Bottom Tape Top Tape Packaging Quantity ΦB (mm) ΦC (mm) W (mm) T (mm) 13.0±0.2 9.0±0.5 12.5±0.5 100±0.5 13.0±0.2 9.5±0.5 13.5±0.5 100±0.5 13.0±0.2 9.5±0.5 13.5±0.5 13.0±0.2 9.0±0.5 12.5±0.5 100±0.5 13.0±0.2 9.5±0.5 13.5±0.5 100±0.5 13.0±0.2 9.5±0.5 13.5±0.5 +1/-0 13.0±0.5 13.0±0.5 15.5±0.5 62±0.5 13.0±0.5 12.5±0.5 16.5±0.5 60 60 60 +1/-0 +1/-0 Embossed Paper Tape Specifications ψ D0 E A F W B T Paper Tape Type A (mm) B (mm) W (mm) P1 Resistor E (mm) F (mm) P0 (mm) P2 P0 P1 (mm) Direction of unreeling P2 (mm) ΦD0 (mm) T (mm) RS-02 0.65±0.10 1.15±0.10 8.0±0.20 1.75±0.10 3.50±0.05 4.00±0.10 2.00±0.05 2.00±0.05 1.50+0.1,-0 0.45±0.10 RS-03 1.10±0.10 1.90±0.10 8.0±0.20 1.75±0.10 3.50±0.05 4.00±0.10 4.00±0.05 2.00±0.05 1.50+0.1,-0 0.70±0.10 RS-05 1.60±0.10 2.40±0.20 8.0±0.20 1.75±0.10 3.50±0.05 4.00±0.10 4.00±0.05 2.00±0.05 1.50+0.1,-0 0.85±0.10 RS-06 1.90±0.10 3.50±0.20 8.0±0.20 1.75±0.10 3.50±0.05 4.00±0.10 4.00±0.05 2.00±0.05 1.50+0.1,-0 0.85±0.10 RS-10 2.90±0.10 3.50±0.20 8.0±0.20 1.75±0.10 3.50±0.05 4.00±0.10 4.00±0.05 2.00±0.05 1.50+0.1,-0 0.85±0.10 www.viking.com.tw For detail questions, contact sales@viking.com.tw 5 Edition : REV.B1 Revision: 06-Mar-2017 RS Series Current Sensing Thick Film Chip Resistor Embossed Plastic Tape Specifications Top Tape ψ D0 E A F W B ψD11.5+0.25,-0 T P1 Resistor P2 P0 Direction of unreeling Embossed Tape P2 (mm) ΦD0 (mm) Type A (mm) B (mm) W (mm) E (mm) F (mm) P0 (mm) P1 (mm) T (mm) RS-0A 2.8±0.10 5.5±0.10 12.0±0.30 1.75±0.10 5.5±0.05 4.00±0.10 4.00±0.10 2.00±0.05 1.50+0.1, -0 1.2 +0 RS-12 3.5±0.10 6.7±0.10 12.0±0.30 1.75±0.10 5.5±0.05 4.00±0.10 4.00±0.10 2.00±0.05 1.50+0.1, -0 1.2 +0 Marking No Marking for 0402 1%, 5% for 0805/1206/1210/2010/2512: 4 digits marking Example: Resistance Marking 47mΩ R047 75mΩ R075 15mΩ R015 750mΩ R750 820mΩ R820 5% for 0603: 3 digits marking in E24 1% for 0603: 3 digits marking with under-line in E96 (non-including E24 series) R10 3 digits marking for E24 or R value suffix is zero in E96: R10=100mΩ; R28=280mΩ 243 3 digits marking for E96: 243=243mΩ; 511=511mΩ www.viking.com.tw For detail questions, contact sales@viking.com.tw 6 Edition : REV.B1 Revision: 06-Mar-2017 RS Series Current Sensing Thick Film Chip Resistor REVISION HISTORY REVISION DATE CHANGE NOTIFICATION DESCRIPTION Version A9 Jun 03, 2014 - - Environmental Characteristics updated Version B - - Remove Material Description Modify Storage Temperature - - Jul 15, 2016 Version B1 Mar 06, 2017 www.viking.com.tw Size 1206 High power product Power rating 1/3W upgrade to 1/2W For detail questions, contact sales@viking.com.tw 7 Edition : REV.B1 Revision: 06-Mar-2017
RS-06FL7--0R91 价格&库存
很抱歉,暂时无法提供与“RS-06FL7--0R91”相匹配的价格&库存,您可以联系我们找货
